[Ovmsdev] High hologram usage
    Thu Feb 20 08:43:51 HKT 2025
Craig,
Can you show your ‘module summary’ so we can see what is running? In particular just v2 or also v3 server?
The only other time I’ve seen something similar is where the module was in poor connectivity - causing it to reconnect frequently and leading to very small connection data transfers (which Hologram and other providers round-up).
> On 20 Feb 2025, at 7:06 AM, Craig Leres via OvmsDev <ovmsdev at lists.openvehicles.com> wrote:
> I have three ovms modules, two are in cars and one is on the bench. Most of the time they are on my home wifi.
> hologram used to bill me less often than once a month. But I noticed recently this had increased to about once every three days. When I looked at usage (see attached) things changed in early January.
> I keep an archive of the builds I've run. On January 8th I upgraded from 3.3.004-246-ge9decc46 (September 8th, 2024) to 3.3.004-332-gadce9471. That seems to be when hologram usage increased.
> Last week I upgraded to 3.3.004-382-ge83be0e7 but usage still seems high. I looked a per-sim usage and though I put similar miles on each car in a month, one is 50% higher than the other. But even the dev unit is way higher than I would expect for a module that is *always* in range of wifi.
> What am I missing?
> 		Craig
> # ovms-z
> OVMS# cell
> MODEM Status
>  Model: SIM7600
>  Network Registration: RegisteredRoaming
>    Provider: T-Mobile Hologram
>    Signal: -85 dBm
>    Mode: LTE,Online
>  State: NetMode
>  Mux: Status up
>  PPP: Connected on channel: #2
>  GPS: Connected on channel: #1
> # ovms-v
> OVMS# cell
> MODEM Status
>  Model: SIM7600
>    Signal: -79 dBm
>    Mode: LTE,Online
>  State: NetMode
>  Mux: Status up
> # dev
> OVMS# cell
> MODEM Status
>  Model: SIM7600
>    Signal: -85 dBm
>    Mode: LTE,Online
>  State: NetMode
>  Mux: Status up
> <hologram.png><persim.png>_______________________________________________
