[Ovmsdev] UI redesign in Android App - Needs beta testing
Chris van der Meijden
chris at arachnon.de
Wed Feb 5 04:37:37 HKT 2025
>From the beginning on I saw, that the "running as service" dot did not
appear on the app icon and that the connection of other apps (my KWGT
widget and my fireplace app) did not work (I did set the settings for
that features).
In the last days I saw that the app sometimes didn't want to connect to
the server. Changing the view from "vehicle" to i.e. "settings" did
bring the connection back.
Today I had a complete breakdown of the app. No connection to the
server possible at all anymore. Deleting the cash did not help.
Uninstall and reinstall of the "old" app brought back the connection.
So I'm back to the old app for now.
Regards
Chris
Am Sonntag, dem 02.02.2025 um 13:05 +0100 schrieb Chris van der Meijden
via OvmsDev:
> Yep I meant the home screen.
> The customizing feature works great.
> The progress display on the climate control button is indeed not self
> explaining.
> Thanx
> Chris
> Am Sonntag, dem 02.02.2025 um 12:40 +0100 schrieb Michael Balzer:
> > Chris,
> > the current feedback of the command being successful is the
> > progress display on the button disappears without an error toast.
> > But you're right, that can easily be missed, especially with a fast
> > connection. An explicit success feedback would be better.
> > Regarding the "two homelink buttons", I assume you mean the quick
> > actions on the home screen. Those are just the defaults, click long
> > on the buttons to customize.
> > Regards,
> > Michael
> > Am 02.02.25 um 11:35 schrieb Chris van der Meijden:
> > > Hey Michael,
> > > I installed the new version and things seem basicly to work for
> > > me so far.
> > > Our e-UP is connected via ODB and T26A. Climate control ist
> > > working. What I'm missing is a response that the climate control
> > > message is accepted. The end result with red arrows layer over
> > > the car looks nice, but I would prefer a two step approach. 1.
> > > message accepted, 2. result OK (the red arrows). The situation on
> > > the wake up button is simmilar. I get no visual response, if the
> > > wake up is working (like making the text bold in the old UI).
> > > The two "home link" buttons on the vehicle screen look lost and
> > > mess up the design (the icons look very different). I only have
> > > room for 5 buttons on a row and due to the two home link buttons
> > > we have six and therefor a second row with only one button on it.
> > > Not that pretty ...
> > > So far my first impressions.
> > > Regards
> > > Chris
> > > Am Sonntag, dem 02.02.2025 um 09:57 +0100 schrieb Michael Balzer
> > > via OvmsDev:
> > > > Everyone,
> > > > I've merged the UI redesign into `master`. I've been using this
> > > > for 3 weeks now without issues, but I can only test my vehicle
> > > > (VW e-Up), and I still can only test the pure OBD installation
> > > > on that one.
> > > > Please install the latest build
> > > > (https://github.com/openvehicles/Open-Vehicle-Android/tree/master/latest
> > > > ) and test for issues with your vehicle types & configurations.
> > > > A big "thank you" to DFJ (Developer From Jokela), impressive
> > > > work!
> > > > Regards,
> > > > Michael
> > > > Am 09.01.25 um 08:33 schrieb Michael Geddes via OvmsDev:
> > > > > Looking good!
> > > > > No crashes when charging
> > > > > Shows as Ioniq 5
> > > > > The widget starts the app correctly.
> > > > > One thing I found was in the Push Notifications/ command
> > > > > area:
> > > > > Portrait mode:
> > > > > Note the really big boxes. This is because the date column is
> > > > > squished to a couple of pixels and it is displaying it
> > > > > wrapped downwards.
> > > > > Looks fine in landscape mode
> > > > > //.ichael
> > > > > On Tue, 31 Dec 2024, 15:47 Michael Geddes,
> > > > > <frog at bunyip.wheelycreek.net> wrote:
> > > > > > Ah, thanks Chris. Maybe you need to obey that setting when
> > > > > > you click on the widget then :)
> > > > > > On Tue, 31 Dec 2024 at 15:38, van der Meijden, Chris via
> > > > > > OvmsDev <ovmsdev at lists.openvehicles.com> wrote:
> > > > > > > The apo crashes regardless how I open it.
> > > > > > > I'm running on LineageOS (based on Android 14) without
> > > > > > > Google. I don't give the app GPS permissions.
> > > > > > > @Michael: The old UI is still in the app. You can select
> > > > > > > it from the gear symbol under "Settings".
> > > > > > > Regards
> > > > > > > Chris
> > > > > > > Am 31. Dezember 2024 03:35:21 MEZ schrieb Michael Geddes
> > > > > > > via OvmsDev <ovmsdev at lists.openvehicles.com>:
> > > > > > > > Font size looks all fixed, thanks.
> > > > > > > > For some reason when I click on the widget it opens the
> > > > > > > > old look ovms still... is the old look still hidden
> > > > > > > > somewhere?
> > > > > > > > Also if I start charging my car (not through the app),
> > > > > > > > then whenever I switch to or open the app, the app
> > > > > > > > crashes.
> > > > > > > > I'm just doing ac charging from a wallbox.
> > > > > > > > //.ichael.
> > > > > > > > On Tue, 31 Dec 2024, 06:48 Developer From Jokela via
> > > > > > > > OvmsDev, <ovmsdev at lists.openvehicles.com> wrote:
> > > > > > > > > Hi.
> > > > > > > > > New update is released at
> > > > > > > > https://github.com/openvehicles/Open-Vehicle-Android/tree/test-dfj-ui/latest
> > > > > > > > > Brief:
> > > > > > > > > - Quick actions customisable
> > > > > > > > > - Twizy UI fixes
> > > > > > > > > - Font size related issues should be gone (hopefully
> > > > > > > > > ;D)
> > > > > > > > > - DFJ
> > > > > > > > > > van der Meijden, Chris <chris at arachnon.de>
> > > > > > > > > > kirjoitti 30.12.2024 kello 13.12:
> > > > > > > > > > I like the design of the Mercedes Ne app. Don't
> > > > > > > > > > need a one to one copy, but it has a good mixture
> > > > > > > > > > between info and links, I think.
> > > > > > > > > > Am 30. Dezember 2024 11:29:37 MEZ schrieb Developer
> > > > > > > > > > From Jokela <info at developerfromjokela.com>:
> > > > > > > > > > > Hi.
> > > > > > > > > > > What info would you like to be shown on main
> > > > > > > > > > > screen?
> > > > > > > > > > > > On 30. Dec 2024, at 11.16, Chris van der
> > > > > > > > > > > > Meijden <chris at arachnon.de> wrote:
> > > > > > > > > > > > Also many thanks for the effort. The new design
> > > > > > > > > > > > is not my cup of tea, but that is question of
> > > > > > > > > > > > personal liking I suppose. For me the menu is
> > > > > > > > > > > > far to present, whereas the information of the
> > > > > > > > > > > > vehicle seems barely visible.
> > > > > > > > > > > > For the e-Up the climate control throws an
> > > > > > > > > > > > error. "Fehler bei der Kommandoausführung".
> > > > > > > > > > > > Kind regards
> > > > > > > > > > > > Chris
> > > > > > > > > > > > Am Montag, dem 30.12.2024 um 15:20 +0800
> > > > > > > > > > > > > Thanks for the update. In general I like the
> > > > > > > > > > > > > new design.
> > > > > > > > > > > > > I've attached a screen shot. The list box
> > > > > > > > > > > > > items need to resize for larger fonts to stop
> > > > > > > > > > > > > them being all cut off.
> > > > > > > > > > > > > Also where does the "Unknown Vehicle model"
> > > > > > > > > > > > > come from?
> > > > > > > > > > > > > <1000012000.jpg>
> > > > > > > > > > > > > I have a slightly larger font setting:
> > > > > > > > > > > > > <1000012001.jpg>
> > > > > > > > > > > > > Also here:
> > > > > > > > > > > > > <1000012002.jpg>
> > > > > > > > > > > > > ..where the labels are overlapping due to the
> > > > > > > > > > > > > font size.
> > > > > > > > > > > > > And the ... here:
> > > > > > > > > > > > > <1000012003.jpg>
> > > > > > > > > > > > > I'm also getting a crash when opening the
> > > > > > > > > > > > > settings on the map. (App disappears. First
> > > > > > > > > > > > > time it prompted to clear cache which I did)
> > > > > > > > > > > > > Is there a new widget? If I click on the
> > > > > > > > > > > > > widget I see the old UI.
> > > > > > > > > > > > > //.ichael
> > > > > > > > > > > > > On Mon, 30 Dec 2024, 07:28 Developer From
> > > > > > > > > > > > > Jokela via OvmsDev,
> > > > > > > > > > > > > > Hi Android users.
> > > > > > > > > > > > > > I’ve recently redesigned UI for Android and
> > > > > > > > > > > > > > it would need some testing.
> > > > > > > > > > > > > > Here is the latest build available for UI
> > > > > > > > > > > > > > redesign:
> > > > > > > > > > > > > > Please report any issues, improvement
> > > > > > > > > > > > > > suggestions, etc.
> > > > > > > > > > > > > > Thank you!
> > > > > > > > > > > > > > Br, DFJ
> > > > > > > > > > > > > > ___________________________________________
> > > > > > > > > > > > > > ____
> > > > > > > > > > > > > > OvmsDev mailing list
> > > > > > > > > > > > > > OvmsDev at lists.openvehicles.com
> > > > > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> > > > > > > > > > > > > _____________________________________________
> > > > > > > > > > > > > __
> > > > > > > > > > <Screenshot_20241230-115518_Mercedes-Benz_1.png>
> > > > > > > > > _______________________________________________
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250204/2f7e365c/attachment-0001.htm>
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250204/2f7e365c/attachment-0002.jpg>
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250204/2f7e365c/attachment-0003.jpg>
