[Ovmsdev] Support for Lilygo T-Call based module
Chris van der Meijden
chris at arachnon.de
Sun Apr 27 15:03:36 HKT 2025
Hi Christian,
very impressive. You did a great job on the development and on the
documentation.
It is good to have an alternative hardware option.
As you mentioned, it is a disadvantage that OTA is not possible, but
that seems to be the price for a cheaper hardware. Other obstacles I
see, is that the hardware seems only available directly from China and
that we need to build our own motherboard. That is for me the greatest
hurdle, alltough you did a great documentation with the Eagle
schematics.
I would like to test your hardware approach, if the hardware would be
available as a "ready to go" kit. Are you planning on providing such a
kit?
I could definitly see this as part of the OVMS repository. Lets see
what the other opinions on that are :-)
Regards
Chris
Am Samstag, dem 26.04.2025 um 17:40 +0200 schrieb Info via OvmsDev:
> Hi,
> I finished the implementation and documentation of the OVMS module
> based
> on the Lilygo T-Call A7670E board (ESP32 WROVER E and a Simcom
> A7670E).
> The module is in operation since more than a month in my Smart EQ.
> The hardware details can be found here:
> https://github.com/zbchristian/OVMS-Lilygo-based-Module
> There are some limitations wrt the standard module:
> - only 4MB Flash -> no OTA update
> - no GPIO extender -> only 2 CAN buses
> - no SD-card support
> The required modification in the firmware:
> - remapping of the ESP32 pins in ovms_peripherals
> - replace some of the GPIO extender pins by standard ESP32 pins
> - new hardware option in menuconfig (set
> CONFIG_OVMS_HW_BASE_LILYGO_1_0=y)
> - Simcom 7670 modem support (already available in the OVMS repo)
> All this is available in the branch lilygo-support of
> https://github.com/zbchristian/Open-Vehicle-Monitoring-System-3-Lilygo-Support
> My question to the main developers: Is there interest to incorporate
> this into the official OVMS repository?
> Best regards
> Christian
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250427/348d8b67/attachment.htm>
