Sat May 4 09:24:13 HKT 2024
Hey Derek,
I do have a friend with a Leaf in his EV collection,  so I can try grab
some more info from his car and work out exactly what (tf) is going on.
On Sat, 4 May 2024 at 08:13, <frog at bunyip.wheelycreek.net> wrote:
> HI Derek,
> For a start, I’m very sorry that the ovms put your car in limp mode.
> That’s quite bad.
> Just FYI those overflows that you have copied are about receiving and not
> sending information, so maybe the poller thread is being overwhelmed or
> stalled somehow.
> I’ve been looking at the code and wondered if you have the ‘can write’
> flag set to true or not?  (Though it shouldn’t make that much difference)
> Even if it were somehow mistakenly polling (ie in the wrong pollstate), it
> should not be doing it that frequently – (at most once a minute). And the
> poll throttle would still be on 1 per second.. so that should put a limit
>  on sends.. and so it is really worrying that somehow that is not happening
> If you have more logs that you send me that don’t just include that
> particular overflow message that would be good.  Did it crash/reboot?
> Maybe it crashed repeatedly?
> //.ichael
> *From:* OvmsDev <ovmsdev-bounces at lists.openvehicles.com> *On Behalf Of *Derek
> Caudwell via OvmsDev
> *Sent:* Friday, May 3, 2024 6:54 PM
> *To:* OVMS Developers <ovmsdev at lists.openvehicles.com>
> *Cc:* Derek Caudwell <d.caudwell at gmail.com>
> *Subject:* Re: [Ovmsdev] OVMS Poller module/singleton
> Hi Michael,
> When running firmware  3.3.004-74-gbd4e7196 on my Nissan Leaf I suspect
> (but can't be 100% sure as it's only been 24h without fault) the new poller
> caused the car to throw the attached faults from overloading the can bus
> whilst driving. The fault was sufficient to send the car into limp mode and
> could not be driven until cleared with LeafSpy. Ovms should not be polling
> in the driving state, so I'm not sure why the poller is overflowing.
> The ovms log repeats this overflow in rapid succession right before the
> failure occurred. I have since reverted to an earlier version and it might
> be advisable for other Leaf owners to do so until the new poller is fully
> operational.
> 2024-05-02 12:22:28.316 NZST I (36847486) vehicle-poll: Poller[Frame]:
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> 2024-05-02 12:22:28.326 NZST I (36847496) vehicle-poll: Poller[Frame]:
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> 2024-05-02 12:22:28.336 NZST I (36847506) vehicle-poll: Poller[Frame]:
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> 2024-05-02 12:22:28.346 NZST I (36847516) vehicle-poll: Poller[Frame]:
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> 2024-05-02 12:22:28.356 NZST I (36847526) vehicle-poll: Poller[Frame]:
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> Task Queue Overflow
> On Fri, 3 May 2024 at 05:40, Michael Balzer via OvmsDev <
> ovmsdev at lists.openvehicles.com> wrote:
> A task may delete itself by calling vTaskDelete(NULL) as the final
> statement, and that's normally a better way to shutdown a task, if you can
> signal the task it should terminate. Deleting a task from outside may
> always result in resources taken by the task not being freed, as the task
> gets terminated wherever it just is.
> As the vehicle task also needs to access vehicle data memory, vehicle
> destruction should not begin until the task has finished, otherwise a task
> job already running while the vehicle destruction takes place may run into
> an illegal memory access (access after free). Keep in mind, destructors are
> executed bottom up, so waiting for the task shutdown within the destructor
> won't help.
> Also, I think "MyCan.DeregisterCallback(TAG)" in ShuttingDown() is now
> obsolete.
> Am 02.05.24 um 15:23 schrieb Michael Geddes:
> Thanks.
> On that race condition... do you think we are better to just delete the
> task  or I saw one recommendation that
> We can delete it outside the while loop in the task itself!
> //.ichael
> On Tue, 30 Apr 2024, 17:46 Michael Balzer via OvmsDev, <
> OK, understood & merged, thanks for the quick fix/workaround.
> I'll ask the Twizy driver to test this.
> PS: side note: there's a shutdown race condition arising from `while
> (!m_is_shutdown)` in the new `OvmsVehicle::VehicleTask()`: if the task
> receives a message while m_is_shutdown already has been set, it will exit
> the loop and return from the task function, which isn't allowed. I think
> FreeRTOS will abort in that case.
> Am 30.04.24 um 08:55 schrieb Michael Geddes:
> No it will start the poll thread of the poller fine for those that don't
> use it.  That's the last commit.... so that should be covered. When the
> callback is registered the thread is force started.
> This is not to say that what you are suggesting isn't a better way
> forward... just that it should work.
> On Tue, 30 Apr 2024, 14:51 Michael Balzer via OvmsDev, <
> Michael,
> (taking this back to the list, as other developers may have helpful ideas
> or suggestions)
> from a first check, your new patch (PR #1008) won't help for vehicles that
> don't use the poller, like the generic DBC vehicle or the Fiat 500 (plus
> possibly non-public third party vehicles). As the poller is normally
> compiled in, these would need a run time switch to re-enable the vehicle
> task, or more suitably default into that configuration and switch to the
> poller task only when the poller gets initialized.
> How about moving the task back into the vehicle class, but keeping your
> task message extensions while doing so, and adding a way for the poller to
> hook into the task? The dedicated vehicle task is an essential part of the
> vehicle framework, but I do remember some occasions where a general way to
> pass custom messages to the vehicle task would have been helpful to use the
> task for more than CAN processing.
> If the poller shall become avaible as a separate service that can be used
> without any vehicle instance (currently not a defined use case), the
> construct of a CAN processor task that can be extended for custom messages
> (or a message processor task that can subscribe to CAN frames) could be
> factored out into a dedicated class or template. The poller could then
> create his own instance of that class, if it cannot hook into an existing
> one.
> Btw, in case you're not aware of this, FreeRTOS also provides queue sets (
> https://www.freertos.org/RTOS-queue-sets.html). We haven't used them in
> the OVMS yet, but they could be useful, especially if message unions become
> large or tasks shall be able to dynamically subscribe to different message
> sources.
> Am 30.04.24 um 01:20 schrieb Michael Geddes:
> It might be worth reverting, but, I've got a patch suggestion that I'll
> push up which will let me know if I understand everything and which might
> provide a solution.
> If this isn't going to work then revert. (P/R coming)
> While the poller was still a part of the vehicle class it was probably
> still all ok.   The poller had taken over what I assume you are talking
> about as the vehicle task.  A call-back fromthe poller was calling
> IncomingPollRxFrame which was then coming from the (now) poller task (is
> that correct?)
> While we have OVMS_COMP_POLLER config defined, we could just use the
> poller task to provide the IncomingPollRxFrame call-back from the poller
> (was vehicle?) task.
> The problem is when OVMS_COMP_POLLER is undefined, we need an alternate
> (maybe we could use the 'Event' loop then) which is when I hacked that bad
> solution.
> //.ichael
> I was thinking though that because everything is being queued we could
> divert some calls into the car
> On Mon, 29 Apr 2024, 18:58 Michael Balzer, <dexter at expeedo.de> wrote:
> Michael,
> I've found a severe design flaw with your poller change. Sorry, I should
> have seen that before, and shouldn't have merged this.
> You have moved the standard CAN frame processing from the vehicle task
> into the CAN task by changing the vehicle from a CAN listener to a CAN
> callback processor. That will break all kind of things, vehicles like the
> Twizy, Smart and many others rely on frame processing being done in the
> dedicated vehicle task.
> This especially induces issues regarding CAN processing capacity, as the
> vehicles rely on having a separate context and not needing to decouple
> complex processing of incoming frames. So this will degrade the CAN
> processing performance seriously in many cases, where additional steps
> involving file or network I/O need to be done.
> So this needs to be changed back.
> I assumed you introduced a new dedicated poller task but kept the vehicle
> task intact. From your naming (OvmsVehicle::IncomingPollRxFrame), it seems
> you misinterpreted the vehicle task's purpose as only being used for
> polling.
> I assume this isn't a small change…? If so we should revert the poller
> merge, to avoid having a defunctional edge build state until the fix.
> Secondly: logging is generally expensive regardless of the log level
> control and log channels enabled. Any log message needs to be queued to the
> log system, so involves a lock and a potential wait state (for the queue) &
> resulting context switch (= minimum delay of 10 ms). Therefore, logging
> must be avoided as far as possible in any time critical context, and is
> forbidden under some circumstances, e.g. in a timer callback (see FreeRTOS
> docs on this). The log system load multiplies with connected web clients or
> enabled file logging and enabled debug / verbose level logging -- that
> quickly becomes too much, usually triggering the task watchdog.
> Your logging of nearly all bus events passing to/from the poller
> (especially the log entry in Queue_PollerFrame) becomes an issue on any
> vehicle that has high frequency running process data frames on the bus,
> like the Twizy or Smart. As a counter measure, I've just added a runtime
> control for all the poller's verbose logging (by default now off), and
> changed some debug level logs to verbose. Not sure if I've catched all that
> may need to be silenced by default. Please check all your log calls and
> place them under the new "trace" control flag wherever appropriate.
> This won't help avoiding issues with process data frame buses though.
> Shall I revert the poller merge for now?
> Am 29.04.24 um 06:18 schrieb Michael Geddes:
> Btw I included the log changes in the p/r which is a few small commits for
> the poller.
> On Mon, 29 Apr 2024, 07:20 Michael Geddes, <frog at bunyip.wheelycreek.net>
> wrote:
> Hey Michael,
> I've got to work now (it's Monday), but I suspect those 'giving up' are
> from unsolicited messages on the bus.
> I can re-order things so that the message will likely be  'dropped (no
> poll entry)' rather than the time-out message.
> And make it a verbose log.
> //.ichael
> On Mon, 29 Apr 2024 at 00:25, Michael Balzer <dexter at expeedo.de> wrote:
> Michael,
> forwarding the Twizy logs to you directly, as they contain the user
> location.
> He has just verified it's the new version, he says the module stops
> responding as soon as he turns on the Twizy.
> His description of his actions is a bit ambiguous, and it seems he didn't
> enable logging to the file persistently.
> According to the server, these were the version boot times:
> 2024-04-28 15:30:56    0    3.3.004-32-g125e0841/ota_0/edge (build idf
> v3.3.4-849-g6e214dc335 Apr 26 2024 19:16:50)
> 2024-04-28 16:21:08    0    3.3.004-32-g125e0841/ota_0/edge (build idf
> 2024-04-28 16:38:33    0    3.3.004-63-gf3595561/ota_1/edge (build idf
> v3.3.4-849-g6e214dc335 Apr 27 2024 07:44:50)
> 2024-04-28 16:40:57    0    3.3.004-63-gf3595561/ota_1/edge (build idf
> 2024-04-28 16:43:14    0    3.3.004-63-gf3595561/ota_1/edge (build idf
> 2024-04-28 16:46:39    0    3.3.004-63-gf3595561/ota_1/edge (build idf
> 2024-04-28 16:54:44    0    3.3.004-32-g125e0841/ota_0/edge (build idf
> Attached is also his crash debug log -- a2ll doesn't tell much about what
> happened, but maybe you get an idea from this.
> After the boot at 16:46, there are immediately lots of these messages:
> 2024-04-28 16:46:33.792 CEST D (39042) vehicle-poll: Poller: Queue
> PollerFrame()
> 2024-04-28 16:46:33.792 CEST D (39042) vehicle-poll: [1]Poller: Incoming -
> giving up
> Am 28.04.24 um 16:44 schrieb Michael Geddes:
> Ah. OK.
> I could try to fix the vin thing using the new way of doing it and get rid
> of a semaphore?
> It would at least identify the problem possibly?
> On Sun, 28 Apr 2024, 22:32 Michael Balzer via OvmsDev, <
> Not sure if that's the problem, but I've found a different behaviour with
> the new PollSetState() implementation.
> The old version only did anything if the new state actually was different
> from the previous one. The Twizy relies on this behaviour, calling
> PollSetState() from the per second ticker (see
> OvmsVehicleRenaultTwizy::ObdTicker1).
> The new implementation apparently always sends the PollState command to
> the task, and that in turn always at least locks the poller mutex. Not sure
> if/how that could cause the observed issues, but it definitely adds quite
> some (unnecessary?) lock/unlock operations.
> Am 28.04.24 um 16:05 schrieb Michael Balzer via OvmsDev:
> The Twizy uses the poller to query the VIN (once) and DTCs (every 10
> seconds while driving), see rt_obd2.cpp.
> It also has its own version of the OBD single request
> (OvmsVehicleRenaultTwizy::ObdRequest), which was the precursor for the
> generalized version. This is used by custom/user Twizy plugins and scripts
> to access ECU internals.
> The Twizy doesn't use IncomingPollRxFrame, but the Twizy's
> IncomingPollReply handler will log any poll responses it doesn't know
> about, so that could lead to a lot of log output if something goes wrong
> there.
> Am 28.04.24 um 15:49 schrieb Michael Geddes via OvmsDev:
> AFAICT the twizzy doesn't use the poller list at all.  So is it missing a
> call-back or something??
> I can see a potential problem with IncomingPollRxFrame being called twice
> as much as it should be but only when there is a poll list.  Maybe
> commenting out this would do it.  (I can find another away to get this
> called on the thread I want).  This might be the problem with the smarted
> void OvmsVehicle::OvmsVehicleSignal::IncomingPollRxFrame(canbus* bus,
> CAN_frame_t *frame, bool success)
>   //if (Ready())
>   //  m_parent->IncomingPollRxFrame(frame, success);
> On Sun, 28 Apr 2024 at 21:10, Michael Balzer via OvmsDev <
> There may also be an issue with the Renault Twizy, I've received a report
> of a user who is using the edge builds, that the latest build wouldn't work.
> He reports all kinds of errors and warnings signaled by the car during
> driving, and switching back to the previous build fixed the issues.
> I've asked him to provide a debug log excerpt if possible.
> Am 28.04.24 um 14:29 schrieb Michael Geddes via OvmsDev:
> OK. That's bad.
> Does the reading work in general?
> Is it just the writing commands?
> Raise a ticket on github and tag me in and we can address it that way.
> On Sun, 28 Apr 2024, 19:49 Thomas Heuer via OvmsDev, <
> Hi,
> The new poller code doesn't seem to work properly with the smarted.
> D (218831) vehicle-poll: [1]PollerNextTick(PRI): cycle complete for
> ticker=215
> V (218831) vehicle-poll: Standard Poll Series: List reset
> D (218831) vehicle-poll: PollSeriesList::NextPollEntry[!v.standard]:
> ReachedEnd
> V (218831) vehicle-poll: [1]PollerSend: Poller Reached End
> D (219691) vehicle-poll: Poller: Queue PollerFrame()
> V (219691) vehicle-poll: Pollers: FrameRx(bus=2)
> *OVMS#* unlock 22
> Vehicle unlocked
> D (219701) vehicle-poll: Poller: Queue PollerFrame()
> V (219701) vehicle-poll: Pollers: FrameRx(bus=2)
> *Von:* OvmsDev <ovmsdev-bounces at lists.openvehicles.com> *Im Auftrag von *Michael
> Geddes via OvmsDev
> *Gesendet:* Sonntag, 28. April 2024 12:27
> *An:* OVMS Developers <ovmsdev at lists.openvehicles.com>
> *Cc:* Michael Geddes <frog at bunyip.wheelycreek.net>
> *Betreff:* [Ovmsdev] OVMS Poller module/singleton
> Hey all,
> The poller singleton code that I've been working on for over a year now is
> merged in. (Thanks Michael for expediting the final step).
> This includes separate multi-frame states per bus and multiple poll lists
> as well as non-blocking one off queries. As well as more 'states'.
> I have included some programming documentation in the change but am happy
> to supply more if needed.
> The ioniq 5 code has some examples of how it can be used. Some examples
> are:
> * grabbing the vin as a one shot without blocking
> * having a short list of queries that are polled quickly for obd2ecu (this
> also demonstrates using a shorter frame break value and then a break after
> successful a response)
> Have a play please!
> Also interested in hearing what user tools might be worth looking at next
> for the poller object.
> //.ichael G.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240504/4c8aed1b/attachment-0001.htm>
