[Ovmsdev] Crashing on restart
Thu Jan 2 22:25:24 HKT 2025
The log shows it actually crashes during the shutdown process -- but
@Michael, I'm pretty sure this is an old issue, turning up now only by
chance.
This looks like a race condition between event handler invocation and
deregistration:
Guru Meditation Error: Core  1 panic'ed (InstrFetchProhibited).Exception
was unhandled.
Backtrace: 0x41000000:0x3ffc8c30 0x401208ed:0x3ffc8c60
0x401209d4:0x3ffc8cc0 0x40120a5d:0x3ffc8d00
→ Crash at *0x41000000* (invalid address), called from:
0x401208ed is in OvmsEvents::HandleQueueSignalEvent(event_queue_t*)
(/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:310).
305           {
306           for (EventCallbackList::iterator itc=el->begin();
itc!=el->end(); ++itc)
307             {
308             m_current_started = monotonictime;
309             m_current_callback = *itc;
*310 m_current_callback->m_callback(m_current_event,
msg->body.signal.data);*
311             m_current_callback = NULL;
312             }
313           }
314         }
 From there it then enters a crash loop from the crash handler somehow
running into an illegal address when trying to access the RTC boot_data
object (?).
I think, when introducing the separate event handling task, we missed
adding a lock to make manipulations & accesses to the event handler list
atomic.
The log shows, the event queue grew significantly due to duktape/scripts
lagging during shutdown (as seen in the log), so the task was quite busy.
So probably a `DeregisterEvent()` call from the shutdown process came
in, invalidating a callback entry just while the event task was
processing that callback list.
Solving this may need some additional thoughts & measures: locking the
whole event registry with handlers lagging like this could lead to a
deadlock… probably at least the Duktape component needs to cleanly
abort/reject all pending events before/while deregistering.
Michael, if you'd like to have a look at this, go ahead.
Am 01.01.25 um 11:47 schrieb Tamás Kovács via OvmsDev:
> Now i change the sd card to a smaller, and formatted to fat32 (16Gb),
> but on reboot is crashing.
> Now connect a computer to the usb port, and create a log in verbose,
> attached to the email.
> Üdvözlettel:
> Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250102/b97d4464/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250102/b97d4464/attachment.sig>
