[Ovmsdev] Levels of poller states
Chris Box chris8086 at ee.eclipse1.net
Tue Feb 25 06:17:01 HKT 2025
On 2025-02-24 01:46, Michael Geddes wrote:
> The one that matters most is OvmsPoller::m_poll_state - as that is the
> one used in processing.  It is possible to set this separately per bus.
That makes sense.
> The one at OvmsPollers level is there if you choose to keep one
> 'poll-state' and so set the values on all busses together... which is
> normally the case.  It's mostly there so multiple calls to setting
> poll-state without actually changing the poll-state will not actually
> have to queue calls.
And that also makes sense, as a common performance optimisation.
> The one at OvmsVehicle is there because that used to be where it sat.
> It's still there for reading convenience and for non-blocking access to
> the value.. but it really should always just be a reference copy of the
> m_poll_state on OvmsPollers.
I see. Yes, I agree it would be better to remove it as a separate
variable. I don't plan to work on that myself, but I'll use your
description in helping to understand the Leaf's state management. Thank
you.
Chris
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250224/afbcb8f6/attachment.htm>
