[Ovmsdev] Source for terminals for a roadster OVT1 cable?
Thu Jun 27 14:02:28 HKT 2024
Can you try the full describe command (like we use in the OVMS makefile):
git describe --always --tags --dirty
> On 27 Jun 2024, at 2:03 AM, Craig Leres via OvmsDev <ovmsdev at lists.openvehicles.com> wrote:
> I hadn't updated the build I run on my module since early April. Today I updated to 3.3.003-814-gd7013460, picked up the new CONFIG_OVMS_COMP_POLLER sdkconfig option, but when I run gmake I get *tons* of warnings (more than 300), e.g:
> gmake[1]: warning: undefined variable 'GNUMAKEFLAGS'
> The result seems to run ok.
> And I guess I don't understand why the "ota" version is different from what "git describe" reports.
> Craig
> OVMS# ota
> Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600
> Firmware: 3.3.004-117-gd7013460-dirty/ota_1/main (build idf v3.3.4-849-g6e214dc33 Jun 26 2024 10:55:23)
> Running partition: ota_1
> Boot partition: ota_1
> Factory image: 3.3.002
> OTA_O image: 3.3.004-20-g447fd7c4-dirty
> OTA_1 image: 3.3.004-117-gd7013460-dirty
> ice 266 % git describe
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240627/3f2744b5/attachment.htm>
