    Chris Box
    chris8086 at ee.eclipse1.net
    Mon Feb  3 06:30:30 HKT 2025
On 2025-02-02 13:44, Michael Balzer wrote:
> That can only happen, if either the Leaf code has a bug with detecting
> the correct vehicle state (and with announcing that by some log /
> event, would need to be "on" or "charging" according to the polling
> scheme)...
> ...or the new poller has a bug, that leads to keeping or re-entering a
> wrong poll state. The latter could affect other vehicles as well.
> You need to check the poll state transitions. These get logged by the
> poller (log tag "vehicle-poll"), which needs to be set to log level
> "debug" for this.
> You should then see log entries "Pollers: Queue SetState" for the state
> change request & "Pollers: PollState(<state>[,<bus>])" for the actual
> state change.
Yes, I can see how this would be bad. I'm learning more about the code
as we go through this.
This evening, I enabled vehicle-poll debug while it was charging. As you
can see from the log below, there was no SetState after charging
stopped. Therefore the poller continued in its current state, and polled
every minute. So something is causing it to miss the state transition.
If you let me know what to do next, I should be able to try that on
Monday.
Thanks
Chris
2025-02-02 21:06:07.482 GMT D (338366402) vehicle-poll:
[1]PollerSend(PRI)[3]: entry at[type=21, pid=1], ticker=2880, wait=0,
cnt=0/0
2025-02-02 21:06:07.542 GMT D (338366462) vehicle-poll:
[1]PollerSend(SRX)[3]: entry at[type=21, pid=2], ticker=2880, wait=0,
cnt=1/0
2025-02-02 21:06:07.842 GMT D (338366762) vehicle-poll:
[1]PollerSend(SRX)[3]: entry at[type=21, pid=6], ticker=2880, wait=0,
cnt=2/0
2025-02-02 21:06:43.162 GMT I (338402082) housekeeping: 2025-02-02
21:06:42 GMT (RAM: 8b=64080-79564 32b=12560 SPI=3264264-3283048)
2025-02-02 21:07:07.482 GMT D (338426402) vehicle-poll:
[1]PollerSend(PRI)[3]: entry at[type=21, pid=1], ticker=2940, wait=0,
cnt=0/0
2025-02-02 21:07:07.542 GMT D (338426462) vehicle-poll:
[1]PollerSend(SRX)[3]: entry at[type=21, pid=2], ticker=2940, wait=0,
cnt=1/0
2025-02-02 21:07:07.852 GMT D (338426772) vehicle-poll:
[1]PollerSend(SRX)[3]: entry at[type=21, pid=6], ticker=2940, wait=0,
cnt=2/0
2025-02-02 21:08:07.482 GMT D (338486402) vehicle-poll:
[1]PollerSend(PRI)[3]: entry at[type=21, pid=1], ticker=3000, wait=0,
cnt=0/0
2025-02-02 21:08:07.532 GMT D (338486452) vehicle-poll:
[1]PollerSend(SRX)[3]: entry at[type=21, pid=2], ticker=3000, wait=0,
cnt=1/0
2025-02-02 21:08:07.842 GMT D (338486762) vehicle-poll:
[1]PollerSend(SRX)[3]: entry at[type=21, pid=6], ticker=3000, wait=0,
cnt=2/0
2025-02-02 21:08:07.882 GMT D (338486802) vehicle-poll:
[1]PollerSend(SRX)[3]: entry at[type=21, pid=4], ticker=3000, wait=0,
cnt=3/0
2025-02-02 21:08:13.142 GMT I (338492062) v-nissanleaf:
RemoteCommandHandler
2025-02-02 21:08:13.142 GMT I (338492062) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:13.142 GMT I (338492062) ovms-server-v3: Tx notify
ovms/notify/info/v-nissanleaf/charge/status=Target charge level reached
(52%)
2025-02-02 21:08:13.152 GMT D (338492072) events:
Signal(notify.info.v-nissanleaf.charge.status)
2025-02-02 21:08:13.242 GMT I (338492162) v-nissanleaf:
RemoteCommandTimer 24
2025-02-02 21:08:13.242 GMT I (338492162) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:13.242 GMT I (338492162) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:13.242 GMT I (338492162) v-nissanleaf: Stop Charging
2025-02-02 21:08:13.322 GMT I (338492242) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:13.322 GMT I (338492242) v-nissanleaf:  MITM turned off
2025-02-02 21:08:13.342 GMT I (338492262) v-nissanleaf:
RemoteCommandTimer 23
2025-02-02 21:08:13.342 GMT I (338492262) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:13.342 GMT I (338492262) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:13.342 GMT I (338492262) v-nissanleaf: Stop Charging
2025-02-02 21:08:13.362 GMT I (338492282) ovms-server-v3: Message
publishing acknowledged (msg_id: 2149)
2025-02-02 21:08:13.422 GMT I (338492342) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:13.422 GMT I (338492342) v-nissanleaf:  MITM turned off
2025-02-02 21:08:13.442 GMT I (338492362) v-nissanleaf:
RemoteCommandTimer 22
2025-02-02 21:08:13.442 GMT I (338492362) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:13.442 GMT I (338492362) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:13.442 GMT I (338492362) v-nissanleaf: Stop Charging
2025-02-02 21:08:13.522 GMT I (338492442) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:13.522 GMT I (338492442) v-nissanleaf:  MITM turned off
2025-02-02 21:08:13.542 GMT I (338492462) v-nissanleaf:
RemoteCommandTimer 21
2025-02-02 21:08:13.542 GMT I (338492462) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:13.542 GMT I (338492462) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:13.542 GMT I (338492462) v-nissanleaf: Stop Charging
2025-02-02 21:08:13.622 GMT I (338492542) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:13.622 GMT I (338492542) v-nissanleaf:  MITM turned off
2025-02-02 21:08:13.642 GMT I (338492562) v-nissanleaf:
RemoteCommandTimer 20
2025-02-02 21:08:13.642 GMT I (338492562) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:13.642 GMT I (338492562) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:13.642 GMT I (338492562) v-nissanleaf: Stop Charging
2025-02-02 21:08:13.722 GMT I (338492642) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:13.722 GMT I (338492642) v-nissanleaf:  MITM turned off
2025-02-02 21:08:13.742 GMT I (338492662) v-nissanleaf:
RemoteCommandTimer 19
2025-02-02 21:08:13.742 GMT I (338492662) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:13.742 GMT I (338492662) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:13.742 GMT I (338492662) v-nissanleaf: Stop Charging
2025-02-02 21:08:13.822 GMT I (338492742) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:13.822 GMT I (338492742) v-nissanleaf:  MITM turned off
2025-02-02 21:08:13.842 GMT I (338492762) v-nissanleaf:
RemoteCommandTimer 18
2025-02-02 21:08:13.842 GMT I (338492762) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:13.842 GMT I (338492762) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:13.842 GMT I (338492762) v-nissanleaf: Stop Charging
2025-02-02 21:08:13.922 GMT I (338492842) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:13.922 GMT I (338492842) v-nissanleaf:  MITM turned off
2025-02-02 21:08:13.942 GMT I (338492862) v-nissanleaf:
RemoteCommandTimer 17
2025-02-02 21:08:13.942 GMT I (338492862) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:13.942 GMT I (338492862) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:13.942 GMT I (338492862) v-nissanleaf: Stop Charging
2025-02-02 21:08:14.022 GMT I (338492942) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:14.022 GMT I (338492942) v-nissanleaf:  MITM turned off
2025-02-02 21:08:14.042 GMT I (338492962) v-nissanleaf:
RemoteCommandTimer 16
2025-02-02 21:08:14.042 GMT I (338492962) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:14.042 GMT I (338492962) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:14.042 GMT I (338492962) v-nissanleaf: Stop Charging
2025-02-02 21:08:14.122 GMT I (338493042) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:14.122 GMT I (338493042) v-nissanleaf:  MITM turned off
2025-02-02 21:08:14.142 GMT I (338493062) v-nissanleaf:
RemoteCommandTimer 15
2025-02-02 21:08:14.142 GMT I (338493062) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:14.142 GMT I (338493062) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:14.142 GMT I (338493062) v-nissanleaf: Stop Charging
2025-02-02 21:08:14.222 GMT I (338493142) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:14.222 GMT I (338493142) v-nissanleaf:  MITM turned off
2025-02-02 21:08:14.242 GMT I (338493162) v-nissanleaf:
RemoteCommandTimer 14
2025-02-02 21:08:14.242 GMT I (338493162) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:14.242 GMT I (338493162) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:14.242 GMT I (338493162) v-nissanleaf: Stop Charging
2025-02-02 21:08:14.322 GMT I (338493242) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:14.322 GMT I (338493242) v-nissanleaf:  MITM turned off
2025-02-02 21:08:14.342 GMT I (338493262) v-nissanleaf:
RemoteCommandTimer 13
2025-02-02 21:08:14.342 GMT I (338493262) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:14.342 GMT I (338493262) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:14.342 GMT I (338493262) v-nissanleaf: Stop Charging
2025-02-02 21:08:14.372 GMT D (338493292) events:
Signal(vehicle.charge.stop)
2025-02-02 21:08:14.382 GMT D (338493302) events:
Signal(vehicle.charge.state)
Signal(vehicle.charge.mode)
2025-02-02 21:08:14.422 GMT I (338493342) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:14.422 GMT I (338493342) v-nissanleaf:  MITM turned off
2025-02-02 21:08:14.442 GMT I (338493362) v-nissanleaf:
RemoteCommandTimer 12
2025-02-02 21:08:14.442 GMT I (338493362) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:14.442 GMT I (338493362) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:14.442 GMT I (338493362) v-nissanleaf: Stop Charging
2025-02-02 21:08:14.522 GMT I (338493442) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:14.522 GMT I (338493442) v-nissanleaf:  MITM turned off
2025-02-02 21:08:14.542 GMT I (338493462) v-nissanleaf:
RemoteCommandTimer 11
2025-02-02 21:08:14.542 GMT I (338493462) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:14.542 GMT I (338493462) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:14.542 GMT I (338493462) v-nissanleaf: Stop Charging
2025-02-02 21:08:14.622 GMT I (338493542) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:14.622 GMT I (338493542) v-nissanleaf:  MITM turned off
2025-02-02 21:08:14.642 GMT I (338493562) v-nissanleaf:
RemoteCommandTimer 10
2025-02-02 21:08:14.642 GMT I (338493562) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:14.642 GMT I (338493562) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:14.642 GMT I (338493562) v-nissanleaf: Stop Charging
2025-02-02 21:08:14.722 GMT I (338493642) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:14.722 GMT I (338493642) v-nissanleaf:  MITM turned off
2025-02-02 21:08:14.742 GMT I (338493662) v-nissanleaf:
RemoteCommandTimer 9
2025-02-02 21:08:14.742 GMT I (338493662) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:14.742 GMT I (338493662) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:14.742 GMT I (338493662) v-nissanleaf: Stop Charging
2025-02-02 21:08:14.822 GMT I (338493742) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:14.822 GMT I (338493742) v-nissanleaf:  MITM turned off
2025-02-02 21:08:14.842 GMT I (338493762) v-nissanleaf:
RemoteCommandTimer 8
2025-02-02 21:08:14.842 GMT I (338493762) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:14.842 GMT I (338493762) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:14.842 GMT I (338493762) v-nissanleaf: Stop Charging
2025-02-02 21:08:14.922 GMT I (338493842) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:14.922 GMT I (338493842) v-nissanleaf:  MITM turned off
2025-02-02 21:08:14.942 GMT I (338493862) v-nissanleaf:
RemoteCommandTimer 7
2025-02-02 21:08:14.942 GMT I (338493862) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:14.942 GMT I (338493862) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:14.942 GMT I (338493862) v-nissanleaf: Stop Charging
2025-02-02 21:08:15.022 GMT I (338493942) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:15.022 GMT I (338493942) v-nissanleaf:  MITM turned off
2025-02-02 21:08:15.042 GMT I (338493962) v-nissanleaf:
RemoteCommandTimer 6
2025-02-02 21:08:15.042 GMT I (338493962) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:15.042 GMT I (338493962) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:15.042 GMT I (338493962) v-nissanleaf: Stop Charging
2025-02-02 21:08:15.122 GMT I (338494042) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:15.122 GMT I (338494042) v-nissanleaf:  MITM turned off
2025-02-02 21:08:15.142 GMT I (338494062) v-nissanleaf:
RemoteCommandTimer 5
2025-02-02 21:08:15.142 GMT I (338494062) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:15.142 GMT I (338494062) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:15.142 GMT I (338494062) v-nissanleaf: Stop Charging
2025-02-02 21:08:15.222 GMT I (338494142) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:15.222 GMT I (338494142) v-nissanleaf:  MITM turned off
2025-02-02 21:08:15.242 GMT I (338494162) v-nissanleaf:
RemoteCommandTimer 4
2025-02-02 21:08:15.242 GMT I (338494162) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:15.242 GMT I (338494162) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:15.242 GMT I (338494162) v-nissanleaf: Stop Charging
2025-02-02 21:08:15.322 GMT I (338494242) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:15.322 GMT I (338494242) v-nissanleaf:  MITM turned off
2025-02-02 21:08:15.342 GMT I (338494262) v-nissanleaf:
RemoteCommandTimer 3
2025-02-02 21:08:15.342 GMT I (338494262) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:15.342 GMT I (338494262) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:15.342 GMT I (338494262) v-nissanleaf: Stop Charging
2025-02-02 21:08:15.422 GMT I (338494342) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:15.422 GMT I (338494342) v-nissanleaf:  MITM turned off
2025-02-02 21:08:15.442 GMT I (338494362) v-nissanleaf:
2025-02-02 21:08:15.442 GMT I (338494362) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:15.442 GMT I (338494362) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:15.442 GMT I (338494362) v-nissanleaf: Stop Charging
2025-02-02 21:08:15.522 GMT I (338494442) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:15.522 GMT I (338494442) v-nissanleaf:  MITM turned off
2025-02-02 21:08:15.542 GMT I (338494462) v-nissanleaf:
2025-02-02 21:08:15.542 GMT I (338494462) v-nissanleaf: New TCU on CAR
Bus
2025-02-02 21:08:15.542 GMT I (338494462) v-nissanleaf: Sending Wakeup
Frame
2025-02-02 21:08:15.542 GMT I (338494462) v-nissanleaf: Stop Charging
2025-02-02 21:08:15.622 GMT I (338494542) v-nissanleaf: MITM attempted
off
2025-02-02 21:08:15.622 GMT I (338494542) v-nissanleaf:  MITM turned off
2025-02-02 21:08:15.642 GMT I (338494562) v-nissanleaf:
RemoteCommandTimer 0
2025-02-02 21:08:22.142 GMT I (338501062) ovms-server-v3: Tx notify
ovms/notify/info/charge/stopped=Charge Stopped, Timer On|0.7Mph|Full:
4:35h|Charged: 3.5kWh|SOC: 52.2%|Ideal range: 66M|Est. range: 41M|ODO:
56580.0M|CAC: 57.5Ah|SOH: 73%
2025-02-02 21:08:22.152 GMT D (338501072) events:
Signal(notify.info.charge.stopped)
2025-02-02 21:08:22.372 GMT I (338501292) ovms-server-v3: Message
publishing acknowledged (msg_id: 2154)
2025-02-02 21:08:23.142 GMT D (338502062) events:
Signal(vehicle.charge.12v.stop)
2025-02-02 21:08:24.142 GMT I (338503062) powermgmt: No longer charging
12V battery..
2025-02-02 21:09:07.482 GMT D (338546402) vehicle-poll:
[1]PollerSend(PRI)[3]: entry at[type=21, pid=1], ticker=3060, wait=0,
cnt=0/0
2025-02-02 21:09:07.482 GMT E (338546402) can: can1: intr=49552907
rxpkt=49533436 txpkt=7319 errflags=0x8000d9 rxerr=0 txerr=8 rxinval=0
rxovr=6 txovr=0 txdelay=309 txfail=8283 wdgreset=0 errreset=8 txqueue=0
2025-02-02 21:09:07.482 GMT E (338546402) can: can1: intr=49552911
rxpkt=49533436 txpkt=7319 errflags=0x8000d9 rxerr=0 txerr=40 rxinval=0
2025-02-02 21:09:07.482 GMT E (338546402) can: can1: intr=49552913
rxpkt=49533436 txpkt=7319 errflags=0x8000d9 rxerr=0 txerr=56 rxinval=0
2025-02-02 21:09:07.482 GMT E (338546402) can: can1: intr=49552915
rxpkt=49533436 txpkt=7319 errflags=0x8000d9 rxerr=0 txerr=72 rxinval=0
2025-02-02 21:09:07.482 GMT E (338546402) can: can1: intr=49552916
rxpkt=49533436 txpkt=7319 errflags=0x8000d9 rxerr=0 txerr=80 rxinval=0
2025-02-02 21:09:07.482 GMT E (338546402) can: can1: intr=49552918
rxpkt=49533436 txpkt=7319 errflags=0x8440d9 rxerr=0 txerr=96 rxinval=0
2025-02-02 21:09:07.482 GMT E (338546402) can: can1: intr=49552920
rxpkt=49533436 txpkt=7319 errflags=0x8040d9 rxerr=0 txerr=112 rxinval=0
2025-02-02 21:09:07.482 GMT E (338546402) can: can1: intr=49552923
rxpkt=49533436 txpkt=7319 errflags=0xa040d9 rxerr=0 txerr=128 rxinval=0
2025-02-02 21:09:08.482 GMT D (338547402) vehicle-poll:
[1]PollerSend(PRI)[3]: entry at[type=21, pid=2], ticker=3060, wait=0,
cnt=0/0
2025-02-02 21:09:09.482 GMT D (338548402) vehicle-poll:
[1]PollerSend(PRI)[3]: entry at[type=21, pid=6], ticker=3060, wait=0,
cnt=0/0
2025-02-02 21:10:10.482 GMT D (338609402) vehicle-poll:
[1]PollerSend(PRI)[3]: entry at[type=21, pid=1], ticker=3120, wait=0,
cnt=0/0
2025-02-02 21:10:11.482 GMT D (338610402) vehicle-poll:
[1]PollerSend(PRI)[3]: entry at[type=21, pid=2], ticker=3120, wait=0,
cnt=0/0
2025-02-02 21:10:12.482 GMT D (338611402) vehicle-poll:
[1]PollerSend(PRI)[3]: entry at[type=21, pid=6], ticker=3120, wait=0,
cnt=0/0
2025-02-02 21:11:13.482 GMT D (338672402) vehicle-poll:
[1]PollerSend(PRI)[3]: entry at[type=21, pid=1], ticker=3180, wait=0,
cnt=0/0
2025-02-02 21:11:14.482 GMT D (338673402) vehicle-poll:
[1]PollerSend(PRI)[3]: entry at[type=21, pid=2], ticker=3180, wait=0,
cnt=0/0
2025-02-02 21:11:15.482 GMT D (338674402) vehicle-poll:
[1]PollerSend(PRI)[3]: entry at[type=21, pid=6], ticker=3180, wait=0,
cnt=0/0
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250202/1adfaa32/attachment-0001.htm>
