[Ovmsdev] access to writer?
Michael Geddes
Fri Sep 13 21:06:40 HKT 2024
Probably the best you can do is do a log. If you the do log monitor yes
and enable the channel it will appear.
I think you need to take a step back and say what your original problem is.
Remember multiple 'writers' can be active / temporarily created depending
On Fri, 13 Sept 2024, 20:40 Michael Balzer via OvmsDev, <
> The short answer is: you can't.
> There is no "current" writer. If a function may need to output text to a
> writer, you need to pass the writer pointer to that function.
> In case of functions that may be called within a user command execution
> and shall then provide output, add the writer to the signature, and only
> use it when it's not null. If the output is important, send it to the
> log if the writer is null.
> If you need to reduce the output for certain output channels, you'll
> also want to pass the "verbosity" parameter along with the writer pointer.
> Am 13.09.24 um 08:55 schrieb sharkcow via OvmsDev:
> > Hi all,
> > I have a dumb question: how do I get access to the current "writer"
> > object in a "regular" function in my vehicle code (not defined by
> > RegisterCommand)?
> > Thanks!
> > sharkcow
> > OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240913/2c07d2e5/attachment-0001.htm>
