[Ovmsdev] Instructions for building the "new idf" version?
Michael Geddes
Mon Sep 16 07:06:48 HKT 2024
I would like to be included in the loop here if you are doing some off-list
discussions and I'll follow along at home. I've already been building with
the updated framework and have contributed a few commits to the main branch
where I can... Though it's been a bit since I last built - I've had some
other things I've been doing in OVMS.
I would like to add to the discussion whether we try to move to a MQTT
framework that supports topic aliases. (Since that's going to be how we
make the server v3 consume less data). WolfMQTT does - but would require
someone to get their head around it!
//.ichael
On Mon, 16 Sept 2024 at 06:37, Craig Leres via OvmsDev <
> On 9/15/24 13:23, Ludovic LANGE via OvmsDev wrote:
> > I've received your 3 mails so it seems that everything went fine -
> > however there may be a little delay between posting and receiving ?
> Yeah, sorry about the noise. I replied to and existing thread and edited
> the fields but thunderbird didn't show that it was including a
> "in-reply-to" header. Once that thread had my news subject, the mailing
> list software will always treat the message as part of that thread...
> > Regarding your "new idf" endeavour it's a good news that you're trying
> > to get your hands dirty on it ! I'll try to help you as much as I can to
> > get you started, however, bear with me, it's been a long time since I
> > did it from scratch so I may omit some (crucial) steps here and there.
> I did a tiny amount of work in this direction a few years ago. My
> vehicles are so far pretty simple and I'm getting pressure to update the
> xtensa toolchain for FreeBSD so this seems like a good time to jump in.
> > First thing - I only really compiled with ESP-IDF 5+ : 5.0.1 / 5.0.2 /
> > 5.0.6 / 5.1.4 / 5.2.2 / 5.3.0 (and also the corresponding "live"
> > branches release-v5.0 / release-v5.1 / release-v5.2 / release-v5.3 , but
> > as these are "moving targets", you can sometime have a working compile
> > and an issue a few months later).
> I want to update the FreeBSD port with a specific release; sounds like I
> should use release-v5.3?
> (I'll probably switch to off-list email with you once I get further along.)
> Thanks!
> Craig
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240916/bb8ab442/attachment-0001.htm>
