[Ovmsdev] System diagram?
Dave Pawson
dave.pawson at gmail.com
Mon Apr 28 17:39:58 HKT 2025
On Mon, 28 Apr 2025 at 09:51, Mark Webb-Johnson <mark at webb-johnson.net>
wrote:
> Yes, hence my questions, are all of those hw interfaces used?
> Mostly. I2C/I2S not as standard (although available for expansion
> modules). ETH, IR, PWM, Temperature, Touch, DAC, all no.
Thanks. I'll see if I can sketch out (my understanding) of the system
I use Mac and Linux myself. I think the developers here are pretty mixes
>> amongst the three platforms.
> Thanks.
Good to know :-)
>> Regarding data sets, I presume you mean CAN bus dumps? I have some for
>> Tesla cars (roadster, S, X). Others typically maintain them for their own
>> cars. People may be reluctant to share as the dumps may contain personally
>> identifiable information (not just VINs, but also things like latitude and
>> longitude coordinates of charging, parking, etc).
> Ouch, fair point.
> Is there any glossary of ODB terms?
> Is it worth providing something to strip out such data (which begs the
> question
> how easy to locate it) for testing purposes?
> I've an ODBeleven, but I don't (normally) get to see raw data.
> I'm guessing prior to emailing it from my phone, the data is converted to
> some 'visual' format?
> Having problems understanding you here. When you say ODBeleven do you mean
> OBDII (OBD 2)?
https://obdeleven.com/ Another ODB interface (bluetooth and phone)
> https://en.wikipedia.org/wiki/OBD-II_PIDs
Understood. That's down at the ("I've no screen space") level.
I was thinking higher level? I'll ask Google.
> If you are looking at vehicle support, the article on that developer page
> is the best starting point we have:
> https://www.openvehicles.com/developers
My thoughts, an opening?
Give me a data set (cleaned or not) for an unknown car and I'll try to
decode it to some
(existing?) intermediate | display format.
I'm quite happy bit twiddling at a low level.
regards
Dave Pawson
XSLT XSL-FO FAQ.
Docbook FAQ.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250428/b126a5db/attachment.htm>
