Derek Caudwell d.caudwell at gmail.com
Thu Jan 16 02:52:15 HKT 2025
I should have added I've been running on  3.3.003 for 6 months now with no
issues.
On Thu, 16 Jan 2025, 7:18 am Derek Caudwell, <d.caudwell at gmail.com> wrote:
> Since the following email I have high confidence the issue on the Leaf is
> related/caused by the poller as there has been no further occurrence and
> Chris has also experienced the car going to neutral on the new poller
> firmware.
> I haven't ruled out it being a fault with my car yet. Shortly after it
> faulted the car was run into so has been off the road for sometime, my
> first step was to replace 12V battery. The ovms unit is now unplugged and
> if it does not fault over the next month while driving I'll be reasonably
> confident it's ovms related.
> Not sure which firmware version the poller updates were included in but it
> was only after upgrading to it that the errors occurred (which could be
> coincidental however it has faulted twice more both on version
> 3.3.004-141-gf729d82c). For periods where I reverted to 3.3.003 it was fine.
> It might be useful to have an extra option on the enable can write to only
> enable it when the car is parked/charging.
> On Wed, 15 Jan 2025, 11:11 pm Michael Balzer via OvmsDev, <
> ovmsdev at lists.openvehicles.com> wrote:
>> Derek, can you comment on this? Do you still have the issue mentioned?
>> Speaking of the Leaf, the code there actually does something fishy in
>> `CommandWakeup()`:
>>   unsigned char data = 0;
>>>>   m_can1->WriteStandard(0x5C0, *8*, &data); //Wakes up the VCM (by
>> spoofing empty battery request heating)
>> And there are CAN transmissions from command execution in the Leaf code,
>> so to be sure there is no TX, listen mode is needed there as well.
>> Regarding CAN trace, you can try with the monitor channel and use the USB
>> console to record the log output. That way you should be able to at least
>> rule out there are regular transmissions -- assuming not every TX will
>> cause an immediate crash.
>> Another / probably better option: when in listen mode, the log will also
>> tell you about TX attempts, as the driver will issue a warning on each.
>> The CAN monitor log may also tell you about bus errors detected.
>> Am 15.01.25 um 10:44 schrieb Simon Ehlen via OvmsDev:
>> There is at least one more Leaf from Derek that has also ended up in limp
>> mode since the new poller.
>> There, too, no polling was actually carried out while driving.
>> I'm not familiar with the framework at all, but does this perhaps offer
>> you enough of an approach to recognize a commonality?
>> Unfortunately I do not have a tool to create a CAN trace.
>> I can't use the OVMS for this, as it no longer responds after a bus crash
>> until I have disconnected it from the OBD and plugged it back in.
>> Cheers,
>> Simon
>> Am 15.01.2025 um 10:18 schrieb Michael Balzer via OvmsDev:
>> The frame acknowledging is done automatically by the CAN transceiver when
>> in active mode, this is part of the CAN protocol to indicate bit errors to
>> the sender.
>> So normally a failure of the system to process received frames fast
>> enough cannot cause any issue on the bus. But the ESP32 has a range of
>> known hardware issues, especially in the embedded CAN transceiver, I
>> wouldn't be surprised if there are more, or if our driver lacks some
>> workaround for these.
>> Maybe the new poller has some bug that causes false transmissions from
>> process data frames received. But many vehicles send process data frames,
>> and we've had no issue reports like this on any of them, and ECUs also
>> normally simply ignore out of sequence protocol frames.
>> You could record a CAN trace to see if there are transmissions, and what
>> kind. If you don't poll and don't send frames from your code, there should
>> be none. If the bus still crashes, that would be an indicator for something
>> going wrong in the transceiver.
>> Am 15.01.25 um 07:15 schrieb Simon Ehlen via OvmsDev:
>> Thanks Mark for the explanation.
>> So does this mean that OVMS tries to acknowledge all incoming messages in
>> active mode?
>> This seems to me to clearly exceed the capacity of OVMS with the mass of
>> incoming messages.
>> In fact, I am currently opening the bus in active mode, as I was hoping
>> to get my code to revive the BMS in OVMS to work.
>> However, unlike the other data, I only get the cell voltages when I
>> actively poll them.
>> To be on the safe side, I will now open the bus in read mode again.
>> However, I am still wondering what in the poller change has altered the
>> OVMS in such a way that the bus is now crashing completely.
>> Currently I have undone the changes since february 2024, this only
>> concerns code from the public repository, there was no change from me in
>> that period.
>> Now the OVMS is running stable again and there are neither queue
>> overflows nor bus crashes.
>> I had also previously increased the following queue sizes, but
>> unfortunately this was not successful:
>> CONFIG_OVMS_HW_EVENT_QUEUE_SIZE=120
>> CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=80
>> CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=80
>> Cheers,
>> Simon
>> Am 15.01.2025 um 02:08 schrieb Mark Webb-Johnson:
>> Note sure if this helps, but some comments:
>>    - Remember than CAN protocol in normal mode is an ‘active’ protocol.
>>    Nodes on the bus are actively acknowledging messages (and that includes
>>    OVMS), even if they never write messages. So in normal mode there is no
>>    absolute ‘read access’. For example, opening the CAN port at the wrong baud
>>    rate, even if not writing messages, will mess up the bus.
>>    - However, if you open the CAN port in ‘listen’ mode, then it is
>>    truly read-only. In that mode it will not acknowledge messages, and cannot
>>    write on the bus at all. I’ve never seen an OVMS mess up a bus in listen
>>    mode, even if the baud rate is wrong. I think the only way for that to
>>    happen would be a hardware layer issue (cabling, termination, etc).
>> On 15 Jan 2025, at 6:30 AM, Simon Ehlen via OvmsDev
>> <ovmsdev at lists.openvehicles.com> <ovmsdev at lists.openvehicles.com> wrote:
>> But what is the reason that a read access to the bus can cause the bus to
>> crash?
>> This is not critical during charging, it just aborts the charging process
>> with an error.
>> While driving, this results in a “stop safely now” error message on the
>> dashboard and the engine is switched off immediately.
>> Cheers,
>> Simon
>> Am 14.01.2025 um 23:22 schrieb Michael Geddes via OvmsDev:
>> You may need to increase  the queue size for the poll task queue.
>> The poller still handles the bus to vehicle notifications even if it is
>> off.
>> Any poller logging on such an intensive load of can messages is likely to
>> be a problem.  This is part of the reason it is flagged off.
>> The total % looks wrong :/
>> //.ichael
>> On Wed, 15 Jan 2025, 03:17 Simon Ehlen via OvmsDev, <
>>> Hi,
>>> I finally got around to merging my code with the current master
>>> (previous merge february 2024).
>>> I have rebuilt my code for a Ford Focus Electric so that it uses the new
>>> OvmsPoller class.
>>> However, I now see a lot of entries like this in my log:
>>> I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 8
>>> I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 3
>>> I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>>> I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 2
>>> I (254448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 24
>>> I (254448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow Run 1
>>> Was this message just hidden before or do I need to make further
>>> adjustments to my code?
>>> My code currently does not use active polling but reads on the busses
>>> (IncomingFrameCanX) on certain modules.
>>> When I look at poller times status, it looks very extensive to me...
>>> OVMS# poller times status
>>> Poller timing is: on
>>> Type           | count  | Utlztn | Time
>>>                 | per s  | [%]    | [ms]
>>> Poll:PRI    Avg|    0.00|  0.0000|    0.003
>>>             Peak|        |  0.0014|    0.041
>>> RxCan1[010] Avg|    0.00|  0.0000|    0.020
>>>             Peak|        |  1.2217|    1.089
>>> RxCan1[030] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  1.2193|    1.241
>>> RxCan1[041] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.6460|    1.508
>>> RxCan1[049] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.6320|    0.630
>>> RxCan1[04c] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.6430|    1.474
>>> RxCan1[04d] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  1.2987|    1.359
>>> RxCan1[076] Avg|    0.00|  0.0000|    0.072
>>>             Peak|        |  0.7818|   15.221
>>> RxCan1[077] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.6274|    0.955
>>> RxCan1[07a] Avg|    0.00|  0.0000|    0.039
>>>             Peak|        |  1.7602|    1.684
>>> RxCan1[07d] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.6621|    1.913
>>> RxCan1[0c8] Avg|    0.00|  0.0000|    0.026
>>>             Peak|        |  0.6292|    1.412
>>> RxCan1[11a] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  1.2635|    1.508
>>> RxCan1[130] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.6548|    0.703
>>> RxCan1[139] Avg|    0.00|  0.0000|    0.021
>>>             Peak|        |  0.6002|    0.984
>>> RxCan1[156] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.1225|    0.479
>>> RxCan1[160] Avg|    0.00|  0.0000|    0.028
>>>             Peak|        |  0.6586|    1.376
>>> RxCan1[165] Avg|    0.00|  0.0000|    0.027
>>>             Peak|        |  0.6368|    1.132
>>> RxCan1[167] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  1.3009|    1.067
>>> RxCan1[171] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.6590|    4.320
>>> RxCan1[178] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.1161|    0.311
>>> RxCan1[179] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.1236|    0.536
>>> RxCan1[180] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.6472|    1.193
>>> RxCan1[185] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.6777|    1.385
>>> RxCan1[1a0] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.6486|    2.276
>>> RxCan1[1e0] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.6725|    1.376
>>> RxCan1[1e4] Avg|    0.00|  0.0000|    0.027
>>>             Peak|        |  0.7370|    1.266
>>> RxCan1[1f0] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.4253|    0.753
>>> RxCan1[200] Avg|    0.00|  0.0000|    0.025
>>>             Peak|        |  0.6262|    0.791
>>> RxCan1[202] Avg|    0.00|  0.0000|    0.021
>>>             Peak|        |  1.2915|    1.257
>>> RxCan1[204] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  1.2620|    1.010
>>> RxCan1[213] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.6331|    1.185
>>> RxCan1[214] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.9977|   34.527
>>> RxCan1[217] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  1.2825|    1.328
>>> RxCan1[218] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.6328|    1.110
>>> RxCan1[230] Avg|    0.00|  0.0000|    0.019
>>>             Peak|        |  0.6742|    5.119
>>> RxCan1[240] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.1163|    0.343
>>> RxCan1[242] Avg|    0.00|  0.0000|    0.025
>>>             Peak|        |  0.3501|    1.015
>>> RxCan1[24a] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.1212|    0.338
>>> RxCan1[24b] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.1289|    0.330
>>> RxCan1[24c] Avg|    0.00|  0.0000|    0.033
>>>             Peak|        |  0.1714|    1.189
>>> RxCan1[25a] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.1289|    0.510
>>> RxCan1[25b] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.6685|    0.930
>>> RxCan1[25c] Avg|    0.00|  0.0000|    0.027
>>>             Peak|        |  1.3298|    2.670
>>> RxCan1[260] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.1271|    0.401
>>> RxCan1[270] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.6439|    0.898
>>> RxCan1[280] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.6502|    1.156
>>> RxCan1[2e4] Avg|    0.00|  0.0000|    0.035
>>>             Peak|        |  0.3389|    0.811
>>> RxCan1[2ec] Avg|    0.00|  0.0000|    0.027
>>>             Peak|        |  0.1417|    0.784
>>> RxCan1[2ed] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.1364|    0.746
>>> RxCan1[2ee] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.1406|    0.965
>>> RxCan1[312] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.1293|    0.978
>>> RxCan1[326] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.1298|    0.518
>>> RxCan1[336] Avg|    0.00|  0.0000|    0.028
>>>             Peak|        |  0.0106|    0.329
>>> RxCan1[352] Avg|    0.00|  0.0000|    0.030
>>>             Peak|        |  0.1054|    0.800
>>> RxCan1[355] Avg|    0.00|  0.0000|    0.027
>>>             Peak|        |  0.0270|    0.546
>>> RxCan1[35e] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.1288|    0.573
>>> RxCan1[365] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.1297|    0.358
>>> RxCan1[366] Avg|    0.00|  0.0000|    0.026
>>>             Peak|        |  0.1429|    1.001
>>> RxCan1[367] Avg|    0.00|  0.0000|    0.026
>>>             Peak|        |  0.1472|    0.828
>>> RxCan1[368] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.1323|    0.931
>>> RxCan1[369] Avg|    0.00|  0.0000|    0.026
>>>             Peak|        |  0.1498|    1.072
>>> RxCan1[380] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.1285|    0.348
>>> RxCan1[38b] Avg|    0.00|  0.0000|    0.021
>>>             Peak|        |  0.3298|    1.168
>>> RxCan1[3b3] Avg|    0.00|  0.0000|    0.025
>>>             Peak|        |  0.1348|    0.920
>>> RxCan1[400] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.0481|    0.445
>>> RxCan1[405] Avg|    0.00|  0.0000|    0.034
>>>             Peak|        |  0.0723|    0.473
>>> RxCan1[40a] Avg|    0.00|  0.0000|    0.025
>>>             Peak|        |  0.1040|    0.543
>>> RxCan1[410] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.1339|    0.678
>>> RxCan1[411] Avg|    0.00|  0.0000|    0.025
>>>             Peak|        |  0.1376|    0.573
>>> RxCan1[416] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.1284|    0.346
>>> RxCan1[421] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.1323|    0.643
>>> RxCan1[42d] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.1362|    1.146
>>> RxCan1[42f] Avg|    0.00|  0.0000|    0.027
>>>             Peak|        |  0.1503|    1.762
>>> RxCan1[430] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.1352|    0.347
>>> RxCan1[434] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.1312|    0.580
>>> RxCan1[435] Avg|    0.00|  0.0000|    0.029
>>>             Peak|        |  0.1109|    1.133
>>> RxCan1[43e] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.2776|    0.686
>>> RxCan1[440] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.0118|    0.276
>>> RxCan1[465] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.0118|    0.279
>>> RxCan1[466] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.0123|    0.310
>>> RxCan1[467] Avg|    0.00|  0.0000|    0.025
>>>             Peak|        |  0.0132|    0.314
>>> RxCan1[472] Avg|    0.00|  0.0000|    0.101
>>>             Peak|        |  0.0307|    1.105
>>> RxCan1[473] Avg|    0.00|  0.0000|    0.051
>>>             Peak|        |  0.0107|    0.575
>>> RxCan1[474] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.0097|    0.289
>>> RxCan1[475] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.0220|    0.327
>>> RxCan1[476] Avg|    0.00|  0.0000|    0.050
>>>             Peak|        |  0.0762|    5.329
>>> RxCan1[477] Avg|    0.00|  0.0000|    0.032
>>>             Peak|        |  0.0283|    0.669
>>> RxCan1[595] Avg|    0.00|  0.0000|    0.026
>>>             Peak|        |  0.0103|    0.297
>>> RxCan1[59e] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.0114|    0.263
>>> RxCan1[5a2] Avg|    0.00|  0.0000|    0.026
>>>             Peak|        |  0.0119|    0.505
>>> RxCan1[5ba] Avg|    0.00|  0.0000|    0.025
>>>             Peak|        |  0.0139|    0.549
>>> RxCan2[020] Avg|    0.00|  0.0000|    0.026
>>>             Peak|        |  0.4923|    1.133
>>> RxCan2[030] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.3297|    1.136
>>> RxCan2[03a] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.2792|    1.275
>>> RxCan2[040] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.2834|    1.080
>>> RxCan2[060] Avg|    0.00|  0.0000|    0.029
>>>             Peak|        |  0.3037|    0.991
>>> RxCan2[070] Avg|    0.00|  0.0000|    0.025
>>>             Peak|        |  0.2291|    0.460
>>> RxCan2[080] Avg|    0.00|  0.0000|    0.043
>>>             Peak|        |  0.4015|    1.007
>>> RxCan2[083] Avg|    0.00|  0.0000|    0.026
>>>             Peak|        |  0.2957|    0.788
>>> RxCan2[090] Avg|    0.00|  0.0000|    0.027
>>>             Peak|        |  0.3951|    1.231
>>> RxCan2[0a0] Avg|    0.00|  0.0000|    0.026
>>>             Peak|        |  0.2560|    0.722
>>> RxCan2[100] Avg|    0.00|  0.0000|    0.046
>>>             Peak|        |  0.4506|   21.961
>>> RxCan2[108] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.3713|    1.125
>>> RxCan2[110] Avg|    0.00|  0.0000|    0.029
>>>             Peak|        |  0.2443|    0.755
>>> RxCan2[130] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.2052|    1.097
>>> RxCan2[150] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.2246|    0.371
>>> RxCan2[160] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.0755|    1.125
>>> RxCan2[180] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.2350|    0.936
>>> RxCan2[190] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.2275|    0.592
>>> RxCan2[1a0] Avg|    0.00|  0.0000|    0.025
>>>             Peak|        |  0.0125|    0.273
>>> RxCan2[1a4] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.2806|    0.632
>>> RxCan2[1a8] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.1683|    0.740
>>> RxCan2[1b0] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.1360|    0.490
>>> RxCan2[1b4] Avg|    0.00|  0.0000|    0.027
>>>             Peak|        |  0.1556|    1.119
>>> RxCan2[1b8] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.1704|    0.616
>>> RxCan2[1c0] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.1317|    0.488
>>> RxCan2[1e0] Avg|    0.00|  0.0000|    0.025
>>>             Peak|        |  0.1460|    0.675
>>> RxCan2[215] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.1191|    0.567
>>> RxCan2[217] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.1167|    0.869
>>> RxCan2[220] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.0918|    0.313
>>> RxCan2[225] Avg|    0.00|  0.0000|    0.025
>>>             Peak|        |  0.3635|    1.018
>>> RxCan2[230] Avg|    0.00|  0.0000|    0.057
>>>             Peak|        |  0.2192|    1.063
>>> RxCan2[240] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.1173|    0.760
>>> RxCan2[241] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.2830|    1.144
>>> RxCan2[250] Avg|    0.00|  0.0000|    0.026
>>>             Peak|        |  0.0701|    0.698
>>> RxCan2[255] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.1755|    1.063
>>> RxCan2[265] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.1771|    0.729
>>> RxCan2[270] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.0667|    0.307
>>> RxCan2[290] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.0410|    0.280
>>> RxCan2[295] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.0881|    0.299
>>> RxCan2[2a0] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.0420|    0.268
>>> RxCan2[2a7] Avg|    0.00|  0.0000|    0.021
>>>             Peak|        |  0.1716|    0.454
>>> RxCan2[2b0] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.0424|    0.300
>>> RxCan2[2c0] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.0470|    0.298
>>> RxCan2[2e0] Avg|    0.00|  0.0000|    0.030
>>>             Peak|        |  0.0324|    1.152
>>> RxCan2[2f0] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.0229|    0.359
>>> RxCan2[2f5] Avg|    0.00|  0.0000|    0.026
>>>             Peak|        |  0.1882|    0.673
>>> RxCan2[300] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.0186|    0.263
>>> RxCan2[310] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.0210|    0.265
>>> RxCan2[320] Avg|    0.00|  0.0000|    0.025
>>>             Peak|        |  0.0207|    0.354
>>> RxCan2[326] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.1466|    0.686
>>> RxCan2[330] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.4580|    0.708
>>> RxCan2[340] Avg|    0.00|  0.0000|    0.031
>>>             Peak|        |  0.1621|    0.785
>>> RxCan2[345] Avg|    0.00|  0.0000|    0.021
>>>             Peak|        |  0.0199|    0.261
>>> RxCan2[35e] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.0686|    0.449
>>> RxCan2[360] Avg|    0.00|  0.0000|    0.025
>>>             Peak|        |  0.0204|    0.289
>>> RxCan2[361] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.1166|    0.316
>>> RxCan2[363] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.0146|    0.304
>>> RxCan2[370] Avg|    0.00|  0.0000|    0.024
>>>             Peak|        |  0.0099|    0.278
>>> RxCan2[381] Avg|    0.00|  0.0000|    0.025
>>>             Peak|        |  0.0468|    0.459
>>> RxCan2[3a0] Avg|    0.00|  0.0000|    0.021
>>>             Peak|        |  0.2339|    0.617
>>> RxCan2[3d0] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.1351|    0.351
>>> RxCan2[3d5] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.0796|    0.692
>>> RxCan2[400] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.0537|    0.307
>>> RxCan2[405] Avg|    0.00|  0.0000|    0.021
>>>             Peak|        |  0.0513|    0.303
>>> RxCan2[40a] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.1099|    0.313
>>> RxCan2[415] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.0204|    0.251
>>> RxCan2[435] Avg|    0.00|  0.0000|    0.028
>>>             Peak|        |  0.0113|    0.342
>>> RxCan2[440] Avg|    0.00|  0.0000|    0.027
>>>             Peak|        |  0.0110|    0.299
>>> RxCan2[465] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.0122|    0.295
>>> RxCan2[466] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.0117|    0.267
>>> RxCan2[467] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.0164|    0.325
>>> RxCan2[501] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.0236|    0.276
>>> RxCan2[503] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.0248|    0.349
>>> RxCan2[504] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.0230|    0.312
>>> RxCan2[505] Avg|    0.00|  0.0000|    0.025
>>>             Peak|        |  0.0256|    0.310
>>> RxCan2[508] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.0281|    0.329
>>> RxCan2[511] Avg|    0.00|  0.0000|    0.022
>>>             Peak|        |  0.0232|    0.282
>>> RxCan2[51e] Avg|    0.00|  0.0000|    0.023
>>>             Peak|        |  0.0248|    0.298
>>> RxCan2[581] Avg|    0.00|  0.0000|    0.025
>>>             Peak|        |  0.0166|    0.286
>>>        Total Avg|    0.00|  0.0000|   43.563
>>> At the same time, calling poller times on, poller times status causes
>>> the bus to crash, although no polls are actively being sent at all.
>>> Cheers,
>>> Simon
>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke <https://www.google.com/maps/search/Am+Rahmen+5+*+D-58313+Herdecke?entry=gmail&source=g>
>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250116/f903600c/attachment-0001.htm>
