Wed Jan 15 17:18:20 HKT 2025
The frame acknowledging is done automatically by the CAN transceiver
when in active mode, this is part of the CAN protocol to indicate bit
errors to the sender.
So normally a failure of the system to process received frames fast
enough cannot cause any issue on the bus. But the ESP32 has a range of
known hardware issues, especially in the embedded CAN transceiver, I
wouldn't be surprised if there are more, or if our driver lacks some
workaround for these.
Maybe the new poller has some bug that causes false transmissions from
process data frames received. But many vehicles send process data
frames, and we've had no issue reports like this on any of them, and
ECUs also normally simply ignore out of sequence protocol frames.
You could record a CAN trace to see if there are transmissions, and what
kind. If you don't poll and don't send frames from your code, there
should be none. If the bus still crashes, that would be an indicator for
something going wrong in the transceiver.
Am 15.01.25 um 07:15 schrieb Simon Ehlen via OvmsDev:
> Thanks Mark for the explanation.
> So does this mean that OVMS tries to acknowledge all incoming messages
> in active mode?
> This seems to me to clearly exceed the capacity of OVMS with the mass
> of incoming messages.
> In fact, I am currently opening the bus in active mode, as I was
> hoping to get my code to revive the BMS in OVMS to work.
> However, unlike the other data, I only get the cell voltages when I
> actively poll them.
> To be on the safe side, I will now open the bus in read mode again.
> However, I am still wondering what in the poller change has altered
> the OVMS in such a way that the bus is now crashing completely.
> Currently I have undone the changes since february 2024, this only
> concerns code from the public repository, there was no change from me
> in that period.
> Now the OVMS is running stable again and there are neither queue
> overflows nor bus crashes.
> I had also previously increased the following queue sizes, but
> unfortunately this was not successful:
> CONFIG_OVMS_HW_EVENT_QUEUE_SIZE=120
> CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=80
> CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=80
> Cheers,
> Simon
> Am 15.01.2025 um 02:08 schrieb Mark Webb-Johnson:
>> Note sure if this helps, but some comments:
>>   * Remember than CAN protocol in normal mode is an ‘active’
>>     protocol. Nodes on the bus are actively acknowledging messages
>>     (and that includes OVMS), even if they never write messages. So
>>     in normal mode there is no absolute ‘read access’. For example,
>>     opening the CAN port at the wrong baud rate, even if not writing
>>     messages, will mess up the bus.
>>   * However, if you open the CAN port in ‘listen’ mode, then it is
>>     truly read-only. In that mode it will not acknowledge messages,
>>     and cannot write on the bus at all. I’ve never seen an OVMS mess
>>     up a bus in listen mode, even if the baud rate is wrong. I think
>>     the only way for that to happen would be a hardware layer issue
>>     (cabling, termination, etc).
>>> On 15 Jan 2025, at 6:30 AM, Simon Ehlen via OvmsDev
>>> <ovmsdev at lists.openvehicles.com> wrote:
>>> But what is the reason that a read access to the bus can cause the
>>> bus to crash?
>>> This is not critical during charging, it just aborts the charging
>>> process with an error.
>>> While driving, this results in a “stop safely now” error message on
>>> the dashboard and the engine is switched off immediately.
>>> Cheers,
>>> Simon
>>> Am 14.01.2025 um 23:22 schrieb Michael Geddes via OvmsDev:
>>>> You may need to increase  the queue size for the poll task queue.
>>>> The poller still handles the bus to vehicle notifications even if
>>>> it is off.
>>>> Any poller logging on such an intensive load of can messages is
>>>> likely to be a problem.  This is part of the reason it is flagged off.
>>>> The total % looks wrong :/
>>>> //.ichael
>>>> On Wed, 15 Jan 2025, 03:17 Simon Ehlen via OvmsDev,
>>>>     Hi,
>>>>     I finally got around to merging my code with the current master
>>>>     (previous merge february 2024).
>>>>     I have rebuilt my code for a Ford Focus Electric so that it
>>>>     uses the new OvmsPoller class.
>>>>     However, I now see a lot of entries like this in my log:
>>>>     I (246448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>>>     Run 8
>>>>     Run 3
>>>>     Run 1
>>>>     Run 2
>>>>     Run 1
>>>>     Run 2
>>>>     Run 1
>>>>     Run 1
>>>>     I (254448) vehicle-poll: Poller[Frame]: RX Task Queue Overflow
>>>>     Run 24
>>>>     Run 1
>>>>     Run 1
>>>>     Run 1
>>>>     Run 1
>>>>     Run 1
>>>>     Queue Overflow Run 1
>>>>     Was this message just hidden before or do I need to make
>>>>     further adjustments to my code?
>>>>     My code currently does not use active polling but reads on the
>>>>     busses (IncomingFrameCanX) on certain modules.
>>>>     When I look at poller times status, it looks very extensive to
>>>>     me...
>>>>     OVMS# poller times status
>>>>     Poller timing is: on
>>>>     Type           | count  | Utlztn | Time
>>>>                     | per s  | [%]    | [ms]
>>>>     Poll:PRI    Avg|    0.00|  0.0000| 0.003
>>>>                 Peak|        |  0.0014| 0.041
>>>>     RxCan1[010] Avg|    0.00|  0.0000| 0.020
>>>>                 Peak|        |  1.2217| 1.089
>>>>     RxCan1[030] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  1.2193| 1.241
>>>>     RxCan1[041] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.6460| 1.508
>>>>     RxCan1[049] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.6320| 0.630
>>>>     RxCan1[04c] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.6430| 1.474
>>>>     RxCan1[04d] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  1.2987| 1.359
>>>>     RxCan1[076] Avg|    0.00|  0.0000| 0.072
>>>>                 Peak|        |  0.7818| 15.221
>>>>     RxCan1[077] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.6274| 0.955
>>>>     RxCan1[07a] Avg|    0.00|  0.0000| 0.039
>>>>                 Peak|        |  1.7602| 1.684
>>>>     RxCan1[07d] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.6621| 1.913
>>>>     RxCan1[0c8] Avg|    0.00|  0.0000| 0.026
>>>>                 Peak|        |  0.6292| 1.412
>>>>     RxCan1[11a] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  1.2635| 1.508
>>>>     RxCan1[130] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.6548| 0.703
>>>>     RxCan1[139] Avg|    0.00|  0.0000| 0.021
>>>>                 Peak|        |  0.6002| 0.984
>>>>     RxCan1[156] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.1225| 0.479
>>>>     RxCan1[160] Avg|    0.00|  0.0000| 0.028
>>>>                 Peak|        |  0.6586| 1.376
>>>>     RxCan1[165] Avg|    0.00|  0.0000| 0.027
>>>>                 Peak|        |  0.6368| 1.132
>>>>     RxCan1[167] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  1.3009| 1.067
>>>>     RxCan1[171] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.6590| 4.320
>>>>     RxCan1[178] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.1161| 0.311
>>>>     RxCan1[179] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.1236| 0.536
>>>>     RxCan1[180] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.6472| 1.193
>>>>     RxCan1[185] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.6777| 1.385
>>>>     RxCan1[1a0] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.6486| 2.276
>>>>     RxCan1[1e0] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.6725| 1.376
>>>>     RxCan1[1e4] Avg|    0.00|  0.0000| 0.027
>>>>                 Peak|        |  0.7370| 1.266
>>>>     RxCan1[1f0] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.4253| 0.753
>>>>     RxCan1[200] Avg|    0.00|  0.0000| 0.025
>>>>                 Peak|        |  0.6262| 0.791
>>>>     RxCan1[202] Avg|    0.00|  0.0000| 0.021
>>>>                 Peak|        |  1.2915| 1.257
>>>>     RxCan1[204] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  1.2620| 1.010
>>>>     RxCan1[213] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.6331| 1.185
>>>>     RxCan1[214] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.9977| 34.527
>>>>     RxCan1[217] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  1.2825| 1.328
>>>>     RxCan1[218] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.6328| 1.110
>>>>     RxCan1[230] Avg|    0.00|  0.0000| 0.019
>>>>                 Peak|        |  0.6742| 5.119
>>>>     RxCan1[240] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.1163| 0.343
>>>>     RxCan1[242] Avg|    0.00|  0.0000| 0.025
>>>>                 Peak|        |  0.3501| 1.015
>>>>     RxCan1[24a] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.1212| 0.338
>>>>     RxCan1[24b] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.1289| 0.330
>>>>     RxCan1[24c] Avg|    0.00|  0.0000| 0.033
>>>>                 Peak|        |  0.1714| 1.189
>>>>     RxCan1[25a] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.1289| 0.510
>>>>     RxCan1[25b] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.6685| 0.930
>>>>     RxCan1[25c] Avg|    0.00|  0.0000| 0.027
>>>>                 Peak|        |  1.3298| 2.670
>>>>     RxCan1[260] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.1271| 0.401
>>>>     RxCan1[270] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.6439| 0.898
>>>>     RxCan1[280] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.6502| 1.156
>>>>     RxCan1[2e4] Avg|    0.00|  0.0000| 0.035
>>>>                 Peak|        |  0.3389| 0.811
>>>>     RxCan1[2ec] Avg|    0.00|  0.0000| 0.027
>>>>                 Peak|        |  0.1417| 0.784
>>>>     RxCan1[2ed] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.1364| 0.746
>>>>     RxCan1[2ee] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.1406| 0.965
>>>>     RxCan1[312] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.1293| 0.978
>>>>     RxCan1[326] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.1298| 0.518
>>>>     RxCan1[336] Avg|    0.00|  0.0000| 0.028
>>>>                 Peak|        |  0.0106| 0.329
>>>>     RxCan1[352] Avg|    0.00|  0.0000| 0.030
>>>>                 Peak|        |  0.1054| 0.800
>>>>     RxCan1[355] Avg|    0.00|  0.0000| 0.027
>>>>                 Peak|        |  0.0270| 0.546
>>>>     RxCan1[35e] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.1288| 0.573
>>>>     RxCan1[365] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.1297| 0.358
>>>>     RxCan1[366] Avg|    0.00|  0.0000| 0.026
>>>>                 Peak|        |  0.1429| 1.001
>>>>     RxCan1[367] Avg|    0.00|  0.0000| 0.026
>>>>                 Peak|        |  0.1472| 0.828
>>>>     RxCan1[368] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.1323| 0.931
>>>>     RxCan1[369] Avg|    0.00|  0.0000| 0.026
>>>>                 Peak|        |  0.1498| 1.072
>>>>     RxCan1[380] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.1285| 0.348
>>>>     RxCan1[38b] Avg|    0.00|  0.0000| 0.021
>>>>                 Peak|        |  0.3298| 1.168
>>>>     RxCan1[3b3] Avg|    0.00|  0.0000| 0.025
>>>>                 Peak|        |  0.1348| 0.920
>>>>     RxCan1[400] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.0481| 0.445
>>>>     RxCan1[405] Avg|    0.00|  0.0000| 0.034
>>>>                 Peak|        |  0.0723| 0.473
>>>>     RxCan1[40a] Avg|    0.00|  0.0000| 0.025
>>>>                 Peak|        |  0.1040| 0.543
>>>>     RxCan1[410] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.1339| 0.678
>>>>     RxCan1[411] Avg|    0.00|  0.0000| 0.025
>>>>                 Peak|        |  0.1376| 0.573
>>>>     RxCan1[416] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.1284| 0.346
>>>>     RxCan1[421] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.1323| 0.643
>>>>     RxCan1[42d] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.1362| 1.146
>>>>     RxCan1[42f] Avg|    0.00|  0.0000| 0.027
>>>>                 Peak|        |  0.1503| 1.762
>>>>     RxCan1[430] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.1352| 0.347
>>>>     RxCan1[434] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.1312| 0.580
>>>>     RxCan1[435] Avg|    0.00|  0.0000| 0.029
>>>>                 Peak|        |  0.1109| 1.133
>>>>     RxCan1[43e] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.2776| 0.686
>>>>     RxCan1[440] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.0118| 0.276
>>>>     RxCan1[465] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.0118| 0.279
>>>>     RxCan1[466] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.0123| 0.310
>>>>     RxCan1[467] Avg|    0.00|  0.0000| 0.025
>>>>                 Peak|        |  0.0132| 0.314
>>>>     RxCan1[472] Avg|    0.00|  0.0000| 0.101
>>>>                 Peak|        |  0.0307| 1.105
>>>>     RxCan1[473] Avg|    0.00|  0.0000| 0.051
>>>>                 Peak|        |  0.0107| 0.575
>>>>     RxCan1[474] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.0097| 0.289
>>>>     RxCan1[475] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.0220| 0.327
>>>>     RxCan1[476] Avg|    0.00|  0.0000| 0.050
>>>>                 Peak|        |  0.0762| 5.329
>>>>     RxCan1[477] Avg|    0.00|  0.0000| 0.032
>>>>                 Peak|        |  0.0283| 0.669
>>>>     RxCan1[595] Avg|    0.00|  0.0000| 0.026
>>>>                 Peak|        |  0.0103| 0.297
>>>>     RxCan1[59e] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.0114| 0.263
>>>>     RxCan1[5a2] Avg|    0.00|  0.0000| 0.026
>>>>                 Peak|        |  0.0119| 0.505
>>>>     RxCan1[5ba] Avg|    0.00|  0.0000| 0.025
>>>>                 Peak|        |  0.0139| 0.549
>>>>     RxCan2[020] Avg|    0.00|  0.0000| 0.026
>>>>                 Peak|        |  0.4923| 1.133
>>>>     RxCan2[030] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.3297| 1.136
>>>>     RxCan2[03a] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.2792| 1.275
>>>>     RxCan2[040] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.2834| 1.080
>>>>     RxCan2[060] Avg|    0.00|  0.0000| 0.029
>>>>                 Peak|        |  0.3037| 0.991
>>>>     RxCan2[070] Avg|    0.00|  0.0000| 0.025
>>>>                 Peak|        |  0.2291| 0.460
>>>>     RxCan2[080] Avg|    0.00|  0.0000| 0.043
>>>>                 Peak|        |  0.4015| 1.007
>>>>     RxCan2[083] Avg|    0.00|  0.0000| 0.026
>>>>                 Peak|        |  0.2957| 0.788
>>>>     RxCan2[090] Avg|    0.00|  0.0000| 0.027
>>>>                 Peak|        |  0.3951| 1.231
>>>>     RxCan2[0a0] Avg|    0.00|  0.0000| 0.026
>>>>                 Peak|        |  0.2560| 0.722
>>>>     RxCan2[100] Avg|    0.00|  0.0000| 0.046
>>>>                 Peak|        |  0.4506| 21.961
>>>>     RxCan2[108] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.3713| 1.125
>>>>     RxCan2[110] Avg|    0.00|  0.0000| 0.029
>>>>                 Peak|        |  0.2443| 0.755
>>>>     RxCan2[130] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.2052| 1.097
>>>>     RxCan2[150] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.2246| 0.371
>>>>     RxCan2[160] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.0755| 1.125
>>>>     RxCan2[180] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.2350| 0.936
>>>>     RxCan2[190] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.2275| 0.592
>>>>     RxCan2[1a0] Avg|    0.00|  0.0000| 0.025
>>>>                 Peak|        |  0.0125| 0.273
>>>>     RxCan2[1a4] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.2806| 0.632
>>>>     RxCan2[1a8] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.1683| 0.740
>>>>     RxCan2[1b0] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.1360| 0.490
>>>>     RxCan2[1b4] Avg|    0.00|  0.0000| 0.027
>>>>                 Peak|        |  0.1556| 1.119
>>>>     RxCan2[1b8] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.1704| 0.616
>>>>     RxCan2[1c0] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.1317| 0.488
>>>>     RxCan2[1e0] Avg|    0.00|  0.0000| 0.025
>>>>                 Peak|        |  0.1460| 0.675
>>>>     RxCan2[215] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.1191| 0.567
>>>>     RxCan2[217] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.1167| 0.869
>>>>     RxCan2[220] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.0918| 0.313
>>>>     RxCan2[225] Avg|    0.00|  0.0000| 0.025
>>>>                 Peak|        |  0.3635| 1.018
>>>>     RxCan2[230] Avg|    0.00|  0.0000| 0.057
>>>>                 Peak|        |  0.2192| 1.063
>>>>     RxCan2[240] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.1173| 0.760
>>>>     RxCan2[241] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.2830| 1.144
>>>>     RxCan2[250] Avg|    0.00|  0.0000| 0.026
>>>>                 Peak|        |  0.0701| 0.698
>>>>     RxCan2[255] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.1755| 1.063
>>>>     RxCan2[265] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.1771| 0.729
>>>>     RxCan2[270] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.0667| 0.307
>>>>     RxCan2[290] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.0410| 0.280
>>>>     RxCan2[295] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.0881| 0.299
>>>>     RxCan2[2a0] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.0420| 0.268
>>>>     RxCan2[2a7] Avg|    0.00|  0.0000| 0.021
>>>>                 Peak|        |  0.1716| 0.454
>>>>     RxCan2[2b0] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.0424| 0.300
>>>>     RxCan2[2c0] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.0470| 0.298
>>>>     RxCan2[2e0] Avg|    0.00|  0.0000| 0.030
>>>>                 Peak|        |  0.0324| 1.152
>>>>     RxCan2[2f0] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.0229| 0.359
>>>>     RxCan2[2f5] Avg|    0.00|  0.0000| 0.026
>>>>                 Peak|        |  0.1882| 0.673
>>>>     RxCan2[300] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.0186| 0.263
>>>>     RxCan2[310] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.0210| 0.265
>>>>     RxCan2[320] Avg|    0.00|  0.0000| 0.025
>>>>                 Peak|        |  0.0207| 0.354
>>>>     RxCan2[326] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.1466| 0.686
>>>>     RxCan2[330] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.4580| 0.708
>>>>     RxCan2[340] Avg|    0.00|  0.0000| 0.031
>>>>                 Peak|        |  0.1621| 0.785
>>>>     RxCan2[345] Avg|    0.00|  0.0000| 0.021
>>>>                 Peak|        |  0.0199| 0.261
>>>>     RxCan2[35e] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.0686| 0.449
>>>>     RxCan2[360] Avg|    0.00|  0.0000| 0.025
>>>>                 Peak|        |  0.0204| 0.289
>>>>     RxCan2[361] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.1166| 0.316
>>>>     RxCan2[363] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.0146| 0.304
>>>>     RxCan2[370] Avg|    0.00|  0.0000| 0.024
>>>>                 Peak|        |  0.0099| 0.278
>>>>     RxCan2[381] Avg|    0.00|  0.0000| 0.025
>>>>                 Peak|        |  0.0468| 0.459
>>>>     RxCan2[3a0] Avg|    0.00|  0.0000| 0.021
>>>>                 Peak|        |  0.2339| 0.617
>>>>     RxCan2[3d0] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.1351| 0.351
>>>>     RxCan2[3d5] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.0796| 0.692
>>>>     RxCan2[400] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.0537| 0.307
>>>>     RxCan2[405] Avg|    0.00|  0.0000| 0.021
>>>>                 Peak|        |  0.0513| 0.303
>>>>     RxCan2[40a] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.1099| 0.313
>>>>     RxCan2[415] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.0204| 0.251
>>>>     RxCan2[435] Avg|    0.00|  0.0000| 0.028
>>>>                 Peak|        |  0.0113| 0.342
>>>>     RxCan2[440] Avg|    0.00|  0.0000| 0.027
>>>>                 Peak|        |  0.0110| 0.299
>>>>     RxCan2[465] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.0122| 0.295
>>>>     RxCan2[466] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.0117| 0.267
>>>>     RxCan2[467] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.0164| 0.325
>>>>     RxCan2[501] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.0236| 0.276
>>>>     RxCan2[503] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.0248| 0.349
>>>>     RxCan2[504] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.0230| 0.312
>>>>     RxCan2[505] Avg|    0.00|  0.0000| 0.025
>>>>                 Peak|        |  0.0256| 0.310
>>>>     RxCan2[508] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.0281| 0.329
>>>>     RxCan2[511] Avg|    0.00|  0.0000| 0.022
>>>>                 Peak|        |  0.0232| 0.282
>>>>     RxCan2[51e] Avg|    0.00|  0.0000| 0.023
>>>>                 Peak|        |  0.0248| 0.298
>>>>     RxCan2[581] Avg|    0.00|  0.0000| 0.025
>>>>                 Peak|        |  0.0166| 0.286
>>>>            Total Avg|    0.00|  0.0000| 43.563
>>>>     At the same time, calling poller times on, poller times status
>>>>     causes the bus to crash, although no polls are actively being
>>>>     sent at all.
>>>>     Cheers,
>>>>     Simon
>>>>     _______________________________________________
>>>>     OvmsDev mailing list
>>>>     OvmsDev at lists.openvehicles.com
>>>>     http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250115/be214335/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250115/be214335/attachment-0001.sig>
