Fri May 3 01:39:32 HKT 2024
A task may delete itself by calling vTaskDelete(NULL) as the final
statement, and that's normally a better way to shutdown a task, if you
can signal the task it should terminate. Deleting a task from outside
may always result in resources taken by the task not being freed, as the
task gets terminated wherever it just is.
As the vehicle task also needs to access vehicle data memory, vehicle
destruction should not begin until the task has finished, otherwise a
task job already running while the vehicle destruction takes place may
run into an illegal memory access (access after free). Keep in mind,
destructors are executed bottom up, so waiting for the task shutdown
within the destructor won't help.
Also, I think "MyCan.DeregisterCallback(TAG)" in ShuttingDown() is now
obsolete.
Am 02.05.24 um 15:23 schrieb Michael Geddes:
> Thanks.
> On that race condition... do you think we are better to just delete
> the task  or I saw one recommendation that
> We can delete it outside the while loop in the task itself!
> //.ichael
> On Tue, 30 Apr 2024, 17:46 Michael Balzer via OvmsDev,
> <ovmsdev at lists.openvehicles.com> wrote:
>     OK, understood & merged, thanks for the quick fix/workaround.
>     I'll ask the Twizy driver to test this.
>     Regards,
>     Michael
>     PS: side note: there's a shutdown race condition arising from
>     `while (!m_is_shutdown)` in the new `OvmsVehicle::VehicleTask()`:
>     if the task receives a message while m_is_shutdown already has
>     been set, it will exit the loop and return from the task function,
>     which isn't allowed. I think FreeRTOS will abort in that case.
>     Am 30.04.24 um 08:55 schrieb Michael Geddes:
>>     No it will start the poll thread of the poller fine for those
>>     that don't use it.  That's the last commit.... so that should be
>>     covered. When the callback is registered the thread is force
>>     started.
>>     This is not to say that what you are suggesting isn't a better
>>     way forward... just that it should work.
>>     Michael
>>     On Tue, 30 Apr 2024, 14:51 Michael Balzer via OvmsDev,
>>         Michael,
>>         (taking this back to the list, as other developers may have
>>         helpful ideas or suggestions)
>>         from a first check, your new patch (PR #1008) won't help for
>>         vehicles that don't use the poller, like the generic DBC
>>         vehicle or the Fiat 500 (plus possibly non-public third party
>>         vehicles). As the poller is normally compiled in, these would
>>         need a run time switch to re-enable the vehicle task, or more
>>         suitably default into that configuration and switch to the
>>         poller task only when the poller gets initialized.
>>         How about moving the task back into the vehicle class, but
>>         keeping your task message extensions while doing so, and
>>         adding a way for the poller to hook into the task? The
>>         dedicated vehicle task is an essential part of the vehicle
>>         framework, but I do remember some occasions where a general
>>         way to pass custom messages to the vehicle task would have
>>         been helpful to use the task for more than CAN processing.
>>         If the poller shall become avaible as a separate service that
>>         can be used without any vehicle instance (currently not a
>>         defined use case), the construct of a CAN processor task that
>>         can be extended for custom messages (or a message processor
>>         task that can subscribe to CAN frames) could be factored out
>>         into a dedicated class or template. The poller could then
>>         create his own instance of that class, if it cannot hook into
>>         an existing one.
>>         Btw, in case you're not aware of this, FreeRTOS also provides
>>         queue sets (https://www.freertos.org/RTOS-queue-sets.html).
>>         We haven't used them in the OVMS yet, but they could be
>>         useful, especially if message unions become large or tasks
>>         shall be able to dynamically subscribe to different message
>>         sources.
>>         Regards,
>>         Michael
>>         Am 30.04.24 um 01:20 schrieb Michael Geddes:
>>>         It might be worth reverting, but, I've got a patch
>>>         suggestion that I'll push up which will let me know if I
>>>         understand everything and which might provide a solution.
>>>         If this isn't going to work then revert. (P/R coming)
>>>         While the poller was still a part of the vehicle class it
>>>         was probably still all ok.   The poller had taken over what
>>>         I assume you are talking about as the vehicle task.  A
>>>         call-back fromthe poller was calling IncomingPollRxFrame
>>>         which was then coming from the (now) poller task (is that
>>>         correct?)
>>>         While we have OVMS_COMP_POLLER config defined, we could just
>>>         use the poller task to provide the IncomingPollRxFrame
>>>         call-back from the poller (was vehicle?) task.
>>>         The problem is when OVMS_COMP_POLLER is undefined, we need
>>>         an alternate (maybe we could use the 'Event' loop then)
>>>         which is when I hacked that bad solution.
>>>         //.ichael
>>>         I was thinking though that because everything is being
>>>         queued we could divert some calls into the car
>>>         On Mon, 29 Apr 2024, 18:58 Michael Balzer,
>>>         <dexter at expeedo.de> wrote:
>>>             Michael,
>>>             I've found a severe design flaw with your poller change.
>>>             Sorry, I should have seen that before, and shouldn't
>>>             have merged this.
>>>             You have moved the standard CAN frame processing from
>>>             the vehicle task into the CAN task by changing the
>>>             vehicle from a CAN listener to a CAN callback processor.
>>>             That will break all kind of things, vehicles like the
>>>             Twizy, Smart and many others rely on frame processing
>>>             being done in the dedicated vehicle task.
>>>             This especially induces issues regarding CAN processing
>>>             capacity, as the vehicles rely on having a separate
>>>             context and not needing to decouple complex processing
>>>             of incoming frames. So this will degrade the CAN
>>>             processing performance seriously in many cases, where
>>>             additional steps involving file or network I/O need to
>>>             be done.
>>>             So this needs to be changed back.
>>>             I assumed you introduced a new dedicated poller task but
>>>             kept the vehicle task intact. From your naming
>>>             (OvmsVehicle::IncomingPollRxFrame), it seems you
>>>             misinterpreted the vehicle task's purpose as only being
>>>             used for polling.
>>>             I assume this isn't a small change…? If so we should
>>>             revert the poller merge, to avoid having a defunctional
>>>             edge build state until the fix.
>>>             Secondly: logging is generally expensive regardless of
>>>             the log level control and log channels enabled. Any log
>>>             message needs to be queued to the log system, so
>>>             involves a lock and a potential wait state (for the
>>>             queue) & resulting context switch (= minimum delay of 10
>>>             ms). Therefore, logging must be avoided as far as
>>>             possible in any time critical context, and is forbidden
>>>             under some circumstances, e.g. in a timer callback (see
>>>             FreeRTOS docs on this). The log system load multiplies
>>>             with connected web clients or enabled file logging and
>>>             enabled debug / verbose level logging -- that quickly
>>>             becomes too much, usually triggering the task watchdog.
>>>             Your logging of nearly all bus events passing to/from
>>>             the poller (especially the log entry in
>>>             Queue_PollerFrame) becomes an issue on any vehicle that
>>>             has high frequency running process data frames on the
>>>             bus, like the Twizy or Smart. As a counter measure, I've
>>>             just added a runtime control for all the poller's
>>>             verbose logging (by default now off), and changed some
>>>             debug level logs to verbose. Not sure if I've catched
>>>             all that may need to be silenced by default. Please
>>>             check all your log calls and place them under the new
>>>             "trace" control flag wherever appropriate.
>>>             This won't help avoiding issues with process data frame
>>>             buses though.
>>>             Shall I revert the poller merge for now?
>>>             Regards,
>>>             Michael
>>>             Am 29.04.24 um 06:18 schrieb Michael Geddes:
>>>>             Btw I included the log changes in the p/r which is a
>>>>             few small commits for the poller.
>>>>             On Mon, 29 Apr 2024, 07:20 Michael Geddes,
>>>>             <frog at bunyip.wheelycreek.net> wrote:
>>>>                 Hey Michael,
>>>>                 I've got to work now (it's Monday), but I suspect
>>>>                 those 'giving up' are from unsolicited messages on
>>>>                 the bus.
>>>>                 I can re-order things so that the message will
>>>>                 likely be  'dropped (no poll entry)' rather than
>>>>                 the time-out message.
>>>>                 And make it a verbose log.
>>>>                 //.ichael
>>>>                 On Mon, 29 Apr 2024 at 00:25, Michael Balzer
>>>>                     Michael,
>>>>                     forwarding the Twizy logs to you directly, as
>>>>                     they contain the user location.
>>>>                     He has just verified it's the new version, he
>>>>                     says the module stops responding as soon as he
>>>>                     turns on the Twizy.
>>>>                     His description of his actions is a bit
>>>>                     ambiguous, and it seems he didn't enable
>>>>                     logging to the file persistently.
>>>>                     According to the server, these were the version
>>>>                     boot times:
>>>>                     2024-04-28 15:30:56 0
>>>>                     3.3.004-32-g125e0841/ota_0/edge (build idf
>>>>                     v3.3.4-849-g6e214dc335 Apr 26 2024 19:16:50)
>>>>                     2024-04-28 16:21:08 0
>>>>                     2024-04-28 16:38:33 0
>>>>                     3.3.004-63-gf3595561/ota_1/edge (build idf
>>>>                     v3.3.4-849-g6e214dc335 Apr 27 2024 07:44:50)
>>>>                     2024-04-28 16:40:57 0
>>>>                     2024-04-28 16:43:14 0
>>>>                     2024-04-28 16:46:39 0
>>>>                     2024-04-28 16:54:44 0
>>>>                     Attached is also his crash debug log -- a2ll
>>>>                     doesn't tell much about what happened, but
>>>>                     maybe you get an idea from this.
>>>>                     After the boot at 16:46, there are immediately
>>>>                     lots of these messages:
>>>>                     2024-04-28 16:46:33.792 CEST D (39042)
>>>>                     vehicle-poll: Poller: Queue PollerFrame()
>>>>                     vehicle-poll: [1]Poller: Incoming - giving up
>>>>                     Regards,
>>>>                     Michael
>>>>                     Am 28.04.24 um 16:44 schrieb Michael Geddes:
>>>>>                     Ah. OK.
>>>>>                     I could try to fix the vin thing using the new
>>>>>                     way of doing it and get rid of a semaphore?
>>>>>                     It would at least identify the problem possibly?
>>>>>                     Michael
>>>>>                     On Sun, 28 Apr 2024, 22:32 Michael Balzer via
>>>>>                     OvmsDev, <ovmsdev at lists.openvehicles.com> wrote:
>>>>>                         Not sure if that's the problem, but I've
>>>>>                         found a different behaviour with the new
>>>>>                         PollSetState() implementation.
>>>>>                         The old version only did anything if the
>>>>>                         new state actually was different from the
>>>>>                         previous one. The Twizy relies on this
>>>>>                         behaviour, calling PollSetState() from the
>>>>>                         per second ticker (see
>>>>>                         OvmsVehicleRenaultTwizy::ObdTicker1).
>>>>>                         The new implementation apparently always
>>>>>                         sends the PollState command to the task,
>>>>>                         and that in turn always at least locks the
>>>>>                         poller mutex. Not sure if/how that could
>>>>>                         cause the observed issues, but it
>>>>>                         definitely adds quite some (unnecessary?)
>>>>>                         lock/unlock operations.
>>>>>                         Am 28.04.24 um 16:05 schrieb Michael
>>>>>                         Balzer via OvmsDev:
>>>>>>                         The Twizy uses the poller to query the
>>>>>>                         VIN (once) and DTCs (every 10 seconds
>>>>>>                         while driving), see rt_obd2.cpp.
>>>>>>                         It also has its own version of the OBD
>>>>>>                         single request
>>>>>>                         (OvmsVehicleRenaultTwizy::ObdRequest),
>>>>>>                         which was the precursor for the
>>>>>>                         generalized version. This is used by
>>>>>>                         custom/user Twizy plugins and scripts to
>>>>>>                         access ECU internals.
>>>>>>                         The Twizy doesn't use
>>>>>>                         IncomingPollRxFrame, but the Twizy's
>>>>>>                         IncomingPollReply handler will log any
>>>>>>                         poll responses it doesn't know about, so
>>>>>>                         that could lead to a lot of log output if
>>>>>>                         something goes wrong there.
>>>>>>                         Am 28.04.24 um 15:49 schrieb Michael
>>>>>>                         Geddes via OvmsDev:
>>>>>>>                         AFAICT the twizzy doesn't use the poller
>>>>>>>                         list at all. So is it missing a
>>>>>>>                         call-back or something??
>>>>>>>                         I can see a potential problem with
>>>>>>>                         IncomingPollRxFrame being called twice
>>>>>>>                         as much as it should be but only when
>>>>>>>                         there is a poll list. Maybe commenting
>>>>>>>                         out this would do it.  (I can find
>>>>>>>                         another away to get this called on the
>>>>>>>                         thread I want).  This might be the
>>>>>>>                         problem with the smarted
>>>>>>>                         void
>>>>>>>                         OvmsVehicle::OvmsVehicleSignal::IncomingPollRxFrame(canbus*
>>>>>>>                         bus, CAN_frame_t *frame, bool success)
>>>>>>>                           //if (Ready())
>>>>>>>                         m_parent->IncomingPollRxFrame(frame,
>>>>>>>                         success);
>>>>>>>                         On Sun, 28 Apr 2024 at 21:10, Michael
>>>>>>>                         Balzer via OvmsDev
>>>>>>>                             There may also be an issue with the
>>>>>>>                             Renault Twizy, I've received a
>>>>>>>                             report of a user who is using the
>>>>>>>                             edge builds, that the latest build
>>>>>>>                             wouldn't work.
>>>>>>>                             He reports all kinds of errors and
>>>>>>>                             warnings signaled by the car during
>>>>>>>                             driving, and switching back to the
>>>>>>>                             previous build fixed the issues.
>>>>>>>                             I've asked him to provide a debug
>>>>>>>                             log excerpt if possible.
>>>>>>>                             Regards,
>>>>>>>                             Michael
>>>>>>>                             Am 28.04.24 um 14:29 schrieb Michael
>>>>>>>                             Geddes via OvmsDev:
>>>>>>>>                             OK. That's bad.
>>>>>>>>                             Does the reading work in general?
>>>>>>>>                             Is it just the writing commands?
>>>>>>>>                             Raise a ticket on github and tag me
>>>>>>>>                             in and we can address it that way.
>>>>>>>>                             Michael
>>>>>>>>                             On Sun, 28 Apr 2024, 19:49 Thomas
>>>>>>>>                             Heuer via OvmsDev,
>>>>>>>>                                 Hi,
>>>>>>>>                                 The new poller code doesn't
>>>>>>>>                                 seem to work properly with the
>>>>>>>>                                 smarted.
>>>>>>>>                                 D (218831) vehicle-poll:
>>>>>>>>                                 [1]PollerNextTick(PRI): cycle
>>>>>>>>                                 complete for ticker=215
>>>>>>>>                                 V (218831) vehicle-poll:
>>>>>>>>                                 Standard Poll Series: List reset
>>>>>>>>                                 PollSeriesList::NextPollEntry[!v.standard]:
>>>>>>>>                                 ReachedEnd
>>>>>>>>                                 [1]PollerSend: Poller Reached End
>>>>>>>>                                 D (219691) vehicle-poll:
>>>>>>>>                                 V (219691) vehicle-poll:
>>>>>>>>                                 Pollers: FrameRx(bus=2)
>>>>>>>>                                 *OVMS#*unlock 22
>>>>>>>>                                 Vehicle unlocked
>>>>>>>>                                 D (219701) vehicle-poll:
>>>>>>>>                                 V (219701) vehicle-poll:
>>>>>>>>                                 *Von:*OvmsDev
>>>>>>>>                                 <ovmsdev-bounces at lists.openvehicles.com>
>>>>>>>>                                 *Im Auftrag von *Michael Geddes
>>>>>>>>                                 via OvmsDev
>>>>>>>>                                 *Gesendet:* Sonntag, 28. April
>>>>>>>>                                 2024 12:27
>>>>>>>>                                 *An:* OVMS Developers
>>>>>>>>                                 *Cc:* Michael Geddes
>>>>>>>>                                 *Betreff:* [Ovmsdev] OVMS
>>>>>>>>                                 Hey all,
>>>>>>>>                                 The poller singleton code that
>>>>>>>>                                 I've been working on for over a
>>>>>>>>                                 year now is merged in. (Thanks
>>>>>>>>                                 Michael for expediting the
>>>>>>>>                                 final step).
>>>>>>>>                                 This includes separate
>>>>>>>>                                 multi-frame states per bus and
>>>>>>>>                                 multiple poll lists as well as
>>>>>>>>                                 non-blocking one off queries.
>>>>>>>>                                 As well as more 'states'.
>>>>>>>>                                 I have included some
>>>>>>>>                                 programming documentation in
>>>>>>>>                                 the change but am happy to
>>>>>>>>                                 supply more if needed.
>>>>>>>>                                 The ioniq 5 code has some
>>>>>>>>                                 examples of how it can be used.
>>>>>>>>                                 Some examples are:
>>>>>>>>                                 * grabbing the vin as a one
>>>>>>>>                                 shot without blocking
>>>>>>>>                                 * having a short list of
>>>>>>>>                                 queries that are polled quickly
>>>>>>>>                                 for obd2ecu (this also
>>>>>>>>                                 demonstrates using a shorter
>>>>>>>>                                 frame break value and then a
>>>>>>>>                                 break after successful a response)
>>>>>>>>                                 Have a play please!
>>>>>>>>                                 Also interested in hearing what
>>>>>>>>                                 user tools might be worth
>>>>>>>>                                 looking at next for the poller
>>>>>>>>                                 object.
>>>>>>>>                                 //.ichael G.
>>>>>>>>                                 _______________________________________________
>>>>>>>>                                 OvmsDev mailing list
>>>>>>>>                                 OvmsDev at lists.openvehicles.com
>>>>>>>>                                 http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>                             Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>                             Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240502/5f1e029e/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240502/5f1e029e/attachment-0001.sig>
