[Ovmsdev] New polling framework example
Sun Sep 8 10:09:25 HKT 2024
The ioniq 5 is probably the best one.
You shouldn't need a huge change to your code but varuous virtual method
signatures have changed.
It would be advantageous to make sure that  when you override methods in
the base that you use the override keyword!
On Sun, 8 Sept 2024, 03:41 solterra--- via OvmsDev, <
> I'm working on the Toyota eTNGA vehicle integration and had a vehicle
> module nearly ready to merge last year. Unfortunately, my car broke
> down, and I've only recently gotten a new one.
> It seems that the polling framework has changed quite a bit since then.
> Could someone point me toward a good example of the new framework so I
> can start converting my module?
> Thanks in advance for your help!
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240908/1b09ec17/attachment.htm>
