Simon Ehlen ovms at highteq.de
Fri Jan 17 18:34:39 HKT 2025
Hi,
> How does the CAN bus crash manifest?
Charging stops during a charging process, the LEDs on the typ 2 socket flash. OVMS cannot be reached via WLAN or WAN.
While driving, the crash of the bus means that the car switches to limp mode. In the Focus Electric, this means that the powertrain is _immediately_ switched off completely and “stop safely now” is displayed on the dashboard. OVMS cannot be reached via WLAN or WAN.
Since the problem does not occur in listen mode, I have to assume that the poller thread somewhere is no longer able to keep up with the acknowledgement and is therefore causing the bus to get out of step.
For the statistics alone, the poller seems to evaluate every frame and therefore has a certain workload or do I have the option of restricting this to certain modules before calling IncomingFrameCan?
Cheers,
Simon
Am 17.01.2025 um 11:08 schrieb Michael Balzer via OvmsDev:
> Simon,
> AFAIK "Pollers[Send]" is the regular "next round" request for the polling task, not a frame transmission. A TX attempt in listen mode would produce a warn level log entry "Cannot write <busname> when not in ACTIVE mode" for tag "esp32can" or "mcp2515".
> With the old poller, you wouldn't have had any indication of a queue overflow, so the new poller may help you to identify an issue in your code.
> You need to understand the new poller not only does polls, it's now the main CAN receiver for the vehicle module. That's why your poller time stats include all process data frames as well, not only protocol frames.
> The overflow means either your CAN processing is too slow to keep up with the packets received, or some other task is hogging the CPU. That would need to be a task with an equal or higher priority as the vehicle task, which has priority level 10 -- only system & networking tasks are above, so that's not likely. (You can check the CPU usage with the "module tasks" command.)
> That means you should check your standard frame processing (`IncomingFrameCanX` callbacks) for potential delays and processing complexity issues.
> The poller statistics can help you track this down, but you need to have at least 10 seconds of statistics, the more the better. Rule of thumb: PRI average at 0.0/second means you don't have enough data yet. (-- //.ichael, correct me if I'm wrong)
>> At the same time, calling poller times on, poller times status causes the bus to crash
> In any case that still doesn't explain how the poller could possibly cause a CAN bus (!) crash without actually doing any transmissions.
> Am 15.01.25 um 19:54 schrieb Simon Ehlen via OvmsDev:
>> I put the two buses back into listen mode and drove a short distance and charged the car. As I said, there is no active polling in my code. As expected, there is therefore no indication of a failed TX attempt in the console log.
>> I only continue to see a lot of RX Task Queue Overflow messages in the log, which I did not have before.
>> I also see a Pollers[Send]: Task Queue Overflow entry, but since I don't see any indication of “cannot write” on that, I'm not assuming that's a “real” send.
>> I (19760210) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 5
>> I (19764420) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>> I (19764420) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 3
>> I (19764740) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>> I (19764750) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 2
>> I (19764750) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>> I (19764870) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>> I (19764870) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 2
>> I (19765270) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 4
>> I (19765270) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 6
>> I (19765610) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 3
>> I (19765930) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>> I (19765930) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 3
>> I (19766260) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 50
>> I (19766260) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 48
>> I (19766260) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 27
>> I (19766270) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 6
>> I (19766270) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 4
>> E (19766280) can: can2: intr=4754831 rxpkt=4757493 txpkt=0 errflags=0x22401c02 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=1 errreset=0
>> E (19766300) can: can2: intr=4754831 rxpkt=4757494 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=1 errreset=0
>> I (19766300) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 7
>> I (19766340) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 39
>> I (19766350) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 32
>> I (19766350) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 17
>> I (19766350) vehicle-poll: Pollers[Send]: Task Queue Overflow
>> E (19766360) can: can2: intr=4754840 rxpkt=4757509 txpkt=0 errflags=0x22401c02 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=1 errreset=0
>> I (19766370) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 4
>> E (19766370) can: can2: intr=4754840 rxpkt=4757510 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=1 errreset=0
>> I (19766430) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 30
>> I (19766430) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 36
>> I (19766430) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 26
>> I (19766430) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 4
>> I (19766430) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>> E (19766450) can: can2: intr=4754855 rxpkt=4757535 txpkt=0 errflags=0x23001001 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=1 errreset=0
>> E (19766460) can: can2: intr=4754855 rxpkt=4757536 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=1 errreset=0
>> E (19766520) can: can2: intr=4754855 rxpkt=4757539 txpkt=0 errflags=0x22001002 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=1 errreset=0
>> I (19766520) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 9
>> I (19766520) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 37
>> I (19766520) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 30
>> I (19766520) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 6
>> I (19766520) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 2
>> I (19766520) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>> I (19766530) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>> E (19766540) can: can2: intr=4754861 rxpkt=4757548 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=1 errreset=0
>> I (19766550) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 3
>> E (19766560) can: can2: intr=4754861 rxpkt=4757552 txpkt=0 errflags=0x23001001 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=1 errreset=0
>> E (19766610) can: can2: intr=4754861 rxpkt=4757553 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=1 errreset=0
>> I (19766610) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 4
>> I (19766610) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 5
>> I (19766610) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 33
>> I (19766610) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 34
>> I (19766610) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 12
>> W (19767070) websocket: WebSocketHandler[0x3f8d79d8]: job queue overflow detected
>> W (19767140) websocket: WebSocketHandler[0x3f8d79d8]: job queue overflow detected
>> W (19767180) websocket: WebSocketHandler[0x3f8d79d8]: job queue overflow resolved, 1 drops
>> W (19767260) websocket: WebSocketHandler[0x3f8d79d8]: job queue overflow detected
>> W (19767310) websocket: WebSocketHandler[0x3f8d79d8]: job queue overflow resolved, 1 drops
>> Cheers
>> Simon
>> Am 15.01.2025 um 19:18 schrieb Derek Caudwell via OvmsDev:
>>> Since the following email I have high confidence the issue on the Leaf is related/caused by the poller as there has been no further occurrence and Chris has also experienced the car going to neutral on the new poller firmware.
>>> I haven't ruled out it being a fault with my car yet. Shortly after it faulted the car was run into so has been off the road for sometime, my first step was to replace 12V battery. The ovms unit is now unplugged and if it does not fault over the next month while driving I'll be reasonably confident it's ovms related.
>>> Not sure which firmware version the poller updates were included in but it was only after upgrading to it that the errors occurred (which could be coincidental however it has faulted twice more both on version 3.3.004-141-gf729d82c). For periods where I reverted to 3.3.003 it was fine.
>>> It might be useful to have an extra option on the enable can write to only enable it when the car is parked/charging.
>>> On Wed, 15 Jan 2025, 11:11 pm Michael Balzer via OvmsDev, <ovmsdev at lists.openvehicles.com> wrote:
>>>     Derek, can you comment on this? Do you still have the issue mentioned?
>>>     Speaking of the Leaf, the code there actually does something fishy in `CommandWakeup()`:
>>>       unsigned char data = 0;
>>>       m_can1->WriteStandard(0x5C0, *_8_*, &data); //Wakes up the VCM (by spoofing empty battery request heating)
>>>     And there are CAN transmissions from command execution in the Leaf code, so to be sure there is no TX, listen mode is needed there as well.
>>>     Regarding CAN trace, you can try with the monitor channel and use the USB console to record the log output. That way you should be able to at least rule out there are regular transmissions -- assuming not every TX will cause an immediate crash.
>>>     Another / probably better option: when in listen mode, the log will also tell you about TX attempts, as the driver will issue a warning on each.
>>>     The CAN monitor log may also tell you about bus errors detected.
>>>     Regards,
>>>     Michael
>>>     Am 15.01.25 um 10:44 schrieb Simon Ehlen via OvmsDev:
>>>>     There is at least one more Leaf from Derek that has also ended up in limp mode since the new poller.
>>>>     There, too, no polling was actually carried out while driving.
>>>>     I'm not familiar with the framework at all, but does this perhaps offer you enough of an approach to recognize a commonality?
>>>>     Unfortunately I do not have a tool to create a CAN trace.
>>>>     I can't use the OVMS for this, as it no longer responds after a bus crash until I have disconnected it from the OBD and plugged it back in.
>>>>     Cheers,
>>>>     Simon
>>>>     Am 15.01.2025 um 10:18 schrieb Michael Balzer via OvmsDev:
>>>>>     The frame acknowledging is done automatically by the CAN transceiver when in active mode, this is part of the CAN protocol to indicate bit errors to the sender.
>>>>>     So normally a failure of the system to process received frames fast enough cannot cause any issue on the bus. But the ESP32 has a range of known hardware issues, especially in the embedded CAN transceiver, I wouldn't be surprised if there are more, or if our driver lacks some workaround for these.
>>>>>     Maybe the new poller has some bug that causes false transmissions from process data frames received. But many vehicles send process data frames, and we've had no issue reports like this on any of them, and ECUs also normally simply ignore out of sequence protocol frames.
>>>>>     You could record a CAN trace to see if there are transmissions, and what kind. If you don't poll and don't send frames from your code, there should be none. If the bus still crashes, that would be an indicator for something going wrong in the transceiver.
>>>>>     Regards,
>>>>>     Michael
>>>>>     Am 15.01.25 um 07:15 schrieb Simon Ehlen via OvmsDev:
>>>>>>     Thanks Mark for the explanation.
>>>>>>     So does this mean that OVMS tries to acknowledge all incoming messages in active mode?
>>>>>>     This seems to me to clearly exceed the capacity of OVMS with the mass of incoming messages.
>>>>>>     In fact, I am currently opening the bus in active mode, as I was hoping to get my code to revive the BMS in OVMS to work.
>>>>>>     However, unlike the other data, I only get the cell voltages when I actively poll them.
>>>>>>     To be on the safe side, I will now open the bus in read mode again.
>>>>>>     However, I am still wondering what in the poller change has altered the OVMS in such a way that the bus is now crashing completely.
>>>>>>     Currently I have undone the changes since february 2024, this only concerns code from the public repository, there was no change from me in that period.
>>>>>>     Now the OVMS is running stable again and there are neither queue overflows nor bus crashes.
>>>>>>     I had also previously increased the following queue sizes, but unfortunately this was not successful:
>>>>>>     CONFIG_OVMS_HW_EVENT_QUEUE_SIZE=120
>>>>>>     CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=80
>>>>>>     CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=80
>>>>>>     Cheers,
>>>>>>     Simon
>>>>>>     Am 15.01.2025 um 02:08 schrieb Mark Webb-Johnson:
>>>>>>>     Note sure if this helps, but some comments:
>>>>>>>       * Remember than CAN protocol in normal mode is an ‘active’ protocol. Nodes on the bus are actively acknowledging messages (and that includes OVMS), even if they never write messages. So in normal mode there is no absolute ‘read access’. For example, opening the CAN port at the wrong baud rate, even if not writing messages, will mess up the bus.
>>>>>>>       * However, if you open the CAN port in ‘listen’ mode, then it is truly read-only. In that mode it will not acknowledge messages, and cannot write on the bus at all. I’ve never seen an OVMS mess up a bus in listen mode, even if the baud rate is wrong. I think the only way for that to happen would be a hardware layer issue (cabling, termination, etc).
>>>>>>>     Regards, Mark.
>>>>>>>>     On 15 Jan 2025, at 6:30 AM, Simon Ehlen via OvmsDev <ovmsdev at lists.openvehicles.com> <mailto:ovmsdev at lists.openvehicles.com> wrote:
>>>>>>>>     But what is the reason that a read access to the bus can cause the bus to crash?
>>>>>>>>     This is not critical during charging, it just aborts the charging process with an error.
>>>>>>>>     While driving, this results in a “stop safely now” error message on the dashboard and the engine is switched off immediately.
>>>>>>>>     Cheers,
>>>>>>>>     Simon
>>>>>>>>     Am 14.01.2025 um 23:22 schrieb Michael Geddes via OvmsDev:
>>>>>>>>>     You may need to increase the queue size for the poll task queue.
>>>>>>>>>     The poller still handles the bus to vehicle notifications even if it is off.
>>>>>>>>>     Any poller logging on such an intensive load of can messages is likely to be a problem.  This is part of the reason it is flagged off.
>>>>>>>>>     The total % looks wrong :/
>>>>>>>>>     //.ichael
>>>>>>>>>     On Wed, 15 Jan 2025, 03:17 Simon Ehlen via OvmsDev, <ovmsdev at lists.openvehicles.com> wrote:
>>>>>>>>>         Hi,
>>>>>>>>>         I finally got around to merging my code with the current master (previous merge february 2024).
>>>>>>>>>         I have rebuilt my code for a Ford Focus Electric so that it uses the new OvmsPoller class.
>>>>>>>>>         However, I now see a lot of entries like this in my log:
>>>>>>>>>         I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 8
>>>>>>>>>         I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 3
>>>>>>>>>         I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>>>>>>>>>         I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 2
>>>>>>>>>         I (254448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 24
>>>>>>>>>         I (254448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>>>>>>>>>         Was this message just hidden before or do I need to make further adjustments to my code?
>>>>>>>>>         My code currently does not use active polling but reads on the busses (IncomingFrameCanX) on certain modules.
>>>>>>>>>         When I look at poller times status, it looks very extensive to me...
>>>>>>>>>         OVMS# poller times status
>>>>>>>>>         Poller timing is: on
>>>>>>>>>         Type           | count  | Utlztn | Time
>>>>>>>>>                         | per s  | [%]    | [ms]
>>>>>>>>>         Poll:PRI    Avg|    0.00| 0.0000|    0.003
>>>>>>>>>                     Peak| |  0.0014|    0.041
>>>>>>>>>         RxCan1[010] Avg|    0.00| 0.0000|    0.020
>>>>>>>>>                     Peak| |  1.2217|    1.089
>>>>>>>>>         RxCan1[030] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  1.2193|    1.241
>>>>>>>>>         RxCan1[041] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.6460|    1.508
>>>>>>>>>         RxCan1[049] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.6320|    0.630
>>>>>>>>>         RxCan1[04c] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.6430|    1.474
>>>>>>>>>         RxCan1[04d] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  1.2987|    1.359
>>>>>>>>>         RxCan1[076] Avg|    0.00| 0.0000|    0.072
>>>>>>>>>                     Peak| |  0.7818|   15.221
>>>>>>>>>         RxCan1[077] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.6274|    0.955
>>>>>>>>>         RxCan1[07a] Avg|    0.00| 0.0000|    0.039
>>>>>>>>>                     Peak| |  1.7602|    1.684
>>>>>>>>>         RxCan1[07d] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.6621|    1.913
>>>>>>>>>         RxCan1[0c8] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>                     Peak| |  0.6292|    1.412
>>>>>>>>>         RxCan1[11a] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  1.2635|    1.508
>>>>>>>>>         RxCan1[130] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.6548|    0.703
>>>>>>>>>         RxCan1[139] Avg|    0.00| 0.0000|    0.021
>>>>>>>>>                     Peak| |  0.6002|    0.984
>>>>>>>>>         RxCan1[156] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.1225|    0.479
>>>>>>>>>         RxCan1[160] Avg|    0.00| 0.0000|    0.028
>>>>>>>>>                     Peak| |  0.6586|    1.376
>>>>>>>>>         RxCan1[165] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>                     Peak| |  0.6368|    1.132
>>>>>>>>>         RxCan1[167] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  1.3009|    1.067
>>>>>>>>>         RxCan1[171] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.6590|    4.320
>>>>>>>>>         RxCan1[178] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.1161|    0.311
>>>>>>>>>         RxCan1[179] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.1236|    0.536
>>>>>>>>>         RxCan1[180] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.6472|    1.193
>>>>>>>>>         RxCan1[185] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.6777|    1.385
>>>>>>>>>         RxCan1[1a0] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.6486|    2.276
>>>>>>>>>         RxCan1[1e0] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.6725|    1.376
>>>>>>>>>         RxCan1[1e4] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>                     Peak| |  0.7370|    1.266
>>>>>>>>>         RxCan1[1f0] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.4253|    0.753
>>>>>>>>>         RxCan1[200] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>                     Peak| |  0.6262|    0.791
>>>>>>>>>         RxCan1[202] Avg|    0.00| 0.0000|    0.021
>>>>>>>>>                     Peak| |  1.2915|    1.257
>>>>>>>>>         RxCan1[204] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  1.2620|    1.010
>>>>>>>>>         RxCan1[213] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.6331|    1.185
>>>>>>>>>         RxCan1[214] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.9977|   34.527
>>>>>>>>>         RxCan1[217] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  1.2825|    1.328
>>>>>>>>>         RxCan1[218] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.6328|    1.110
>>>>>>>>>         RxCan1[230] Avg|    0.00| 0.0000|    0.019
>>>>>>>>>                     Peak| |  0.6742|    5.119
>>>>>>>>>         RxCan1[240] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.1163|    0.343
>>>>>>>>>         RxCan1[242] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>                     Peak| |  0.3501|    1.015
>>>>>>>>>         RxCan1[24a] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.1212|    0.338
>>>>>>>>>         RxCan1[24b] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.1289|    0.330
>>>>>>>>>         RxCan1[24c] Avg|    0.00| 0.0000|    0.033
>>>>>>>>>                     Peak| |  0.1714|    1.189
>>>>>>>>>         RxCan1[25a] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.1289|    0.510
>>>>>>>>>         RxCan1[25b] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.6685|    0.930
>>>>>>>>>         RxCan1[25c] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>                     Peak| |  1.3298|    2.670
>>>>>>>>>         RxCan1[260] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.1271|    0.401
>>>>>>>>>         RxCan1[270] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.6439|    0.898
>>>>>>>>>         RxCan1[280] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.6502|    1.156
>>>>>>>>>         RxCan1[2e4] Avg|    0.00| 0.0000|    0.035
>>>>>>>>>                     Peak| |  0.3389|    0.811
>>>>>>>>>         RxCan1[2ec] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>                     Peak| |  0.1417|    0.784
>>>>>>>>>         RxCan1[2ed] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.1364|    0.746
>>>>>>>>>         RxCan1[2ee] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.1406|    0.965
>>>>>>>>>         RxCan1[312] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.1293|    0.978
>>>>>>>>>         RxCan1[326] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.1298|    0.518
>>>>>>>>>         RxCan1[336] Avg|    0.00| 0.0000|    0.028
>>>>>>>>>                     Peak| |  0.0106|    0.329
>>>>>>>>>         RxCan1[352] Avg|    0.00| 0.0000|    0.030
>>>>>>>>>                     Peak| |  0.1054|    0.800
>>>>>>>>>         RxCan1[355] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>                     Peak| |  0.0270|    0.546
>>>>>>>>>         RxCan1[35e] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.1288|    0.573
>>>>>>>>>         RxCan1[365] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.1297|    0.358
>>>>>>>>>         RxCan1[366] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>                     Peak| |  0.1429|    1.001
>>>>>>>>>         RxCan1[367] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>                     Peak| |  0.1472|    0.828
>>>>>>>>>         RxCan1[368] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.1323|    0.931
>>>>>>>>>         RxCan1[369] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>                     Peak| |  0.1498|    1.072
>>>>>>>>>         RxCan1[380] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.1285|    0.348
>>>>>>>>>         RxCan1[38b] Avg|    0.00| 0.0000|    0.021
>>>>>>>>>                     Peak| |  0.3298|    1.168
>>>>>>>>>         RxCan1[3b3] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>                     Peak| |  0.1348|    0.920
>>>>>>>>>         RxCan1[400] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.0481|    0.445
>>>>>>>>>         RxCan1[405] Avg|    0.00| 0.0000|    0.034
>>>>>>>>>                     Peak| |  0.0723|    0.473
>>>>>>>>>         RxCan1[40a] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>                     Peak| |  0.1040|    0.543
>>>>>>>>>         RxCan1[410] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.1339|    0.678
>>>>>>>>>         RxCan1[411] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>                     Peak| |  0.1376|    0.573
>>>>>>>>>         RxCan1[416] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.1284|    0.346
>>>>>>>>>         RxCan1[421] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.1323|    0.643
>>>>>>>>>         RxCan1[42d] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.1362|    1.146
>>>>>>>>>         RxCan1[42f] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>                     Peak| |  0.1503|    1.762
>>>>>>>>>         RxCan1[430] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.1352|    0.347
>>>>>>>>>         RxCan1[434] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.1312|    0.580
>>>>>>>>>         RxCan1[435] Avg|    0.00| 0.0000|    0.029
>>>>>>>>>                     Peak| |  0.1109|    1.133
>>>>>>>>>         RxCan1[43e] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.2776|    0.686
>>>>>>>>>         RxCan1[440] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.0118|    0.276
>>>>>>>>>         RxCan1[465] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.0118|    0.279
>>>>>>>>>         RxCan1[466] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.0123|    0.310
>>>>>>>>>         RxCan1[467] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>                     Peak| |  0.0132|    0.314
>>>>>>>>>         RxCan1[472] Avg|    0.00| 0.0000|    0.101
>>>>>>>>>                     Peak| |  0.0307|    1.105
>>>>>>>>>         RxCan1[473] Avg|    0.00| 0.0000|    0.051
>>>>>>>>>                     Peak| |  0.0107|    0.575
>>>>>>>>>         RxCan1[474] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.0097|    0.289
>>>>>>>>>         RxCan1[475] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.0220|    0.327
>>>>>>>>>         RxCan1[476] Avg|    0.00| 0.0000|    0.050
>>>>>>>>>                     Peak| |  0.0762|    5.329
>>>>>>>>>         RxCan1[477] Avg|    0.00| 0.0000|    0.032
>>>>>>>>>                     Peak| |  0.0283|    0.669
>>>>>>>>>         RxCan1[595] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>                     Peak| |  0.0103|    0.297
>>>>>>>>>         RxCan1[59e] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.0114|    0.263
>>>>>>>>>         RxCan1[5a2] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>                     Peak| |  0.0119|    0.505
>>>>>>>>>         RxCan1[5ba] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>                     Peak| |  0.0139|    0.549
>>>>>>>>>         RxCan2[020] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>                     Peak| |  0.4923|    1.133
>>>>>>>>>         RxCan2[030] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.3297|    1.136
>>>>>>>>>         RxCan2[03a] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.2792|    1.275
>>>>>>>>>         RxCan2[040] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.2834|    1.080
>>>>>>>>>         RxCan2[060] Avg|    0.00| 0.0000|    0.029
>>>>>>>>>                     Peak| |  0.3037|    0.991
>>>>>>>>>         RxCan2[070] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>                     Peak| |  0.2291|    0.460
>>>>>>>>>         RxCan2[080] Avg|    0.00| 0.0000|    0.043
>>>>>>>>>                     Peak| |  0.4015|    1.007
>>>>>>>>>         RxCan2[083] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>                     Peak| |  0.2957|    0.788
>>>>>>>>>         RxCan2[090] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>                     Peak| |  0.3951|    1.231
>>>>>>>>>         RxCan2[0a0] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>                     Peak| |  0.2560|    0.722
>>>>>>>>>         RxCan2[100] Avg|    0.00| 0.0000|    0.046
>>>>>>>>>                     Peak| |  0.4506|   21.961
>>>>>>>>>         RxCan2[108] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.3713|    1.125
>>>>>>>>>         RxCan2[110] Avg|    0.00| 0.0000|    0.029
>>>>>>>>>                     Peak| |  0.2443|    0.755
>>>>>>>>>         RxCan2[130] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.2052|    1.097
>>>>>>>>>         RxCan2[150] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.2246|    0.371
>>>>>>>>>         RxCan2[160] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.0755|    1.125
>>>>>>>>>         RxCan2[180] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.2350|    0.936
>>>>>>>>>         RxCan2[190] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.2275|    0.592
>>>>>>>>>         RxCan2[1a0] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>                     Peak| |  0.0125|    0.273
>>>>>>>>>         RxCan2[1a4] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.2806|    0.632
>>>>>>>>>         RxCan2[1a8] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.1683|    0.740
>>>>>>>>>         RxCan2[1b0] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.1360|    0.490
>>>>>>>>>         RxCan2[1b4] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>                     Peak| |  0.1556|    1.119
>>>>>>>>>         RxCan2[1b8] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.1704|    0.616
>>>>>>>>>         RxCan2[1c0] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.1317|    0.488
>>>>>>>>>         RxCan2[1e0] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>                     Peak| |  0.1460|    0.675
>>>>>>>>>         RxCan2[215] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.1191|    0.567
>>>>>>>>>         RxCan2[217] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.1167|    0.869
>>>>>>>>>         RxCan2[220] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.0918|    0.313
>>>>>>>>>         RxCan2[225] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>                     Peak| |  0.3635|    1.018
>>>>>>>>>         RxCan2[230] Avg|    0.00| 0.0000|    0.057
>>>>>>>>>                     Peak| |  0.2192|    1.063
>>>>>>>>>         RxCan2[240] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.1173|    0.760
>>>>>>>>>         RxCan2[241] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.2830|    1.144
>>>>>>>>>         RxCan2[250] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>                     Peak| |  0.0701|    0.698
>>>>>>>>>         RxCan2[255] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.1755|    1.063
>>>>>>>>>         RxCan2[265] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.1771|    0.729
>>>>>>>>>         RxCan2[270] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.0667|    0.307
>>>>>>>>>         RxCan2[290] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.0410|    0.280
>>>>>>>>>         RxCan2[295] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.0881|    0.299
>>>>>>>>>         RxCan2[2a0] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.0420|    0.268
>>>>>>>>>         RxCan2[2a7] Avg|    0.00| 0.0000|    0.021
>>>>>>>>>                     Peak| |  0.1716|    0.454
>>>>>>>>>         RxCan2[2b0] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.0424|    0.300
>>>>>>>>>         RxCan2[2c0] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.0470|    0.298
>>>>>>>>>         RxCan2[2e0] Avg|    0.00| 0.0000|    0.030
>>>>>>>>>                     Peak| |  0.0324|    1.152
>>>>>>>>>         RxCan2[2f0] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.0229|    0.359
>>>>>>>>>         RxCan2[2f5] Avg|    0.00| 0.0000|    0.026
>>>>>>>>>                     Peak| |  0.1882|    0.673
>>>>>>>>>         RxCan2[300] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.0186|    0.263
>>>>>>>>>         RxCan2[310] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.0210|    0.265
>>>>>>>>>         RxCan2[320] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>                     Peak| |  0.0207|    0.354
>>>>>>>>>         RxCan2[326] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.1466|    0.686
>>>>>>>>>         RxCan2[330] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.4580|    0.708
>>>>>>>>>         RxCan2[340] Avg|    0.00| 0.0000|    0.031
>>>>>>>>>                     Peak| |  0.1621|    0.785
>>>>>>>>>         RxCan2[345] Avg|    0.00| 0.0000|    0.021
>>>>>>>>>                     Peak| |  0.0199|    0.261
>>>>>>>>>         RxCan2[35e] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.0686|    0.449
>>>>>>>>>         RxCan2[360] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>                     Peak| |  0.0204|    0.289
>>>>>>>>>         RxCan2[361] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.1166|    0.316
>>>>>>>>>         RxCan2[363] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.0146|    0.304
>>>>>>>>>         RxCan2[370] Avg|    0.00| 0.0000|    0.024
>>>>>>>>>                     Peak| |  0.0099|    0.278
>>>>>>>>>         RxCan2[381] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>                     Peak| |  0.0468|    0.459
>>>>>>>>>         RxCan2[3a0] Avg|    0.00| 0.0000|    0.021
>>>>>>>>>                     Peak| |  0.2339|    0.617
>>>>>>>>>         RxCan2[3d0] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.1351|    0.351
>>>>>>>>>         RxCan2[3d5] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.0796|    0.692
>>>>>>>>>         RxCan2[400] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.0537|    0.307
>>>>>>>>>         RxCan2[405] Avg|    0.00| 0.0000|    0.021
>>>>>>>>>                     Peak| |  0.0513|    0.303
>>>>>>>>>         RxCan2[40a] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.1099|    0.313
>>>>>>>>>         RxCan2[415] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.0204|    0.251
>>>>>>>>>         RxCan2[435] Avg|    0.00| 0.0000|    0.028
>>>>>>>>>                     Peak| |  0.0113|    0.342
>>>>>>>>>         RxCan2[440] Avg|    0.00| 0.0000|    0.027
>>>>>>>>>                     Peak| |  0.0110|    0.299
>>>>>>>>>         RxCan2[465] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.0122|    0.295
>>>>>>>>>         RxCan2[466] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.0117|    0.267
>>>>>>>>>         RxCan2[467] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.0164|    0.325
>>>>>>>>>         RxCan2[501] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.0236|    0.276
>>>>>>>>>         RxCan2[503] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.0248|    0.349
>>>>>>>>>         RxCan2[504] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.0230|    0.312
>>>>>>>>>         RxCan2[505] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>                     Peak| |  0.0256|    0.310
>>>>>>>>>         RxCan2[508] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.0281|    0.329
>>>>>>>>>         RxCan2[511] Avg|    0.00| 0.0000|    0.022
>>>>>>>>>                     Peak| |  0.0232|    0.282
>>>>>>>>>         RxCan2[51e] Avg|    0.00| 0.0000|    0.023
>>>>>>>>>                     Peak| |  0.0248|    0.298
>>>>>>>>>         RxCan2[581] Avg|    0.00| 0.0000|    0.025
>>>>>>>>>                     Peak| |  0.0166|    0.286
>>>>>>>>>                Total Avg| 0.00|  0.0000|   43.563
>>>>>>>>>         At the same time, calling poller times on, poller times status causes the bus to crash, although no polls are actively being sent at all.
>>>>>>>>>         Cheers,
>>>>>>>>>         Simon
>>>>>>>>>         _______________________________________________
>>>>>>>>>         OvmsDev mailing list
>>>>>>>>>         OvmsDev at lists.openvehicles.com
>>>>>>>>>         http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>     Michael Balzer *Am Rahmen 5 * D-58313 Herdecke <https://www.google.com/maps/search/Am+Rahmen+5+*+D-58313+Herdecke?entry=gmail&source=g>
>>>>>     Fon 02330 9104094 * Handy 0176 20698926
> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250117/d82f7e02/attachment-0001.htm>
