[Ovmsdev] OBD poller module shell proposal
Michael Geddes
Tue Mar 26 15:46:03 HKT 2024
Yeah wow. So close and yet so far.
Fix pushed.
On Sat, 23 Mar 2024 at 21:58, Michael Balzer <dexter at expeedo.de> wrote:
> Michael,
> looking forward to test this, but trying to run your branch with the VW
> e-Up leads to an early crash boot loop.
> Apparently `OvmsPollers::PollSetPidList()` doesn't check for a NULL plist:
> 0x40195b6f is in OvmsPollers::PollSetPidList(canbus*,
> OvmsPoller::poll_pid_t const*, OvmsPoller::VehicleSignal*)
> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/poller/src/vehicle_poller.cpp:1201).
> 1196 bool hasbus[1+VEHICLE_MAXBUSSES];
> 1197 for (int i = 0 ; i <= VEHICLE_MAXBUSSES; ++i)
> 1198 hasbus[i] = false;
> 1199
> 1200 // Check for an Empty list.
> *1201 if (plist->txmoduleid == 0)*
> 1202 {
> 1203 plist = nullptr;
> 1204 ESP_LOGD(TAG, "PollSetPidList - Setting Empty List");
> 1205 }
> 0x401a2675 is in OvmsVehicle::PollSetPidList(canbus*,
> OvmsPoller::poll_pid_t const*)
> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/vehicle/vehicle.cpp:2278).
> 2273 return m_pollsignal;
> 2274 }
> 2275 void OvmsVehicle::PollSetPidList(canbus* bus, const
> OvmsPoller::poll_pid_t* plist)
> 2276 {
> 2277 m_poll_bus_default = bus;
> 2278 MyPollers.PollSetPidList(bus, plist, GetPollerSignal());
> 2279 }
> 2280 #endif
> 2281
> 2282 /**
> 0x4023209e is in OvmsVehicleVWeUp::OBDInit()
> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/vehicle_vweup/src/vweup_obd.cpp:233).
> 228 obd_state_t previous_state = m_obd_state;
> 229 m_obd_state = OBDS_Config;
> 230
> 231 if (previous_state != OBDS_Pause)
> 232 {
> *233 PollSetPidList(m_can1, NULL);*
> 234 PollSetThrottling(0);
> 235 PollSetResponseSeparationTime(1);
> 236
> 237 if (StandardMetrics.ms_v_charge_inprogress->AsBool())
> Am 21.03.24 um 10:17 schrieb Michael Geddes:
> I've pushed up my working tree here:
> https://github.com/frogonwheels/Open-Vehicle-Monitoring-System-3/tree/new-poller
> partly for feedback, and partly because I wanted it backed up!
> This incorporates about 10 pull/requests worth of work which is why I
> didn't even add it as a draft, so I see this as taking some number of
> months to push up.
> Of interest is really the final components/poller/src/vehicle_poller*
> files and how that has all come together.. I've added some preliminary
> documentation for that which I'm quite happy to accept any critiques or
> requests for specific information!
> The Duktape metrics 'stale, age' methods are probably ready for a p/r
> as-is.
> //.ichael
> On Sun, 17 Mar 2024 at 16:58, Michael Geddes <frog at bunyip.wheelycreek.net>
> wrote:
>> Thanks Michael,
>> I'll definitely add the config - pretty much sorted out the singleton
>> (except for the change of directory). Just wondering if I should rebase
>> this change down earlier or just keep it as the 'last change' that is
>> making the final break. It might be a better transition that way?
>> Anyway have a look at this little class below; we have a bunch of
>> different implementations for an event register and came up with the
>> OvmsCallBackRegister below.
>> In my example the event notification looks like this:
>> void PollRunFinished(canbus *bus)
>> m_runfinished_callback.Call(
>> [bus](const std::string &name, const PollCallback &cb)
>> cb(bus, nullptr);
>> I could possibly but it in main/ovms_utils.h ?? It could also use a
>> std:map to implement it, though I think we save space this way and tbh the
>> use case wouldn't be doing a lot of Register and Unregister which would be
>> the slowest operations... I've made it not shrink the list size .... but
>> again, not that important in the context.
>> Thoughts?
>> //.ichael
>> --------------8< -----------------------------------
>> /* Call-back register.
>> * The list does not shrink which is fine for this use-case.
>> * Can be made inexpensively threadsafe/re-entrant safe.
>> template <typename FN>
>> class OvmsCallBackRegister
>> private:
>> class CallbackEntry
>> public:
>> CallbackEntry(const std::string &caller, FN callback)
>> m_name = caller;
>> m_callback = callback;
>> ~CallbackEntry() {}
>> public:
>> std::string m_name;
>> FN m_callback;
>> typedef std::forward_list<CallbackEntry> callbacklist_t;
>> callbacklist_t m_list;
>> public:
>> ~OvmsCallBackRegister()
>> void Register(const std::string &nametag, FN callback)
>> // Replace
>> for (auto it = m_list.begin(); it != m_list.end(); ++it)
>> if ((*it).m_name == nametag)
>> (*it).m_callback = callback;
>> return;
>> if (!callback)
>> return;
>> if (!(*it).m_callback)
>> CallbackEntry &entry = *it;
>> entry.m_name = nametag;
>> entry.m_callback = callback;
>> return;
>> m_list.push_front(CallbackEntry(nametag, callback));
>> void Deregister(const std::string &nametag)
>> Register(nametag, nullptr);
>> typedef std::function<void (const std::string &nametag, FN callback)>
>> visit_fn_t;
>> void Call(visit_fn_t visit)
>> const CallbackEntry &entry = *it;
>> if (entry.m_callback)
>> visit(entry.m_name, entry.m_callback);
>> On Thu, 14 Mar 2024 at 12:08, Mark Webb-Johnson <mark at webb-johnson.net>
>> wrote:
>>> Michael,
>>> I suggest that if it is a separate component then better to move it to
>>> it’s own component directory (just as canopen is done).
>>> For completeness, I suggest it would also be good to include
>>> a CONFIG_OVMS_COMP_* sdkconfig (default: yes), and put that as a
>>> requirement for your component (as well as for any vehicle doing polling, I
>>> guess).
>>> Regards, Mark
>>> On 14 Mar 2024, at 11:01 AM, Michael Geddes <frog at bunyip.wheelycreek.net>
>>> wrote:
>>> Thanks Michael, Mark,
>>> Sorry for not acknowledging earlier.. this feedback is great; I've just
>>> been cogitating on the consequences.
>>> I still have the Poller hanging onto the vehicle by a thread so I should
>>> just cut the thread making the Poller a separate singleton (it's still
>>> embedded in the vehicle class for now with a small interface joining them).
>>> If I do, does it need to get moved to a new directory or can it stay in
>>> the vehicle/ directory? The file vehicle_poller.cpp (and the _isotp and
>>> vwtp parts to it) are still pretty much as they were with only a change in
>>> class name..
>>> I think I just need the poller to get its own values of m_can1 etc and
>>> provide a different way of getting the feedback results.
>>> I also need to make sure I'm not cutting off the 'vehicle' class' access
>>> to non-solicited messages (ie stuff that is just on the bus).
>>> //.ichael
>>> On Mon, 11 Mar 2024 at 14:51, Michael Balzer <dexter at expeedo.de> wrote:
>>>> Actually, separating the poller from the vehicle was part of the plan
>>>> of reworking it into a job/worker architecture. I see no reason the
>>>> generalized poller would need to remain coupled to the vehicle.
>>>> That's why I placed the OBD single request command in the "obdii"
>>>> hierarchy (although a more proper naming would have been e.g. "isotp", but
>>>> changing the name or having both would confuse users -- and meanwhile the
>>>> poller also supports a non-ISO TP variant).
>>>> Regards,
>>>> Michael
>>>> Am 11.03.24 um 00:51 schrieb Mark Webb-Johnson:
>>>> Michael,
>>>> It depends on whether the poller can *only* be used in the vehicle
>>>> class or if it is a framework all by itself (for example with commands to
>>>> manually poll specific PIDs, etc).
>>>> If *only* within vehicle framework, then putting it as a sub-command
>>>> under ‘vehicle’ seems sensible.
>>>> If more general purpose, then perhaps look at ‘copen’
>>>> (component/canopen) as an example.
>>>> Regards, Mark.
>>>> On 10 Mar 2024, at 7:25 AM, Michael Geddes
>>>> <frog at bunyip.wheelycreek.net> <frog at bunyip.wheelycreek.net> wrote:
>>>> Hi all,
>>>> I know some of this (especially for the status) functionality is
>>>> predicated on code that's not gone up yet - however this is allowing
>>>> 'pause' and 'resume' of the poller (which has been merged).
>>>> My question is not so much about the functionality and status
>>>> information, but about the location of the *poller* subcommand. (See
>>>> below).
>>>> Should 'vehicle' be exclusively for switching the vehicle type? Should
>>>> the 'poller' command be top-level? Under obdii?
>>>> Thoughts welcome.
>>>> If you do vehicle poller pause then the last line reads 'Vehicle OBD
>>>> Polling is paused'
>>>> -------8<----------------------------------------
>>>> *OVMS# vehicle ?*
>>>> Usage: vehicle [list|module|poller|status]
>>>> list Show list of available vehicle modules
>>>> module Set (or clear) vehicle module
>>>> poller OBD polling status
>>>> status Show vehicle module status
>>>> *OVMS# vehicle poller ?*
>>>> Usage: vehicle poller [pause|resume]
>>>> pause Pause OBD Polling
>>>> resume Resume OBD Polling
>>>> *OVMS# vehicle poller*
>>>> OBD Polling running on bus 1 with an active list
>>>> Time between polling ticks is 1000ms with 1 secondary sub-ticks
>>>> Last poll command received 1s (ticks) ago.
>>>> Vehicle OBD Polling is running.
>>>> OvmsDev mailing list
>>>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240326/84e7a067/attachment-0001.htm>
