[Ovmsdev] Support for Lilygo T-Call based module
Chris van der Meijden
chris at arachnon.de
Tue Apr 29 13:09:49 HKT 2025
Hi Christian
Thank you for your generous offer.
I'm deep into other projects at the moment, so I woukd not feel
comfortable when your hardware would be laying around at my place and I
would not be spending the time with it it deserves.
And as Carsten now jumped in, there will be some good team testing.
So thank you again. I will be following the development with great
interest and surely will step into this hardware somewhere in the
future.
Success
Chris
Am Montag, dem 28.04.2025 um 15:16 +0000 schrieb Carsten Schmiemann via
OvmsDev:
> Hi Christian,
> really nice work, thanks.
> I immediately ordered 5 PCBs and will test it on my electric scooter
> from NIU which has a CAN bus and I did some reverse engineering
> already. Only the high price of an OVMS 3.3 module was holding me
> back :-)
> Greetings from Germany
> Carsten
> Von: OvmsDev <ovmsdev-bounces at lists.openvehicles.com> im Auftrag von
> Info Zeitnitz via OvmsDev <ovmsdev at lists.openvehicles.com>
> Gesendet: Montag, 28. April 2025 14:24:32
> An: ovmsdev at lists.openvehicles.com
> Cc: Info Zeitnitz
> Betreff: Re: [Ovmsdev] Support for Lilygo T-Call based module
> Hi Chris and Mark,
> thanks for your positive responses.
> The Simcom modem is already supported by my last PR, so no extra
> configuration required. This is independent from the hardware
> selection.
> The currently used single config CONFIG_OVMS_HW_BASE_LILYGO_1_0 takes
> care of 2 things: - Change the pin assignment of the ESP32 to match
> the Lilygo module and the motherboard - Reassign required signals of
> the GPIO extender
> chip max7317 to ESP32 IO pins. This is only related to the powering
> of the modem. Thats all. The latter can easily be handled by an
> alternative config, if the max7317 is disabled. But there is the need
> to handle an alternative IO mapping in ovms_peripherals.h
> and this is very specific for the Lilygo/motherboard combination. I
> do not care, whether this is handled as a separate HW version, or is
> achieved by just an additional optional config to rearrange pins. To
> keep it completely flexible, a free pin mapping could
> be available via menuconfig or an extra file, but that might be too
> error prone. Concerning the availability of the hardware: at this
> stage, I will not be able to provide kits for this hardware option.
> Probably someone else is interested doing this? Chris,
> if you are interested to test it, I could provide you with a
> partially assembled motherboard (most passive components and the
> DC/DC converter). As far as I see, you are located in Germany as
> well, so shipment would be no problem. Best regards Christian
> Am 27.04.2025 um 14:44 schrieb Mark Webb-Johnson via OvmsDev:
> > Chris,
> > I guess if somebody wanted to, it could be available as an
> > unsoldered kit of Pcb and parts. The problem with assembled kits is
> > CE (and ROHS) certification for sale in EU, but unsoldered kits are
> > generally considered exempted from that (although the radio /
> > antenna part of it is a gray area).
> > Regards, Mark
> > > On Apr 27, 2025, at 3:03 PM, Chris van der Meijden via
> > > OvmsDev<ovmsdev at lists.openvehicles.com> wrote:
> > > Hi Christian,
> > > very impressive. You did a great job on the development and on
> > > the documentation.
> > > It is good to have an alternative hardware option.
> > > As you mentioned, it is a disadvantage that OTA is not possible,
> > > but that seems to be the price for a cheaper hardware. Other
> > > obstacles I see, is that the hardware seems only available
> > > directly from China and that we need to build our own
> > > motherboard. That is for me the greatest hurdle, alltough you did
> > > a great documentation with the Eagle schematics.
> > > I would like to test your hardware approach, if the hardware
> > > would be available as a "ready to go" kit. Are you planning on
> > > providing such a kit?
> > > I could definitly see this as part of the OVMS repository. Lets
> > > see what the other opinions on that are :-)
> > > Regards
> > > Chris
> > > Am Samstag, dem 26.04.2025 um 17:40 +0200 schrieb Info via
> > > OvmsDev:
> > > > Hi,
> > > > I finished the implementation and documentation of the OVMS
> > > > module based
> > > > on the Lilygo T-Call A7670E board (ESP32 WROVER E and a Simcom
> > > > A7670E).
> > > > The module is in operation since more than a month in my Smart
> > > > EQ.
> > > > The hardware details can be found here:
> > > > https://github.com/zbchristian/OVMS-Lilygo-based-Module
> > > > There are some limitations wrt the standard module:
> > > > - only 4MB Flash -> no OTA update
> > > > - no GPIO extender -> only 2 CAN buses
> > > > - no SD-card support
> > > > The required modification in the firmware:
> > > > - remapping of the ESP32 pins in ovms_peripherals
> > > > - replace some of the GPIO extender pins by standard ESP32 pins
> > > > - new hardware option in menuconfig (set
> > > > CONFIG_OVMS_HW_BASE_LILYGO_1_0=y)
> > > > - Simcom 7670 modem support (already available in the OVMS
> > > > repo)
> > > > All this is available in the branch lilygo-support of
> > > https://github.com/zbchristian/Open-Vehicle-Monitoring-System-3-Lilygo-Support
> > > > My question to the main developers: Is there interest to
> > > > incorporate
> > > > this into the official OVMS repository?
> > > > Best regards
> > > > Christian
> > > > _______________________________________________
> > > > OvmsDev mailing list
> > > > OvmsDev at lists.openvehicles.com
> > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250429/11d0656c/attachment.htm>
