[Ovmsdev] How I got sphinx working on ubuntu 23.1 + WSL
Michael Geddes
Sun Nov 17 08:19:19 HKT 2024
Firstly, thanks to Michael Balzer for fixing my errors in the rst files I
checked in. (Also, apparently I can't spell Auxiliary - doh). I _had_
tried to get sphinx working recently and failed miserably, so I tried again
this morning.
The problem is that ubuntu:
* Doesn't provide a package for m2r2 or sphinx-mdinclude (a fork of m2r2)
* No longer allows you to pip install into the main python library path
So first I got rid of the installed sphinx-doc
sudo apt remove sphinx-doc
Then I set up a sphinx virtual environment
pipx install sphinx
pipx inject sphinx sphinx_rtd_theme docutils mistune requests
sphinx-mdinclude
For some reason I was getting run-time python errors with m2r2 which is why
I tried switching to mdinclude.
In docs/source/conf.py I changed
extensions = [ 'm2r2' ]
to be 'sphinx_mdinclude' instead of 'm2r2'
The pipx command creates a virtual execution environment for sphinx and
puts a shim for sphinx in your local path that runs it in the virtual
environment.
//.ichael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241117/71965e0d/attachment.htm>
