Thu May 16 03:08:40 HKT 2024
esp_timer_get_time() is the right choice for precision timing.
I'd say uint32 is enough though, even if counting microseconds that can
hold a total of more than 71 hours of actual processing time. uint64 has
a significant performance penalty, although I don't recall the overhead
for simple additions.
Also & more important, the average wouldn't be my main focus, but the
maximum processing time seen per ID, which seems to be missing in your
draft.
Second thought on the average… the exact overall average really has a
minor meaning, I'd rather see the current average, adapting to the
current mode of operation (drive/charge/…). I suggest feeding the
measurements to a low pass filter to get the smoothed average of the
last n measurements. Pattern:
runavg = ((N-1) * runavg + newval) / N
By using a low power of 2 for N (e.g. 8 or 16), you can replace the
division by a simple bit shift, and have enough headroom to use 32 bit
integers.
Am 15.05.24 um 06:51 schrieb Michael Geddes via OvmsDev:
> Formatting aside, I have implemented what I think Michael B was
> suggesting. This is a sample run on the Ioniq 5 (which doesn't have
> unsolicited RX events).
> This uses the call esp_timer_get_time() got get a 64bit *microseconds*
> since started value - and works out the time to execute that way. It's
> looking at absolute time and not time in the Task - so other things
> going on at the same time in other tasks will have an effect. (The
> normal tick count doesn't have nearly enough resolution to be useful -
> any other ideas on measurement?) I've got total accumulated time
> displaying in seconds and the average in milliseconds currently - but
> I can change that easy enough.
> The cumulative time is stored as uint64_t which will be plenty, as
> 32bit wouldn't be nearly enough.
> OVMS# *poller time on*
> Poller timing is now on
> OVMS# *poller time status*
> Poller timing is: on
> Poll [PRI] : n=390 tot=0.2s ave=0.586ms
> Poll [SRX] : n=316 tot=0.1s ave=0.196ms
> CAN1 RX[0778] : n=382 tot=0.2s ave=0.615ms
> CAN1 RX[07a8] : n=48 tot=0.0s ave=0.510ms
> CAN1 RX[07bb] : n=162 tot=0.1s ave=0.519ms
> CAN1 RX[07ce] : n=33 tot=0.0s ave=0.469ms
> CAN1 RX[07ea] : n=408 tot=0.2s ave=0.467ms
> CAN1 RX[07ec] : n=486 tot=0.2s ave=0.477ms
> CAN3 RX[07df] : n=769 tot=0.2s ave=0.261ms
> CAN1 TX[0770] : n=191 tot=0.0s ave=0.054ms
> CAN1 TX[07a0] : n=16 tot=0.0s ave=0.047ms
> CAN1 TX[07b3] : n=31 tot=0.0s ave=0.069ms
> CAN1 TX[07c6] : n=11 tot=0.0s ave=0.044ms
> CAN1 TX[07e2] : n=82 tot=0.0s ave=0.067ms
> CAN1 TX[07e4] : n=54 tot=0.0s ave=0.044ms
> Set State : n=7 tot=0.0s ave=0.104ms
> This is probably going to be quite useful in general! The TX
> call-backs don't seem to be significant here. (oh, I should probably
> implement a reset of the values too).
> //.ichael
> On Sun, 12 May 2024 at 22:58, Michael Geddes
> <frog at bunyip.wheelycreek.net> wrote:
> Yeah - I certainly wasn't going to put a hard limit. Just a log
> above a certain time, that being said, the idea of just collecting
> stats (being able to turn it on via a "poller timer" set of
> commands) would be much more useful. I'll look into that.
> Average time is probably a good stat - and certainly what we care
> about.
> I actually am hopeful that those couple of things I did might help
> reduce that average time quite a bit (that short-cutting the isotp
> protocol handling especially).
> That p/r with logging changes might help reduce the unproductive
> log time further, but also makes it possible to turn on the poller
> logging without the RX task logs kicking in.
> //.ichael
> On Sun, 12 May 2024 at 22:29, Michael Balzer via OvmsDev
> <ovmsdev at lists.openvehicles.com> wrote:
> Warning / gathering debug statistics about slow processing can
> be helpful, but there must not be a hard limit. Frame/poll
> response processing may need disk or network I/O, and the
> vehicle task may be starving from punctual high loads on
> higher priority tasks (e.g. networking) or by needing to wait
> for some semaphore -- that's outside the application's
> control, and must not lead to termination/recreation of the
> task (in case you're heading towards that direction).
> I have no idea how much processing time the current vehicles
> actually need in their respective worst cases. Your draft is
> probably too lax, poll responses and frames normally need to
> be processed much faster. I'd say 10 ms is already too slow,
> but any wait for a queue/semaphore will already mean at least
> 10 ms (FreeRTOS tick). Probably best to begin with just
> collecting stats.
> Btw, to help in narrowing down the actual problem case, the
> profiler could collect max times per RX message ID.
> Am 12.05.24 um 10:41 schrieb Michael Geddes:
>> I have a question for Michael B (or whoever) - I have a
>> commit lined up that would add a bit of a time check to the
>> poller loop. What do we expect the maximum time to execute a
>> poller loop command should be?
>> This is a rough idea (in ms) I have.. based on nothing much
>> really, so any ideas would be appreciated:
>> int TardyMaxTime_ms(OvmsPoller::OvmsPollEntryType entry_type)
>> switch (entry_type)
>> case OvmsPoller::OvmsPollEntryType::Poll: return 80;
>> case OvmsPoller::OvmsPollEntryType::FrameRx: return 30;
>> case OvmsPoller::OvmsPollEntryType::FrameTx: return 20;
>> case OvmsPoller::OvmsPollEntryType::Command: return 10;
>> case OvmsPoller::OvmsPollEntryType::PollState: return 15;
>> default: return 80;
>> //.ichael
>> On Mon, 6 May 2024 at 07:45, Michael Geddes
>> I realise that I was only using the standard cable to
>> test - which probably is not sufficient - I haven't
>> looked closely at how the Leaf OBD to Db9 cable is
>> different from standard.
>> Ah, my bad out the queue length. We are definitely
>> queueing more messages though. From my log of when the
>> overflow happened, the poller was in state 0 which means
>> OFF - ie nothing was being sent!!
>> I'll look at the TX message thing - opt in sounds good -
>> though it shouldn't be playing that much of a part here
>> as the TXs are infrequent in this case (or zero when the
>> leaf is off or driving) - On the ioniq 5 when I'm using
>> the HUD - I'm polling quite frequently - multiple times
>> per second and that seems to be fine!.
>> I did find an issue with the throttling .. but it would
>> still mostly apply the throttling where it matters, so
>> again, it shouldn't be the problem (also, we aren't
>> transmitting in the leaf case).
>> The change I made to the logging of RX messages showed
>> how many in a row were dropped... and it was mostly 1
>> only in a run - which means even if it is a short time
>> between - that means that the drops are being interleaved
>> by at least one success!
>> Sooo.. I'm still wondering what is going on. Some things
>> I'm going to try:
>> * If the number of messages on the Can bus (coming in
>> through RX) means that the queue is slowly getting longer
>> and not quite catching up, then making the queue longer
>> will help it last longer... but only pushes the problem
>> down the road.
>> - Add 'current queue length' to the poller status
>> information to see if this is indeed the case?
>> - Add some kind of alert when the queue reaches a % full?
>> * Once you start overflowing and getting overflow log
>> messages, I wonder if this is then contributing to the
>> problem.
>> - Push the overflow logging into Poller Task which can
>> look at how many drops occurred since last received item.
>> * Split up the flags for the poller messages into 2:
>> - Messages that are/could be happening in the TX/RX tasks
>> - Other noisy messages that always happen in the
>> poller task.
>> Thoughts on what else we might measure to figure out what
>> is going on?
>> //.ichael
>> On Sun, 5 May 2024, 19:29 Michael Balzer via OvmsDev,
>> Michael,
>> the queue size isn't in bytes, it's in messages:
>>> * @param uxQueueLength The maximum number of items
>>> that the queue can contain.
>>> * @param uxItemSize The number of bytes each item
>>> in the queue will require.
>> Also, from the time stamps in Dereks log excerpt,
>> there were quite some dropped frames in that time
>> window -- at least 23 frames in 40 ms, that's bad.
>> Queue sizes are currently:
>> CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=60
>> CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=60
>> The new poller now channels all TX callbacks through
>> the task queue additionally to RX and commands. So
>> setting the queue size to be larger than the CAN RX
>> queue size seems appropriate.
>> Nevertheless, an overflow with more than 60 waiting
>> messages still indicates some too long processing
>> time in the vehicle task.
>> TX callbacks previously were done directly in the CAN
>> context, and no current vehicle overrides the empty
>> default handler, so this imposed almost no additional
>> overhead. By requiring a queue entry for each TX
>> callback, this feature now has a potentially high
>> impact for all vehicles. If passing these to the task
>> is actually necessary, it needs to become an opt-in
>> feature, so only vehicles subscribing to the callback
>> actually need to cope with that additional load &
>> potential processing delays involved.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240515/56066602/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240515/56066602/attachment-0001.sig>
