[Ovmsdev] How I got sphinx working on ubuntu 23.1 + WSL
Michael Geddes
Sun Nov 17 17:43:29 HKT 2024
OK.
I assume that file will get restored? Apart from m2r2 needing to be
replaced by mdinclude, I'm assuming my solution is actually the method
intended by Ubuntu people .
On Sun, 17 Nov 2024, 14:11 Chris van der Meijden, <chris at arachnon.de> wrote:
> Hi Michael,
> to get get pip working on Debian I need to remove (or rename) the file
> /usr/lib/python3.11/EXTERNALLY-MANAGED
> After doing that I can use pip as normal. It should be the same on Ubuntu.
> There are other solutions too:
> https://www.makeuseof.com/fix-pip-error-externally-managed-environment-linux/
> But this is the one I prefer.
> Regards
> Chris
> Am Sonntag, dem 17.11.2024 um 08:19 +0800 schrieb Michael Geddes via
> OvmsDev:
> Firstly, thanks to Michael Balzer for fixing my errors in the rst files I
> checked in. (Also, apparently I can't spell Auxiliary - doh). I _had_
> tried to get sphinx working recently and failed miserably, so I tried again
> this morning.
> The problem is that ubuntu:
> * Doesn't provide a package for m2r2 or sphinx-mdinclude (a fork of m2r2)
> * No longer allows you to pip install into the main python library path
> So first I got rid of the installed sphinx-doc
> sudo apt remove sphinx-doc
> Then I set up a sphinx virtual environment
> pipx install sphinx
> pipx inject sphinx sphinx_rtd_theme docutils mistune requests
> sphinx-mdinclude
> For some reason I was getting run-time python errors with m2r2 which is
> why I tried switching to mdinclude.
> In docs/source/conf.py I changed
> extensions = [ 'm2r2' ]
> to be 'sphinx_mdinclude' instead of 'm2r2'
> The pipx command creates a virtual execution environment for sphinx and
> puts a shim for sphinx in your local path that runs it in the virtual
> environment.
> //.ichael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241117/39760283/attachment.htm>
