[Ovmsdev] Warning in Duktape
Mon Jul 22 08:36:56 HKT 2024
I have tidied up the implementation significantly and I've fixed up all the
life-time issues, as well as disallowing overriding existing commands.
(Though you could still add a sub-command to a system command).  It now
persists quite happily, doesn't crash on GC and functions as expected :).
I've also implemented shut-down registering so it cleans up before getting
to the destructor.
It's now down to security and the question of whether we differentiate user
plugin commands from system ones.
//.ichael
On Sun, 21 Jul 2024 at 08:34, Michael Geddes <frog at bunyip.wheelycreek.net>
wrote:
> Well since I've been doing some Duktape stuff lately, I recalled this
> loose end and have come up with a solution.
> There were a few issues - please let me know if you have a problem with
> any of them.
> Firstly the Command registration map is using const char *  and we can't
> guarantee the lifetime of the duktape strings so I've moved them over to
> std::string.
> This applies to OvmsCommandMap itself as well as OvmsCommand - m_name,
> m_title and m_usage_template.
> I think the intention was to have something like this for the register
> command.. it was missing a parameter. It now looks like this:
> OvmsCommand.Register( function, parent, command, description,
> parameter_desc, minargs, maxargs).
> Missing maxargs will mean maxargs = minargs.
> Missing minargs will mean no parameters.
> The calling function will be passed 2 parameters:  the name of the command
> and an array of strings (the argv).
> For sub-commands, these will be separated by '/'.   So  something like
> "me/too".
> I think this way is simple but effective.
> It would be good to add completion, but that can be added later.
> One of the things I wanted to talk about is what security protections we
> need to add to prevent a script from taking over an existing function! (or
> future function).
> When vim initially added user commands and functions it was a free-for-all
> but somebody soon realised there needed to be some restrictions to avoid
> issues..
> so what they did was force user function and commands to start with a
> capital letter.  I would like people's thoughts on whether we need to do
> something similar.
> It might be that we would be satisfied with failing if system commands
> were attempted to be overridden. Should we allow adding sub-commands to
> system commands?
> I can see that might be useful..
> I have added a sample below of a working function:
> --8<----
> mycommand = function(c, argv){
>   print("Hello There: "+c+"\n");
>   if (argv.length == 0)
>     print("Simple\n");
>   else
>     print("Script: "+argv[0]+"\n")
> OvmsCommand.Register(mycommand, "", "me", "My Script", "[string]", 0, 3)
> *OVMS#* *me xx*
> Hello There: me
> Script: xx
> *OVMS# **me xx yy*
> Hello There: me
> Script: xx
> *OVMS#* *me xx yy*
> Hello There: me
> Script: xx
> *OVMS#*
> On Sun, 23 Oct 2022 at 22:15, Michael Balzer <dexter at expeedo.de> wrote:
>> That's an open end, implementing command registration for Duktape.
>> There's a thread on this… found it:
>> http://lists.openvehicles.com/pipermail/ovmsdev/2020-July/006952.html
>> Am 23.10.22 um 15:38 schrieb Michael Geddes:
>> There's an unused variable 'dcc' warning in the below code.
>> It seems that the 'Perform the callback' is not being 'performed!
>> Is this deliberate?
>> //.ichael
>> void DukOvmsCommandRegisterRun(int verbosity, OvmsWriter* writer,
>> OvmsCommand* cmd, int argc, const char* const* argv)
>>   ESP_LOGD(TAG, "DukOvmsCommandRegisterRun(%s)",cmd->GetName());
>>   auto it = MyDuktape.m_cmdmap.find(cmd);
>>   if (it == MyDuktape.m_cmdmap.end())
>>     ESP_LOGE(TAG, "Command '%s' cannot be found in registry",cmd->GetName
>>     return;
>>   else
>>     DuktapeConsoleCommand* dcc = it->second;
>>     // Perform the callback
>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240722/34d96174/attachment.htm>
