[Ovmsdev] Another incident
    Michael Geddes
    Sun Feb  9 11:45:37 HKT 2025
Just fyi a 'dip' is 12v voltage decreasing momentarily. A blip is the
reverse.  Charging.dip is dipping while charging.
There's a separate low voltage state for the 12v monitor.
//.ichael
On Sun, 9 Feb 2025, 06:35 Dan Edwards via OvmsDev, <
> Hi Chris,
> Not sure if you’ve investigated the I-key system error , but thought I’d
> add my experience here.
> I have been receiving the same I-key system error in my 2012 leaf, with
> all the same symptoms and resolution as yours. This leaf doesn’t have OVMS
> installed at the moment, so maybe your issue is not due to OVMS.
> If you google I-key system error , you’ll find posts on issues with the
> BCM, which have been resolved with cleaning contacts on bcm (if there’s
> been moisture issues), and others replacing 12v acc battery.
> I’m pretty sure I’ve narrowed it down to 12v battery issues in my case,
> after inspecting BCM behind glove box in RHD edition, finding no issue,
> recharging 12v, and removing any known 12v drain like OVMS or odb dongle,
> just waiting for a recurrence to confirm.
> Check your DTCs with leafspy, if it shows a bunch of DTCs including a
> B2604 BCM Shift PN diag, then likely low 12v, try a 24 hr charge or replace
> it.
> The OVMS log also shows 12v dip around the same time as your issue. This
> may explain OVMS shutdown as well if you’ve got it set to shut down due to
>  low 12v battery, although I though that might be more graceful.
> Cheers Dan
> On 9 Feb 2025, at 8:35 am, Chris Box via OvmsDev <
> Hi,
> It's happened again. Yesterday while driving the Leaf lost drive mode,
> forcing pulling over. I couldn't reengage gear until I had disconnected the
> 12v battery.
> Looking at the evidence today, the incident can't be explained by writing
> random bytes in CommandWakeup(), nor by having the wrong timing. It
> actually suggests that OVMS locked up ten minutes before the car was
> impacted.
> Here's what happened.
> 13:15 to 13:17 I drove off from home, but forgot an item so quickly
> returned back there.
> The sd log records this activity just fine, and the last entries before
> the suspected hang were these:
> 2025-02-07 13:19:59.174 GMT D (93751944) events: Signal(vehicle.asleep)
> 2025-02-07 13:22:29.184 GMT I (93901954) housekeeping: 2025-02-07 13:22:28
> GMT (RAM: 8b=79028-81980 32b=12560 SPI=3262992-3285432)
> There should have been the next housekeeping message at 13:27:29 but none
> was recorded on the sd. Log flushes are configured to occur after 30
> seconds.
> The last MQTT metric update my server received was around 13:27:50. This
> showed it was connected to home wifi.
> At 13:28 I unlocked the car, started it and drove off without noticing
> anything unusual. None of this activity appears in the log.
> During the drive there should have been a connection via Hologram to my
> server, but none was received.
> Ten minutes later at 13:38 I was driving when a yellow warning light came
> on and the car moved to neutral. Essentially the same symptoms as in
> January: turning off and on would not clear the fault; it couldn't detect
> brake status meaning it told me to press brake pedal when I already was.
> Also showed I-key system error.
> As I was stranded I used the only option I knew of to clear the fault, and
> I disconnected the 12v battery. On restoring power and dismissing the fault
> notice, it was happy to drive.
> The log shows this cold start SNTP was at 13:44. On returning home,
> unfortunately 'boot status' says nothing about a crash, presumably because
> any information was lost when I pulled power.
> So it seems there is some mechanism by which OVMS can lock up, without
> watchdog oversight. And that ten minutes later it can do something that
> becomes a critical issue for the car systems.
> Chris
> Relevant log entries below, all part of the same file. 1970 follows
> immediately after 13:22:29.184.
> 2025-02-07 13:17:50.184 GMT D (93622984) vehicle-poll: Pollers: Queue
> SetState()
> PollState(0)
> 2025-02-07 13:17:50.184 GMT D (93622984) events: Signal(vehicle.off)
> 2025-02-07 13:17:51.144 GMT D (93623944) events:
> Signal(vehicle.aux.12v.charging.dip)
> 2025-02-07 13:17:53.144 GMT D (93625944) events:
> Signal(vehicle.aux.12v.dip)
> 2025-02-07 13:17:54.824 GMT E (93627624) can: can2: intr=15711227
> rxpkt=15730955 txpkt=100 errflags=0x22401c02 rxerr=0 txerr=0 rxinval=0
> rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0 txqueue=0
> 2025-02-07 13:17:56.754 GMT D (93629554) events: Signal(vehicle.locked)
> 2025-02-07 13:17:59.744 GMT E (93632544) can: can2: intr=15716706
> rxpkt=15736447 txpkt=100 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0
> 2025-02-07 13:18:09.144 GMT D (93641944) events:
> Signal(vehicle.charge.12v.stop)
> 2025-02-07 13:18:10.144 GMT I (93642944) powermgmt: No longer charging 12V
> battery..
> 2025-02-07 13:18:33.174 GMT D (93665944) events:
> Signal(vehicle.aux.12v.normal)
> 2025-02-07 13:18:33.764 GMT E (93666534) can: can2: intr=15754521
> rxpkt=15774368 txpkt=100 errflags=0x22401c02 rxerr=0 txerr=0 rxinval=0
> 2025-02-07 13:18:45.174 GMT I (93677944) ovms-server-v3: Connection is
> <redacted>
> 2025-02-07 13:18:45.174 GMT I (93677944) ovms-server-v3: Status:
> Connecting...
> 2025-02-07 13:18:45.224 GMT D (93677994) events:
> Signal(server.v3.connecting)
> 2025-02-07 13:18:48.624 GMT I (93681394) ovms-server-v3: Connection
> successful
> 2025-02-07 13:18:48.644 GMT I (93681414) ovms-server-v3: Status: OVMS V3
> MQTT login successful
> 2025-02-07 13:18:48.644 GMT D (93681414) events:
> Signal(server.v3.connected)
> 2025-02-07 13:18:49.174 GMT I (93681944) ovms-server-v3: Subscribe to MQTT
> topics
> 2025-02-07 13:18:49.174 GMT I (93681944) ovms-server-v3: Transmit all
> metrics
> 2025-02-07 13:18:49.464 GMT I (93682234) ovms-server-v3: Subscription
> acknowledged
> 1970-01-01 00:00:08.424 GMT I (7994) command: OpenLogfile: now logging to
> file '/sd/logs/log'
> 1970-01-01 00:00:13.474 GMT D (13034) events: Signal(system.event)
> 1970-01-01 00:00:13.474 GMT D (13034) events: Signal(system.wifi.scan.done)
> 1970-01-01 00:00:19.424 GMT I (18984) cellular: State: Enter Identify state
> 1970-01-01 00:00:19.434 GMT I (18994) cellular: Identified cellular modem:
> SIM7600/Experimental support for SIMCOM SIM7600
> 1970-01-01 00:00:19.434 GMT I (18994) cellular: Set modem driver to
> 'SIM7600'
> 1970-01-01 00:00:19.434 GMT I (18994) cellular: State: Enter PoweredOn
> state
> 1970-01-01 00:00:19.424 GMT D (18994) events:
> Signal(system.modem.installed)
> 1970-01-01 00:00:19.434 GMT D (19004) events:
> Signal(system.modem.poweredon)
> 1970-01-01 00:00:23.474 GMT D (23034) events: Signal(system.event)
> 1970-01-01 00:00:23.474 GMT D (23034) events: Signal(system.wifi.scan.done)
> 1970-01-01 00:00:33.474 GMT D (33034) events: Signal(system.event)
> 1970-01-01 00:00:33.474 GMT D (33034) events: Signal(system.wifi.scan.done)
> 1970-01-01 00:00:39.434 GMT I (38994) cellular: State: Enter MuxStart state
> 1970-01-01 00:00:39.444 GMT I (39004) gsm-mux: Start MUX
> 1970-01-01 00:00:39.444 GMT D (39004) events: Signal(system.modem.muxstart)
> 1970-01-01 00:00:39.444 GMT I (39014) gsm-mux: Channel #0 is open
> 1970-01-01 00:00:39.464 GMT I (39024) gsm-mux: Channel #1 is open
> 1970-01-01 00:00:39.464 GMT I (39024) gsm-mux: Channel #2 is open
> 1970-01-01 00:00:39.474 GMT I (39034) gsm-mux: Channel #3 is open
> 1970-01-01 00:00:39.484 GMT I (39044) gsm-mux: Channel #4 is open
> 1970-01-01 00:00:40.414 GMT I (39984) cellular: State: Enter NetWait state
> 1970-01-01 00:00:40.414 GMT D (39984) events: Signal(system.modem.netwait)
> 1970-01-01 00:00:43.474 GMT D (43034) events: Signal(system.event)
> 1970-01-01 00:00:43.474 GMT D (43034) events: Signal(system.wifi.scan.done)
> 1970-01-01 00:00:46.054 GMT D (45624) events: Signal(vehicle.awake)
> 1970-01-01 00:00:50.444 GMT I (50014) cellular: Network Registration
> status: RegisteredRoaming
> 1970-01-01 00:00:51.414 GMT I (50984) cellular: State: Enter NetStart state
> 1970-01-01 00:00:51.434 GMT D (50994) events: Signal(vehicle.aux.12v.blip)
> 1970-01-01 00:00:51.434 GMT D (50994) events: Signal(system.modem.netstart)
> 1970-01-01 00:00:51.444 GMT D (51004) events:
> Signal(vehicle.charge.12v.start)
> 1970-01-01 00:00:51.434 GMT I (51004) cellular: Network Mode: LTE,Online
> 1970-01-01 00:00:52.414 GMT I (51984) powermgmt: Charging 12V battery..
> 1970-01-01 00:00:52.464 GMT I (52034) cellular: PPP Connection is ready to
> start
> 1970-01-01 00:00:53.424 GMT I (52984) cellular: State: Enter NetMode state
> 1970-01-01 00:00:53.424 GMT I (52984) gsm-ppp: Initialising...
> 1970-01-01 00:00:53.434 GMT D (52994) events: Signal(system.modem.netmode)
> 1970-01-01 00:00:53.484 GMT D (53044) events: Signal(system.event)
> 1970-01-01 00:00:53.484 GMT D (53044) events: Signal(system.wifi.scan.done)
> 1970-01-01 00:00:53.594 GMT I (53154) gsm-ppp: StatusCallBack: None
> 1970-01-01 00:00:53.594 GMT I (53154) gsm-ppp: status_cb: Connected
> 1970-01-01 00:00:53.594 GMT I (53154) gsm-ppp:    our_ipaddr  =
> 100.83.212.151
> 1970-01-01 00:00:53.594 GMT I (53154) gsm-ppp:    his_ipaddr  = 10.64.64.64
> 1970-01-01 00:00:53.594 GMT I (53154) gsm-ppp:    netmask     =
> 255.255.255.255
> 1970-01-01 00:00:53.594 GMT I (53154) gsm-ppp:    DNS#0       = 8.8.8.8
> 1970-01-01 00:00:53.584 GMT I (53154) gsm-ppp:    DNS#1       = 8.8.4.4
> 1970-01-01 00:00:53.594 GMT I (53154) gsm-ppp:    our6_ipaddr = ::
> 1970-01-01 00:00:53.594 GMT D (53154) events: Signal(network.interface.up)
> 1970-01-01 00:00:53.604 GMT D (53164) events: Signal(system.modem.gotip)
> 1970-01-01 00:00:53.604 GMT I (53164) netmanager: Interface priority is
> pp2 (100.83.212.151/255.255.255.255 gateway 10.64.64.64)
> 1970-01-01 00:00:53.604 GMT I (53164) netmanager: Set DNS#2 0.0.0.0
> 1970-01-01 00:00:53.594 GMT I (53164) netmanager: MODEM up (with WIFI
> client down): starting network with MODEM
> 1970-01-01 00:00:53.594 GMT D (53164) events: Signal(network.modem.up)
> 1970-01-01 00:00:53.594 GMT D (53164) events: Signal(network.up)
> 1970-01-01 00:00:53.604 GMT I (53174) time: Starting SNTP client
> 1970-01-01 00:00:53.604 GMT D (53174) events:
> Signal(network.interface.change)
> 1970-01-01 00:00:53.614 GMT D (53174) events: Signal(network.mgr.init)
> 1970-01-01 00:00:53.614 GMT I (53174) webserver: Launching Web Server
> 2025-02-07 13:44:08.584 GMT I (53184) webserver: Binding to port 80 (http)
> 2025-02-07 13:44:08.584 GMT I (53184) ssh: Launching SSH Server
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250209/7bf24a47/attachment-0001.htm>
