[Ovmsdev] Adding Pollers object to Duktape
Wed Jul 3 14:24:00 HKT 2024
I figured I may as well add an OvmsPoller object to DukTape for Ovms.   I'm
waiting to get back to my OVMS so that I can test it.. but this is the
documentation I have for the stuff I have coded. Thoughts on this?
What do people think of OvmsPoller.Times sub-object?   I've added a general
mechanism for this.
Also should I have OvmsPoller.Pause()  or OvmsPoller.SetUserPaused(true)  ?
OvmsPoller
The Ovms Poller object represents the poller sub-system. It contains the
following methods:
- ``ispaused = OvmsPoller.GetPaused()``: Return true if the poller is
paused by the system/user.
- ``ispaused = OvmsPoller.GetUserPaused()``: Return true if the poller is
paused by the user.
- ``OvmsPoller.Pause()``: Pause the poller (adds User poller pause)
- ``OvmsPoller.Resume()``: Remove the User poller pause.
- ``tracemode = OvmsPoller.GetTrace()``: Return the current trace mode.
- ``OvmsPoller.SetTrace(tracemode)``: Set the current trace mode.
    The Traces still require that 'Verbose' and 'Debug' levels (depending)
for the 'vehicle-poll'
    debug tag are set.
    Trace modes for verbose logging can be one of:
    - ``on``: On for poller loop
    - ``txrx``: On for txrx queue (this can be hazardous for some cars)
    - ``all``: On for both poller loop and txrx queuing
    - ``off``: Logging Off
    Note that only ``on`` and ``off`` are recommended.
The poller object also contains a ``Times`` property for the OBD Poll-Time
tracing
which contains the following methods:
- ``isrunning = OvmsPoller.Times.GetEnabled()``: Returns true if the
time-tracing is enabled
- ``OvmsPoller.Times.SetEnabled(isrunning)``: Sets the enabled status of
the timer-tracing
- ``OvmsPoller.Times.Reset()``: Reset the timers (doesn't affect their
current state).
- ``OvmsPoller.Times.GetStatus()``: Gets the status of the various times.
This returns an object
    of this format:
    .. code-block:: javascript
    return_value = {
      "items": {
        "Poll:PRI" : {
          "count_hz":    1,
          "avg_util_pm": 0.529,
          "peak_util_pm":0.652,
          "avg_time_ms": 0.052,
          "peak_time_ms":1.516
        "Poll:SRX": {
          "count_hz":    1.47,
          "avg_util_pm": 0.302,
          "peak_util_pm":0.44,
          "avg_time_ms": 0.02,
          "peak_time_ms":0.573
        "RxCan1[778]": {
          "count_hz":    0.74,
          "avg_util_pm": 0.427,
          "peak_util_pm":0.826,
          "avg_time_ms": 0.063,
          "peak_time_ms":1.872
        "RxCan1[7a8]": {
          "count_hz":    0.35,
          "avg_util_pm": 0.183,
          "peak_util_pm":0.355,
          "peak_time_ms":1.382
        "TxCan1[7b3]": {
          "count_hz":    0.07,
          "avg_util_pm": 0.005,
          "peak_util_pm":0.01,
          "avg_time_ms": 0.007,
          "peak_time_ms":0.099
        "TxCan1[7c6]": {
          "count_hz":    0,
          "avg_util_pm": 0,
          "peak_util_pm":0.009,
          "avg_time_ms": 0.004,
          "peak_time_ms":0.098
        "Cmd:State": {
          "count_hz":    0,
          "avg_util_pm": 0,
          "peak_util_pm":0,
          "avg_time_ms": 0.011,
          "peak_time_ms":0.109
      "tot_count_hz": 11.76,
      "tot_util_pm": 6.247,
      "tot_time_ms": 4.628
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240703/0cfd7375/attachment.htm>
