The messages can get out of sequence if there are temporary network issues.
For example (this case probably), IDs 1-5 get lost and need to be
retransmitted.
The protocol includes a time offset, and the server tries to adjust the
timestamp accordingly, but offset resolution is currently 1 second and
the server bases the corrections on it's own time, so there can be
discrepancies.
Am 23.06.24 um 11:03 schrieb Michael Geddes via OvmsDev:
> This is by-and-large working (pushed). The only thing is that
> occasionally the records seem to be coming in out-of-order. For
> example (after some munging with jq)
> "2024-06-23 05:28:16",6,"RxCan1[7bb]",13.63,5.933,8.526,0.06,3.685
> "2024-06-23 05:28:16",7,"RxCan1[7ce]",0.57,0.195,0.365,0.034,0.759
> "2024-06-23 05:28:16",8,"RxCan1[7ea]",4.41,1.796,2.416,0.052,1.557
> "2024-06-23 05:28:16",9,"RxCan1[7ec]",18.95,7.672,11.532,0.112,19.324
> "2024-06-23 05:28:16",10,"RxCan3[7df]",9.09,1.554,1.999,0.023,1.242
> "2024-06-23 05:28:16",16,"TxCan1[7e4]",2.15,0.06,0.094,0.003,0.079
> "2024-06-23 05:28:16",17,"Cmd:Thrtl",0,0,0.004,0.004,0.044
> "2024-06-23 05:28:16",18,"Cmd:RspSp",0,0,0.002,0.002,0.019
> "2024-06-23 05:28:16",19,"Cmd:SucSp",0,0,0.002,0.002,0.018
> "2024-06-23 05:28:16",20,"Cmd:State",0,0,0,0.01,0.104
> "2024-06-23 05:28:17",1,"Poll:PRI",1.07,0.472,0.565,0.039,0.675
> "2024-06-23 05:28:17",2,"Poll:SEC",2.17,0.433,0.527,0.02,0.474
> "2024-06-23 05:28:17",3,"Poll:SRX",6.51,1.369,1.952,0.022,0.524
> "2024-06-23 05:28:17",4,"RxCan1[778]",2.42,1.216,1.801,0.064,2.412
> "2024-06-23 05:28:17",5,"RxCan1[7a8]",0.9,0.367,0.769,0.045,1.343
> The items 1-5 should be before 6,but the timestamp is after.
> //.ichael
> *From:*OvmsDev <ovmsdev-bounces at lists.openvehicles.com> *On Behalf Of
> *Michael Balzer via OvmsDev
> *Sent:* Friday, June 21, 2024 11:40 PM
> *To:* OVMS Developers <ovmsdev at lists.openvehicles.com>
> *Cc:* Michael Balzer <dexter at expeedo.de>
> *Subject:* Re: [Ovmsdev] OVMS Poller module/singleton
> Michael,
> "data" notifications correspond to the V2/MP "historical" message type:
> * https://docs.openvehicles.com/en/latest/protocol_v2/messages.html#historical-data-update-message-0x48-h
> So a record type of "*-LOG-Poll" would be OK, but I suggest using
> "*-LOG-PollStats" to be more precise.
> The record ID needs to be an integer, and the default V2 server
> database defines this to be a 32 bit signed integer. Note that sending
> a new record won't overwrite an existing one with the same ID, as the
> timestamp is part of the primary key. I suggest using your report line
> number.
> You can provide a header as line 0 then, or you can leave adding a
> header to the download tool (as do all the other data records up to
> now). If you use my server, you can download all data from the car UI,
> if you use another public server, you can still use my download tool
> via this page:
> * https://dexters-web.de/downloadtool?lang=EN
> Download tools other than the ones I provide in my web UI are the
> scripts in the server repository's client directory:
> * https://github.com/openvehicles/Open-Vehicle-Server/tree/master/clients
> The most simple form is shown by the "serverlog.sh" script, for adding
> headers see e.g. "rt_fetchlogs.sh". I normally let my server send me
> the logs by mail on a daily base, these include all historical data
> files with headers added.
> Assuming record type "*-LOG-PollStats", I've just added auto headers
> to my tool based on your template as follows:
> * type,count_hz,avg_util_pm,peak_util_pm,avg_time_ms,peak_time_ms
> (keeping the header style consistent with the other logs)
> So you can now simply send the data rows, the tool will prepend the
> header once on each download.
> Am 19.06.24 um 11:10 schrieb Michael Geddes:
> Sure, I can do that.
> I did it this way because it was easier and could mostly do it in
> one message. As soon as I added spaces for alignment it pushed the
> message over 2 notifications. Also, I wasn't sure about making a
> new Data type and how that worked.
> I'm assuming something like: *-LOG-Poll would work (unless you
> want to suggest something else) The next 2 cols seem to be ID and
> lifetime.
> What do I use as an ID? Can it be an alpha string or does it have
> to be a number? (LIke using the first column descriptor). I'm not
> sure
> how the ID column is treated. I _could_ just send a line number
> for the dump group I guess?
> These are the columns I have. I can force the two cols to be
> always permille.
> "Type","Count (hz)","Avg utlization (permille)","Peak utlization
> (permille)", "Avg Time (ms)","Peak Time (ms)"
> Type is the only alpha column.. but if I can use that for the ID I
> guess that would be better?
> How would I provide a header if I wanted to? Is there some
> indicator saying it's a header line? I'm not sure I want to - just
> asking.
> //.ichael
> On Wed, 19 June 2024, 00:11 Michael Balzer via OvmsDev,
> <ovmsdev at lists.openvehicles.com> wrote:
> Michael,
> I've received the new drive report notifications now; these
> need to be changed: please do not use text notifications to
> transport CSV data. That's what "data" notifications are meant
> for, which are stored in their raw form on the server for
> later retrieval. See e.g. the vehicle trip & grid logs for
> reference on how to build the messages, or have a look at the
> specific Twizy and UpMiiGo data messages.
> Data notifications also are designed to transport one row at a
> time, so you normally don't run into buffer size issues. A
> header can be supplied as a row, but you normally add one when
> downloading the data from the server, so tools don't need to
> filter these out. I provide headers automatically on my server
> for known message types, just send me your template and I'll
> include that.
> Apart from that, the timing statistics now seem to work pretty
> well, providing valuable insights.
> Am 14.06.24 um 08:59 schrieb Michael Geddes:
> Thankyou.
> I was more worried that we might be waiting on each other.
> I don't think I have quite the correct able to test on my
> friends Leaf properly, or does it use the standard cable?
> Anyway, let me know what I can do to.
> //.ichael
> On Fri, 14 Jun 2024 at 14:46, Michael Balzer via OvmsDev
> Sorry, I know I'm behind with PRs.
> I'll try to find some time this weekend.
> Am 14.06.24 um 08:31 schrieb Michael Geddes via OvmsDev:
> Was this all good? I want to make sure I get to
> the bottom of this whole issue asap!
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/1018
> Was there something else you needed me to work on
> to make sure this all works for all supported cars?
> //.ichael
> On Sun, 26 May 2024 at 21:15, Michael Balzer via
> OvmsDev <ovmsdev at lists.openvehicles.com> wrote:
> OK, I see now why it wouldn't send the
> notification: the V2 & V3 server register for
> notifications up to COMMAND_RESULT_NORMAL =
> 1024 characters.
> The report quickly becomes larger than 1024
> characters, so the notifications no longer get
> sent via the server connectors.
> You need to either reduce the size, split the
> report, or use data notifications instead.
> On the reset value init: for my float
> targeting smoothing helper class for the
> UpMiiGo, I implemented a gradual ramp up from
> 1 to the requested sample size. You can do
> something similar also with powers of 2. IOW,
> yes, initialization from the first values
> received is perfectly OK.
> Am 26.05.24 um 14:35 schrieb Michael Geddes:
> It _/should/_ already be sending a report
> on charge stop.
> MyEvents.RegisterEvent(TAG,
> "vehicle.charge.stop",
> std::bind(&OvmsPollers::VehicleChargeStop,
> this, _1, _2));
> Reset on charge start/vehicle on is a good
> idea.
> A question – would it be silly if the
> first value after a reset, rather than
> using 0 average to start with, if the
> average got set to the initial value? I’m
> in 2 minds about it. It would make the
> average more useful quicker.
> //.ichael
> On Sun, 26 May 2024, 19:39 Michael Balzer
> via OvmsDev,
> As the averages quickly decline when
> idle, an automatic report should
> probably also be sent on charge stop.
> Also, I think you should automatically
> reset the timer statistics on drive &
> charge start.
> First stats from charging my UpMiiGo:
> Type | count | Utlztn | Time
> | per s | [‰] | [ms]
> Poll:PRI Avg| 1.00| 0.723| 0.716
> Peak| | 1.282| 3.822
> Poll:SRX Avg| 7.72| 1.246| 0.184
> Peak| | 3.128| 1.058
> RxCan1[7ae] Avg| 2.48| 0.915| 0.362
> Peak| | 1.217| 1.661
> RxCan1[7cf] Avg| 4.76| 1.928| 0.397
> Peak| | 2.317| 2.687
> RxCan1[7ed] Avg| 3.38| 1.251| 0.327
> Peak| | 8.154| 12.273
> RxCan1[7ee] Avg| 0.21| 0.066| 0.297
> Peak| | 0.225| 1.690
> TxCan1[744] Avg| 1.49| 0.022| 0.011
> Peak| | 0.032| 0.095
> TxCan1[765] Avg| 3.89| 0.134| 0.027
> Peak| | 0.155| 0.113
> TxCan1[7e5] Avg| 2.32| 0.038| 0.013
> Peak| | 0.295| 0.084
> TxCan1[7e6] Avg| 1 0.21| 0.002|
> 0.008
> Peak| | 0.010| 0.041
> Cmd:State Avg| 0.00| 0.000| 0.007
> Peak| | 0.005| 0.072
> Total Avg| 27.46| 6.324| 2.349
> Overall healthy I'd say, but let's see
> how it compares.
> 7ed is the BMS, the peak time is
> probably related to the extended cell
> data logging -- I've enabled log
> intervals for both cell voltages &
> temperatures.
> Am 26.05.24 um 08:42 schrieb Michael
> Balzer via OvmsDev:
> The notification works on my
> devices, it only has a garbled per
> mille character -- see attached
> screenshot. The same applies to
> the mail version:
> Poller timing is: on
> | per s | [‰] | [ms]
> Poll:PRI Avg| 0.25| 0.119| 0.382
> Peak| | 0.513| 0.678
> RxCan1[597] Avg| 0.01| 0.004| 0.021
> Peak| | 0.000| 0.338
> RxCan1[59b] Avg| 0.01| 0.011| 0.053
> Peak| | 0.000| 0.848
> Cmd:State Avg| 0.01| 0.002| 0.012
> Peak| | 0.000| 0.120
> Total Avg| 0.28| 0.135| 0.468
> The encoding is a general issue.
> The character encoding for text
> messages via V2/MP is quite old &
> clumsy, it's got an issue with the
> degree celcius character as well.
> We previously tried to keep all
> text messages within the SMS safe
> character set (which e.g. lead to
> writing just "C" instead of "°C").
> I'd say we should head towards
> UTF-8 now. If we ever refit SMS
> support, we can recode on the fly.
> Regarding not seeing the
> notification on your phone:
> a) Check your notification
> subtype/channel filters on the
> module. See
> https://docs.openvehicles.com/en/latest/userguide/notifications.html#suppress-notifications
> b) Check your notification vehicle
> filters on the phone (menu on
> notification tab): if you enabled
> the vehicle filter, it will add
> the messages of not currently
> selected vehicles to the list
> only, but not raise a system
> notification. (Applies to the
> Android App, no idea about the iOS
> version)
> Am 26.05.24 um 06:32 schrieb
> Michael Geddes:
> Hi,
> I'm trying to finalise this
> now .. and one last thing is
> that I don't get the report
> coming to my mobile. I'm using
> the command:
> MyNotify.NotifyString("info",
> "poller.report", buf.c_str());
> Where the buffer string is
> just the same as the report
> output. Should I be using some
> other format or command?
> I get "alert" types (like the
> ioniq5 door-open alert) fine
> to my mobile.
> Michael.
> On Sun, 19 May 2024, 12:51
> wrote:
> A builtin web UI for this
> seems a bit over the top.
> Builtin web config pages
> should focus on user
> features, this is clearly
> a feature only needed
> during/for the
> development/extension of a
> vehicle adapter.
> Development features in
> the web UI are confusing
> for end users.
> If persistent
> enabling/disabling is done
> by a simple config command
> (e.g. "config set can
> poller.trace on"), that's
> also doable by users.
> Am 19.05.24 um 02:06
> I was so focused on
> how I calculated the
> value that I totally
> missed that ‰ would be
> a better description.
> I could also use the
> system 'Ratio' unit...
> so % or ‰.
> I'll make space to put
> 'Avg' on the row. Was
> trying to limit the
> width for output on a
> mobile. I agree it
> would make it easier
> to understand.
> Totals also makes sense.
> Should I make this a
> configuration that can
> be set on the
> web-page? I'd
> probably use a
> configuration change
> notification so that
> the very bit setting
> is sync'd with the
> 'configuration' value.
> //.ichael
> On Sat, 18 May 2024,
> 14:05 Michael Balzer,
> <dexter at expeedo.de> wrote:
> I'm not sure
> whether the
> 'max' should
> be the maximum
> of the
> smoothed
> value.. or the
> maximum of the
> raw value.
> It should normally
> be the maximum of
> the raw value I
> think, the maximum
> of the smoothed
> value cannot tell
> about how bad the
> processing of an
> ID can become.
> The naming in the
> table is a bit
> confusing I think.
> (besides: I've
> never seen "ave"
> as the
> abbreviation for
> average)
> If I understand
> you correctly,
> "time ms per s" is
> the time share in
> per mille, so
> something in that
> direction would be
> more clear, and
> "length ms" would
> then be "time [ms]".
> The totals for all
> averages in the
> table foot would
> also be nice.
> Maybe "Ave" (or
> avg?) also should
> be placed on the
> left, as the
> "peak" label now
> suggests being the
> peak of the average.
> Btw, keep in mind,
> not all "edge"
> users / testers
> are developers
> (e.g. the Twizy
> driver I'm in
> contact with),
> collecting stats
> feedback for
> vehicles from
> testers should be
> straight forward.
> Maybe add a
> data/history
> record, sent
> automatically on
> every drive/charge
> stop when the
> poller tracing is on?
> Am 18.05.24 um
> 02:28 schrieb
> Michael Geddes:
> You did say
> max/pead
> value. I also
> halved the N
> for both.
> I'm not sure
> whether the
> 'max' should
> be the maximum
> of the
> smoothed
> value.. or the
> maximum of the
> raw value.
> This is
> currently the
> raw-value
> maximum.
> The problem is
> that the
> middle column
> is the maximum
> of the {{sum
> over 10s} /
> (10*1000,000)
> I could easily
> change the
> 'period' to 1s
> and see how
> that goes..
> was just
> trying to
> reduce the
> larger
> calculations.
> Usage: poller
> [pause|resume|status|times|trace]
> OVMS# poller
> time status
> Poller timing
> is: on
> Type |
> Count | Ave
> time | Ave length
> per s | ms
> per s | ms
> Poll:PRI |
> 1.00|
> 0.559| 0.543
> peak |
> 0.663| 1.528
> Poll:SRX |
> 0.08|
> 0.009| 0.038
> peak |
> 0.068| 0.146
> CAN1 RX[778] |
> 0.11|
> 0.061| 0.280
> peak |
> 0.458| 1.046
> CAN1 RX[7a8] |
> 0.04|
> 0.024| 0.124
> peak |
> 0.160| 0.615
> CAN1 TX[770] |
> 0.05|
> 0.004| 0.016
> peak |
> 0.022| 0.102
> CAN1 TX[7a0] |
> 0.02|
> 0.002| 0.011
> peak |
> 0.010| 0.098
> CAN1 TX[7b3] |
> 0.01|
> 0.001| 0.006
> peak |
> 0.000| 0.099
> CAN1 TX[7e2] |
> 0.02|
> 0.002| 0.011
> peak |
> 0.010| 0.099
> CAN1 TX[7e4] |
> 0.08|
> 0.008| 0.048
> peak |
> 0.049| 0.107
> Cmd:State |
> 0.00|
> 0.000| 0.005
> peak |
> 0.000| 0.094
> On Fri, 17 May
> 2024 at 15:26,
> Michael Geddes
> <frog at bunyip.wheelycreek.net>
> wrote:
> This is
> what I
> have now.
> The one on
> the end is
> the one
> MIchael B
> was after
> using an N
> of 32. (up
> for
> discussion).
> The middle
> is the
> time spent
> in that
> even t per
> second.
> It
> accumulates
> times (in
> microseconds),
> and then
> every 10s
> it stores
> it as
> smoothed (N=16)
> value.
> The Count
> is similar
> (except
> that we
> store a
> value of
> '100' as 1
> event so
> it can be
> still
> integers
> and has 2
> decimal
> places).
> Every
> received
> poll does
> a
> 64bit difference
> to 32bit
> (for the
> elapsed
> time) and
> 64bit
> comparison
> (for
> end-of-period).
> It also
> does 1x
> 32bit
> smoothing
> and 2x
> 32bit adds.
> Then at
> the end of
> a 10s
> period, it
> will do a
> 64bit add
> to get the
> next
> end-of-period
> value, as
> well as
> the 2x
> 32bit
> smoothing
> calcs.
> This is
> from the
> Ioniq 5 so
> not any
> big values
> yet. You
> can
> certainly
> see how
> insignificant
> the TX
> callbacks are.
> I'll leave
> it on for
> when the
> car is
> moving and
> gets some
> faster
> polling.
> OVMS# poll
> time status
> Poller
> timing is: on
> Type
> | Count
> | Ave
> time |
> Ave Length
> | per s
> | ms
> per s | ms
> Poll:PRI
> 1.00|
> 0.540| 0.539
> Poll:SRX
> 0.03|
> 0.004| 0.017
> CAN1
> RX[778] |
> 0.06|
> 0.042| 0.175
> CAN1
> TX[770] |
> 0.04|
> 0.002| 0.008
> Cmd:State
> 0.01|
> 0.001| 0.005
> ----------------------8<--------------------------------
> Nice
> smoothing
> class
> (forces N
> as a power
> of 2):
> constexpr
> unsigned
> floorlog2(unsigned
> x)
> return
> x == 1 ? 0
> 1+floorlog2(x
> >> 1);
> Maintain a
> smoothed
> average
> using
> shifts for
> division.
> * T
> should be
> an integer
> type
> * N
> needs to
> be a power
> of 2
> template
> <typename
> T, unsigned N>
> class
> average_util_t
> private:
> T m_ave;
> public:
> average_util_t()
> : m_ave(0) {}
> static
> const
> uint8_t
> _BITS =
> floorlog2(N);
> void
> add( T val)
> static_assert(N
> == (1 <<
> _BITS), "N
> must be a
> power of 2");
> m_ave =
> (((N-1) *
> m_ave) +
> val) >> _BITS;
> T
> get() {
> return
> m_ave; }
> operator
> T() {
> return
> m_ave; }
> On Thu, 16
> May 2024
> at 10:29,
> Geddes
> wrote:
> Thanks
> Michael,
> My
> calculations
> give
> me
> ((2^32)-1)
> (1000*1000*3600)
> = only
> 1.2
> hours
> of
> processing
> time
> in
> 32bit.
> The
> initial
> subtraction
> is
> 64bit
> anyway
> and I
> can't
> see a
> further 64bit
> addition
> being
> a
> problem.
> I have
> the
> calculations
> being
> performed
> in
> doubles
> at
> print-out
> where
> performance
> is not
> really
> an
> issue
> anyway.
> (Though
> apparently
> doing
> 64 bit
> division
> is
> worse
> than
> floating
> point).
> In
> addition
> * I
> currently have
> this
> being
> able
> to be
> turned
> on and
> off
> and
> reset
> manually
> (only
> do it
> when
> required).
> * For
> the
> lower
> volume
> commands,
> the
> smoothed
> average
> is not
> going
> to be
> useful
> - the
> count
> is
> more
> interesting
> for
> different
> reasons.
> * The
> total
> time
> is
> quite
> useful.
> Ie a
> high
> average
> time
> doesn't
> matter
> if the
> count
> is
> low.
> The
> things
> that
> are
> affecting
> performance
> are
> stuff
> with
> high
> total
> time.
> Stuff
> which
> is
> happening
> 100
> times
> a
> second
> needs
> to be
> a much
> lower
> average
> than
> once a
> second.
> * A
> measure
> like
> 'time
> per
> minute/second'
> and
> possibly
> count
> per
> minute/seconds
> as a
> smoothed average
> would
> potentially
> be
> more
> useful.
> (or in
> addition?)
> I
> think
> we
> could
> do
> _that_
> in a
> reasonably
> efficient
> manner
> using
> a 64
> bit
> 'last
> measured
> time',
> a 32
> bit
> accumulated
> value
> and
> the
> stored
> 32 bit
> rolling
> average.
> It
> would
> boils
> down
> to
> some
> iterative
> (integer)
> sums
> and
> multiplications
> plus a
> divide
> by n ^
> (time
> periods
> passed)
> which
> is a
> shift
> - and
> which
> can be
> optimised
> to '0'
> if
> 'time-periods-passed'
> is
> more
> than
> 32/(bits-per-n)
> effectively
> limiting
> the
> number
> of
> iterations.
> The
> one
> issue
> I can
> see is
> that
> we
> need
> to
> calculate
> 'number
> of
> time-periods
> passed'
> which
> is a
> 64 bit
> subtraction
> followed
> by a
> 32 bit
> division
> (not
> optimisable to
> a
> simple
> shift).
> * I'm
> also
> happy
> to
> keep a
> rolling
> (32bit)
> average
> time.
> Even
> if you
> assume
> averages
> in the
> 100ms,
> 32bit
> is
> going
> to
> happily
> support
> an N
> of 64
> or
> even 128.
> Am
> I
> right
> in
> thinking
> that
> the
> choice
> of N
> is
> highly
> dependent
> on
> frequency.
> For
> things
> happening
> 100
> times
> per
> second,
> you
> might
> want
> an N
> like
> 128..
> where
> things
> happening
> once per
> second,
> you
> might
> want
> an N
> of 4
> or 8.
> The
> other
> things
> we
> keep
> track
> of in
> this
> manner
> we
> have a
> better
> idea
> of the
> frequency
> of the
> thing.
> How
> about
> we
> have
> (per
> record
> type):
> total
> count
> (since
> last
> reset?)
> (32 bit)
> smoothed
> average
> of
> time
> per
> instance
> (32 bit)
> ?xx?
> total
> accumulated
> time
> since
> last
> reset
> (64bit)
> with
> the
> below
> stats
> this
> is
> much
> less
> useful
> last-measured-time
> (64 bit)
> accumulated
> count
> since
> last
> time-period
> (16bit
> - but
> maybe
> 32bit
> anyway
> for
> byte
> alignment?)
> smoothed
> average
> of
> count
> per
> time-period
> (32bit)
> accumulated
> time
> since
> last
> time-period
> (32bit)
> smoothed
> average
> of
> time
> per
> time-period
> (32bit)
> It's
> possible
> to
> keep the
> Is
> this
> going
> to be
> too
> much
> per
> record
> type?
> The
> number
> of
> 'records'
> we are
> keeping
> is
> quite
> low
> (so 10
> to 20
> maybe)
> - so
> it's
> not a
> huge
> memory
> burden.
> Thoughts?
> //.ichael
> On
> Thu,
> 16 May
> 2024
> at
> 03:09,
> Balzer
> via
> OvmsDev
> wrote:
> esp_timer_get_time()
> is
> the
> right
> choice
> for
> precision
> timing.
> I'd
> say
> uint32
> is
> enough
> though,
> even
> if
> counting
> microseconds
> that
> can
> hold
> a
> total
> of
> more
> than
> 71
> hours
> of
> actual
> processing
> time.
> uint64
> has
> a
> significant
> performance
> penalty,
> although
> I
> don't
> recall
> the
> overhead
> for
> simple
> additions.
> Also
> more
> important,
> the
> average
> wouldn't
> be
> my
> main
> focus,
> but
> the
> maximum
> processing
> time
> seen
> per
> ID,
> which
> seems
> to
> be
> missing
> in
> your
> draft.
> Second
> thought
> on
> the
> average…
> the
> exact
> overall
> average
> really
> has
> a
> minor
> meaning,
> I'd
> rather
> see
> the
> current
> average,
> adapting
> to
> the
> current
> mode
> of
> operation
> (drive/charge/…).
> I
> suggest
> feeding
> the
> measurements
> to
> a
> low
> pass
> filter
> to
> get
> the
> smoothed
> average
> of
> the
> last
> n
> measurements.
> Pattern:
> runavg
> ((N-1)
> runavg
> newval)
> / N
> By
> using
> a
> low
> power
> of
> 2
> for
> N
> (e.g.
> 8
> or
> 16),
> you
> can
> replace
> the
> division
> by
> a
> simple
> bit
> shift,
> and
> have
> enough
> headroom
> to
> use
> 32
> bit
> integers.
> Am
> 15.05.24
> um
> 06:51
> schrieb
> Geddes
> via
> OvmsDev:
> Formatting
> aside,
> I
> have
> implemented
> what
> I
> think
> B
> was
> suggesting.
> This
> is
> a
> sample
> run
> on
> the
> Ioniq
> 5
> (which
> doesn't
> have
> unsolicited RX
> events).
> This
> uses
> the
> call esp_timer_get_time()
> got
> get
> a
> 64bit
> *microseconds*
> since
> started
> value
> and
> works
> out
> the
> time
> to
> execute
> that
> way.
> It's
> looking
> at
> absolute
> time
> and
> not
> time
> in
> the
> Task
> so
> other
> things
> going
> on
> at
> the
> same
> time
> in
> other
> tasks
> will
> have
> an
> effect.
> (The
> normal
> tick
> count
> doesn't
> have
> nearly
> enough
> resolution
> to
> be
> useful
> any
> other
> ideas
> on
> measurement?)
> I've
> got
> total
> accumulated
> time
> displaying
> in
> seconds
> and
> the
> average
> in
> milliseconds
> currently
> but
> I
> can
> change
> that
> easy
> enough.
> The
> cumulative
> time
> is
> stored
> as
> uint64_t
> which
> will
> be
> plenty,
> as
> 32bit
> wouldn't
> be
> nearly
> enough.
> OVMS#
> *poller
> time
> on*
> Poller
> timing
> is
> now
> on
> OVMS#
> *poller
> time
> status*
> Poller
> timing
> is:
> on
> Poll
> [PRI]
> n=390
> tot=0.2s
> ave=0.586ms
> Poll
> [SRX]
> n=316
> tot=0.1s
> ave=0.196ms
> CAN1
> RX[0778]
> n=382
> tot=0.2s
> ave=0.615ms
> CAN1
> RX[07a8]
> n=48
> tot=0.0s
> ave=0.510ms
> CAN1
> RX[07bb]
> n=162
> tot=0.1s
> ave=0.519ms
> CAN1
> RX[07ce]
> n=33
> tot=0.0s
> ave=0.469ms
> CAN1
> RX[07ea]
> n=408
> tot=0.2s
> ave=0.467ms
> CAN1
> RX[07ec]
> n=486
> tot=0.2s
> ave=0.477ms
> CAN3
> RX[07df]
> n=769
> tot=0.2s
> ave=0.261ms
> CAN1
> TX[0770]
> n=191
> tot=0.0s
> ave=0.054ms
> CAN1
> TX[07a0]
> n=16
> tot=0.0s
> ave=0.047ms
> CAN1
> TX[07b3]
> n=31
> tot=0.0s
> ave=0.069ms
> CAN1
> TX[07c6]
> n=11
> tot=0.0s
> ave=0.044ms
> CAN1
> TX[07e2]
> n=82
> tot=0.0s
> ave=0.067ms
> CAN1
> TX[07e4]
> n=54
> tot=0.0s
> ave=0.044ms
> Set
> State
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240623/ccb64316/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240623/ccb64316/attachment-0001.sig>
