[Ovmsdev] Fwd: Firmware release 3.3.005 / CAN SAE timing
Craig Leres
leres at xse.com
Sat Aug 9 09:25:22 HKT 2025
[I never saw this hit the mailing list and do not see it in the archives...]
-------- Forwarded Message --------
Subject: Re: [Ovmsdev] Firmware release 3.3.005 / CAN SAE timing
Date: Thu, 7 Aug 2025 17:05:07 -0700
To: Michael Balzer <dexter at expeedo.de>, OVMS Developers
<ovmsdev at lists.openvehicles.com>
On 8/1/25 15:20, Craig Leres wrote:
>> You could also try a smaller keepalive value (e.g. a minute?) or
>> determine and apply the keepalive interval of your MQTT hub.
> I built and booted 3.3.005-20-g60be058e. Did I set the keep alive to one
> minute correctly?
That seemed to do the trick; I have all three of my modules running with
that version and my daily hologram.io usage has stayed under 1MB.
I'm still curious why there can be so much cellular data when the unit
is in range of wifi.
Craig
