[Ovmsdev] Instructions for building the "new idf" version?
    Michael Geddes
    Sat Sep 21 17:26:24 HKT 2024
I'm using esp-idf from   https://github.com/espressif/esp-idf.git
The previous was some months ago on release/v5.2 a36d8bc742 which ran on an
ovms unit not connected to a car.
I've just done a compile off v5.3 .. with a series of patches that I've got
from Ludovic and some extras from myself.
I've also used the latest mongoose which is annoyingly problematic as they
re-did the whole way it was put together making it impossible just to apply
patches.  I've re-implemented some of the good things they used to have wrt
defines and there are a couple  of things that ovms team added that would
be required.  One of those is that the 'certificate' is meant to be a
filename and there was a patch to the ovms version that allowed that
filename string to be the certificate itself.
//.ichael
On Fri, 20 Sept 2024 at 10:29, Craig Leres via OvmsDev <
> On 9/19/24 14:36, Craig Leres via OvmsDev wrote:
> > On 9/15/24 16:08, Craig Leres via OvmsDev wrote:
> >> What version of the toolchain are you building with?
> > The most recent appears to be crosstool-ng-1.26.0 (Sep 2023), is that
> > what you folks are using?
> Poking around I see my ubuntu 22.04 ssd, that I use to compile esp32
> arduino sketches, is using gcc 8.4.0 (crosstool-NG esp-2021r2-patch5).
> (This version is bundled somehow with arduino 1.8.19.)
> What I'm expecting is that we would pick one specific, recent version of
> the toolchain to (eventually) be supported for building ovms.
> For references purposes the "latest" crosstool-ng is 1.26.0 (gcc 13.2).
>                 Craig
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240921/747507dc/attachment.htm>
