Mon Jan 20 15:33:16 HKT 2025
> Maybe the Poller AddFilter should be AddFilter(1, 0x700, 0x800)
> which passes to the canbus AddFilter( '0' + busno, busfrom, busto);
> (to be consistent with the pollers number of busses)
AddFilter with bus=0 (actual zero, not '0') translates to "any bus",
which is handy for can logging. Probably not needed for a vehicle
implementation, but still I'd suggest keeping it consistent, so '0' +
busno should only be applied for busno >= 1.
I think the char digits for actual buses stuck from the string spec
parsing, could be changed if necessary.
Am 20.01.25 um 01:40 schrieb Michael Geddes via OvmsDev:
> The AddFilter calls canbus::AddFilter.
> If the frame 'MsgID' matches the bus and is within the range, then it
> is INCLUDED.
> This means if you add a filter for one bus, you have to add it for all
> busses.
> AddFilter('1', 0x700, 0x800) ;
> would allow only msgid from 0x700 to 0x800 for bus 1.
> The char is a bit weird, but that's the original call.
> I wonder if I should make it a bit different in the translation.
> If you included that in a commit, I wouldn't object.
> On Mon, 20 Jan 2025 at 04:51, Simon Ehlen via OvmsDev
> <ovmsdev at lists.openvehicles.com> wrote:
> Am 19.01.2025 um 13:51 schrieb Michael Geddes:
>> With my latest push - you could also call AddFilter() before
>> turning on the CAN bus and reduce the load on the Poll queue.
> Hi Michael,
> I'd be happy to try it out. Can you please give me brief
> instructions on how to use AddFilter()?
> Do I enter the MsgIDs that I want to evaluate or the ones that
> should be discarded?
> Thank you!
> Cheers,
> Simon
>> On Sun, 19 Jan 2025 at 20:40, Simon Ehlen via OvmsDev
>> Hi,
>> Am 19.01.2025 um 12:48 schrieb Michael Balzer via OvmsDev:
>>> Regarding CAN timing, our ESP32CAN/SJA1000 configuration is
>>> mostly according to the SAE/CiA recommendations, with one
>>> exception: we generally enable multi (triple) sampling,
>>> regardless of the bus speed:
>>> esp32can::InitController():
>>> /* Set sampling
>>> * 1 -> triple; the bus is sampled three times;
>>> recommended for low/medium speed buses (class A and B)
>>> where filtering spikes on the bus line is beneficial
>>> * 0 -> single; the bus is sampled once; recommended for
>>> high speed buses (SAE class C)*/
>>> MODULE_ESP32CAN->BTR1.B.SAM=0x1;
>>> SAE defines "high speed" (class C) as speeds >= 125 kbit/s.
>>> See SAE J2284-1, -2 & -3, section 6.10.8 Data Sample Mode:
>>> "The data sampling shall always be set to single sample mode."
>>> If setting SAM=0 for 500 kbit/s, our timing setup is exactly
>>> as recommended by two tested SJA1000 timing calculators on
>>> the web.
>>> Maybe we should give that a try? I.e.
>>> MODULE_ESP32CAN->BTR1.B.SAM = (MyESP32can->m_speed <
>>> CAN_SPEED_125KBPS) ? 1 : 0;
>>> Simon, can you try if that helps?
>> I have adjusted the corresponding line.
>> I will check tomorrow whether this has an effect on the
>> active mode.
>> I tried your recommendation and set the
>> CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE to both 200 and 400. I
>> have not yet checked whether the bus also crashes in active
>> mode. However, I can see in listening mode that when I abort
>> a running loading process (there are currently no overflows),
>> many overflow messages are received.
>>> But as you also use can2, I wouldn't rule out a timing issue
>>> with the MCP2515 configuration. At which speed do you have
>>> can2, and did you have some indication from the vehicle
>>> error codes regarding a specific bus?
>> RegisterCanBus(1, CAN_MODE_LISTEN, CAN_SPEED_500KBPS);
>> RegisterCanBus(2, CAN_MODE_LISTEN, CAN_SPEED_125KBPS);
>> I do not receive any feedback from the car as to which bus is
>> affected, unfortunately no error code is saved for the
>> incident. Do you have the option of specifying the affected
>> bus in the overflow logging?
>> Cheers,
>> Simon
>>> Am 17.01.25 um 17:49 schrieb Michael Balzer via OvmsDev:
>>>> OK, I've got a new idea: CAN timing.
>>>> Comparing our esp32can bit timing to the esp-idf driver's,
>>>> there seem to be some differences:
>>>> https://github.com/espressif/esp-idf/blob/master/components/hal/include/hal/twai_types_deprecated.h#L75
>>>> Transceivers are normally tolerant to small timing offsets.
>>>> Maybe being off a little bit has no effect under normal
>>>> conditions, but it has when the transceiver has to cope
>>>> with a filled RX queue. That could be causing the
>>>> transceiver to slide just out of sync. If the timing gets
>>>> garbled, the transceiver would signal errors in the packets
>>>> to the bus, possibly so many the vehicle ECUs decide to
>>>> raise an error condition.
>>>> Is that plausible?
>>>> On why the new poller could be causing this (in combination
>>>> with too slow processing by the vehicle): as mentioned, the
>>>> standard CAN listener mechanism doesn't care about queue
>>>> overflows. The poller does.
>>>> `OvmsPollers::Queue_PollerFrame()` does a log call when
>>>> Tx/Rx tracing is enabled, that could even block, but
>>>> tracing is optional and only meant for debugging. Not
>>>> optional is the overflow counting using an atomic uint32.
>>>> The atomic types are said to be fast, but I never checked
>>>> their actual implementation on the ESP32. Maybe they can
>>>> block as well?
>>>> @Simon: it would be an option to try commenting out the
>>>> overflow counting, to see if that's causing the issue.
>>>> Regards,
>>>> Michael
>>>> Am 17.01.25 um 15:37 schrieb Chris Box via OvmsDev:
>>>>> Yes, I can confirm I've had one experience of the Leaf
>>>>> switching to Neutral while driving, with a yellow warning
>>>>> symbol on the dash. It refused to reselect Drive until I
>>>>> had switched the car off and back on. Derek wasn't so
>>>>> lucky and he need to clear fault codes before the car
>>>>> would work.
>>>>> On returning home, I found OVMS was not accessible over a
>>>>> network. I didn't try a USB cable. Unplugging and
>>>>> reinserting the OBD cable caused OVMS to rejoin Wi-Fi.
>>>>> However the SD logs showed nothing from the time of the
>>>>> event. CAN writes are enabled, so it can perform SOC limiting.
>>>>> My car has been using this firmware since 21st November,
>>>>> based on the git master of that day. As a relatively new
>>>>> user of OVMS (only since October) I don't have much
>>>>> experience of older firmware.
>>>>> Perhaps a safeguard should be implemented before releasing
>>>>> a new stable firmware that will be automatically
>>>>> downloaded by Leaf owners. But I don't have the expertise
>>>>> to know what that safeguard should be. Derek's suggestion
>>>>> of 'only CAN write when parked' appears to be a good idea.
>>>>> Chris
>>>>> On 2025-01-15 18:18, Derek Caudwell via OvmsDev wrote:
>>>>>> Since the following email I have high confidence the
>>>>>> issue on the Leaf is related/caused by the poller as
>>>>>> there has been no further occurrence and Chris has also
>>>>>> experienced the car going to neutral on the new poller
>>>>>> firmware.
>>>>>> I haven't ruled out it being a fault with my car yet.
>>>>>> Shortly after it faulted the car was run into so has been
>>>>>> off the road for sometime, my first step was to replace
>>>>>> 12V battery. The ovms unit is now unplugged and if it
>>>>>> does not fault over the next month while driving I'll be
>>>>>> reasonably confident it's ovms related.
>>>>>> Not sure which firmware version the poller updates were
>>>>>> included in but it was only after upgrading to it that
>>>>>> the errors occurred (which could be coincidental however
>>>>>> it has faulted twice more both on version
>>>>>> 3.3.004-141-gf729d82c). For periods where I reverted to
>>>>>> 3.3.003 it was fine.
>>>>>> It might be useful to have an extra option on the enable
>>>>>> can write to only enable it when the car is parked/charging.
>>>>> OvmsDev mailing list
>>>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>>>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250120/1b243862/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250120/1b243862/attachment-0001.sig>
