Sun May 26 19:37:57 HKT 2024
As the averages quickly decline when idle, an automatic report should
probably also be sent on charge stop.
Also, I think you should automatically reset the timer statistics on
drive & charge start.
First stats from charging my UpMiiGo:
Type | count | Utlztn | Time
| per s | [‰] | [ms]
Poll:PRI Avg| 1.00| 0.723| 0.716
Peak| | 1.282| 3.822
Poll:SRX Avg| 7.72| 1.246| 0.184
Peak| | 3.128| 1.058
RxCan1[7ae] Avg| 2.48| 0.915| 0.362
Peak| | 1.217| 1.661
RxCan1[7cf] Avg| 4.76| 1.928| 0.397
Peak| | 2.317| 2.687
RxCan1[7ed] Avg| 3.38| 1.251| 0.327
Peak| | 8.154| 12.273
RxCan1[7ee] Avg| 0.21| 0.066| 0.297
Peak| | 0.225| 1.690
TxCan1[744] Avg| 1.49| 0.022| 0.011
Peak| | 0.032| 0.095
TxCan1[765] Avg| 3.89| 0.134| 0.027
Peak| | 0.155| 0.113
TxCan1[7e5] Avg| 2.32| 0.038| 0.013
Peak| | 0.295| 0.084
TxCan1[7e6] Avg| 0.21| 0.002| 0.008
Peak| | 0.010| 0.041
Cmd:State Avg| 0.00| 0.000| 0.007
Peak| | 0.005| 0.072
Total Avg| 27.46| 6.324| 2.349
Overall healthy I'd say, but let's see how it compares.
7ed is the BMS, the peak time is probably related to the extended cell
data logging -- I've enabled log intervals for both cell voltages &
temperatures.
Am 26.05.24 um 08:42 schrieb Michael Balzer via OvmsDev:
> The notification works on my devices, it only has a garbled per mille
> character -- see attached screenshot. The same applies to the mail
> version:
>> Poller timing is: on
>> | per s | [‰] | [ms]
>> Poll:PRI Avg| 0.25| 0.119| 0.382
>> Peak| | 0.513| 0.678
>> RxCan1[597] Avg| 0.01| 0.004| 0.021
>> Peak| | 0.000| 0.338
>> RxCan1[59b] Avg| 0.01| 0.011| 0.053
>> Peak| | 0.000| 0.848
>> Cmd:State Avg| 0.01| 0.002| 0.012
>> Peak| | 0.000| 0.120
>> Total Avg| 0.28| 0.135| 0.468
> The encoding is a general issue. The character encoding for text
> messages via V2/MP is quite old & clumsy, it's got an issue with the
> degree celcius character as well. We previously tried to keep all text
> messages within the SMS safe character set (which e.g. lead to writing
> just "C" instead of "°C"). I'd say we should head towards UTF-8 now.
> If we ever refit SMS support, we can recode on the fly.
> Regarding not seeing the notification on your phone:
> a) Check your notification subtype/channel filters on the module. See
> https://docs.openvehicles.com/en/latest/userguide/notifications.html#suppress-notifications
> b) Check your notification vehicle filters on the phone (menu on
> notification tab): if you enabled the vehicle filter, it will add the
> messages of not currently selected vehicles to the list only, but not
> raise a system notification. (Applies to the Android App, no idea
> about the iOS version)
> Am 26.05.24 um 06:32 schrieb Michael Geddes:
>> Hi,
>> I'm trying to finalise this now .. and one last thing is that I don't
>> get the report coming to my mobile. I'm using the command:
>> MyNotify.NotifyString("info", "poller.report", buf.c_str());
>> Where the buffer string is just the same as the report output.
>> Should I be using some other format or command?
>> I get "alert" types (like the ioniq5 door-open alert) fine to my mobile.
>> Michael.
>> On Sun, 19 May 2024, 12:51 Michael Balzer via OvmsDev,
>> <ovmsdev at lists.openvehicles.com> wrote:
>> A builtin web UI for this seems a bit over the top. Builtin web
>> config pages should focus on user features, this is clearly a
>> feature only needed during/for the development/extension of a
>> vehicle adapter. Development features in the web UI are confusing
>> for end users.
>> If persistent enabling/disabling is done by a simple config
>> command (e.g. "config set can poller.trace on"), that's also
>> doable by users.
>> Am 19.05.24 um 02:06 schrieb Michael Geddes:
>>> I was so focused on how I calculated the value that I totally
>>> missed that ‰ would be a better description. I could also use
>>> the system 'Ratio' unit... so % or ‰.
>>> I'll make space to put 'Avg' on the row. Was trying to limit
>>> the width for output on a mobile. I agree it would make it
>>> easier to understand.
>>> Totals also makes sense.
>>> Should I make this a configuration that can be set on the
>>> web-page? I'd probably use a configuration change notification
>>> so that the very bit setting is sync'd with the 'configuration'
>>> value.
>>> //.ichael
>>> On Sat, 18 May 2024, 14:05 Michael Balzer, <dexter at expeedo.de>
>>> wrote:
>>>> I'm not sure whether the 'max' should be the maximum of the
>>>> smoothed value.. or the maximum of the raw value.
>>> It should normally be the maximum of the raw value I think,
>>> the maximum of the smoothed value cannot tell about how bad
>>> the processing of an ID can become.
>>> The naming in the table is a bit confusing I think.
>>> (besides: I've never seen "ave" as the abbreviation for average)
>>> If I understand you correctly, "time ms per s" is the time
>>> share in per mille, so something in that direction would be
>>> more clear, and "length ms" would then be "time [ms]".
>>> The totals for all averages in the table foot would also be
>>> nice.
>>> Maybe "Ave" (or avg?) also should be placed on the left, as
>>> the "peak" label now suggests being the peak of the average.
>>> Btw, keep in mind, not all "edge" users / testers are
>>> developers (e.g. the Twizy driver I'm in contact with),
>>> collecting stats feedback for vehicles from testers should
>>> be straight forward. Maybe add a data/history record, sent
>>> automatically on every drive/charge stop when the poller
>>> tracing is on?
>>> Am 18.05.24 um 02:28 schrieb Michael Geddes:
>>>> You did say max/pead value. I also halved the N for both.
>>>> This is currently the raw-value maximum.
>>>> The problem is that the middle column is the maximum of the
>>>> {{sum over 10s} / (10*1000,000)
>>>> I could easily change the 'period' to 1s and see how that
>>>> goes.. was just trying to reduce the larger calculations.
>>>> Usage: poller [pause|resume|status|times|trace]
>>>> OVMS# poller time status
>>>> Type | Count | Ave time | Ave length
>>>> | per s | ms per s | ms
>>>> Poll:PRI | 1.00| 0.559| 0.543
>>>> peak | | 0.663| 1.528
>>>> Poll:SRX | 0.08| 0.009| 0.038
>>>> peak | | 0.068| 0.146
>>>> CAN1 RX[778] | 0.11| 0.061| 0.280
>>>> peak | | 0.458| 1.046
>>>> CAN1 RX[7a8] | 0.04| 0.024| 0.124
>>>> peak | | 0.160| 0.615
>>>> CAN1 TX[770] | 0.05| 0.004| 0.016
>>>> peak | | 0.022| 0.102
>>>> CAN1 TX[7a0] | 0.02| 0.002| 0.011
>>>> peak | | 0.010| 0.098
>>>> CAN1 TX[7b3] | 0.01| 0.001| 0.006
>>>> peak | | 0.000| 0.099
>>>> CAN1 TX[7e2] | 0.02| 0.002| 0.011
>>>> peak | | 0.010| 0.099
>>>> CAN1 TX[7e4] | 0.08| 0.008| 0.048
>>>> peak | | 0.049| 0.107
>>>> Cmd:State | 0.00| 0.000| 0.005
>>>> peak | | 0.000| 0.094
>>>> On Fri, 17 May 2024 at 15:26, Michael Geddes
>>>> <frog at bunyip.wheelycreek.net> wrote:
>>>> This is what I have now.
>>>> The one on the end is the one MIchael B was after using
>>>> an N of 32. (up for discussion).
>>>> The middle is the time spent in that even t per
>>>> second. It accumulates times (in microseconds), and
>>>> then every 10s it stores it as smoothed (N=16) value.
>>>> The Count is similar (except that we store a value of
>>>> '100' as 1 event so it can be still integers and has 2
>>>> decimal places).
>>>> Every received poll does a 64bit difference to 32bit
>>>> (for the elapsed time) and 64bit comparison (for
>>>> end-of-period).
>>>> It also does 1x 32bit smoothing and 2x 32bit adds.
>>>> Then at the end of a 10s period, it will do a 64bit add
>>>> to get the next end-of-period value, as well as the 2x
>>>> 32bit smoothing calcs.
>>>> This is from the Ioniq 5 so not any big values yet.
>>>> You can certainly see how insignificant the TX
>>>> callbacks are.
>>>> I'll leave it on for when the car is moving and gets
>>>> some faster polling.
>>>> OVMS# poll time status
>>>> Type | Count | Ave time | Ave Length
>>>> Poll:PRI | 1.00| 0.540| 0.539
>>>> Poll:SRX | 0.03| 0.004| 0.017
>>>> CAN1 RX[778] | 0.06| 0.042| 0.175
>>>> CAN1 TX[770] | 0.04| 0.002| 0.008
>>>> Cmd:State | 0.01| 0.001| 0.005
>>>> ----------------------8<--------------------------------
>>>> Nice smoothing class (forces N as a power of 2):
>>>> constexpr unsigned floorlog2(unsigned x)
>>>> return x == 1 ? 0 : 1+floorlog2(x >> 1);
>>>> /* Maintain a smoothed average using shifts for division.
>>>> * T should be an integer type
>>>> * N needs to be a power of 2
>>>> template <typename T, unsigned N>
>>>> class average_util_t
>>>> private:
>>>> T m_ave;
>>>> public:
>>>> average_util_t() : m_ave(0) {}
>>>> static const uint8_t _BITS = floorlog2(N);
>>>> void add( T val)
>>>> static_assert(N == (1 << _BITS), "N must be a
>>>> power of 2");
>>>> m_ave = (((N-1) * m_ave) + val) >> _BITS;
>>>> T get() { return m_ave; }
>>>> operator T() { return m_ave; }
>>>> On Thu, 16 May 2024 at 10:29, Michael Geddes
>>>> Thanks Michael,
>>>> My calculations give me ((2^32)-1) /
>>>> (1000*1000*3600) = only 1.2 hours of processing
>>>> time in 32bit. The initial subtraction is 64bit
>>>> anyway and I can't see a further 64bit addition
>>>> being a problem. I have the calculations being
>>>> performed in doubles at print-out where performance
>>>> is not really an issue anyway. (Though apparently
>>>> doing 64 bit division is worse than floating point).
>>>> In addition
>>>> * I currently have this being able to be turned on
>>>> and off and reset manually (only do it when required).
>>>> * For the lower volume commands, the smoothed
>>>> average is not going to be useful - the count is
>>>> more interesting for different reasons.
>>>> * The total time is quite useful. Ie a high average
>>>> time doesn't matter if the count is low. The
>>>> things that are affecting performance are stuff
>>>> with high total time. Stuff which is happening 100
>>>> times a second needs to be a much lower average
>>>> than once a second.
>>>> * A measure like 'time per minute/second' and
>>>> possibly count per minute/seconds as a
>>>> smoothed average would potentially be more useful.
>>>> (or in addition?)
>>>> I think we could do _that_ in a reasonably
>>>> efficient manner using a 64 bit 'last measured
>>>> time', a 32 bit accumulated value and the stored 32
>>>> bit rolling average.
>>>> It would boils down to some iterative (integer)
>>>> sums and multiplications plus a divide by n ^ (time
>>>> periods passed) - which is a shift - and which can
>>>> be optimised to '0' if 'time-periods-passed' is
>>>> more than 32/(bits-per-n) - effectively limiting
>>>> the number of iterations.
>>>> The one issue I can see is that we need to
>>>> calculate 'number of time-periods passed' which is
>>>> a 64 bit subtraction followed by a 32 bit division
>>>> (not optimisable to a simple shift).
>>>> * I'm also happy to keep a rolling (32bit) average
>>>> time.
>>>> Even if you assume averages in the 100ms, 32bit
>>>> is going to happily support an N of 64 or even 128.
>>>> Am I right in thinking that the choice of N is
>>>> highly dependent on frequency. For things happening
>>>> 100 times per second, you might want an N like
>>>> 128.. where things happening once per
>>>> second, you might want an N of 4 or 8. The
>>>> other things we keep track of in this manner we
>>>> have a better idea of the frequency of the thing.
>>>> How about we have (per record type):
>>>> * total count (since last reset?) (32 bit)
>>>> * smoothed average of time per instance (32 bit)
>>>> * ?xx? total accumulated time since last reset
>>>> (64bit) ?? <-- with the below stats this is much
>>>> less useful
>>>> * last-measured-time (64 bit)
>>>> * accumulated count since last time-period (16bit
>>>> - but maybe 32bit anyway for byte alignment?)
>>>> * smoothed average of count per time-period (32bit)
>>>> * accumulated time since last time-period (32bit)
>>>> * smoothed average of time per time-period (32bit)
>>>> It's possible to keep the
>>>> Is this going to be too much per record type? The
>>>> number of 'records' we are keeping is quite low (so
>>>> 10 to 20 maybe) - so it's not a huge memory burden.
>>>> Thoughts?
>>>> //.ichael
>>>> On Thu, 16 May 2024 at 03:09, Michael Balzer via
>>>> OvmsDev <ovmsdev at lists.openvehicles.com> wrote:
>>>> esp_timer_get_time() is the right choice for
>>>> precision timing.
>>>> I'd say uint32 is enough though, even if
>>>> counting microseconds that can hold a total of
>>>> more than 71 hours of actual processing time.
>>>> uint64 has a significant performance penalty,
>>>> although I don't recall the overhead for simple
>>>> additions.
>>>> Also & more important, the average wouldn't be
>>>> my main focus, but the maximum processing time
>>>> seen per ID, which seems to be missing in your
>>>> draft.
>>>> Second thought on the average… the exact
>>>> overall average really has a minor meaning, I'd
>>>> rather see the current average, adapting to the
>>>> current mode of operation (drive/charge/…). I
>>>> suggest feeding the measurements to a low pass
>>>> filter to get the smoothed average of the last
>>>> n measurements. Pattern:
>>>> runavg = ((N-1) * runavg + newval) / N
>>>> By using a low power of 2 for N (e.g. 8 or 16),
>>>> you can replace the division by a simple bit
>>>> shift, and have enough headroom to use 32 bit
>>>> integers.
>>>> Regards,
>>>> Michael
>>>> Am 15.05.24 um 06:51 schrieb Michael Geddes via
>>>> OvmsDev:
>>>>> Formatting aside, I have implemented what I
>>>>> think Michael B was suggesting. This is a
>>>>> sample run on the Ioniq 5 (which doesn't have
>>>>> unsolicited RX events).
>>>>> This uses the call esp_timer_get_time() got
>>>>> get a 64bit *microseconds* since started value
>>>>> - and works out the time to execute that way.
>>>>> It's looking at absolute time and not time in
>>>>> the Task - so other things going on at the
>>>>> same time in other tasks will have an effect.
>>>>> (The normal tick count doesn't have nearly
>>>>> enough resolution to be useful - any other
>>>>> ideas on measurement?) I've got total
>>>>> accumulated time displaying in seconds and the
>>>>> average in milliseconds currently - but I can
>>>>> change that easy enough.
>>>>> The cumulative time is stored as uint64_t
>>>>> which will be plenty, as 32bit wouldn't be
>>>>> nearly enough.
>>>>> OVMS# *poller time on*
>>>>> Poller timing is now on
>>>>> OVMS# *poller time status*
>>>>> Poll [PRI] : n=390 tot=0.2s ave=0.586ms
>>>>> Poll [SRX] : n=316 tot=0.1s ave=0.196ms
>>>>> CAN1 RX[0778] : n=382 tot=0.2s
>>>>> ave=0.615ms
>>>>> CAN1 RX[07a8] : n=48 tot=0.0s
>>>>> ave=0.510ms
>>>>> CAN1 RX[07bb] : n=162 tot=0.1s
>>>>> ave=0.519ms
>>>>> CAN1 RX[07ce] : n=33 tot=0.0s
>>>>> ave=0.469ms
>>>>> CAN1 RX[07ea] : n=408 tot=0.2s
>>>>> ave=0.467ms
>>>>> CAN1 RX[07ec] : n=486 tot=0.2s
>>>>> ave=0.477ms
>>>>> CAN3 RX[07df] : n=769 tot=0.2s
>>>>> ave=0.261ms
>>>>> CAN1 TX[0770] : n=191 tot=0.0s
>>>>> ave=0.054ms
>>>>> CAN1 TX[07a0] : n=16 tot=0.0s
>>>>> ave=0.047ms
>>>>> CAN1 TX[07b3] : n=31 tot=0.0s
>>>>> ave=0.069ms
>>>>> CAN1 TX[07c6] : n=11 tot=0.0s
>>>>> ave=0.044ms
>>>>> CAN1 TX[07e2] : n=82 tot=0.0s
>>>>> ave=0.067ms
>>>>> CAN1 TX[07e4] : n=54 tot=0.0s
>>>>> ave=0.044ms
>>>>> Set State : n=7 tot=0.0s ave=0.104ms
>>>>> This is probably going to be quite useful in
>>>>> general! The TX call-backs don't seem to be
>>>>> significant here. (oh, I should probably
>>>>> implement a reset of the values too).
>>>>> //.ichael
>>>>> On Sun, 12 May 2024 at 22:58, Michael Geddes
>>>>> Yeah - I certainly wasn't going to put a
>>>>> hard limit. Just a log above a certain
>>>>> time, that being said, the idea of just
>>>>> collecting stats (being able to turn it on
>>>>> via a "poller timer" set of commands)
>>>>> would be much more useful. I'll look into
>>>>> that.
>>>>> Average time is probably a good stat - and
>>>>> certainly what we care about.
>>>>> I actually am hopeful that those couple of
>>>>> things I did might help reduce that
>>>>> average time quite a bit (that
>>>>> short-cutting the isotp protocol handling
>>>>> especially).
>>>>> That p/r with logging changes might help
>>>>> reduce the unproductive log time further,
>>>>> but also makes it possible to turn on the
>>>>> poller logging without the RX task logs
>>>>> kicking in.
>>>>> //.ichael
>>>>> On Sun, 12 May 2024 at 22:29, Michael
>>>>> Balzer via OvmsDev
>>>>> Warning / gathering debug statistics
>>>>> about slow processing can be helpful,
>>>>> but there must not be a hard limit.
>>>>> Frame/poll response processing may
>>>>> need disk or network I/O, and the
>>>>> vehicle task may be starving from
>>>>> punctual high loads on higher priority
>>>>> tasks (e.g. networking) or by needing
>>>>> to wait for some semaphore -- that's
>>>>> outside the application's control, and
>>>>> must not lead to
>>>>> termination/recreation of the task (in
>>>>> case you're heading towards that
>>>>> direction).
>>>>> I have no idea how much processing
>>>>> time the current vehicles actually
>>>>> need in their respective worst cases.
>>>>> Your draft is probably too lax, poll
>>>>> responses and frames normally need to
>>>>> be processed much faster. I'd say 10
>>>>> ms is already too slow, but any wait
>>>>> for a queue/semaphore will already
>>>>> mean at least 10 ms (FreeRTOS tick).
>>>>> Probably best to begin with just
>>>>> collecting stats.
>>>>> Btw, to help in narrowing down the
>>>>> actual problem case, the profiler
>>>>> could collect max times per RX message ID.
>>>>> Regards,
>>>>> Michael
>>>>> Am 12.05.24 um 10:41 schrieb Michael
>>>>> Geddes:
>>>>>> I have a question for Michael B (or
>>>>>> whoever) - I have a commit lined up
>>>>>> that would add a bit of a time check
>>>>>> to the poller loop. What do we expect
>>>>>> the maximum time to execute a poller
>>>>>> loop command should be?
>>>>>> This is a rough idea (in ms) I have..
>>>>>> based on nothing much really, so any
>>>>>> ideas would be appreciated:
>>>>>> int
>>>>>> TardyMaxTime_ms(OvmsPoller::OvmsPollEntryType
>>>>>> entry_type)
>>>>>> switch (entry_type)
>>>>>> case
>>>>>> OvmsPoller::OvmsPollEntryType::Poll:
>>>>>> return 80;
>>>>>> case
>>>>>> OvmsPoller::OvmsPollEntryType::FrameRx:
>>>>>> return 30;
>>>>>> case
>>>>>> OvmsPoller::OvmsPollEntryType::FrameTx:
>>>>>> return 20;
>>>>>> case
>>>>>> OvmsPoller::OvmsPollEntryType::Command:
>>>>>> return 10;
>>>>>> case
>>>>>> OvmsPoller::OvmsPollEntryType::PollState:
>>>>>> return 15;
>>>>>> default: return 80;
>>>>>> //.ichael
>>>>>> On Mon, 6 May 2024 at 07:45, Michael
>>>>>> Geddes <frog at bunyip.wheelycreek.net>
>>>>>> wrote:
>>>>>> I realise that I was only using
>>>>>> the standard cable to test -
>>>>>> which probably is not sufficient
>>>>>> - I haven't looked closely at how
>>>>>> the Leaf OBD to Db9 cable is
>>>>>> different from standard.
>>>>>> Ah, my bad out the queue length.
>>>>>> We are definitely queueing more
>>>>>> messages though. From my log of
>>>>>> when the overflow happened, the
>>>>>> poller was in state 0 which means
>>>>>> OFF - ie nothing was being sent!!
>>>>>> I'll look at the TX message thing
>>>>>> - opt in sounds good - though it
>>>>>> shouldn't be playing that much of
>>>>>> a part here as the TXs are
>>>>>> infrequent in this case (or zero
>>>>>> when the leaf is off or driving)
>>>>>> - On the ioniq 5 when I'm using
>>>>>> the HUD - I'm polling quite
>>>>>> frequently - multiple times per
>>>>>> second and that seems to be fine!.
>>>>>> I did find an issue with the
>>>>>> throttling .. but it would still
>>>>>> mostly apply the throttling where
>>>>>> it matters, so again, it
>>>>>> shouldn't be the problem (also,
>>>>>> we aren't transmitting in the
>>>>>> leaf case).
>>>>>> The change I made to the logging
>>>>>> of RX messages showed how many in
>>>>>> a row were dropped... and it was
>>>>>> mostly 1 only in a run - which
>>>>>> means even if it is a short time
>>>>>> between - that means that the
>>>>>> drops are being interleaved by at
>>>>>> least one success!
>>>>>> Sooo.. I'm still wondering what
>>>>>> is going on. Some things I'm
>>>>>> going to try:
>>>>>> * If the number of messages on
>>>>>> the Can bus (coming in through
>>>>>> RX) means that the queue is
>>>>>> slowly getting longer and not
>>>>>> quite catching up, then making
>>>>>> the queue longer will help it
>>>>>> last longer... but only pushes
>>>>>> the problem down the road.
>>>>>> - Add 'current queue length' to
>>>>>> the poller status information to
>>>>>> see if this is indeed the case?
>>>>>> - Add some kind of alert when
>>>>>> the queue reaches a % full?
>>>>>> * Once you start overflowing and
>>>>>> getting overflow log messages, I
>>>>>> wonder if this is then
>>>>>> contributing to the problem.
>>>>>> - Push the overflow logging
>>>>>> into Poller Task which can look
>>>>>> at how many drops occurred since
>>>>>> last received item.
>>>>>> * Split up the flags for the
>>>>>> poller messages into 2:
>>>>>> - Messages that are/could be
>>>>>> happening in the TX/RX tasks
>>>>>> - Other noisy messages that
>>>>>> always happen in the poller task.
>>>>>> Thoughts on what else we might
>>>>>> measure to figure out what is
>>>>>> going on?
>>>>>> //.ichael
>>>>>> On Sun, 5 May 2024, 19:29 Michael
>>>>>> Balzer via OvmsDev,
>>>>>> wrote:
>>>>>> Michael,
>>>>>> the queue size isn't in
>>>>>> bytes, it's in messages:
>>>>>>> * @param uxQueueLength The
>>>>>>> maximum number of items that
>>>>>>> the queue can contain.
>>>>>>> * @param uxItemSize The
>>>>>>> number of bytes each item in
>>>>>>> the queue will require.
>>>>>> Also, from the time stamps in
>>>>>> Dereks log excerpt, there
>>>>>> were quite some dropped
>>>>>> frames in that time window --
>>>>>> at least 23 frames in 40 ms,
>>>>>> that's bad.
>>>>>> Queue sizes are currently:
>>>>>> CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=60
>>>>>> CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=60
>>>>>> The new poller now channels
>>>>>> all TX callbacks through the
>>>>>> task queue additionally to RX
>>>>>> and commands. So setting the
>>>>>> queue size to be larger than
>>>>>> the CAN RX queue size seems
>>>>>> appropriate.
>>>>>> Nevertheless, an overflow
>>>>>> with more than 60 waiting
>>>>>> messages still indicates some
>>>>>> too long processing time in
>>>>>> the vehicle task.
>>>>>> TX callbacks previously were
>>>>>> done directly in the CAN
>>>>>> context, and no current
>>>>>> vehicle overrides the empty
>>>>>> default handler, so this
>>>>>> imposed almost no additional
>>>>>> overhead. By requiring a
>>>>>> queue entry for each TX
>>>>>> callback, this feature now
>>>>>> has a potentially high impact
>>>>>> for all vehicles. If passing
>>>>>> these to the task is actually
>>>>>> necessary, it needs to become
>>>>>> an opt-in feature, so only
>>>>>> vehicles subscribing to the
>>>>>> callback actually need to
>>>>>> cope with that additional
>>>>>> load & potential processing
>>>>>> delays involved.
>>>>>> Regards,
>>>>>> Michael
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240526/16eb96ee/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240526/16eb96ee/attachment-0001.sig>
