OK, I see now why it wouldn't send the notification: the V2 & V3 server
register for notifications up to COMMAND_RESULT_NORMAL = 1024 characters.
The report quickly becomes larger than 1024 characters, so the
notifications no longer get sent via the server connectors.
You need to either reduce the size, split the report, or use data
notifications instead.
On the reset value init: for my float targeting smoothing helper class
for the UpMiiGo, I implemented a gradual ramp up from 1 to the requested
sample size. You can do something similar also with powers of 2. IOW,
yes, initialization from the first values received is perfectly OK.
Am 26.05.24 um 14:35 schrieb Michael Geddes:
> It _/should/_ already be sending a report on charge stop.
> MyEvents.RegisterEvent(TAG, "vehicle.charge.stop",
> std::bind(&OvmsPollers::VehicleChargeStop, this, _1, _2));
> Reset on charge start/vehicle on is a good idea.
> A question – would it be silly if the first value after a reset,
> rather than using 0 average to start with, if the average got set to
> the initial value? I’m in 2 minds about it. It would make the average
> more useful quicker.
> //.ichael
> On Sun, 26 May 2024, 19:39 Michael Balzer via OvmsDev,
> <ovmsdev at lists.openvehicles.com> wrote:
> As the averages quickly decline when idle, an automatic report
> should probably also be sent on charge stop.
> Also, I think you should automatically reset the timer statistics
> on drive & charge start.
> First stats from charging my UpMiiGo:
> Type | count | Utlztn | Time
> | per s | [‰] | [ms]
> Poll:PRI Avg| 1.00| 0.723| 0.716
> Peak| | 1.282| 3.822
> Poll:SRX Avg| 7.72| 1.246| 0.184
> Peak| | 3.128| 1.058
> RxCan1[7ae] Avg| 2.48| 0.915| 0.362
> Peak| | 1.217| 1.661
> RxCan1[7cf] Avg| 4.76| 1.928| 0.397
> Peak| | 2.317| 2.687
> RxCan1[7ed] Avg| 3.38| 1.251| 0.327
> Peak| | 8.154| 12.273
> RxCan1[7ee] Avg| 0.21| 0.066| 0.297
> Peak| | 0.225| 1.690
> TxCan1[744] Avg| 1.49| 0.022| 0.011
> Peak| | 0.032| 0.095
> TxCan1[765] Avg| 3.89| 0.134| 0.027
> Peak| | 0.155| 0.113
> TxCan1[7e5] Avg| 2.32| 0.038| 0.013
> Peak| | 0.295| 0.084
> TxCan1[7e6] Avg| 1 0.21| 0.002| 0.008
> Peak| | 0.010| 0.041
> Cmd:State Avg| 0.00| 0.000| 0.007
> Peak| | 0.005| 0.072
> Total Avg| 27.46| 6.324| 2.349
> Overall healthy I'd say, but let's see how it compares.
> 7ed is the BMS, the peak time is probably related to the extended
> cell data logging -- I've enabled log intervals for both cell
> voltages & temperatures.
> Am 26.05.24 um 08:42 schrieb Michael Balzer via OvmsDev:
> The notification works on my devices, it only has a garbled
> per mille character -- see attached screenshot. The same
> applies to the mail version:
> Poller timing is: on
> | per s | [‰] | [ms]
> Poll:PRI Avg| 0.25| 0.119| 0.382
> Peak| | 0.513| 0.678
> RxCan1[597] Avg| 0.01| 0.004| 0.021
> Peak| | 0.000| 0.338
> RxCan1[59b] Avg| 0.01| 0.011| 0.053
> Peak| | 0.000| 0.848
> Cmd:State Avg| 0.01| 0.002| 0.012
> Peak| | 0.000| 0.120
> Total Avg| 0.28| 0.135| 0.468
> The encoding is a general issue. The character encoding for
> text messages via V2/MP is quite old & clumsy, it's got an
> issue with the degree celcius character as well. We previously
> tried to keep all text messages within the SMS safe character
> set (which e.g. lead to writing just "C" instead of "°C"). I'd
> say we should head towards UTF-8 now. If we ever refit SMS
> support, we can recode on the fly.
> Regarding not seeing the notification on your phone:
> a) Check your notification subtype/channel filters on the
> module. See
> https://docs.openvehicles.com/en/latest/userguide/notifications.html#suppress-notifications
> b) Check your notification vehicle filters on the phone (menu
> on notification tab): if you enabled the vehicle filter, it
> will add the messages of not currently selected vehicles to
> the list only, but not raise a system notification. (Applies
> to the Android App, no idea about the iOS version)
> Am 26.05.24 um 06:32 schrieb Michael Geddes:
> Hi,
> I'm trying to finalise this now .. and one last thing is
> that I don't get the report coming to my mobile. I'm using
> the command:
> MyNotify.NotifyString("info", "poller.report", buf.c_str());
> Where the buffer string is just the same as the report
> output. Should I be using some other format or command?
> I get "alert" types (like the ioniq5 door-open alert) fine
> to my mobile.
> Michael.
> On Sun, 19 May 2024, 12:51 Michael Balzer via OvmsDev,
> A builtin web UI for this seems a bit over the top.
> Builtin web config pages should focus on user
> features, this is clearly a feature only needed
> during/for the development/extension of a vehicle
> adapter. Development features in the web UI are
> confusing for end users.
> If persistent enabling/disabling is done by a simple
> config command (e.g. "config set can poller.trace
> on"), that's also doable by users.
> Am 19.05.24 um 02:06 schrieb Michael Geddes:
> I was so focused on how I calculated the value
> that I totally missed that ‰ would be a better
> description. I could also use the system 'Ratio'
> unit... so % or ‰.
> I'll make space to put 'Avg' on the row. Was
> trying to limit the width for output on a mobile.
> I agree it would make it easier to understand.
> Totals also makes sense.
> Should I make this a configuration that can be set
> on the web-page? I'd probably use a
> configuration change notification so that the very
> bit setting is sync'd with the 'configuration' value.
> //.ichael
> On Sat, 18 May 2024, 14:05 Michael Balzer,
> <dexter at expeedo.de> wrote:
> I'm not sure whether the 'max' should be
> the maximum of the smoothed value.. or the
> maximum of the raw value.
> It should normally be the maximum of the raw
> value I think, the maximum of the smoothed
> value cannot tell about how bad the processing
> of an ID can become.
> The naming in the table is a bit confusing I
> think. (besides: I've never seen "ave" as the
> abbreviation for average)
> If I understand you correctly, "time ms per s"
> is the time share in per mille, so something
> in that direction would be more clear, and
> "length ms" would then be "time [ms]".
> The totals for all averages in the table foot
> would also be nice.
> Maybe "Ave" (or avg?) also should be placed on
> the left, as the "peak" label now suggests
> being the peak of the average.
> Btw, keep in mind, not all "edge" users /
> testers are developers (e.g. the Twizy driver
> I'm in contact with), collecting stats
> feedback for vehicles from testers should be
> straight forward. Maybe add a data/history
> record, sent automatically on every
> drive/charge stop when the poller tracing is on?
> Am 18.05.24 um 02:28 schrieb Michael Geddes:
> You did say max/pead value. I also halved
> the N for both.
> This is currently the raw-value maximum.
> The problem is that the middle column is
> the maximum of the {{sum over 10s} /
> (10*1000,000)
> I could easily change the 'period' to 1s
> and see how that goes.. was just trying to
> reduce the larger calculations.
> Usage: poller
> [pause|resume|status|times|trace]
> OVMS# poller time status
> Type | Count | Ave time | Ave
> length
> | per s | ms per s | ms
> Poll:PRI | 1.00| 0.559| 0.543
> peak | | 0.663| 1.528
> Poll:SRX | 0.08| 0.009| 0.038
> peak | | 0.068| 0.146
> CAN1 RX[778] | 0.11| 0.061| 0.280
> peak | | 0.458| 1.046
> CAN1 RX[7a8] | 0.04| 0.024| 0.124
> peak | | 0.160| 0.615
> CAN1 TX[770] | 0.05| 0.004| 0.016
> peak | | 0.022| 0.102
> CAN1 TX[7a0] | 0.02| 0.002| 0.011
> peak | | 0.010| 0.098
> CAN1 TX[7b3] | 0.01| 0.001| 0.006
> peak | | 0.000| 0.099
> CAN1 TX[7e2] | 0.02| 0.002| 0.011
> peak | | 0.010| 0.099
> CAN1 TX[7e4] | 0.08| 0.008| 0.048
> peak | | 0.049| 0.107
> Cmd:State | 0.00| 0.000| 0.005
> peak | | 0.000| 0.094
> On Fri, 17 May 2024 at 15:26, Michael
> Geddes <frog at bunyip.wheelycreek.net> wrote:
> This is what I have now.
> The one on the end is the one MIchael
> B was after using an N of 32. (up for
> discussion).
> The middle is the time spent in that
> even t per second. It accumulates
> times (in microseconds), and then
> every 10s it stores it as
> smoothed (N=16) value.
> The Count is similar (except that we
> store a value of '100' as 1 event so
> it can be still integers and has 2
> decimal places).
> Every received poll does a
> 64bit difference to 32bit (for the
> elapsed time) and 64bit comparison
> (for end-of-period).
> It also does 1x 32bit smoothing and 2x
> 32bit adds.
> Then at the end of a 10s period, it
> will do a 64bit add to get the next
> end-of-period value, as well as the 2x
> 32bit smoothing calcs.
> This is from the Ioniq 5 so not any
> big values yet. You can certainly see
> how insignificant the TX callbacks are.
> I'll leave it on for when the car is
> moving and gets some faster polling.
> OVMS# poll time status
> Ave Length
> Poll:PRI | 1.00| 0.540| 0.539
> Poll:SRX | 0.03| 0.004| 0.017
> CAN1 RX[778] | 0.06| 0.042| 0.175
> CAN1 TX[770] | 0.04| 0.002| 0.008
> Cmd:State | 0.01| 0.001| 0.005
> ----------------------8<--------------------------------
> Nice smoothing class (forces N as a
> power of 2):
> constexpr unsigned floorlog2(unsigned x)
> return x == 1 ? 0 : 1+floorlog2(x
> >> 1);
> /* Maintain a smoothed average using
> shifts for division.
> * T should be an integer type
> * N needs to be a power of 2
> template <typename T, unsigned N>
> class average_util_t
> private:
> T m_ave;
> public:
> average_util_t() : m_ave(0) {}
> static const uint8_t _BITS =
> floorlog2(N);
> void add( T val)
> static_assert(N == (1 << _BITS), "N
> must be a power of 2");
> m_ave = (((N-1) * m_ave) +
> val) >> _BITS;
> T get() { return m_ave; }
> operator T() { return m_ave; }
> On Thu, 16 May 2024 at 10:29, Michael
> wrote:
> Thanks Michael,
> My calculations give me ((2^32)-1)
> / (1000*1000*3600) = only 1.2
> hours of processing time in
> 32bit. The initial subtraction is
> 64bit anyway and I can't see a
> further 64bit addition being a
> problem. I have the calculations
> being performed in doubles at
> print-out where performance is not
> really an issue anyway. (Though
> apparently doing 64 bit division
> is worse than floating point).
> In addition
> * I currently have this being able
> to be turned on and off and reset
> manually (only do it when required).
> * For the lower volume commands,
> the smoothed average is not going
> to be useful - the count is more
> interesting for different reasons.
> * The total time is quite useful.
> Ie a high average time doesn't
> matter if the count is low. The
> things that are affecting
> performance are stuff with high
> total time. Stuff which is
> happening 100 times a second needs
> to be a much lower average than
> once a second.
> * A measure like 'time per
> minute/second' and possibly count
> per minute/seconds as a
> smoothed average would potentially
> be more useful. (or in addition?)
> I think we could do _that_ in a
> reasonably efficient manner using
> a 64 bit 'last measured time', a
> 32 bit accumulated value and the
> stored 32 bit rolling average.
> It would boils down to some
> iterative (integer) sums and
> multiplications plus a divide by n
> ^ (time periods passed) - which
> is a shift - and which can be
> optimised to '0' if
> 'time-periods-passed' is more than
> 32/(bits-per-n) - effectively
> limiting the number of iterations.
> The one issue I can see is that we
> need to calculate 'number of
> time-periods passed' which is a 64
> bit subtraction followed by a 32
> bit division (not optimisable to a
> simple shift).
> * I'm also happy to keep a rolling
> (32bit) average time.
> Even if you assume averages in
> the 100ms, 32bit is going to
> happily support an N of 64 or even
> 128.
> Am I right in thinking that the
> choice of N is highly dependent on
> frequency. For things happening
> 100 times per second, you might
> want an N like 128.. where things
> happening once per
> second, you might want an N of
> 4 or 8. The other things we keep
> track of in this manner we have a
> better idea of the frequency of
> the thing.
> How about we have (per record type):
> * total count (since last
> reset?) (32 bit)
> * smoothed average of time per
> instance (32 bit)
> * ?xx? total accumulated time
> since last reset (64bit) ?? <--
> with the below stats this is much
> less useful
> * last-measured-time (64 bit)
> * accumulated count since last
> time-period (16bit - but maybe
> 32bit anyway for byte alignment?)
> * smoothed average of count per
> time-period (32bit)
> * accumulated time since last
> time-period (32bit)
> time-period (32bit)
> It's possible to keep the
> Is this going to be too much per
> record type? The number of
> 'records' we are keeping is quite
> low (so 10 to 20 maybe) - so it's
> not a huge memory burden.
> Thoughts?
> //.ichael
> On Thu, 16 May 2024 at 03:09,
> wrote:
> esp_timer_get_time() is the
> right choice for precision timing.
> I'd say uint32 is enough
> though, even if counting
> microseconds that can hold a
> total of more than 71 hours of
> actual processing time. uint64
> has a significant performance
> penalty, although I don't
> recall the overhead for simple
> additions.
> Also & more important, the
> average wouldn't be my main
> focus, but the maximum
> processing time seen per ID,
> which seems to be missing in
> your draft.
> Second thought on the average…
> the exact overall average
> really has a minor meaning,
> I'd rather see the current
> average, adapting to the
> current mode of operation
> (drive/charge/…). I suggest
> feeding the measurements to a
> low pass filter to get the
> smoothed average of the last n
> measurements. Pattern:
> runavg = ((N-1) * runavg +
> newval) / N
> By using a low power of 2 for
> N (e.g. 8 or 16), you can
> replace the division by a
> simple bit shift, and have
> enough headroom to use 32 bit
> integers.
> Am 15.05.24 um 06:51 schrieb
> Michael Geddes via OvmsDev:
> Formatting aside, I have
> implemented what I think
> Michael B was suggesting.
> This is a sample run on
> the Ioniq 5 (which doesn't
> have unsolicited RX events).
> This uses the
> call esp_timer_get_time()
> got get a 64bit
> *microseconds* since
> started value - and works
> out the time to execute
> that way. It's looking at
> absolute time and not time
> in the Task - so other
> things going on at the
> same time in other tasks
> will have an effect. (The
> normal tick count doesn't
> have nearly enough
> resolution to be useful -
> any other ideas on
> measurement?) I've got
> displaying in seconds and
> the average in
> milliseconds currently -
> but I can change that easy
> enough.
> The cumulative time is
> stored as uint64_t which
> will be plenty, as 32bit
> wouldn't be nearly enough.
> OVMS# *poller time on*
> Poller timing is now on
> OVMS# *poller time status*
> Poll [PRI] :
> n=390 tot=0.2s ave=0.586ms
> Poll [SRX] :
> n=316 tot=0.1s ave=0.196ms
> CAN1 RX[0778] :
> n=382 tot=0.2s ave=0.615ms
> CAN1 RX[07a8] :
> n=48 tot=0.0s ave=0.510ms
> CAN1 RX[07bb] :
> n=162 tot=0.1s ave=0.519ms
> CAN1 RX[07ce] :
> n=33 tot=0.0s ave=0.469ms
> CAN1 RX[07ea] :
> n=408 tot=0.2s ave=0.467ms
> CAN1 RX[07ec] :
> n=486 tot=0.2s ave=0.477ms
> CAN3 RX[07df] :
> n=769 tot=0.2s ave=0.261ms
> CAN1 TX[0770] :
> n=191 tot=0.0s ave=0.054ms
> CAN1 TX[07a0] :
> n=16 tot=0.0s ave=0.047ms
> CAN1 TX[07b3] :
> n=31 tot=0.0s ave=0.069ms
> CAN1 TX[07c6] :
> n=11 tot=0.0s ave=0.044ms
> CAN1 TX[07e2] :
> n=82 tot=0.0s ave=0.067ms
> CAN1 TX[07e4] :
> n=54 tot=0.0s ave=0.044ms
> Set State : n=7
> tot=0.0s ave=0.104ms
> This is probably going to
> be quite useful in
> general! The TX call-backs
> don't seem to be
> significant here. (oh, I
> should probably implement
> a reset of the values too).
> //.ichael
> On Sun, 12 May 2024 at
> 22:58, Michael Geddes
> wrote:
> Yeah - I certainly
> wasn't going to put a
> hard limit. Just a log
> above a certain time,
> that being said, the
> idea of just
> collecting stats
> (being able to turn it
> on via a "poller
> timer" set of
> commands) would be
> much more useful. I'll
> look into that.
> Average time is
> probably a good stat -
> and certainly what we
> care about.
> I actually am hopeful
> that those couple of
> things I did might
> help reduce that
> average time quite a
> bit (that
> short-cutting the
> isotp protocol
> handling especially).
> That p/r with logging
> changes might help
> reduce the
> unproductive log time
> further, but
> also makes it possible
> to turn on the poller
> logging without the RX
> task logs kicking in.
> //.ichael
> 22:29, Michael Balzer
> via OvmsDev
> wrote:
> Warning /
> gathering debug
> statistics about
> slow processing
> can be helpful,
> but there must not
> be a hard limit.
> Frame/poll
> response
> processing may
> need disk or
> network I/O, and
> the vehicle task
> may be starving
> from punctual high
> loads on higher
> priority tasks
> (e.g. networking)
> or by needing to
> wait for some
> semaphore --
> that's outside the
> application's
> control, and must
> not lead to
> termination/recreation
> of the task (in
> case you're
> heading towards
> that direction).
> I have no idea how
> much processing
> time the current
> vehicles actually
> need in their
> respective worst
> cases. Your draft
> is probably too
> lax, poll
> responses and
> frames normally
> need to be
> processed much
> faster. I'd say 10
> ms is already too
> slow, but any wait
> for a
> queue/semaphore
> will already mean
> at least 10 ms
> (FreeRTOS tick).
> Probably best to
> begin with just
> collecting stats.
> Btw, to help in
> narrowing down the
> actual problem
> case, the profiler
> could collect max
> times per RX
> message ID.
> Am 12.05.24 um
> 10:41 schrieb
> Michael Geddes:
> I have a
> question for
> Michael B (or
> whoever) - I
> have a commit
> lined up that
> would add a
> bit of a time
> check to the
> poller loop.
> What do we
> expect the
> maximum time
> to execute a
> poller loop
> command should
> be?
> This is a
> rough idea (in
> ms) I have..
> based on
> nothing much
> really, so any
> ideas would be
> appreciated:
> int
> TardyMaxTime_ms(OvmsPoller::OvmsPollEntryType
> entry_type)
> switch
> (entry_type)
> case
> OvmsPoller::OvmsPollEntryType::Poll:
> return 80;
> case
> OvmsPoller::OvmsPollEntryType::FrameRx:
> return 30;
> case
> OvmsPoller::OvmsPollEntryType::FrameTx:
> return 20;
> case
> OvmsPoller::OvmsPollEntryType::Command:
> return 10;
> case
> OvmsPoller::OvmsPollEntryType::PollState:
> return 15;
> default:
> return 80;
> //.ichael
> On Mon, 6 May
> 2024 at 07:45,
> Michael Geddes
> wrote:
> I realise
> that I was
> only using
> the
> standard
> cable to
> test -
> which
> probably is
> not
> sufficient
> - I
> haven't
> looked
> closely at
> how the
> Leaf OBD
> to Db9
> cable is
> different
> from standard.
> Ah, my bad
> out the
> queue
> length.
> We are
> definitely
> queueing
> more
> messages
> though.
> From my
> log of
> when the
> overflow
> happened,
> the poller
> was in
> state 0
> which
> means OFF
> - ie
> nothing
> was being
> sent!!
> I'll look
> at the TX
> message
> thing -
> opt in
> sounds
> good -
> though it
> shouldn't
> be playing
> that much
> of a part
> here as
> the TXs
> are
> infrequent
> in this
> case (or
> zero when
> the leaf
> is off
> or driving)
> - On the
> ioniq 5
> when I'm
> using the
> HUD - I'm
> polling
> quite
> frequently
> - multiple
> times per
> second and
> that seems
> to be fine!.
> I did find
> an issue
> with the
> throttling ..
> but it
> would
> still
> mostly
> apply the
> throttling
> where it
> matters,
> so again,
> it
> shouldn't
> be the
> problem
> (also, we
> aren't
> transmitting
> in the
> leaf case).
> The change
> I made to
> the
> logging of
> RX
> messages
> showed how
> many in a
> row were
> dropped...
> and it was
> mostly 1
> only in a
> run -
> which
> means even
> if it is a
> short time
> between -
> that means
> that the
> drops are
> being
> interleaved
> by at
> least one
> success!
> Sooo.. I'm
> still
> wondering
> what is
> going on.
> Some
> things I'm
> going to try:
> * If the
> number of
> messages
> on the Can
> bus
> (coming in
> through
> RX) means
> that the
> queue is
> slowly
> getting
> longer and
> not quite
> catching
> up, then
> making the
> queue
> longer
> will help
> it last
> longer...
> but only
> pushes the
> problem
> down the road.
> - Add
> 'current
> queue
> length' to
> the poller
> status
> information
> to see if
> this is
> indeed the
> case?
> - Add
> some kind
> of alert
> when the
> queue
> reaches a
> % full?
> * Once you
> start
> overflowing
> and
> getting
> overflow
> log
> messages,
> I wonder
> if this is
> then
> contributing
> to the
> problem.
> - Push
> the
> overflow
> logging
> into
> Poller
> Task which
> can look
> at how
> many drops
> occurred
> since last
> received item.
> * Split up
> the flags
> for the
> poller
> messages
> into 2:
> Messages
> that
> are/could
> be
> happening
> in the
> TX/RX tasks
> - Other
> noisy
> messages
> that
> always
> happen in
> the poller
> task.
> Thoughts
> on what
> else we
> might
> measure to
> figure out
> what is
> going on?
> //.ichael
> On Sun, 5
> May 2024,
> 19:29
> Balzer via
> OvmsDev,
> wrote:
> Michael,
> the
> queue
> size
> isn't
> in
> bytes,
> it's
> in
> messages:
> @param
> uxQueueLength
> The
> maximum
> number
> of
> items
> that
> the
> queue
> can
> contain.
> @param
> uxItemSize
> The
> number
> of
> bytes
> each
> item
> in
> the
> queue
> will
> require.
> Also,
> from
> the
> time
> stamps
> in
> Dereks
> log
> excerpt,
> there
> were
> quite
> some
> dropped
> frames
> in
> that
> time
> window
> -- at
> least
> 23
> frames
> in 40
> ms,
> that's
> bad.
> Queue
> sizes
> are
> currently:
> CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=60
> CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=60
> The
> new
> poller
> now
> channels
> all TX
> callbacks
> through
> the
> task
> queue
> additionally
> to RX
> and
> commands.
> So
> setting
> the
> queue
> size
> to be
> larger
> than
> the
> CAN RX
> queue
> size
> seems
> appropriate.
> Nevertheless,
> an
> overflow
> with
> more
> than
> 60
> waiting
> messages
> still
> indicates
> some
> too
> long
> processing
> time
> in the
> vehicle
> task.
> TX
> callbacks
> previously
> were
> done
> directly
> in the
> CAN
> context,
> and no
> current
> vehicle
> overrides
> the
> empty
> default
> handler,
> so
> this
> imposed
> almost
> no
> additional
> overhead.
> By
> requiring
> a
> queue
> entry
> for
> each
> TX
> callback,
> this
> feature
> now
> has a
> potentially
> high
> impact
> for
> all
> vehicles.
> If
> passing
> these
> to the
> task
> is
> actually
> necessary,
> it
> needs
> to
> become
> an
> opt-in
> feature,
> so
> only
> vehicles
> subscribing
> to the
> callback
> actually
> need
> to
> cope
> with
> that
> additional
> load &
> potential
> processing
> delays
> involved.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240526/e3a1b53a/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240526/e3a1b53a/attachment-0001.sig>
