[Ovmsdev] OBD poller module shell proposal
Michael Geddes
Sun Mar 31 08:44:52 HKT 2024
I have pushed up changes for PR#966 as well as to the 'new-poller' branch
that handle the PollerStateTicker()
//.ichael
On Sat, 30 Mar 2024 at 08:39, Michael Geddes <frog at bunyip.wheelycreek.net>
wrote:
> Thanks so much for giving this a good run.
> I totally missed that about the purpose of PollerStateTicker() damn.
> I think I can call this on primary ticks only from PollerSend() itself
> outside of the mutex. That would work - I'll get onto that.
> In the original PR# 966 PollerSend() is an OvmsVehicle() member and as
> such this is a no-brainer.
> That would mean it will get called from the Rx/Poller task rather than the
> schedule (ticker1) task which is not necessarily a bad thing... but
> different.
> I believe that for the Poller implementation though, this will need to be
> an event similar to PollRunFinished() - which kind of has similar usage
> but occurs between (effectively) poller ticks (ie when all the
> entries in the list have been dealt with) rather than what will be at the
> beginning of each Primary tick.
> Unless you have an objection - I'll pass in (canbus* bus) to this -
> //.ichael
> On Fri, 29 Mar 2024 at 21:51, Michael Balzer <dexter at expeedo.de> wrote:
>> Michael,
>> first feedback: testing this revealed some strange issues with vehicle
>> state changes apparently not being detected or reacted to properly.
>> A quick first check shows you have changed the way, the
>> PollerStateTicker() hook works: it's now called independently from / as of
>> the component ticker.1 registration sequence after the poller's primary
>> send, rather than before.
>> The callback was explicitly meant to provide a means to change the poller
>> state just before the next poll would take place:
>> * PollerStateTicker: check for state changes (stub, override with
>> vehicle implementation)
>> * This is called by VehicleTicker1() just before the next PollerSend().
>> * Implement your poller state transition logic in this method, so the
>> changes
>> * will get applied immediately.
>> This change is already present in PR #966, so I'll delay merging that.
>> Apart from that, the new poller seems to work normally, i.e. the polling
>> scheme works and results are coming in, at least regarding ISOTP. I haven't
>> tested VWTP yet.
>> Am 26.03.24 um 08:46 schrieb Michael Geddes:
>> Yeah wow. So close and yet so far.
>> Fix pushed.
>> On Sat, 23 Mar 2024 at 21:58, Michael Balzer <dexter at expeedo.de> wrote:
>>> Michael,
>>> looking forward to test this, but trying to run your branch with the VW
>>> e-Up leads to an early crash boot loop.
>>> Apparently `OvmsPollers::PollSetPidList()` doesn't check for a NULL
>>> plist:
>>> 0x40195b6f is in OvmsPollers::PollSetPidList(canbus*,
>>> OvmsPoller::poll_pid_t const*, OvmsPoller::VehicleSignal*)
>>> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/poller/src/vehicle_poller.cpp:1201).
>>> 1196 bool hasbus[1+VEHICLE_MAXBUSSES];
>>> 1197 for (int i = 0 ; i <= VEHICLE_MAXBUSSES; ++i)
>>> 1198 hasbus[i] = false;
>>> 1199
>>> 1200 // Check for an Empty list.
>>> *1201 if (plist->txmoduleid == 0)*
>>> 1202 {
>>> 1203 plist = nullptr;
>>> 1204 ESP_LOGD(TAG, "PollSetPidList - Setting Empty List");
>>> 1205 }
>>> 0x401a2675 is in OvmsVehicle::PollSetPidList(canbus*,
>>> OvmsPoller::poll_pid_t const*)
>>> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/vehicle/vehicle.cpp:2278).
>>> 2273 return m_pollsignal;
>>> 2274 }
>>> 2275 void OvmsVehicle::PollSetPidList(canbus* bus, const
>>> OvmsPoller::poll_pid_t* plist)
>>> 2276 {
>>> 2277 m_poll_bus_default = bus;
>>> 2278 MyPollers.PollSetPidList(bus, plist, GetPollerSignal());
>>> 2279 }
>>> 2280 #endif
>>> 2281
>>> 2282 /**
>>> 0x4023209e is in OvmsVehicleVWeUp::OBDInit()
>>> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/vehicle_vweup/src/vweup_obd.cpp:233).
>>> 228 obd_state_t previous_state = m_obd_state;
>>> 229 m_obd_state = OBDS_Config;
>>> 230
>>> 231 if (previous_state != OBDS_Pause)
>>> 232 {
>>> *233 PollSetPidList(m_can1, NULL);*
>>> 234 PollSetThrottling(0);
>>> 235 PollSetResponseSeparationTime(1);
>>> 236
>>> 237 if (StandardMetrics.ms_v_charge_inprogress->AsBool())
>>> Am 21.03.24 um 10:17 schrieb Michael Geddes:
>>> I've pushed up my working tree here:
>>> https://github.com/frogonwheels/Open-Vehicle-Monitoring-System-3/tree/new-poller
>>> partly for feedback, and partly because I wanted it backed up!
>>> This incorporates about 10 pull/requests worth of work which is why I
>>> didn't even add it as a draft, so I see this as taking some number of
>>> months to push up.
>>> Of interest is really the final components/poller/src/vehicle_poller*
>>> files and how that has all come together.. I've added some preliminary
>>> documentation for that which I'm quite happy to accept any critiques or
>>> requests for specific information!
>>> The Duktape metrics 'stale, age' methods are probably ready for a p/r
>>> as-is.
>>> //.ichael
>>> On Sun, 17 Mar 2024 at 16:58, Michael Geddes <
>>> frog at bunyip.wheelycreek.net> wrote:
>>>> Thanks Michael,
>>>> I'll definitely add the config - pretty much sorted out the singleton
>>>> (except for the change of directory). Just wondering if I should rebase
>>>> this change down earlier or just keep it as the 'last change' that is
>>>> making the final break. It might be a better transition that way?
>>>> Anyway have a look at this little class below; we have a bunch of
>>>> different implementations for an event register and came up with the
>>>> OvmsCallBackRegister below.
>>>> In my example the event notification looks like this:
>>>> void PollRunFinished(canbus *bus)
>>>> m_runfinished_callback.Call(
>>>> [bus](const std::string &name, const PollCallback &cb)
>>>> cb(bus, nullptr);
>>>> I could possibly but it in main/ovms_utils.h ?? It could also use a
>>>> std:map to implement it, though I think we save space this way and tbh the
>>>> use case wouldn't be doing a lot of Register and Unregister which would be
>>>> the slowest operations... I've made it not shrink the list size .... but
>>>> again, not that important in the context.
>>>> Thoughts?
>>>> //.ichael
>>>> --------------8< -----------------------------------
>>>> /* Call-back register.
>>>> * The list does not shrink which is fine for this use-case.
>>>> * Can be made inexpensively threadsafe/re-entrant safe.
>>>> template <typename FN>
>>>> class OvmsCallBackRegister
>>>> private:
>>>> class CallbackEntry
>>>> public:
>>>> CallbackEntry(const std::string &caller, FN callback)
>>>> m_name = caller;
>>>> m_callback = callback;
>>>> ~CallbackEntry() {}
>>>> public:
>>>> std::string m_name;
>>>> FN m_callback;
>>>> typedef std::forward_list<CallbackEntry> callbacklist_t;
>>>> callbacklist_t m_list;
>>>> public:
>>>> ~OvmsCallBackRegister()
>>>> void Register(const std::string &nametag, FN callback)
>>>> // Replace
>>>> for (auto it = m_list.begin(); it != m_list.end(); ++it)
>>>> if ((*it).m_name == nametag)
>>>> (*it).m_callback = callback;
>>>> return;
>>>> if (!callback)
>>>> return;
>>>> if (!(*it).m_callback)
>>>> CallbackEntry &entry = *it;
>>>> entry.m_name = nametag;
>>>> entry.m_callback = callback;
>>>> return;
>>>> m_list.push_front(CallbackEntry(nametag, callback));
>>>> void Deregister(const std::string &nametag)
>>>> Register(nametag, nullptr);
>>>> typedef std::function<void (const std::string &nametag, FN
>>>> callback)> visit_fn_t;
>>>> void Call(visit_fn_t visit)
>>>> const CallbackEntry &entry = *it;
>>>> if (entry.m_callback)
>>>> visit(entry.m_name, entry.m_callback);
>>>> On Thu, 14 Mar 2024 at 12:08, Mark Webb-Johnson <mark at webb-johnson.net>
>>>> wrote:
>>>>> Michael,
>>>>> I suggest that if it is a separate component then better to move it to
>>>>> it’s own component directory (just as canopen is done).
>>>>> For completeness, I suggest it would also be good to include
>>>>> a CONFIG_OVMS_COMP_* sdkconfig (default: yes), and put that as a
>>>>> requirement for your component (as well as for any vehicle doing polling, I
>>>>> guess).
>>>>> Regards, Mark
>>>>> On 14 Mar 2024, at 11:01 AM, Michael Geddes <
>>>>> Thanks Michael, Mark,
>>>>> Sorry for not acknowledging earlier.. this feedback is great; I've
>>>>> just been cogitating on the consequences.
>>>>> I still have the Poller hanging onto the vehicle by a thread so I
>>>>> should just cut the thread making the Poller a separate singleton (it's
>>>>> still embedded in the vehicle class for now with a small interface joining
>>>>> them).
>>>>> If I do, does it need to get moved to a new directory or can it stay
>>>>> in the vehicle/ directory? The file vehicle_poller.cpp (and the _isotp and
>>>>> vwtp parts to it) are still pretty much as they were with only a change in
>>>>> class name..
>>>>> I think I just need the poller to get its own values of m_can1 etc and
>>>>> provide a different way of getting the feedback results.
>>>>> I also need to make sure I'm not cutting off the 'vehicle' class'
>>>>> access to non-solicited messages (ie stuff that is just on the bus).
>>>>> //.ichael
>>>>> On Mon, 11 Mar 2024 at 14:51, Michael Balzer <dexter at expeedo.de>
>>>>> wrote:
>>>>>> Actually, separating the poller from the vehicle was part of the plan
>>>>>> of reworking it into a job/worker architecture. I see no reason the
>>>>>> generalized poller would need to remain coupled to the vehicle.
>>>>>> That's why I placed the OBD single request command in the "obdii"
>>>>>> hierarchy (although a more proper naming would have been e.g. "isotp", but
>>>>>> changing the name or having both would confuse users -- and meanwhile the
>>>>>> poller also supports a non-ISO TP variant).
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 11.03.24 um 00:51 schrieb Mark Webb-Johnson:
>>>>>> Michael,
>>>>>> It depends on whether the poller can *only* be used in the vehicle
>>>>>> class or if it is a framework all by itself (for example with commands to
>>>>>> manually poll specific PIDs, etc).
>>>>>> If *only* within vehicle framework, then putting it as a sub-command
>>>>>> under ‘vehicle’ seems sensible.
>>>>>> If more general purpose, then perhaps look at ‘copen’
>>>>>> (component/canopen) as an example.
>>>>>> Regards, Mark.
>>>>>> On 10 Mar 2024, at 7:25 AM, Michael Geddes
>>>>>> <frog at bunyip.wheelycreek.net> <frog at bunyip.wheelycreek.net> wrote:
>>>>>> Hi all,
>>>>>> I know some of this (especially for the status) functionality is
>>>>>> predicated on code that's not gone up yet - however this is allowing
>>>>>> 'pause' and 'resume' of the poller (which has been merged).
>>>>>> My question is not so much about the functionality and status
>>>>>> information, but about the location of the *poller* subcommand. (See
>>>>>> below).
>>>>>> Should 'vehicle' be exclusively for switching the vehicle type?
>>>>>> Should the 'poller' command be top-level? Under obdii?
>>>>>> Thoughts welcome.
>>>>>> If you do vehicle poller pause then the last line reads 'Vehicle
>>>>>> OBD Polling is paused'
>>>>>> -------8<----------------------------------------
>>>>>> *OVMS# vehicle ?*
>>>>>> Usage: vehicle [list|module|poller|status]
>>>>>> list Show list of available vehicle modules
>>>>>> module Set (or clear) vehicle module
>>>>>> poller OBD polling status
>>>>>> status Show vehicle module status
>>>>>> *OVMS# vehicle poller ?*
>>>>>> Usage: vehicle poller [pause|resume]
>>>>>> pause Pause OBD Polling
>>>>>> resume Resume OBD Polling
>>>>>> *OVMS# vehicle poller*
>>>>>> OBD Polling running on bus 1 with an active list
>>>>>> Time between polling ticks is 1000ms with 1 secondary sub-ticks
>>>>>> Last poll command received 1s (ticks) ago.
>>>>>> Vehicle OBD Polling is running.
>>>>>> OvmsDev mailing list
>>>>>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240331/b76aa240/attachment-0001.htm>
