[Ovmsdev] Access to a diagnostic session with private access
didier at ernotte.com
Tue Oct 1 00:21:59 HKT 2024
In fact I found that if I am fast enough on the keyboard I can send the "10 03" and "27 03", without any problem, but if I am too slow, I have this "service not supported in active session" error. I guess the ECU put itself back in active mode instead of diag mode if no data is sent within a short timeframe.
Didier
Le lundi 30 septembre 2024 à 12 h 16 min 43 s HAE, didier at ernotte.com <didier at ernotte.com> a écrit :
Thanks, with the "re obdii tester" command I was able to keep the private session alive and send my data to get the battery cell info hidden in a internal routine of the ECU.
Didier
Le dimanche 29 septembre 2024 à 14 h 02 min 49 s HAE, Craig Leres via OvmsDev <ovmsdev at lists.openvehicles.com> a écrit :
On 9/29/24 00:50, Michael Balzer via OvmsDev wrote:
> you may need to send a periodic "tester present" signal after entering
> the diagnostic session via "10 03".
Interesting. In J1850, secondary id 0x03 (state of health/node alive)
is periodically sent by many modules.
Craig
OvmsDev mailing list
OvmsDev at lists.openvehicles.com
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240930/b03fbc20/attachment.htm>
