[Ovmsdev] Can bus error while read canbus
didier at ernotte.com
Fri Nov 1 02:06:36 HKT 2024
Hi Michael,
It seems like there is no poller.
OVMS# log level debug
Logging level for * set to debug
I (185165) webcommand: HttpCommandStream[0x3f8d8ae4]: 3314760 bytes free, executing: log level debugI (193855) webserver: HTTP POST /api/executeI (193865) webcommand: HttpCommandStream[0x3f8e2890]: 3314548 bytes free, executing: poller statusOVMS# poller status
No OBD Pollers active.I (198035) webserver: HTTP POST /api/executeI (198035) webcommand: HttpCommandStream[0x3f8e2890]: 3312220 bytes free, executing: poller resumeD (198045) vehicle-poll: Pollers: Queue Command()D (198045) vehicle-poll: Pollers: Command Resume (user)OVMS# poller resume
Vehicle OBD Polling Resume RequestedI (214195) webserver: HTTP POST /api/executeOVMS# poller status
No OBD Pollers active.I (214195) webcommand: HttpCommandStream[0x3f8e2890]: 3316368 bytes free, executing: poller statusD (217755) websocket: WebSocket[0x3f8e32ec] handler 0x3f8e3668 closed; 3 clients activeD (217755) events: Signal(server.web.socket.closed)D (217755) websocket: WebSocket[0x3f8d5e74] handler 0x3f8e2c90 closed; 2 clients activeD (217765) events: Signal(server.web.socket.closed)Didier
Le jeudi 31 octobre 2024 à 02 h 58 min 01 s HAE, Michael Balzer via OvmsDev <ovmsdev at lists.openvehicles.com> a écrit :
Didier,
the error message tells the now separated poller isn't started and also cannot be started for the request.
Check "poller status":
OVMS# poller status
Poller on Can1
List: active
State: 0
Last Request: 1s (ticks)
Time between polling ticks: 1000ms
Last Poll Received: 0s (ticks) ago
Poll Queue Length: 0
OBD polling is Resumed
Enable logging for tag "vehicle-poll" and issue "poller trace on" or possibly "poller trace all" if that doesn't show the cause.
Am 30.10.24 um 22:55 schrieb didier--- via OvmsDev:
Hi,
I don't know what changed on my OVMS box, but I am no longer abl to read manually (in the shell) any PID with the "obdii can1 request...". I receive the tranmission failure error. But it used to work fine a couple of days ago. Other commands works great like "re obdii scan start...", so the connection with the OMVS box, communication on the OBD2 port, etc works fine. What could go wrong ? I tried to download the lasted image. Same error.
Here is a session that I did :
OVMS# re obdii scan start 1 7e4 dd00 de00 -r7ec
Scan started: bus 1, ecu 7e4, rxid 7ec-7ec, polltype 22, PID dd00-de00 (step 1), timeout 3 seconds
I (804831) webcommand: HttpCommandStream[0x3f8d76b0]: 3317288 bytes free, executing: re obdii scan start 1 7e4 dd00 de00 -r7ecI (810981) re-pid: Scan of 7e4 completeI (817271) webserver: HTTP POST /api/executeOVMS# re obdii scan statusScan complete (7e4 dd00-de00)Scan started : 2024-10-30 17:46:53 EDTLast response: 2024-10-30 17:46:53 EDT7e4[7ec]:dd00 70 e8 79 bb7e4[7ec]:dd01 01 1c f87e4[7ec]:dd02 3a7e4[7ec]:dd04 3d7e4[7ec]:dd05 3a7e4[7ec]:dd06 e77e4[7ec]:dd08 007e4[7ec]:dd09 00I (817271) webcommand: HttpCommandStream[0x3f8d7350]: 3314968 bytes free, executing: re obdii scan statusI (821941) webserver: HTTP POST /api/executeI (821941) webcommand: HttpCommandStream[0x3f8d7414]: 3318624 bytes free, executing: obdii can1 request device 7E4 7EC 22dd00OVMS# obdii can1 request device 7E4 7EC 22dd007e4[7ec] 22dd00: ERROR: transmission failure (CAN bus error) Didier
OvmsDev mailing list
OvmsDev at lists.openvehicles.com
Fon 02330 9104094 * Handy 0176 20698926 _______________________________________________
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241031/c484859f/attachment-0001.htm>
