Sun Jan 19 11:26:14 HKT 2025
P/R Created
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/1100
Let me know if you want me to split it up or ANY changes and I'll get onto
it asap.
Maybe somebody could grab the code and check it out in the context of
specifying some filters.  This will prevent those messages from coming to
the vehicle implementation at all.. and even from going through the poller
queue.  It is non-blocking meaning that the filter is briefly
inopperational while the filter is being modified.
On Sun, 19 Jan 2025 at 11:02, Michael Geddes <frog at bunyip.wheelycreek.net>
wrote:
> On Sat, 18 Jan 2025 at 17:08, Michael Balzer via OvmsDev <
> ovmsdev at lists.openvehicles.com> wrote:
>> I have commented out the line with the Atomic_Increment statement. Now I
>> no longer receive any messages with “RX Task Queue Overflow Run”
>> Here is the output of poller times status:
>> The main question is if you still get the CAN bus crash (vehicle running
>> into issues) with that modification in active mode. Timing statistics were
>> not expected to change.
> I have a feeling that the atomic operations are along the lines of:
> * Set Interrupts off
> * atomic operation
> * Set interrupts on
> Which means no real 'blocking' .. just not allowing interrupts and
> therefor task switching for a couple of instructions.
>> Nearly 2800 frames per second is quite a lot, and most is on can1 with
>> many frame periods at 20 ms. Yet the total processing time averages at
>> 30-40 ms, so there is no actual CPU capacity issue for that amount of
>> frames.
>> @Derek: can you please supply these statistics for the Leaf in drive mode
>> as well?
>> Am 18.01.25 um 02:42 schrieb Michael Geddes via OvmsDev:
>> Maybe try setting CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE = 160   and see
>> if that reduces the overflow?
>> Simons car sends at least 91 process data frame IDs on can1 and 84 on
>> can2. Worst case would be these come all in within the shortest possible
>> time span, that would mean the queue needs to be able to hold 175 frames.
>> I'd add some headroom and round up to 200.
>> But keep in mind, if the Incoming processing actually occasionally gets
>> blocked for up to 60 ms -- as indicated by Simons statistics --, the queue
>> may need to be twice as large.
>>  I was thinking that the frame filter would be here:
>> void OvmsPollers::PollerRxCallback(const CAN_frame_t* frame, bool success)
>>   Queue_PollerFrame(*frame, success, false);
>> which I guess is executed in  the task handling the CAN queue.  (we don't
>> know how many frames get dropped there).
>> Actually we do know that, or at least have some indication, as we count
>> the CAN transceiver queue overruns. That info is included as "Rx overflw"
>> in the can status output & as "rxovr" in the logs.
>> Adding a filter before queueing the frame would exclude the filtered IDs
>> from all vehicle processing. I meant adding a filter just to exclude IDs
>> from the timing statistics, assuming those are the culprits, as Simon wrote
>> the issue only appears after enabling the timing statistics and printing
>> them. That's why I asked if printing might need to lock the statistics for
>> too long in case of such a long list.
>> Completely blocking ID ranges from processing by the vehicle should
>> normally not be necessary, unless the Incoming handler is written very
>> poorly.
>> Yet, if we add that, a mutex in the CAN RX callback must be avoided, or
>> would need to be non-blocking:
>> The only real concern is thread safety between checking and adding to the
>> filter - so the check itself might have to be mutexed.
>>   // Check filter
>>   OvmsRecMutexLock lock(&m_filter_mutex);
>>     if (! m_filter->IsFiltered(frame))
>>       return;
>> A mutex like that could block the CAN task, which must be avoided at all
>> cost. I introduced CAN callbacks for vehicles & applications that need to
>> react to certain frames as fast as possible, e.g. to maintain control
>> precedence, so cannot use the standard CAN listener mechanism (frame
>> queueing).
>> The current poller callback use is OK, if (!) the atomic type really
>> isn't the culprit, ie doesn't block.
>> So if (!) an ID filter needs to be added before queueing, it needs to be
>> done in a way that needs no mutex. But I don't see an issue with the
>> vehicle passing a fixed filter when registering with the poller/buses. The
>> filter doesn't need to by mutable on the fly.
>> Am 17.01.25 um 19:42 schrieb Simon Ehlen via OvmsDev:
>> The poller statistics can help you track this down, but you need to have
>> at least 10 seconds of statistics, the more the better. Rule of thumb: PRI
>> average at 0.0/second means you don't have enough data yet.
>> There were again many messages with “RX Task Queue Overflow Run”.
>> Here are the statistics of poller times status:
>> OVMS# poll times status
>> Poller timing is: on
>> Type           | count  | Utlztn | Time
>>                | per s  | [%]    | [ms]
>> Poll:PRI    Avg|    1.00|  0.0043|    0.004
>>            Peak|        |  0.0043|    0.052
>> RxCan1[010] Avg|   34.26|  1.6741|    0.015
>>            Peak|        |  1.6741|    1.182
>> RxCan1[030] Avg|   34.06|  1.7085|    0.020
>>            Peak|        |  1.7085|    1.390
>> RxCan1[041] Avg|   49.89|  0.8109|    0.016
>>            Peak|        |  0.8541|    1.098
>> RxCan1[049] Avg|   50.00|  1.5970|    0.019
>>            Peak|        |  1.7154|   32.233
>> RxCan1[04c] Avg|   49.92|  0.8340|    0.014
>>            Peak|        |  0.8933|    1.995
>> RxCan1[04d] Avg|   34.43|  1.6211|    0.014
>>            Peak|        |  1.6756|    1.318
>> RxCan1[076] Avg|   50.00|  0.8362|    0.024
>>            Peak|        |  0.8784|    2.185
>> RxCan1[077] Avg|   50.00|  0.7837|    0.014
>>            Peak|        |  0.8083|    1.156
>> RxCan1[07a] Avg|   34.31|  2.1870|    0.017
>>            Peak|        |  2.3252|    1.888
>> RxCan1[07d] Avg|   50.00|  0.8001|    0.013
>>            Peak|        |  0.8434|    1.150
>> RxCan1[0c8] Avg|   49.96|  0.8359|    0.013
>>            Peak|        |  0.8715|    1.171
>> RxCan1[11a] Avg|   34.35|  1.6701|    0.020
>>            Peak|        |  1.6981|    1.273
>> RxCan1[130] Avg|   50.00|  0.7902|    0.018
>>            Peak|        |  0.8513|    0.980
>> RxCan1[139] Avg|   49.92|  0.7872|    0.013
>>            Peak|        |  0.8219|    0.795
>> RxCan1[156] Avg|   10.00|  0.1620|    0.014
>>            Peak|        |  0.1729|    0.919
>> RxCan1[160] Avg|   50.04|  0.7977|    0.014
>>            Peak|        |  0.8232|    1.495
>> RxCan1[165] Avg|   49.85|  0.7976|    0.014
>>            Peak|        |  0.8486|    1.015
>> RxCan1[167] Avg|   34.39|  1.6025|    0.016
>>            Peak|        |  1.6888|    1.354
>> RxCan1[171] Avg|   50.00|  0.8150|    0.017
>>            Peak|        |  0.8488|    1.091
>> RxCan1[178] Avg|   10.00|  0.1614|    0.014
>>            Peak|        |  0.1702|    0.903
>> RxCan1[179] Avg|   10.00|  0.1630|    0.017
>>            Peak|        |  0.1663|    1.336
>> RxCan1[180] Avg|   50.00|  0.8137|    0.014
>>            Peak|        |  0.8605|    1.566
>> RxCan1[185] Avg|   50.04|  0.8033|    0.013
>>            Peak|        |  0.8393|    1.126
>> RxCan1[1a0] Avg|   49.92|  0.7748|    0.013
>>            Peak|        |  0.8169|    1.184
>> RxCan1[1e0] Avg|   49.92|  0.7738|    0.014
>>            Peak|        |  0.8028|    1.049
>> RxCan1[1e4] Avg|   49.89|  0.9692|    0.018
>>            Peak|        |  1.0096|    1.332
>> RxCan1[1f0] Avg|   33.22|  0.5544|    0.014
>>            Peak|        |  0.5855|    0.848
>> RxCan1[200] Avg|   49.92|  0.7879|    0.015
>>            Peak|        |  0.8345|    1.206
>> RxCan1[202] Avg|   34.28|  1.7075|    0.016
>>            Peak|        |  1.7874|    1.218
>> RxCan1[204] Avg|   34.35|  1.5641|    0.013
>>            Peak|        |  1.6427|    1.235
>> RxCan1[213] Avg|   49.89|  0.7814|    0.015
>>            Peak|        |  0.8232|    0.910
>> RxCan1[214] Avg|   49.92|  0.7736|    0.014
>>            Peak|        |  0.8216|    0.800
>> RxCan1[217] Avg|   34.31|  1.6294|    0.014
>>            Peak|        |  1.7165|    1.153
>> RxCan1[218] Avg|   49.86|  0.7877|    0.013
>>            Peak|        |  0.8290|    1.068
>> RxCan1[230] Avg|   50.00|  0.7596|    0.014
>>            Peak|        |  0.7660|    1.021
>> RxCan1[240] Avg|   10.00|  0.1669|    0.013
>>            Peak|        |  0.1835|    0.887
>> RxCan1[242] Avg|   24.96|  0.4764|    0.020
>>            Peak|        |  0.4963|    1.501
>> RxCan1[24a] Avg|    9.89|  0.1789|    0.015
>>            Peak|        |  0.2009|    0.874
>> RxCan1[24b] Avg|    9.89|  0.1702|    0.014
>>            Peak|        |  0.1870|    1.195
>> RxCan1[24c] Avg|    9.89|  0.2146|    0.019
>>            Peak|        |  0.2187|    1.242
>> RxCan1[25a] Avg|   10.00|  0.1603|    0.013
>>            Peak|        |  0.1667|    0.720
>> RxCan1[25b] Avg|   49.94|  0.7918|    0.017
>>            Peak|        |  0.8454|    1.666
>> RxCan1[25c] Avg|   34.24|  1.5331|    0.013
>>            Peak|        |  1.5997|    1.538
>> RxCan1[260] Avg|   10.00|  0.1626|    0.014
>>            Peak|        |  0.1682|    0.718
>> RxCan1[270] Avg|   49.90|  0.8120|    0.014
>>            Peak|        |  0.8460|    1.671
>> RxCan1[280] Avg|   49.92|  0.7777|    0.019
>>            Peak|        |  0.8447|    1.157
>> RxCan1[2e4] Avg|   19.89|  0.5778|    0.032
>>            Peak|        |  0.6648|    2.226
>> RxCan1[2ec] Avg|   10.00|  0.1701|    0.014
>>            Peak|        |  0.1755|    0.928
>> RxCan1[2ed] Avg|   10.00|  0.1650|    0.013
>>            Peak|        |  0.1747|    0.917
>> RxCan1[2ee] Avg|    9.98|  0.1544|    0.013
>>            Peak|        |  0.1588|    1.312
>> RxCan1[312] Avg|   10.00|  0.1648|    0.017
>>            Peak|        |  0.1690|    0.922
>> RxCan1[326] Avg|    9.89|  0.1603|    0.015
>>            Peak|        |  0.1833|    1.230
>> RxCan1[336] Avg|    1.00|  0.0146|    0.015
>>            Peak|        |  0.0150|    0.349
>> RxCan1[352] Avg|    6.66|  0.1223|    0.022
>>            Peak|        |  0.1338|    1.015
>> RxCan1[355] Avg|    2.00|  0.0424|    0.019
>>            Peak|        |  0.0431|    0.786
>> RxCan1[35e] Avg|    9.96|  0.1570|    0.013
>>            Peak|        |  0.1644|    0.579
>> RxCan1[365] Avg|   10.00|  0.1600|    0.014
>>            Peak|        |  0.1653|    0.961
>> RxCan1[366] Avg|   10.00|  0.1716|    0.013
>>            Peak|        |  0.1890|    0.987
>> RxCan1[367] Avg|    9.93|  0.1793|    0.015
>>            Peak|        |  0.1864|    0.984
>> RxCan1[368] Avg|   10.00|  0.1645|    0.014
>>            Peak|        |  0.1778|    0.768
>> RxCan1[369] Avg|   10.00|  0.1562|    0.016
>>            Peak|        |  0.1606|    0.724
>> RxCan1[380] Avg|   10.00|  0.1619|    0.014
>>            Peak|        |  0.1644|    0.605
>> RxCan1[38b] Avg|   25.00|  0.3991|    0.016
>>            Peak|        |  0.4280|    1.448
>> RxCan1[3b3] Avg|   10.00|  0.1537|    0.013
>>            Peak|        |  0.1610|    0.380
>> RxCan1[400] Avg|    4.00|  0.0626|    0.014
>>            Peak|        |  0.0626|    0.251
>> RxCan1[405] Avg|    3.90|  0.1019|    0.028
>>            Peak|        |  0.1019|    0.781
>> RxCan1[40a] Avg|    7.90|  0.1256|    0.020
>>            Peak|        |  0.1256|    0.991
>> RxCan1[410] Avg|   10.00|  0.1643|    0.016
>>            Peak|        |  0.1839|    1.634
>> RxCan1[411] Avg|   10.00|  0.1532|    0.013
>>            Peak|        |  0.1645|    0.824
>> RxCan1[416] Avg|   10.00|  0.1516|    0.016
>>            Peak|        |  0.1582|    0.807
>> RxCan1[421] Avg|   10.00|  0.1648|    0.013
>>            Peak|        |  0.1740|    0.839
>> RxCan1[42d] Avg|   10.00|  0.1548|    0.014
>>            Peak|        |  0.1658|    0.741
>> RxCan1[42f] Avg|   10.00|  0.1527|    0.013
>>            Peak|        |  0.1578|    0.667
>> RxCan1[430] Avg|   10.00|  0.1730|    0.016
>>            Peak|        |  0.1880|    1.209
>> RxCan1[434] Avg|   10.00|  0.1620|    0.021
>>            Peak|        |  0.1712|    1.140
>> RxCan1[435] Avg|    6.66|  0.1104|    0.014
>>            Peak|        |  0.1121|    1.011
>> RxCan1[43e] Avg|   20.00|  0.3194|    0.013
>>            Peak|        |  0.3434|    1.212
>> RxCan1[440] Avg|    1.00|  0.0160|    0.014
>>            Peak|        |  0.0175|    0.315
>> RxCan1[465] Avg|    1.00|  0.0172|    0.015
>>            Peak|        |  0.0194|    0.404
>> RxCan1[466] Avg|    1.00|  0.0198|    0.015
>>            Peak|        |  0.0252|    0.890
>> RxCan1[467] Avg|    1.00|  0.0152|    0.014
>>            Peak|        |  0.0160|    0.217
>> RxCan1[472] Avg|    0.70|  0.0533|    0.075
>>            Peak|        |  0.0546|    0.990
>> RxCan1[473] Avg|    0.65|  0.0325|    0.051
>>            Peak|        |  0.0361|    0.774
>> RxCan1[474] Avg|    1.00|  0.0146|    0.014
>>            Peak|        |  0.0151|    0.189
>> RxCan1[475] Avg|    2.00|  0.0332|    0.015
>>            Peak|        |  0.0362|    0.513
>> RxCan1[476] Avg|    2.00|  0.0305|    0.014
>>            Peak|        |  0.0307|    0.249
>> RxCan1[477] Avg|    2.00|  0.0309|    0.014
>>            Peak|        |  0.0311|    0.438
>> RxCan1[595] Avg|    1.00|  0.0151|    0.014
>>            Peak|        |  0.0160|    0.230
>> RxCan1[59e] Avg|    1.00|  0.0179|    0.015
>>            Peak|        |  0.0209|    0.716
>> RxCan1[5a2] Avg|    1.00|  0.0154|    0.016
>>            Peak|        |  0.0184|    0.699
>> RxCan1[5ba] Avg|    1.00|  0.0159|    0.017
>>            Peak|        |  0.0174|    0.485
>> RxCan2[010] Avg|    0.00|  0.0000|    0.015
>>            Peak|        |  0.0000|    0.146
>> RxCan2[020] Avg|   31.10|  0.5159|    0.015
>>            Peak|        |  0.5730|    0.992
>> RxCan2[030] Avg|   20.70|  0.3506|    0.016
>>            Peak|        |  0.3956|    1.055
>> RxCan2[03a] Avg|   18.65|  0.3157|    0.014
>>            Peak|        |  0.3292|    0.702
>> RxCan2[040] Avg|   18.60|  0.3111|    0.015
>>            Peak|        |  0.3474|    0.953
>> RxCan2[060] Avg|   18.60|  0.3182|    0.014
>>            Peak|        |  0.3569|    0.694
>> RxCan2[070] Avg|   15.55|  0.4581|    0.017
>>            Peak|        |  0.6859|   39.212
>> RxCan2[080] Avg|   15.50|  0.5041|    0.029
>>            Peak|        |  0.5414|    1.555
>> RxCan2[083] Avg|   18.70|  0.3083|    0.014
>>            Peak|        |  0.3325|    0.557
>> RxCan2[090] Avg|   23.40|  0.3961|    0.014
>>            Peak|        |  0.4445|    1.218
>> RxCan2[0a0] Avg|   15.55|  0.2734|    0.014
>>            Peak|        |  0.3144|    1.062
>> RxCan2[100] Avg|   15.50|  0.2645|    0.016
>>            Peak|        |  0.2875|    1.021
>> RxCan2[108] Avg|   23.40|  0.4231|    0.016
>>            Peak|        |  0.4680|    1.297
>> RxCan2[110] Avg|   15.55|  0.2467|    0.014
>>            Peak|        |  0.2684|    0.475
>> RxCan2[130] Avg|   13.30|  0.2231|    0.014
>>            Peak|        |  0.2447|    0.512
>> RxCan2[150] Avg|   15.50|  0.2533|    0.015
>>            Peak|        |  0.2836|    0.823
>> RxCan2[160] Avg|    4.70|  0.0784|    0.014
>>            Peak|        |  0.0863|    0.608
>> RxCan2[180] Avg|   15.55|  0.2713|    0.015
>>            Peak|        |  0.2841|    0.884
>> RxCan2[190] Avg|   15.50|  0.2596|    0.014
>>            Peak|        |  0.2825|    0.743
>> RxCan2[1a0] Avg|    0.95|  0.0164|    0.015
>>            Peak|        |  0.0164|    0.346
>> RxCan2[1a4] Avg|   18.65|  0.3232|    0.015
>>            Peak|        |  0.3515|    0.989
>> RxCan2[1a8] Avg|   11.60|  0.1911|    0.016
>>            Peak|        |  0.2012|    0.757
>> RxCan2[1b0] Avg|    9.35|  0.1558|    0.016
>>            Peak|        |  0.1641|    0.795
>> RxCan2[1b4] Avg|    9.35|  0.1543|    0.015
>>            Peak|        |  0.1617|    1.217
>> RxCan2[1b8] Avg|   11.65|  0.2003|    0.014
>>            Peak|        |  0.2236|    1.549
>> RxCan2[1c0] Avg|    9.40|  0.1532|    0.016
>>            Peak|        |  0.1673|    0.955
>> RxCan2[1e0] Avg|    9.30|  0.1582|    0.015
>>            Peak|        |  0.1708|    0.661
>> RxCan2[215] Avg|    7.80|  0.1409|    0.016
>>            Peak|        |  0.1531|    0.660
>> RxCan2[217] Avg|    7.80|  0.1239|    0.014
>>            Peak|        |  0.1333|    0.520
>> RxCan2[220] Avg|    6.20|  0.1041|    0.015
>>            Peak|        |  0.1094|    0.652
>> RxCan2[225] Avg|   23.40|  0.4648|    0.015
>>            Peak|        |  0.4696|    4.288
>> RxCan2[230] Avg|    6.20|  0.3120|    0.048
>>            Peak|        |  0.3377|    1.065
>> RxCan2[240] Avg|    7.70|  0.1248|    0.014
>>            Peak|        |  0.1364|    0.635
>> RxCan2[241] Avg|   18.60|  0.3258|    0.014
>>            Peak|        |  0.3343|    1.288
>> RxCan2[250] Avg|    4.70|  0.0761|    0.014
>>            Peak|        |  0.0809|    0.322
>> RxCan2[255] Avg|   11.75|  0.2058|    0.014
>>            Peak|        |  0.2283|    0.937
>> RxCan2[265] Avg|   11.65|  0.1964|    0.014
>>            Peak|        |  0.2068|    0.965
>> RxCan2[270] Avg|    4.70|  0.0808|    0.016
>>            Peak|        |  0.0949|    0.729
>> RxCan2[290] Avg|    3.15|  0.0498|    0.015
>>            Peak|        |  0.0504|    0.449
>> RxCan2[295] Avg|    6.25|  0.1019|    0.014
>>            Peak|        |  0.1094|    0.859
>> RxCan2[2a0] Avg|    3.15|  0.0550|    0.014
>>            Peak|        |  0.0551|    0.779
>> RxCan2[2a7] Avg|   11.65|  0.1929|    0.014
>>            Peak|        |  0.2080|    0.775
>> RxCan2[2b0] Avg|    3.00|  0.0497|    0.015
>>            Peak|        |  0.0562|    0.528
>> RxCan2[2c0] Avg|    3.10|  0.0534|    0.016
>>            Peak|        |  0.0592|    0.501
>> RxCan2[2e0] Avg|    1.55|  0.0247|    0.014
>>            Peak|        |  0.0289|    0.319
>> RxCan2[2f0] Avg|    1.55|  0.0244|    0.014
>>            Peak|        |  0.0273|    0.192
>> RxCan2[2f5] Avg|   11.65|  0.2078|    0.016
>>            Peak|        |  0.2333|    0.879
>> RxCan2[300] Avg|    1.60|  0.0266|    0.018
>>            Peak|        |  0.0278|    0.724
>> RxCan2[310] Avg|    1.55|  0.0276|    0.016
>>            Peak|        |  0.0285|    0.759
>> RxCan2[320] Avg|    1.60|  0.0240|    0.014
>>            Peak|        |  0.0258|    0.179
>> RxCan2[326] Avg|    9.30|  0.1550|    0.014
>>            Peak|        |  0.1582|    0.850
>> RxCan2[330] Avg|   29.95|  0.5311|    0.015
>>            Peak|        |  0.5565|    4.522
>> RxCan2[340] Avg|    7.75|  0.1693|    0.024
>>            Peak|        |  0.1868|    1.148
>> RxCan2[345] Avg|    1.60|  0.0292|    0.016
>>            Peak|        |  0.0316|    0.471
>> RxCan2[350] Avg|    0.00|  0.0000|    0.019
>>            Peak|        |  0.0000|    0.188
>> RxCan2[35e] Avg|    4.70|  0.0851|    0.019
>>            Peak|        |  0.0911|    1.023
>> RxCan2[360] Avg|    1.60|  0.0258|    0.015
>>            Peak|        |  0.0284|    0.306
>> RxCan2[361] Avg|    7.75|  0.1341|    0.017
>>            Peak|        |  0.1487|    0.761
>> RxCan2[363] Avg|    1.20|  0.0203|    0.016
>>            Peak|        |  0.0220|    0.421
>> RxCan2[370] Avg|    0.85|  0.0140|    0.016
>>            Peak|        |  0.0162|    0.354
>> RxCan2[381] Avg|    3.15|  0.0512|    0.016
>>            Peak|        |  0.0546|    0.416
>> RxCan2[3a0] Avg|   15.60|  0.2548|    0.015
>>            Peak|        |  0.2890|    0.976
>> RxCan2[3d0] Avg|    9.35|  0.1553|    0.019
>>            Peak|        |  0.1612|    1.115
>> RxCan2[3d5] Avg|    5.15|  0.0836|    0.016
>>            Peak|        |  0.0867|    0.479
>> RxCan2[3e0] Avg|    0.00|  0.0000|    0.014
>>            Peak|        |  0.0000|    0.142
>> RxCan2[400] Avg|    3.55|  0.0613|    0.017
>>            Peak|        |  0.0695|    0.501
>> RxCan2[405] Avg|    3.50|  0.0584|    0.018
>>            Peak|        |  0.0626|    0.686
>> RxCan2[40a] Avg|    7.10|  0.1278|    0.017
>>            Peak|        |  0.1389|    1.244
>> RxCan2[415] Avg|    1.60|  0.0258|    0.014
>>            Peak|        |  0.0287|    0.266
>> RxCan2[435] Avg|    0.85|  0.0165|    0.019
>>            Peak|        |  0.0167|    0.367
>> RxCan2[440] Avg|    0.85|  0.0128|    0.019
>>            Peak|        |  0.0141|    0.885
>> RxCan2[465] Avg|    0.95|  0.0177|    0.016
>>            Peak|        |  0.0195|    0.721
>> RxCan2[466] Avg|    0.95|  0.0147|    0.014
>>            Peak|        |  0.0160|    0.184
>> RxCan2[467] Avg|    0.95|  0.0172|    0.017
>>            Peak|        |  0.0188|    0.391
>> RxCan2[501] Avg|    1.45|  0.0273|    0.016
>>            Peak|        |  0.0327|    0.996
>> RxCan2[503] Avg|    1.45|  0.0288|    0.020
>>            Peak|        |  0.0338|    0.970
>> RxCan2[504] Avg|    1.40|  0.0241|    0.015
>>            Peak|        |  0.0263|    0.609
>> RxCan2[505] Avg|    1.40|  0.0255|    0.015
>>            Peak|        |  0.0296|    0.866
>> RxCan2[508] Avg|    1.35|  0.0237|    0.017
>>            Peak|        |  0.0237|    0.384
>> RxCan2[511] Avg|    1.35|  0.0226|    0.016
>>            Peak|        |  0.0228|    0.426
>> RxCan2[51e] Avg|    1.40|  0.0221|    0.014
>>            Peak|        |  0.0245|    0.211
>> RxCan2[581] Avg|    0.80|  0.0189|    0.019
>>            Peak|        |  0.0290|    1.217
>> RxCan2[606] Avg|    0.00|  0.0000|    0.014
>> RxCan2[657] Avg|    0.00|  0.0000|    0.014
>>            Peak|        |  0.0000|    0.137
>> Cmd:State   Avg|    0.00|  0.0000|    0.002
>>            Peak|        |  0.0000|    0.024
>>       Total Avg| 2748.42| 58.3344|   28.718
>> @Simon: it would be an option to try commenting out the overflow
>> counting, to see if that's causing the issue.
>> OVMS# poll time status
>>                | per s  | [%]    | [ms]
>> Poll:PRI    Avg|    1.00|  0.0045|    0.004
>>            Peak|        |  0.0046|    0.064
>> RxCan1[010] Avg|   34.26|  2.2574|    0.021
>>            Peak|        |  2.2574|    4.609
>> RxCan1[030] Avg|   34.26|  2.3820|    0.021
>>            Peak|        |  2.3820|    1.135
>> RxCan1[041] Avg|   49.89|  1.2059|    0.021
>>            Peak|        |  1.2295|    5.331
>> RxCan1[049] Avg|   49.96|  1.2400|    0.030
>>            Peak|        |  1.2699|    1.402
>> RxCan1[04c] Avg|   49.92|  1.1752|    0.021
>>            Peak|        |  1.2072|    4.502
>> RxCan1[04d] Avg|   34.31|  2.4433|    0.022
>>            Peak|        |  2.4773|    1.368
>> RxCan1[076] Avg|   49.96|  1.2071|    0.024
>>            Peak|        |  1.2554|    2.007
>> RxCan1[077] Avg|   49.96|  1.2012|    0.022
>>            Peak|        |  1.2492|    1.955
>> RxCan1[07a] Avg|   34.35|  2.9251|    0.030
>>            Peak|        |  3.1103|    1.829
>> RxCan1[07d] Avg|   49.96|  1.1954|    0.022
>>            Peak|        |  1.2282|    1.074
>> RxCan1[0c8] Avg|   49.89|  1.2491|    0.021
>>            Peak|        |  1.3169|    1.181
>> RxCan1[11a] Avg|   34.39|  2.4423|    0.024
>>            Peak|        |  2.5693|    1.491
>> RxCan1[130] Avg|   49.95|  1.1312|    0.020
>>            Peak|        |  1.1684|    1.218
>> RxCan1[139] Avg|   49.92|  1.1547|    0.021
>>            Peak|        |  1.1778|    1.199
>> RxCan1[156] Avg|    9.96|  0.2391|    0.023
>>            Peak|        |  0.2591|    1.943
>> RxCan1[160] Avg|   49.96|  1.1657|    0.031
>>            Peak|        |  1.2017|    2.158
>> RxCan1[165] Avg|   49.96|  1.1257|    0.021
>>            Peak|        |  1.1652|    1.471
>> RxCan1[167] Avg|   34.31|  2.2871|    0.021
>>            Peak|        |  2.3374|    1.776
>> RxCan1[171] Avg|   49.96|  1.1879|    0.023
>>            Peak|        |  1.2268|    1.166
>> RxCan1[178] Avg|   10.00|  0.2371|    0.029
>>            Peak|        |  0.2459|    1.516
>> RxCan1[179] Avg|   10.00|  0.2196|    0.021
>>            Peak|        |  0.2260|    0.758
>> RxCan1[180] Avg|   49.96|  1.1703|    0.022
>>            Peak|        |  1.2103|    1.481
>> RxCan1[185] Avg|   49.95|  1.1127|    0.020
>>            Peak|        |  1.1636|    1.292
>> RxCan1[1a0] Avg|   49.96|  1.1009|    0.020
>>            Peak|        |  1.1468|    1.060
>> RxCan1[1e0] Avg|   49.96|  1.1744|    0.021
>>            Peak|        |  1.2027|    1.240
>> RxCan1[1e4] Avg|   49.96|  1.3733|    0.032
>>            Peak|        |  1.4085|    1.523
>> RxCan1[1f0] Avg|   33.30|  0.7625|    0.023
>>            Peak|        |  0.8004|    3.349
>> RxCan1[200] Avg|   49.92|  1.1462|    0.021
>>            Peak|        |  1.1809|    1.254
>> RxCan1[202] Avg|   34.39|  2.4034|    0.028
>>            Peak|        |  2.5611|    1.472
>> RxCan1[204] Avg|   34.30|  2.2541|    0.022
>>            Peak|        |  2.2924|    2.015
>> RxCan1[213] Avg|   49.96|  1.1599|    0.027
>>            Peak|        |  1.1794|    1.714
>> RxCan1[214] Avg|   49.96|  1.1537|    0.022
>>            Peak|        |  1.1941|    1.439
>> RxCan1[217] Avg|   34.39|  2.2490|    0.020
>>            Peak|        |  2.2856|    3.766
>> RxCan1[218] Avg|   49.96|  1.1291|    0.021
>>            Peak|        |  1.1646|    1.547
>> RxCan1[230] Avg|   49.96|  1.1272|    0.020
>>            Peak|        |  1.2237|    1.295
>> RxCan1[240] Avg|   10.00|  0.2191|    0.021
>>            Peak|        |  0.2226|    1.067
>> RxCan1[242] Avg|   24.96|  0.6911|    0.024
>>            Peak|        |  0.7161|    1.180
>> RxCan1[24a] Avg|    9.96|  0.2345|    0.024
>>            Peak|        |  0.2535|    0.779
>> RxCan1[24b] Avg|    9.96|  0.2433|    0.023
>>            Peak|        |  0.2697|    2.085
>> RxCan1[24c] Avg|    9.96|  0.3103|    0.029
>>            Peak|        |  0.3203|    0.809
>> RxCan1[25a] Avg|   10.00|  0.2346|    0.022
>>            Peak|        |  0.2405|    1.223
>> RxCan1[25b] Avg|   49.89|  1.2121|    0.020
>>            Peak|        |  1.3659|   19.523
>> RxCan1[25c] Avg|   34.31|  2.4193|    0.019
>>            Peak|        |  2.8022|   58.153
>> RxCan1[260] Avg|    9.93|  0.2149|    0.024
>>            Peak|        |  0.2174|    1.096
>> RxCan1[270] Avg|   49.96|  1.2042|    0.026
>>            Peak|        |  1.2755|   20.612
>> RxCan1[280] Avg|   49.96|  1.0922|    0.020
>>            Peak|        |  1.1312|    1.266
>> RxCan1[2e4] Avg|   19.96|  0.6942|    0.044
>>            Peak|        |  0.8604|    1.533
>> RxCan1[2ec] Avg|   10.00|  0.3727|    0.025
>>            Peak|        |  0.5154|   28.819
>> RxCan1[2ed] Avg|   10.00|  0.2298|    0.023
>>            Peak|        |  0.2378|    1.345
>> RxCan1[2ee] Avg|    9.96|  0.2172|    0.019
>>            Peak|        |  0.2210|    1.058
>> RxCan1[312] Avg|   10.00|  0.2206|    0.020
>>            Peak|        |  0.2396|    1.060
>> RxCan1[326] Avg|    9.96|  0.2099|    0.020
>>            Peak|        |  0.2158|    0.507
>> RxCan1[336] Avg|    1.00|  0.0212|    0.020
>>            Peak|        |  0.0233|    0.315
>> RxCan1[352] Avg|    6.64|  0.1675|    0.024
>>            Peak|        |  0.1818|    1.048
>> RxCan1[355] Avg|    2.00|  0.0540|    0.027
>>            Peak|        |  0.0619|    1.209
>> RxCan1[35e] Avg|    9.98|  0.2221|    0.021
>>            Peak|        |  0.2284|    1.186
>> RxCan1[365] Avg|   10.00|  0.2282|    0.023
>>            Peak|        |  0.2335|    0.769
>> RxCan1[366] Avg|   10.00|  0.3163|    0.022
>>            Peak|        |  0.6330|   23.587
>> RxCan1[367] Avg|   10.00|  0.2417|    0.021
>>            Peak|        |  0.2568|    1.417
>> RxCan1[368] Avg|    9.96|  0.2187|    0.019
>>            Peak|        |  0.2250|    1.135
>> RxCan1[369] Avg|    9.99|  0.2277|    0.021
>>            Peak|        |  0.2334|    0.667
>> RxCan1[380] Avg|    9.96|  0.2133|    0.020
>>            Peak|        |  0.2161|    0.560
>> RxCan1[38b] Avg|   24.92|  0.5622|    0.022
>>            Peak|        |  0.5716|    1.618
>> RxCan1[3b3] Avg|   10.00|  0.2132|    0.023
>>            Peak|        |  0.2194|    1.106
>> RxCan1[400] Avg|    4.00|  0.0885|    0.019
>>            Peak|        |  0.0885|    0.570
>> RxCan1[405] Avg|    3.70|  0.1414|    0.036
>>            Peak|        |  0.1414|    0.710
>> RxCan1[40a] Avg|    8.00|  0.1887|    0.021
>>            Peak|        |  0.1887|    1.027
>> RxCan1[410] Avg|   10.00|  0.2141|    0.023
>>            Peak|        |  0.2188|    0.984
>> RxCan1[411] Avg|   10.00|  0.2325|    0.023
>>            Peak|        |  0.2447|    0.660
>> RxCan1[416] Avg|   10.00|  0.2326|    0.022
>>            Peak|        |  0.2389|    0.774
>> RxCan1[421] Avg|   10.00|  0.2245|    0.021
>>            Peak|        |  0.2271|    1.160
>> RxCan1[42d] Avg|   10.00|  0.2315|    0.021
>>            Peak|        |  0.2411|    0.677
>> RxCan1[42f] Avg|   10.00|  0.2480|    0.020
>>            Peak|        |  0.2975|    8.093
>> RxCan1[430] Avg|   10.00|  0.2203|    0.019
>>            Peak|        |  0.2302|    0.847
>> RxCan1[434] Avg|   10.00|  0.2331|    0.019
>>            Peak|        |  0.2620|    1.150
>> RxCan1[435] Avg|    6.68|  0.1445|    0.020
>>            Peak|        |  0.1486|    1.063
>> RxCan1[43e] Avg|   20.00|  0.4515|    0.021
>>            Peak|        |  0.4632|    1.013
>> RxCan1[440] Avg|    1.00|  0.0210|    0.019
>>            Peak|        |  0.0218|    0.294
>> RxCan1[465] Avg|    0.95|  0.0214|    0.023
>>            Peak|        |  0.0215|    0.587
>> RxCan1[466] Avg|    0.95|  0.0211|    0.021
>>            Peak|        |  0.0215|    0.350
>> RxCan1[467] Avg|    0.95|  0.0191|    0.020
>>            Peak|        |  0.0201|    0.444
>> RxCan1[472] Avg|    0.68|  0.0588|    0.085
>>            Peak|        |  0.0606|    1.170
>> RxCan1[473] Avg|    0.66|  0.0407|    0.062
>>            Peak|        |  0.0492|    1.329
>> RxCan1[474] Avg|    1.00|  0.0218|    0.021
>>            Peak|        |  0.0237|    0.278
>> RxCan1[475] Avg|    1.96|  0.0466|    0.024
>>            Peak|        |  0.0570|    1.112
>> RxCan1[476] Avg|    2.00|  0.0454|    0.020
>>            Peak|        |  0.0497|    0.409
>> RxCan1[477] Avg|    2.00|  0.0497|    0.022
>>            Peak|        |  0.0595|    0.864
>> RxCan1[595] Avg|    1.00|  0.0223|    0.021
>>            Peak|        |  0.0241|    0.296
>> RxCan1[59e] Avg|    1.00|  0.0233|    0.024
>>            Peak|        |  0.0289|    0.713
>> RxCan1[5a2] Avg|    1.00|  0.0200|    0.020
>>            Peak|        |  0.0204|    0.264
>> RxCan1[5ba] Avg|    1.00|  0.0206|    0.021
>>            Peak|        |  0.0238|    0.515
>> RxCan2[020] Avg|   33.30|  0.7938|    0.022
>>            Peak|        |  0.7938|    4.793
>> RxCan2[030] Avg|   22.20|  0.5229|    0.022
>>            Peak|        |  0.5229|    0.985
>> RxCan2[03a] Avg|   19.90|  0.4700|    0.022
>>            Peak|        |  0.4700|    0.804
>> RxCan2[040] Avg|   19.90|  0.4678|    0.023
>>            Peak|        |  0.4678|    1.222
>> RxCan2[060] Avg|   20.00|  0.6480|    0.050
>>            Peak|        |  0.6480|   20.997
>> RxCan2[070] Avg|   16.60|  0.3944|    0.022
>>            Peak|        |  0.3944|    1.053
>> RxCan2[080] Avg|   16.70|  0.7032|    0.041
>>            Peak|        |  0.7032|    1.611
>> RxCan2[083] Avg|   20.10|  0.4329|    0.021
>>            Peak|        |  0.4329|    0.520
>> RxCan2[090] Avg|   24.90|  0.5674|    0.017
>>            Peak|        |  0.5674|    1.149
>> RxCan2[0a0] Avg|   16.60|  0.3836|    0.023
>>            Peak|        |  0.3836|    0.933
>> RxCan2[100] Avg|   16.50|  0.3661|    0.021
>>            Peak|        |  0.3661|    0.740
>> RxCan2[108] Avg|   24.90|  0.5923|    0.025
>>            Peak|        |  0.5923|    0.859
>> RxCan2[110] Avg|   16.70|  0.3906|    0.023
>>            Peak|        |  0.3906|    0.697
>> RxCan2[130] Avg|   14.40|  0.3341|    0.022
>>            Peak|        |  0.3341|    0.829
>> RxCan2[150] Avg|   16.50|  0.4025|    0.020
>>            Peak|        |  0.4025|    1.120
>> RxCan2[160] Avg|    4.90|  0.1252|    0.025
>>            Peak|        |  0.1252|    0.502
>> RxCan2[180] Avg|   16.60|  0.3899|    0.023
>>            Peak|        |  0.3899|    0.799
>> RxCan2[190] Avg|   16.60|  0.3892|    0.025
>>            Peak|        |  0.3892|    1.172
>> RxCan2[1a0] Avg|    1.00|  0.0281|    0.025
>>            Peak|        |  0.0281|    0.695
>> RxCan2[1a4] Avg|   20.00|  0.4525|    0.022
>>            Peak|        |  0.4525|    1.231
>> RxCan2[1a8] Avg|   12.50|  0.2886|    0.020
>>            Peak|        |  0.2886|    1.048
>> RxCan2[1b0] Avg|   10.00|  0.2300|    0.023
>>            Peak|        |  0.2300|    0.579
>> RxCan2[1b4] Avg|   10.00|  0.2334|    0.022
>>            Peak|        |  0.2334|    0.947
>> RxCan2[1b8] Avg|   12.40|  0.2970|    0.023
>>            Peak|        |  0.2970|    0.909
>> RxCan2[1c0] Avg|   10.00|  0.2257|    0.021
>>            Peak|        |  0.2257|    0.983
>> RxCan2[1e0] Avg|   10.00|  0.2141|    0.023
>>            Peak|        |  0.2141|    0.556
>> RxCan2[215] Avg|    8.30|  0.2047|    0.025
>>            Peak|        |  0.2047|    0.786
>> RxCan2[217] Avg|    8.30|  0.2033|    0.022
>>            Peak|        |  0.2033|    1.135
>> RxCan2[220] Avg|    6.70|  0.1647|    0.020
>>            Peak|        |  0.1647|    0.961
>> RxCan2[225] Avg|   24.90|  0.6136|    0.026
>>            Peak|        |  0.6136|    1.018
>> RxCan2[230] Avg|    6.70|  0.4045|    0.057
>>            Peak|        |  0.4045|    1.532
>> RxCan2[240] Avg|    8.20|  0.1849|    0.021
>>            Peak|        |  0.1849|    0.510
>> RxCan2[241] Avg|   20.00|  0.4312|    0.021
>>            Peak|        |  0.4312|    5.110
>> RxCan2[250] Avg|    5.00|  0.1072|    0.021
>>            Peak|        |  0.1072|    0.320
>> RxCan2[255] Avg|   12.50|  0.3091|    0.022
>>            Peak|        |  0.3091|    0.904
>> RxCan2[265] Avg|   12.50|  0.2819|    0.021
>>            Peak|        |  0.2819|    1.035
>> RxCan2[270] Avg|    5.00|  0.1189|    0.022
>>            Peak|        |  0.1189|    0.631
>> RxCan2[290] Avg|    3.30|  0.0740|    0.023
>>            Peak|        |  0.0740|    0.455
>> RxCan2[295] Avg|    6.60|  0.1431|    0.023
>>            Peak|        |  0.1431|    0.504
>> RxCan2[2a0] Avg|    3.30|  0.0686|    0.020
>>            Peak|        |  0.0686|    0.445
>> RxCan2[2a7] Avg|   12.50|  0.2869|    0.021
>>            Peak|        |  0.2869|    0.660
>> RxCan2[2b0] Avg|    3.20|  0.0707|    0.023
>>            Peak|        |  0.0707|    0.331
>> RxCan2[2c0] Avg|    3.20|  0.0988|    0.026
>>            Peak|        |  0.0988|    0.932
>> RxCan2[2e0] Avg|    1.60|  0.0388|    0.024
>>            Peak|        |  0.0388|    0.393
>> RxCan2[2f0] Avg|    1.70|  0.0376|    0.021
>>            Peak|        |  0.0376|    0.282
>> RxCan2[2f5] Avg|   12.50|  0.2833|    0.021
>>            Peak|        |  0.2833|    0.855
>> RxCan2[300] Avg|    1.70|  0.0398|    0.023
>>            Peak|        |  0.0398|    0.488
>> RxCan2[310] Avg|    1.60|  0.0480|    0.026
>>            Peak|        |  0.0480|    0.937
>> RxCan2[320] Avg|    1.70|  0.0346|    0.020
>>            Peak|        |  0.0346|    0.370
>> RxCan2[326] Avg|    9.90|  0.2200|    0.022
>>            Peak|        |  0.2200|    0.502
>> RxCan2[330] Avg|   32.30|  0.7323|    0.021
>>            Peak|        |  0.7323|    1.130
>> RxCan2[340] Avg|    8.20|  0.2375|    0.028
>>            Peak|        |  0.2375|    0.578
>> RxCan2[345] Avg|    1.60|  0.0393|    0.022
>>            Peak|        |  0.0393|    0.590
>> RxCan2[35e] Avg|    5.00|  0.1303|    0.023
>>            Peak|        |  0.1303|    0.943
>> RxCan2[360] Avg|    1.70|  0.0381|    0.025
>>            Peak|        |  0.0381|    0.922
>> RxCan2[361] Avg|    8.20|  0.1907|    0.023
>>            Peak|        |  0.1907|    1.119
>> RxCan2[363] Avg|    1.30|  0.0337|    0.024
>>            Peak|        |  0.0337|    0.425
>> RxCan2[370] Avg|    0.90|  0.0194|    0.022
>>            Peak|        |  0.0194|    0.246
>> RxCan2[381] Avg|    3.20|  0.0684|    0.024
>>            Peak|        |  0.0684|    0.828
>> RxCan2[3a0] Avg|   16.60|  0.3734|    0.022
>>            Peak|        |  0.3734|    0.636
>> RxCan2[3d0] Avg|   10.00|  0.2262|    0.023
>>            Peak|        |  0.2262|    0.663
>> RxCan2[3d5] Avg|    5.60|  0.1335|    0.022
>>            Peak|        |  0.1335|    1.222
>> RxCan2[400] Avg|    4.00|  0.0949|    0.022
>>            Peak|        |  0.0949|    0.715
>> RxCan2[405] Avg|    3.70|  0.0861|    0.022
>>            Peak|        |  0.0861|    0.443
>> RxCan2[40a] Avg|    8.00|  0.1853|    0.021
>>            Peak|        |  0.1853|    0.552
>> RxCan2[415] Avg|    1.60|  0.0341|    0.021
>>            Peak|        |  0.0341|    0.273
>> RxCan2[435] Avg|    0.90|  0.0220|    0.025
>>            Peak|        |  0.0220|    0.354
>> RxCan2[440] Avg|    0.90|  0.0199|    0.021
>>            Peak|        |  0.0199|    0.266
>> RxCan2[465] Avg|    0.90|  0.0234|    0.028
>>            Peak|        |  0.0234|    0.633
>> RxCan2[466] Avg|    1.00|  0.0222|    0.021
>>            Peak|        |  0.0222|    0.322
>> RxCan2[467] Avg|    1.00|  0.0221|    0.020
>>            Peak|        |  0.0221|    0.355
>> RxCan2[501] Avg|    1.50|  0.0335|    0.023
>>            Peak|        |  0.0335|    0.393
>> RxCan2[503] Avg|    1.50|  0.0370|    0.022
>>            Peak|        |  0.0370|    0.546
>> RxCan2[504] Avg|    1.40|  0.0328|    0.022
>>            Peak|        |  0.0328|    0.489
>> RxCan2[505] Avg|    1.40|  0.0290|    0.021
>>            Peak|        |  0.0290|    0.354
>> RxCan2[508] Avg|    1.40|  0.0318|    0.023
>>            Peak|        |  0.0318|    0.408
>> RxCan2[511] Avg|    1.40|  0.0306|    0.022
>>            Peak|        |  0.0306|    0.328
>> RxCan2[51e] Avg|    1.40|  0.0310|    0.022
>>            Peak|        |  0.0310|    0.269
>> RxCan2[581] Avg|    1.00|  0.0222|    0.022
>>            Peak|        |  0.0222|    0.256
>>       Total Avg| 2795.57| 82.7745|   40.174
>> Cheers,
>> Simon
>> Am 17.01.2025 um 17:49 schrieb Michael Balzer via OvmsDev:
>> OK, I've got a new idea: CAN timing.
>> Comparing our esp32can bit timing to the esp-idf driver's, there seem to
>> be some differences:
>> https://github.com/espressif/esp-idf/blob/master/components/hal/include/hal/twai_types_deprecated.h#L75
>> Transceivers are normally tolerant to small timing offsets. Maybe being
>> off a little bit has no effect under normal conditions, but it has when the
>> transceiver has to cope with a filled RX queue. That could be causing the
>> transceiver to slide just out of sync. If the timing gets garbled, the
>> transceiver would signal errors in the packets to the bus, possibly so many
>> the vehicle ECUs decide to raise an error condition.
>> Is that plausible?
>> On why the new poller could be causing this (in combination with too slow
>> processing by the vehicle): as mentioned, the standard CAN listener
>> mechanism doesn't care about queue overflows. The poller does.
>> `OvmsPollers::Queue_PollerFrame()` does a log call when Tx/Rx tracing is
>> enabled, that could even block, but tracing is optional and only meant for
>> debugging. Not optional is the overflow counting using an atomic uint32.
>> The atomic types are said to be fast, but I never checked their actual
>> implementation on the ESP32. Maybe they can block as well?
>> Am 17.01.25 um 15:37 schrieb Chris Box via OvmsDev:
>> Yes, I can confirm I've had one experience of the Leaf switching to
>> Neutral while driving, with a yellow warning symbol on the dash. It refused
>> to reselect Drive until I had switched the car off and back on. Derek
>> wasn't so lucky and he need to clear fault codes before the car would work.
>> On returning home, I found OVMS was not accessible over a network. I
>> didn't try a USB cable. Unplugging and reinserting the OBD cable caused
>> OVMS to rejoin Wi-Fi. However the SD logs showed nothing from the time of
>> the event. CAN writes are enabled, so it can perform SOC limiting.
>> My car has been using this firmware since 21st November, based on the git
>> master of that day. As a relatively new user of OVMS (only since October) I
>> don't have much experience of older firmware.
>> Perhaps a safeguard should be implemented before releasing a new stable
>> firmware that will be automatically downloaded by Leaf owners. But I don't
>> have the expertise to know what that safeguard should be. Derek's
>> suggestion of 'only CAN write when parked' appears to be a good idea.
>> Chris
>> On 2025-01-15 18:18, Derek Caudwell via OvmsDev wrote:
>> Since the following email I have high confidence the issue on the Leaf is
>> related/caused by the poller as there has been no further occurrence and
>> Chris has also experienced the car going to neutral on the new poller
>> firmware.
>> I haven't ruled out it being a fault with my car yet. Shortly after it
>> faulted the car was run into so has been off the road for sometime, my
>> first step was to replace 12V battery. The ovms unit is now unplugged and
>> if it does not fault over the next month while driving I'll be reasonably
>> confident it's ovms related.
>> Not sure which firmware version the poller updates were included in but
>> it was only after upgrading to it that the errors occurred (which could be
>> coincidental however it has faulted twice more both on version
>> 3.3.004-141-gf729d82c). For periods where I reverted to 3.3.003 it was fine.
>> It might be useful to have an extra option on the enable can write to
>> only enable it when the car is parked/charging.
>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250119/fafefeb6/attachment-0001.htm>
