Sorry, I know I'm behind with PRs.
I'll try to find some time this weekend.
Am 14.06.24 um 08:31 schrieb Michael Geddes via OvmsDev:
> Was this all good? I want to make sure I get to the bottom of this
> whole issue asap!
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/1018
> Was there something else you needed me to work on to make sure this
> all works for all supported cars?
> //.ichael
> On Sun, 26 May 2024 at 21:15, Michael Balzer via OvmsDev
> <ovmsdev at lists.openvehicles.com> wrote:
> OK, I see now why it wouldn't send the notification: the V2 & V3
> server register for notifications up to COMMAND_RESULT_NORMAL =
> 1024 characters.
> The report quickly becomes larger than 1024 characters, so the
> notifications no longer get sent via the server connectors.
> You need to either reduce the size, split the report, or use data
> notifications instead.
> On the reset value init: for my float targeting smoothing helper
> class for the UpMiiGo, I implemented a gradual ramp up from 1 to
> the requested sample size. You can do something similar also with
> powers of 2. IOW, yes, initialization from the first values
> received is perfectly OK.
> Am 26.05.24 um 14:35 schrieb Michael Geddes:
>> It _/should/_ already be sending a report on charge stop.
>> MyEvents.RegisterEvent(TAG, "vehicle.charge.stop",
>> std::bind(&OvmsPollers::VehicleChargeStop, this, _1, _2));
>> Reset on charge start/vehicle on is a good idea.
>> A question – would it be silly if the first value after a reset,
>> rather than using 0 average to start with, if the average got set
>> to the initial value? I’m in 2 minds about it. It would make the
>> average more useful quicker.
>> //.ichael
>> On Sun, 26 May 2024, 19:39 Michael Balzer via OvmsDev,
>> As the averages quickly decline when idle, an automatic
>> report should probably also be sent on charge stop.
>> Also, I think you should automatically reset the timer
>> statistics on drive & charge start.
>> First stats from charging my UpMiiGo:
>> Type | count | Utlztn | Time
>> | per s | [‰] | [ms]
>> Poll:PRI Avg| 1.00| 0.723| 0.716
>> Peak| | 1.282| 3.822
>> Poll:SRX Avg| 7.72| 1.246| 0.184
>> Peak| | 3.128| 1.058
>> RxCan1[7ae] Avg| 2.48| 0.915| 0.362
>> Peak| | 1.217| 1.661
>> RxCan1[7cf] Avg| 4.76| 1.928| 0.397
>> Peak| | 2.317| 2.687
>> RxCan1[7ed] Avg| 3.38| 1.251| 0.327
>> Peak| | 8.154| 12.273
>> RxCan1[7ee] Avg| 0.21| 0.066| 0.297
>> Peak| | 0.225| 1.690
>> TxCan1[744] Avg| 1.49| 0.022| 0.011
>> Peak| | 0.032| 0.095
>> TxCan1[765] Avg| 3.89| 0.134| 0.027
>> Peak| | 0.155| 0.113
>> TxCan1[7e5] Avg| 2.32| 0.038| 0.013
>> Peak| | 0.295| 0.084
>> TxCan1[7e6] Avg| 1 0.21| 0.002| 0.008
>> Peak| | 0.010| 0.041
>> Cmd:State Avg| 0.00| 0.000| 0.007
>> Peak| | 0.005| 0.072
>> Total Avg| 27.46| 6.324| 2.349
>> Overall healthy I'd say, but let's see how it compares.
>> 7ed is the BMS, the peak time is probably related to the
>> extended cell data logging -- I've enabled log intervals for
>> both cell voltages & temperatures.
>> Am 26.05.24 um 08:42 schrieb Michael Balzer via OvmsDev:
>> The notification works on my devices, it only has a
>> garbled per mille character -- see attached screenshot.
>> The same applies to the mail version:
>> Poller timing is: on
>> | per s | [‰] | [ms]
>> Poll:PRI Avg| 0.25| 0.119| 0.382
>> Peak| | 0.513| 0.678
>> RxCan1[597] Avg| 0.01| 0.004| 0.021
>> Peak| | 0.000| 0.338
>> RxCan1[59b] Avg| 0.01| 0.011| 0.053
>> Peak| | 0.000| 0.848
>> Cmd:State Avg| 0.01| 0.002| 0.012
>> Peak| | 0.000| 0.120
>> Total Avg| 0.28| 0.135| 0.468
>> The encoding is a general issue. The character encoding
>> for text messages via V2/MP is quite old & clumsy, it's
>> got an issue with the degree celcius character as well.
>> We previously tried to keep all text messages within the
>> SMS safe character set (which e.g. lead to writing just
>> "C" instead of "°C"). I'd say we should head towards
>> UTF-8 now. If we ever refit SMS support, we can recode on
>> the fly.
>> Regarding not seeing the notification on your phone:
>> a) Check your notification subtype/channel filters on the
>> module. See
>> https://docs.openvehicles.com/en/latest/userguide/notifications.html#suppress-notifications
>> b) Check your notification vehicle filters on the phone
>> (menu on notification tab): if you enabled the vehicle
>> filter, it will add the messages of not currently
>> selected vehicles to the list only, but not raise a
>> system notification. (Applies to the Android App, no idea
>> about the iOS version)
>> Am 26.05.24 um 06:32 schrieb Michael Geddes:
>> Hi,
>> I'm trying to finalise this now .. and one last thing
>> is that I don't get the report coming to my mobile.
>> I'm using the command:
>> MyNotify.NotifyString("info", "poller.report",
>> buf.c_str());
>> Where the buffer string is just the same as the
>> report output. Should I be using some other format
>> or command?
>> I get "alert" types (like the ioniq5 door-open alert)
>> fine to my mobile.
>> Michael.
>> On Sun, 19 May 2024, 12:51 Michael Balzer via
>> OvmsDev, <ovmsdev at lists.openvehicles.com> wrote:
>> A builtin web UI for this seems a bit over the
>> top. Builtin web config pages should focus on
>> user features, this is clearly a feature only
>> needed during/for the development/extension of a
>> vehicle adapter. Development features in the web
>> UI are confusing for end users.
>> If persistent enabling/disabling is done by a
>> simple config command (e.g. "config set can
>> poller.trace on"), that's also doable by users.
>> Am 19.05.24 um 02:06 schrieb Michael Geddes:
>> I was so focused on how I calculated the
>> value that I totally missed that ‰ would be a
>> better description. I could also use the
>> system 'Ratio' unit... so % or ‰.
>> I'll make space to put 'Avg' on the row. Was
>> trying to limit the width for output on a
>> mobile. I agree it would make it easier to
>> understand.
>> Totals also makes sense.
>> Should I make this a configuration that can
>> be set on the web-page? I'd probably use a
>> configuration change notification so that the
>> very bit setting is sync'd with the
>> 'configuration' value.
>> //.ichael
>> On Sat, 18 May 2024, 14:05 Michael Balzer,
>> <dexter at expeedo.de> wrote:
>> I'm not sure whether the 'max' should
>> be the maximum of the smoothed
>> value.. or the maximum of the raw value.
>> It should normally be the maximum of the
>> raw value I think, the maximum of the
>> smoothed value cannot tell about how bad
>> the processing of an ID can become.
>> The naming in the table is a bit
>> confusing I think. (besides: I've never
>> seen "ave" as the abbreviation for average)
>> If I understand you correctly, "time ms
>> per s" is the time share in per mille, so
>> something in that direction would be more
>> clear, and "length ms" would then be
>> "time [ms]".
>> The totals for all averages in the table
>> foot would also be nice.
>> Maybe "Ave" (or avg?) also should be
>> placed on the left, as the "peak" label
>> now suggests being the peak of the average.
>> Btw, keep in mind, not all "edge" users /
>> testers are developers (e.g. the Twizy
>> driver I'm in contact with), collecting
>> stats feedback for vehicles from testers
>> should be straight forward. Maybe add a
>> data/history record, sent automatically
>> on every drive/charge stop when the
>> poller tracing is on?
>> Am 18.05.24 um 02:28 schrieb Michael Geddes:
>> You did say max/pead value. I also
>> halved the N for both.
>> This is currently the raw-value maximum.
>> The problem is that the middle column
>> is the maximum of the {{sum over 10s}
>> / (10*1000,000)
>> I could easily change the 'period' to
>> 1s and see how that goes.. was just
>> trying to reduce the larger
>> calculations.
>> Usage: poller
>> [pause|resume|status|times|trace]
>> OVMS# poller time status
>> Type | Count | Ave time |
>> Ave length
>> | per s | ms per s | ms
>> Poll:PRI | 1.00| 0.559| 0.543
>> peak | | 0.663| 1.528
>> Poll:SRX | 0.08| 0.009| 0.038
>> peak | | 0.068| 0.146
>> CAN1 RX[778] | 0.11| 0.061| 0.280
>> peak | | 0.458| 1.046
>> CAN1 RX[7a8] | 0.04| 0.024| 0.124
>> peak | | 0.160| 0.615
>> CAN1 TX[770] | 0.05| 0.004| 0.016
>> peak | | 0.022| 0.102
>> CAN1 TX[7a0] | 0.02| 0.002| 0.011
>> peak | | 0.010| 0.098
>> CAN1 TX[7b3] | 0.01| 0.001| 0.006
>> peak | | 0.000| 0.099
>> CAN1 TX[7e2] | 0.02| 0.002| 0.011
>> peak | | 0.010| 0.099
>> CAN1 TX[7e4] | 0.08| 0.008| 0.048
>> peak | | 0.049| 0.107
>> Cmd:State | 0.00| 0.000| 0.005
>> peak | | 0.000| 0.094
>> On Fri, 17 May 2024 at 15:26, Michael
>> Geddes <frog at bunyip.wheelycreek.net>
>> wrote:
>> This is what I have now.
>> The one on the end is the one
>> MIchael B was after using an N of
>> 32. (up for discussion).
>> The middle is the time spent in
>> that even t per second. It
>> accumulates times (in
>> microseconds), and then every 10s
>> it stores it as smoothed (N=16)
>> value.
>> The Count is similar (except that
>> we store a value of '100' as 1
>> event so it can be still integers
>> and has 2 decimal places).
>> Every received poll does a
>> 64bit difference to 32bit (for
>> the elapsed time) and 64bit
>> comparison (for end-of-period).
>> It also does 1x 32bit smoothing
>> and 2x 32bit adds.
>> Then at the end of a 10s period,
>> it will do a 64bit add to get the
>> next end-of-period value, as well
>> as the 2x 32bit smoothing calcs.
>> This is from the Ioniq 5 so not
>> any big values yet. You can
>> certainly see how insignificant
>> the TX callbacks are.
>> I'll leave it on for when the car
>> is moving and gets some faster
>> polling.
>> OVMS# poll time status
>> Type | Count | Ave
>> time | Ave Length
>> | per s | ms per
>> s | ms
>> Poll:PRI | 1.00| 0.540|
>> 0.539
>> Poll:SRX | 0.03| 0.004|
>> 0.017
>> CAN1 RX[778] | 0.06| 0.042|
>> 0.175
>> CAN1 TX[770] | 0.04| 0.002|
>> 0.008
>> Cmd:State | 0.01| 0.001|
>> 0.005
>> ----------------------8<--------------------------------
>> Nice smoothing class (forces N as
>> a power of 2):
>> constexpr unsigned
>> floorlog2(unsigned x)
>> return x == 1 ? 0 :
>> 1+floorlog2(x >> 1);
>> /* Maintain a smoothed average
>> using shifts for division.
>> * T should be an integer type
>> * N needs to be a power of 2
>> template <typename T, unsigned N>
>> class average_util_t
>> private:
>> T m_ave;
>> public:
>> average_util_t() : m_ave(0) {}
>> static const uint8_t _BITS
>> = floorlog2(N);
>> void add( T val)
>> static_assert(N == (1 << _BITS),
>> "N must be a power of 2");
>> m_ave = (((N-1) * m_ave)
>> + val) >> _BITS;
>> T get() { return m_ave; }
>> operator T() { return m_ave; }
>> On Thu, 16 May 2024 at 10:29,
>> Michael Geddes
>> <frog at bunyip.wheelycreek.net> wrote:
>> Thanks Michael,
>> My calculations give me
>> ((2^32)-1) / (1000*1000*3600)
>> = only 1.2 hours of
>> processing time in 32bit.
>> The initial subtraction is
>> 64bit anyway and I can't see
>> a further 64bit addition
>> being a problem. I have the
>> calculations being performed
>> in doubles at print-out where
>> performance is not really an
>> issue anyway. (Though
>> apparently doing 64 bit
>> division is worse than
>> floating point).
>> In addition
>> * I currently have this being
>> able to be turned on and off
>> and reset manually (only do
>> it when required).
>> * For the lower volume
>> commands, the smoothed
>> average is not going to be
>> useful - the count is more
>> interesting for different
>> reasons.
>> * The total time is quite
>> useful. Ie a high average
>> time doesn't matter if the
>> count is low. The things that
>> are affecting performance are
>> stuff with high total time.
>> Stuff which is happening 100
>> times a second needs to be a
>> much lower average than once
>> a second.
>> * A measure like 'time per
>> minute/second' and possibly
>> count per minute/seconds as a
>> smoothed average would
>> potentially be more useful.
>> (or in addition?)
>> I think we could do _that_ in
>> a reasonably efficient manner
>> using a 64 bit 'last measured
>> time', a 32 bit accumulated
>> value and the stored 32 bit
>> rolling average.
>> It would boils down to some
>> iterative (integer) sums and
>> multiplications plus a divide
>> by n ^ (time periods passed)
>> - which is a shift - and
>> which can be optimised to '0'
>> if 'time-periods-passed' is
>> more than 32/(bits-per-n) -
>> effectively limiting the
>> number of iterations.
>> The one issue I can see is
>> that we need to calculate
>> 'number of time-periods
>> passed' which is a 64 bit
>> subtraction followed by a 32
>> bit division (not
>> optimisable to a simple shift).
>> * I'm also happy to keep a
>> rolling (32bit) average time.
>> Even if you assume
>> averages in the 100ms, 32bit
>> is going to happily support
>> an N of 64 or even 128.
>> Am I right in thinking
>> that the choice of N is
>> highly dependent on
>> frequency. For things
>> happening 100 times per
>> second, you might want an N
>> like 128.. where things
>> happening once per
>> N of 4 or 8. The other
>> things we keep track of in
>> this manner we have a better
>> idea of the frequency of the
>> thing.
>> How about we have (per record
>> type):
>> * total count (since last
>> reset?) (32 bit)
>> * smoothed average of time
>> per instance (32 bit)
>> * ?xx? total accumulated
>> time since last reset (64bit)
>> ?? <-- with the below stats
>> this is much less useful
>> * last-measured-time (64 bit)
>> * accumulated count since
>> last time-period (16bit - but
>> maybe 32bit anyway for byte
>> alignment?)
>> * smoothed average of count
>> per time-period (32bit)
>> * accumulated time since
>> last time-period (32bit)
>> It's possible to keep the
>> Is this going to be too much
>> per record type? The number
>> of 'records' we are keeping
>> is quite low (so 10 to 20
>> maybe) - so it's not a huge
>> memory burden.
>> Thoughts?
>> //.ichael
>> On Thu, 16 May 2024 at 03:09,
>> wrote:
>> esp_timer_get_time() is
>> the right choice for
>> precision timing.
>> I'd say uint32 is enough
>> though, even if counting
>> microseconds that can
>> hold a total of more than
>> 71 hours of actual
>> processing time. uint64
>> has a significant
>> performance penalty,
>> although I don't recall
>> the overhead for simple
>> additions.
>> Also & more important,
>> the average wouldn't be
>> my main focus, but the
>> maximum processing time
>> seen per ID, which seems
>> to be missing in your draft.
>> Second thought on the
>> average… the exact
>> overall average really
>> has a minor meaning, I'd
>> rather see the current
>> average, adapting to the
>> current mode of operation
>> (drive/charge/…). I
>> suggest feeding the
>> measurements to a low
>> pass filter to get the
>> smoothed average of the
>> last n measurements. Pattern:
>> runavg = ((N-1) * runavg
>> + newval) / N
>> By using a low power of 2
>> for N (e.g. 8 or 16), you
>> can replace the division
>> by a simple bit shift,
>> and have enough headroom
>> to use 32 bit integers.
>> Am 15.05.24 um 06:51
>> via OvmsDev:
>> Formatting aside, I
>> have implemented what
>> I think Michael B was
>> suggesting. This is a
>> sample run on the
>> Ioniq 5 (which
>> doesn't have
>> unsolicited RX events).
>> This uses the
>> call esp_timer_get_time()
>> got get a 64bit
>> *microseconds* since
>> started value - and
>> works out the time to
>> execute that way.
>> It's looking at
>> absolute time and not
>> time in the Task - so
>> other things going on
>> at the same time in
>> other tasks will have
>> an effect. (The
>> normal tick count
>> doesn't have nearly
>> enough resolution to
>> be useful - any other
>> ideas on
>> measurement?) I've
>> got total accumulated
>> time displaying in
>> seconds and the
>> average in
>> milliseconds
>> currently - but I can
>> change that easy enough.
>> The cumulative time
>> is stored as uint64_t
>> which will be plenty,
>> as 32bit wouldn't be
>> nearly enough.
>> OVMS# *poller time on*
>> Poller timing is now on
>> OVMS# *poller time
>> status*
>> Poll [PRI]
>> : n=390 tot=0.2s
>> ave=0.586ms
>> Poll [SRX]
>> : n=316 tot=0.1s
>> ave=0.196ms
>> CAN1 RX[0778]
>> : n=382 tot=0.2s
>> ave=0.615ms
>> CAN1 RX[07a8]
>> : n=48 tot=0.0s
>> ave=0.510ms
>> CAN1 RX[07bb]
>> : n=162 tot=0.1s
>> ave=0.519ms
>> CAN1 RX[07ce]
>> : n=33 tot=0.0s
>> ave=0.469ms
>> CAN1 RX[07ea]
>> : n=408 tot=0.2s
>> ave=0.467ms
>> CAN1 RX[07ec]
>> : n=486 tot=0.2s
>> ave=0.477ms
>> CAN3 RX[07df]
>> : n=769 tot=0.2s
>> ave=0.261ms
>> CAN1 TX[0770]
>> : n=191 tot=0.0s
>> ave=0.054ms
>> CAN1 TX[07a0]
>> : n=16 tot=0.0s
>> ave=0.047ms
>> CAN1 TX[07b3]
>> : n=31 tot=0.0s
>> ave=0.069ms
>> CAN1 TX[07c6]
>> : n=11 tot=0.0s
>> ave=0.044ms
>> CAN1 TX[07e2]
>> : n=82 tot=0.0s
>> ave=0.067ms
>> CAN1 TX[07e4]
>> : n=54 tot=0.0s
>> ave=0.044ms
>> Set State
>> : n=7 tot=0.0s
>> ave=0.104ms
>> This is probably
>> going to be quite
>> useful in general!
>> The TX call-backs
>> don't seem to be
>> significant here.
>> (oh, I should
>> probably implement a
>> reset of the values too).
>> //.ichael
>> On Sun, 12 May 2024
>> at 22:58, Michael
>> Geddes
>> wrote:
>> Yeah - I
>> certainly wasn't
>> going to put a
>> hard limit. Just
>> a log above a
>> certain time,
>> that being said,
>> the idea of just
>> collecting stats
>> (being able to
>> turn it on via a
>> "poller timer"
>> set of commands)
>> would be much
>> more useful. I'll
>> look into that.
>> Average time is
>> probably a good
>> stat - and
>> certainly what we
>> care about.
>> I actually am
>> hopeful that
>> those couple of
>> things I did
>> might help reduce
>> that average time
>> quite a bit (that
>> short-cutting the
>> isotp protocol
>> handling
>> especially).
>> That p/r with
>> logging changes
>> might help reduce
>> the unproductive
>> log time further,
>> but also makes it
>> possible to turn
>> on the poller
>> logging without
>> the RX task logs
>> kicking in.
>> //.ichael
>> On Sun, 12 May
>> 2024 at 22:29,
>> Michael Balzer
>> via OvmsDev
>> wrote:
>> Warning /
>> gathering
>> debug
>> statistics
>> about slow
>> processing
>> can be
>> helpful, but
>> there must
>> not be a hard
>> limit.
>> Frame/poll
>> response
>> processing
>> may need disk
>> or network
>> I/O, and the
>> vehicle task
>> may be
>> starving from
>> punctual high
>> loads on
>> higher
>> priority
>> tasks (e.g.
>> networking)
>> or by needing
>> to wait for
>> some
>> semaphore --
>> that's
>> outside the
>> application's
>> control, and
>> must not lead
>> to
>> termination/recreation
>> of the task
>> (in case
>> you're
>> heading
>> towards that
>> direction).
>> I have no
>> idea how much
>> processing
>> time the
>> current
>> vehicles
>> actually need
>> in their
>> respective
>> worst cases.
>> Your draft is
>> probably too
>> lax, poll
>> responses and
>> frames
>> normally need
>> to be
>> processed
>> much faster.
>> I'd say 10 ms
>> is already
>> too slow, but
>> any wait for
>> a
>> queue/semaphore
>> will already
>> mean at least
>> 10 ms
>> (FreeRTOS
>> tick).
>> Probably best
>> to begin with
>> just
>> collecting stats.
>> Btw, to help
>> in narrowing
>> down the
>> actual
>> problem case,
>> the profiler
>> could collect
>> max times per
>> RX message ID.
>> Am 12.05.24
>> um 10:41
>> schrieb
>> Michael Geddes:
>> I have a
>> question
>> for
>> B (or
>> whoever)
>> - I have
>> a commit
>> lined up
>> that
>> would add
>> a bit of
>> a time
>> check to
>> the
>> poller
>> loop.
>> What do
>> we expect
>> the
>> maximum time
>> to
>> execute a
>> poller
>> loop
>> command
>> should be?
>> This is a
>> rough
>> idea (in
>> ms) I
>> have..
>> based on
>> nothing
>> much
>> really,
>> so any
>> ideas
>> would be
>> appreciated:
>> int
>> TardyMaxTime_ms(OvmsPoller::OvmsPollEntryType
>> entry_type)
>> switch
>> (entry_type)
>> case
>> OvmsPoller::OvmsPollEntryType::Poll:
>> return 80;
>> case
>> OvmsPoller::OvmsPollEntryType::FrameRx:
>> return 30;
>> case
>> OvmsPoller::OvmsPollEntryType::FrameTx:
>> return 20;
>> case
>> OvmsPoller::OvmsPollEntryType::Command:
>> return 10;
>> case
>> OvmsPoller::OvmsPollEntryType::PollState:
>> return 15;
>> default:
>> return 80;
>> //.ichael
>> On Mon, 6
>> May 2024
>> at 07:45,
>> Geddes
>> wrote:
>> I
>> realise
>> that
>> I was
>> only
>> using
>> the
>> standard
>> cable
>> to
>> test
>> which
>> probably is
>> not
>> sufficient
>> - I
>> haven't
>> looked
>> closely
>> at
>> how
>> the
>> Leaf
>> OBD
>> to
>> Db9
>> cable
>> is
>> different
>> from
>> standard.
>> Ah,
>> my
>> bad
>> out
>> the
>> queue
>> length.
>> We
>> are
>> definitely
>> queueing
>> more
>> messages
>> though.
>> From
>> my
>> log
>> of
>> when
>> the
>> overflow
>> happened,
>> the
>> poller
>> was
>> in
>> state
>> 0
>> which
>> means
>> OFF -
>> ie
>> nothing
>> was
>> being
>> sent!!
>> I'll
>> look
>> at
>> the
>> TX
>> message
>> thing
>> - opt
>> in
>> sounds
>> good
>> though
>> it
>> shouldn't
>> be
>> playing
>> that
>> much
>> of a
>> part
>> here
>> as
>> the
>> TXs
>> are
>> infrequent
>> in
>> this
>> case
>> (or
>> zero
>> when
>> the
>> leaf
>> is
>> off
>> or driving)
>> - On
>> the
>> ioniq
>> 5
>> when
>> I'm
>> using
>> the
>> HUD -
>> I'm
>> polling
>> quite
>> frequently
>> multiple
>> times
>> per
>> second
>> and
>> that
>> seems
>> to be
>> fine!.
>> I did
>> find
>> an
>> issue
>> with
>> the
>> throttling ..
>> but
>> it
>> would
>> still
>> mostly
>> apply
>> the
>> throttling
>> where
>> it
>> matters,
>> so
>> again,
>> it
>> shouldn't
>> be
>> the
>> problem
>> (also,
>> we
>> aren't
>> transmitting
>> in
>> the
>> leaf
>> case).
>> The
>> change
>> I
>> made
>> to
>> the
>> logging
>> of RX
>> messages
>> showed
>> how
>> many
>> in a
>> row
>> were
>> dropped...
>> and
>> it
>> was
>> mostly
>> 1
>> only
>> in a
>> run -
>> which
>> means
>> even
>> if it
>> is a
>> short
>> time
>> between
>> that
>> means
>> that
>> the
>> drops
>> are
>> being
>> interleaved
>> by at
>> least
>> one
>> success!
>> Sooo..
>> I'm
>> still
>> wondering
>> what
>> is
>> going
>> on.
>> Some
>> things
>> I'm
>> going
>> to try:
>> * If
>> the
>> number
>> of
>> messages
>> on
>> the
>> Can
>> bus
>> (coming
>> in
>> through
>> RX)
>> means
>> that
>> the
>> queue
>> is
>> slowly
>> getting
>> longer
>> and
>> not
>> quite
>> catching
>> up,
>> then
>> making
>> the
>> queue
>> longer
>> will
>> help
>> it
>> last
>> longer...
>> but
>> only
>> pushes
>> the
>> problem
>> down
>> the road.
>> Add
>> 'current
>> queue
>> length'
>> to
>> the
>> poller
>> status
>> information
>> to
>> see
>> if
>> this
>> is
>> indeed
>> the
>> case?
>> Add
>> some
>> kind
>> of
>> alert
>> when
>> the
>> queue
>> reaches
>> a % full?
>> Once
>> you
>> start
>> overflowing
>> and
>> getting
>> overflow
>> log
>> messages,
>> I
>> wonder
>> if
>> this
>> is
>> then
>> contributing
>> to
>> the
>> problem.
>> Push
>> the
>> overflow
>> logging
>> into
>> Poller
>> Task
>> which
>> can
>> look
>> at
>> how
>> many
>> drops
>> occurred
>> since
>> last
>> received
>> item.
>> Split
>> up
>> the
>> flags
>> for
>> the
>> poller
>> messages
>> into 2:
>> Messages
>> that
>> are/could
>> be
>> happening
>> in
>> the
>> TX/RX
>> tasks
>> Other
>> noisy
>> messages
>> that
>> always
>> happen
>> in
>> the
>> poller
>> task.
>> Thoughts
>> on
>> what
>> else
>> we
>> might
>> measure
>> to
>> figure
>> out
>> what
>> is
>> going on?
>> //.ichael
>> On
>> Sun,
>> 5 May
>> 2024,
>> 19:29
>> Balzer
>> via
>> OvmsDev,
>> wrote:
>> Michael,
>> the
>> queue
>> size
>> isn't
>> in
>> bytes,
>> it's
>> in
>> messages:
>> @param
>> uxQueueLength
>> The
>> maximum
>> number
>> of
>> items
>> that
>> the
>> queue
>> can
>> contain.
>> @param
>> uxItemSize
>> The
>> number
>> of
>> bytes
>> each
>> item
>> in
>> the
>> queue
>> will
>> require.
>> Also,
>> from
>> the
>> time
>> stamps
>> in
>> Dereks
>> log
>> excerpt,
>> there
>> were
>> quite
>> some
>> dropped
>> frames
>> in
>> that
>> time
>> window
>> at
>> least
>> 23
>> frames
>> in
>> 40
>> ms,
>> that's
>> bad.
>> Queue
>> sizes
>> are
>> currently:
>> CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=60
>> CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=60
>> The
>> new
>> poller
>> now
>> channels
>> all
>> TX
>> callbacks
>> through
>> the
>> task
>> queue
>> additionally
>> to
>> RX
>> and
>> commands.
>> So
>> setting
>> the
>> queue
>> size
>> to
>> be
>> larger
>> than
>> the
>> CAN
>> RX
>> queue
>> size
>> seems
>> appropriate.
>> Nevertheless,
>> an
>> overflow
>> with
>> more
>> than
>> 60
>> waiting
>> messages
>> still
>> indicates
>> some
>> too
>> long
>> processing
>> time
>> in
>> the
>> vehicle
>> task.
>> TX
>> callbacks
>> previously
>> were
>> done
>> directly
>> in
>> the
>> CAN
>> context,
>> and
>> no
>> current
>> vehicle
>> overrides
>> the
>> empty
>> default
>> handler,
>> so
>> this
>> imposed
>> almost
>> no
>> additional
>> overhead.
>> By
>> requiring
>> a
>> queue
>> entry
>> for
>> each
>> TX
>> callback,
>> this
>> feature
>> now
>> has
>> a
>> potentially
>> high
>> impact
>> for
>> all
>> vehicles.
>> If
>> passing
>> these
>> to
>> the
>> task
>> is
>> actually
>> necessary,
>> it
>> needs
>> to
>> become
>> an
>> opt-in
>> feature,
>> so
>> only
>> vehicles
>> subscribing
>> to
>> the
>> callback
>> actually
>> need
>> to
>> cope
>> with
>> that
>> additional
>> load
>> potential
>> processing
>> delays
>> involved.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240614/8f468685/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240614/8f468685/attachment-0001.sig>
