Michael,
the queue size isn't in bytes, it's in messages:
> * @param uxQueueLength The maximum number of items that the queue can
> contain.
> * @param uxItemSize The number of bytes each item in the queue will
> require.
Also, from the time stamps in Dereks log excerpt, there were quite some
dropped frames in that time window -- at least 23 frames in 40 ms,
that's bad.
Queue sizes are currently:
CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=60
CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=60
The new poller now channels all TX callbacks through the task queue
additionally to RX and commands. So setting the queue size to be larger
than the CAN RX queue size seems appropriate.
Nevertheless, an overflow with more than 60 waiting messages still
indicates some too long processing time in the vehicle task.
TX callbacks previously were done directly in the CAN context, and no
current vehicle overrides the empty default handler, so this imposed
almost no additional overhead. By requiring a queue entry for each TX
callback, this feature now has a potentially high impact for all
vehicles. If passing these to the task is actually necessary, it needs
to become an opt-in feature, so only vehicles subscribing to the
callback actually need to cope with that additional load & potential
processing delays involved.
Am 05.05.24 um 11:59 schrieb Michael Geddes via OvmsDev:
> OK.
> I did some logging changes to confirm that it's only _just_ getting
> overwhelmed..ie dropping 1 (or occasionally 2) RX frames in a row but
> then picking the next ones up...
> So increasing the queue size (I doubled it but maybe that was
> excessive) seems to do the trick. I think the queue size is in bytes
> and the queue packet size has increased at least a little bit.
> On Sat, 4 May 2024, 09:24 Michael Geddes,
> <frog at bunyip.wheelycreek.net> wrote:
> Hey Derek,
> I do have a friend with a Leaf in his EV collection, so I can try
> grab some more info from his car and work out exactly what (tf) is
> going on.
> On Sat, 4 May 2024 at 08:13, <frog at bunyip.wheelycreek.net> wrote:
> HI Derek,
> For a start, I’m very sorry that the ovms put your car in limp
> mode. That’s quite bad.
> Just FYI those overflows that you have copied are about
> receiving and not sending information, so maybe the poller
> thread is being overwhelmed or stalled somehow.
> I’ve been looking at the code and wondered if you have the
> ‘can write’ flag set to true or not? (Though it shouldn’t make
> that much difference)
> Even if it were somehow mistakenly polling (ie in the wrong
> pollstate), it should not be doing it that frequently – (at
> most once a minute). And the poll throttle would still be on 1
> per second.. so that should put a limit on sends.. and so it
> is really worrying that somehow that is not happening :/
> If you have more logs that you send me that don’t just include
> that particular overflow message that would be good. Did it
> crash/reboot? Maybe it crashed repeatedly?
> //.ichael
> *From:*OvmsDev <ovmsdev-bounces at lists.openvehicles.com> *On
> Behalf Of *Derek Caudwell via OvmsDev
> *Sent:* Friday, May 3, 2024 6:54 PM
> *To:* OVMS Developers <ovmsdev at lists.openvehicles.com>
> *Cc:* Derek Caudwell <d.caudwell at gmail.com>
> *Subject:* Re: [Ovmsdev] OVMS Poller module/singleton
> Hi Michael,
> When running firmware 3.3.004-74-gbd4e7196 on my Nissan Leaf I
> suspect (but can't be 100% sure as it's only been 24h without
> fault) the new poller caused the car to throw the attached
> faults from overloading the can bus whilst driving. The fault
> was sufficient to send the car into limp mode and could not be
> driven until cleared with LeafSpy. Ovms should not be polling
> in the driving state, so I'm not sure why the poller is
> overflowing.
> The ovms log repeats this overflow in rapid succession right
> before the failure occurred. I have since reverted to an
> earlier version and it might be advisable for other Leaf
> owners to do so until the new poller is fully operational.
> 2024-05-02 12:22:28.316 NZST I (36847486) vehicle-poll:
> Poller[Frame]: Task Queue Overflow
> 2024-05-02 12:22:28.326 NZST I (36847496) vehicle-poll:
> 2024-05-02 12:22:28.336 NZST I (36847506) vehicle-poll:
> 2024-05-02 12:22:28.346 NZST I (36847516) vehicle-poll:
> 2024-05-02 12:22:28.356 NZST I (36847526) vehicle-poll:
> On Fri, 3 May 2024 at 05:40, Michael Balzer via OvmsDev
> <ovmsdev at lists.openvehicles.com> wrote:
> A task may delete itself by calling vTaskDelete(NULL) as
> the final statement, and that's normally a better way to
> shutdown a task, if you can signal the task it should
> terminate. Deleting a task from outside may always result
> in resources taken by the task not being freed, as the
> task gets terminated wherever it just is.
> As the vehicle task also needs to access vehicle data
> memory, vehicle destruction should not begin until the
> task has finished, otherwise a task job already running
> while the vehicle destruction takes place may run into an
> illegal memory access (access after free). Keep in mind,
> destructors are executed bottom up, so waiting for the
> task shutdown within the destructor won't help.
> Also, I think "MyCan.DeregisterCallback(TAG)" in
> ShuttingDown() is now obsolete.
> Am 02.05.24 um 15:23 schrieb Michael Geddes:
> Thanks.
> On that race condition... do you think we are better
> to just delete the task or I saw one recommendation that
> We can delete it outside the while loop in the task
> itself!
> //.ichael
> On Tue, 30 Apr 2024, 17:46 Michael Balzer via OvmsDev,
> OK, understood & merged, thanks for the quick
> fix/workaround.
> I'll ask the Twizy driver to test this.
> PS: side note: there's a shutdown race condition
> arising from `while (!m_is_shutdown)` in the new
> `OvmsVehicle::VehicleTask()`: if the task receives
> a message while m_is_shutdown already has been
> set, it will exit the loop and return from the
> task function, which isn't allowed. I think
> FreeRTOS will abort in that case.
> Am 30.04.24 um 08:55 schrieb Michael Geddes:
> No it will start the poll thread of the poller
> fine for those that don't use it. That's the
> last commit.... so that should be covered.
> When the callback is registered the thread is
> force started.
> This is not to say that what you are
> suggesting isn't a better way forward... just
> that it should work.
> On Tue, 30 Apr 2024, 14:51 Michael Balzer via
> OvmsDev, <ovmsdev at lists.openvehicles.com> wrote:
> Michael,
> (taking this back to the list, as other
> developers may have helpful ideas or
> suggestions)
> from a first check, your new patch (PR
> #1008) won't help for vehicles that don't
> use the poller, like the generic DBC
> vehicle or the Fiat 500 (plus possibly
> non-public third party vehicles). As the
> poller is normally compiled in, these
> would need a run time switch to re-enable
> the vehicle task, or more suitably default
> into that configuration and switch to the
> poller task only when the poller gets
> initialized.
> How about moving the task back into the
> vehicle class, but keeping your task
> message extensions while doing so, and
> adding a way for the poller to hook into
> the task? The dedicated vehicle task is an
> essential part of the vehicle framework,
> but I do remember some occasions where a
> general way to pass custom messages to the
> vehicle task would have been helpful to
> use the task for more than CAN processing.
> If the poller shall become avaible as a
> separate service that can be used without
> any vehicle instance (currently not a
> defined use case), the construct of a CAN
> processor task that can be extended for
> custom messages (or a message processor
> task that can subscribe to CAN frames)
> could be factored out into a dedicated
> class or template. The poller could then
> create his own instance of that class, if
> it cannot hook into an existing one.
> Btw, in case you're not aware of this,
> FreeRTOS also provides queue sets
> (https://www.freertos.org/RTOS-queue-sets.html).
> We haven't used them in the OVMS yet, but
> they could be useful, especially if
> message unions become large or tasks shall
> be able to dynamically subscribe to
> different message sources.
> Am 30.04.24 um 01:20 schrieb Michael Geddes:
> It might be worth reverting, but, I've
> got a patch suggestion that I'll push
> up which will let me know if I
> understand everything and which might
> provide a solution.
> If this isn't going to work then
> revert. (P/R coming)
> While the poller was still a part of
> the vehicle class it was probably
> still all ok. The poller had taken
> over what I assume you are talking
> about as the vehicle task. A
> call-back fromthe poller was calling
> IncomingPollRxFrame which was then
> coming from the (now) poller task (is
> that correct?)
> While we have OVMS_COMP_POLLER config
> defined, we could just use the poller
> task to provide the
> IncomingPollRxFrame call-back from the
> poller (was vehicle?) task.
> The problem is when OVMS_COMP_POLLER
> is undefined, we need an alternate
> (maybe we could use the 'Event' loop
> then) which is when I hacked that bad
> solution.
> //.ichael
> I was thinking though that because
> everything is being queued we could
> divert some calls into the car
> On Mon, 29 Apr 2024, 18:58 Michael
> Balzer, <dexter at expeedo.de> wrote:
> Michael,
> I've found a severe design flaw
> with your poller change. Sorry, I
> should have seen that before, and
> shouldn't have merged this.
> You have moved the standard CAN
> frame processing from the vehicle
> task into the CAN task by changing
> the vehicle from a CAN listener to
> a CAN callback processor. That
> will break all kind of things,
> vehicles like the Twizy, Smart and
> many others rely on frame
> processing being done in the
> dedicated vehicle task.
> This especially induces issues
> regarding CAN processing capacity,
> as the vehicles rely on having a
> separate context and not needing
> to decouple complex processing of
> incoming frames. So this will
> degrade the CAN processing
> performance seriously in many
> cases, where additional steps
> involving file or network I/O need
> to be done.
> So this needs to be changed back.
> I assumed you introduced a new
> dedicated poller task but kept the
> vehicle task intact. From your
> naming
> (OvmsVehicle::IncomingPollRxFrame),
> it seems you misinterpreted the
> vehicle task's purpose as only
> being used for polling.
> I assume this isn't a small
> change…? If so we should revert
> the poller merge, to avoid having
> a defunctional edge build state
> until the fix.
> Secondly: logging is generally
> expensive regardless of the log
> level control and log channels
> enabled. Any log message needs to
> be queued to the log system, so
> involves a lock and a potential
> wait state (for the queue) &
> resulting context switch (=
> minimum delay of 10 ms).
> Therefore, logging must be avoided
> as far as possible in any time
> critical context, and is forbidden
> under some circumstances, e.g. in
> a timer callback (see FreeRTOS
> docs on this). The log system load
> multiplies with connected web
> clients or enabled file logging
> and enabled debug / verbose level
> logging -- that quickly becomes
> too much, usually triggering the
> task watchdog.
> Your logging of nearly all bus
> events passing to/from the poller
> (especially the log entry in
> Queue_PollerFrame) becomes an
> issue on any vehicle that has high
> frequency running process data
> frames on the bus, like the Twizy
> or Smart. As a counter measure,
> I've just added a runtime control
> for all the poller's verbose
> logging (by default now off), and
> changed some debug level logs to
> verbose. Not sure if I've catched
> all that may need to be silenced
> by default. Please check all your
> log calls and place them under the
> new "trace" control flag wherever
> appropriate.
> This won't help avoiding issues
> with process data frame buses though.
> Shall I revert the poller merge
> for now?
> Am 29.04.24 um 06:18 schrieb
> Michael Geddes:
> Btw I included the log changes
> in the p/r which is a few
> small commits for the poller.
> On Mon, 29 Apr 2024, 07:20
> Michael Geddes,
> wrote:
> Hey Michael,
> I've got to work now (it's
> Monday), but I suspect
> those 'giving up' are from
> unsolicited messages on
> the bus.
> I can re-order things so
> that the message will
> likely be 'dropped (no
> poll entry)' rather than
> the time-out message.
> And make it a verbose log.
> //.ichael
> On Mon, 29 Apr 2024 at
> 00:25, Michael Balzer
> Michael,
> forwarding the Twizy
> logs to you directly,
> as they contain the
> user location.
> He has just verified
> it's the new version,
> he says the module
> stops responding as
> soon as he turns on
> the Twizy.
> His description of his
> actions is a bit
> ambiguous, and it
> seems he didn't enable
> logging to the file
> persistently.
> According to the
> server, these were the
> version boot times:
> 2024-04-28 15:30:56 0
> 3.3.004-32-g125e0841/ota_0/edge
> (build idf
> v3.3.4-849-g6e214dc335
> Apr 26 2024 19:16:50)
> 2024-04-28 16:21:08 0
> (build idf
> 2024-04-28 16:38:33 0
> 3.3.004-63-gf3595561/ota_1/edge
> (build idf
> Apr 27 2024 07:44:50)
> 2024-04-28 16:40:57 0
> (build idf
> 2024-04-28 16:43:14 0
> (build idf
> 2024-04-28 16:46:39 0
> (build idf
> 2024-04-28 16:54:44 0
> (build idf
> Attached is also his
> crash debug log --
> a2ll doesn't tell much
> about what happened,
> but maybe you get an
> idea from this.
> After the boot at
> 16:46, there are
> immediately lots of
> these messages:
> 2024-04-28
> 16:46:33.792 CEST D
> (39042) vehicle-poll:
> Poller: Queue
> PollerFrame()
> 2024-04-28
> 16:46:33.792 CEST D
> [1]Poller: Incoming -
> giving up
> Am 28.04.24 um 16:44
> Ah. OK.
> I could try to fix
> the vin thing
> using the new way
> of doing it and
> get rid of a
> semaphore?
> It would at least
> identify the
> problem possibly?
> On Sun, 28 Apr
> 2024, 22:32
> Michael Balzer via
> OvmsDev,
> wrote:
> Not sure if
> that's the
> problem, but
> I've found a
> different
> behaviour with
> the new
> PollSetState()
> implementation.
> The old
> version only
> did anything
> if the new
> state actually
> was different
> from the
> previous one.
> The Twizy
> relies on this
> behaviour,
> calling
> PollSetState()
> from the per
> second ticker
> (see
> OvmsVehicleRenaultTwizy::ObdTicker1).
> The new
> implementation
> apparently
> always sends
> the PollState
> command to the
> task, and that
> in turn always
> at least locks
> the poller
> mutex. Not
> sure if/how
> that could
> cause the
> observed
> issues, but it
> definitely
> adds quite
> some
> (unnecessary?)
> lock/unlock
> operations.
> Am 28.04.24 um
> 16:05 schrieb
> Michael Balzer
> via OvmsDev:
> The Twizy
> uses the
> poller to
> query the
> VIN (once)
> and DTCs
> (every 10
> seconds
> while
> driving),
> see
> rt_obd2.cpp.
> It also
> has its
> own
> version of
> the OBD
> single
> request
> (OvmsVehicleRenaultTwizy::ObdRequest),
> which was
> the
> precursor
> for the
> generalized
> version.
> This is
> used by
> custom/user
> Twizy
> plugins
> and
> scripts to
> access ECU
> internals.
> The Twizy
> doesn't
> use
> IncomingPollRxFrame,
> but the
> Twizy's
> IncomingPollReply
> handler
> will log
> any poll
> responses
> it doesn't
> know
> about, so
> that could
> lead to a
> lot of log
> output if
> something
> goes wrong
> there.
> Am
> 28.04.24
> um 15:49
> schrieb
> Geddes via
> OvmsDev:
> AFAICT
> the
> twizzy
> doesn't
> use
> the
> poller
> list
> at
> all.
> So is
> it
> missing
> a
> call-back
> or
> something??
> I can
> see a
> potential
> problem
> with
> IncomingPollRxFrame
> being
> called
> twice
> as
> much
> as it
> should
> be but
> only
> when
> there
> is a
> poll
> list.
> Maybe
> commenting
> out
> this
> would
> do
> it.
> (I can
> find
> another
> away
> to get
> this
> called
> on the
> thread
> I
> want).
> This
> might
> be the
> problem
> with
> the
> smarted
> void
> OvmsVehicle::OvmsVehicleSignal::IncomingPollRxFrame(canbus*
> bus,
> CAN_frame_t
> *frame,
> bool
> success)
> //if
> (Ready())
> m_parent->IncomingPollRxFrame(frame,
> success);
> On
> Sun,
> 28 Apr
> 2024
> at
> 21:10,
> Balzer
> via
> OvmsDev
> wrote:
> There
> may
> also
> be
> an
> issue
> with
> the
> Renault
> Twizy,
> I've
> received
> a
> report
> of
> a
> user
> who
> is
> using
> the
> edge
> builds,
> that
> the
> latest
> build
> wouldn't
> work.
> He
> reports
> all
> kinds
> of
> errors
> and
> warnings
> signaled
> by
> the
> car
> during
> driving,
> and
> switching
> back
> to
> the
> previous
> build
> fixed
> the
> issues.
> I've
> asked
> him
> to
> provide
> a
> debug
> log
> excerpt
> if
> possible.
> Am
> 28.04.24
> um
> 14:29
> schrieb
> Geddes
> via
> OvmsDev:
> OK.
> That's
> bad.
> Does
> the
> reading
> work
> in
> general?
> Is
> it
> just
> the
> writing
> commands?
> Raise
> a
> ticket
> on
> github
> and
> tag
> me
> in
> and
> we
> can
> address
> it
> that
> way.
> On
> Sun,
> 28
> Apr
> 2024,
> 19:49
> Thomas
> Heuer
> via
> OvmsDev,
> wrote:
> Hi,
> The
> new
> poller
> code
> doesn't
> seem
> to
> work
> properly
> with
> the
> smarted.
> D
> (218831)
> vehicle-poll:
> [1]PollerNextTick(PRI):
> cycle
> complete
> for
> ticker=215
> V
> (218831)
> vehicle-poll:
> Standard
> Poll
> Series:
> List
> reset
> D
> (218831)
> vehicle-poll:
> PollSeriesList::NextPollEntry[!v.standard]:
> ReachedEnd
> V
> (218831)
> vehicle-poll:
> [1]PollerSend:
> Poller
> Reached
> End
> D
> (219691)
> vehicle-poll:
> Poller:
> Queue
> PollerFrame()
> D
> (219691)
> vehicle-poll:
> Poller:
> Queue
> PollerFrame()
> V
> (219691)
> vehicle-poll:
> Pollers:
> FrameRx(bus=2)
> D
> (219691)
> vehicle-poll:
> Poller:
> Queue
> PollerFrame()
> V
> (219691)
> vehicle-poll:
> Pollers:
> FrameRx(bus=2)
> V
> (219691)
> vehicle-poll:
> Pollers:
> FrameRx(bus=2)
> D
> (219691)
> vehicle-poll:
> Poller:
> Queue
> PollerFrame()
> *OVMS#*unlock
> 22
> Vehicle
> unlocked
> V
> (219691)
> vehicle-poll:
> Pollers:
> FrameRx(bus=2)
> D
> (219691)
> vehicle-poll:
> Poller:
> Queue
> PollerFrame()
> V
> (219691)
> vehicle-poll:
> Pollers:
> FrameRx(bus=2)
> D
> (219701)
> vehicle-poll:
> Poller:
> Queue
> PollerFrame()
> V
> (219701)
> vehicle-poll:
> Pollers:
> FrameRx(bus=2)
> D
> (219701)
> vehicle-poll:
> Poller:
> Queue
> PollerFrame()
> V
> (219701)
> vehicle-poll:
> Pollers:
> FrameRx(bus=2)
> D
> (219701)
> vehicle-poll:
> Poller:
> Queue
> PollerFrame()
> V
> (219701)
> vehicle-poll:
> Pollers:
> FrameRx(bus=2)
> D
> (219701)
> vehicle-poll:
> Poller:
> Queue
> PollerFrame()
> V
> (219701)
> vehicle-poll:
> Pollers:
> FrameRx(bus=2)
> D
> (219701)
> vehicle-poll:
> Poller:
> Queue
> PollerFrame()
> V
> (219701)
> vehicle-poll:
> Pollers:
> FrameRx(bus=2)
> D
> (219701)
> vehicle-poll:
> Poller:
> Queue
> PollerFrame()
> V
> (219701)
> vehicle-poll:
> Pollers:
> FrameRx(bus=2)
> D
> (219701)
> vehicle-poll:
> Poller:
> Queue
> PollerFrame()
> V
> (219701)
> vehicle-poll:
> Pollers:
> FrameRx(bus=2)
> D
> (219701)
> vehicle-poll:
> Poller:
> Queue
> PollerFrame()
> V
> (219701)
> vehicle-poll:
> Pollers:
> FrameRx(bus=2)
> D
> (219701)
> vehicle-poll:
> Poller:
> Queue
> PollerFrame()
> V
> (219701)
> vehicle-poll:
> Pollers:
> FrameRx(bus=2)
> D
> (219701)
> vehicle-poll:
> Poller:
> Queue
> PollerFrame()
> V
> (219701)
> vehicle-poll:
> Pollers:
> FrameRx(bus=2)
> D
> (219701)
> vehicle-poll:
> Poller:
> Queue
> PollerFrame()
> *Von:*OvmsDev
> *Im
> Auftrag
> von
> *Michael
> Geddes
> via
> OvmsDev
> *Gesendet:*
> Sonntag,
> 28.
> April
> 2024
> 12:27
> *An:*
> OVMS
> Developers
> *Cc:*
> Geddes
> *Betreff:*
> [Ovmsdev]
> OVMS
> Poller
> module/singleton
> Hey
> all,
> The
> poller
> singleton
> code
> that
> I've
> been
> working
> on
> for
> over
> a
> year
> now
> is
> merged
> in.
> (Thanks
> for
> expediting
> the
> final
> step).
> This
> includes
> separate
> multi-frame
> states
> per
> bus
> and
> multiple
> poll
> lists
> as
> well
> as
> non-blocking
> one
> off
> queries.
> As
> well
> as
> more
> 'states'.
> I
> have
> included
> some
> programming
> documentation
> in
> the
> change
> but
> am
> happy
> to
> supply
> more
> if
> needed.
> The
> ioniq
> 5
> code
> has
> some
> examples
> of
> how
> it
> can
> be
> used.
> Some
> examples
> are:
> grabbing
> the
> vin
> as
> a
> one
> shot
> without
> blocking
> having
> a
> short
> list
> of
> queries
> that
> are
> polled
> quickly
> for
> obd2ecu
> (this
> also
> demonstrates
> using
> a
> shorter
> frame
> break
> value
> and
> then
> a
> break
> after
> successful
> a
> response)
> Have
> a
> play
> please!
> Also
> interested
> in
> hearing
> what
> user
> tools
> might
> be
> worth
> looking
> at
> next
> for
> the
> poller
> object.
> //.ichael
> G.
> OvmsDev
> mailing
> list
> OvmsDev
> mailing
> list
> OvmsDev
> mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240505/810f118c/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240505/810f118c/attachment-0001.sig>
