[Ovmsdev] Working on ESP-IDF5 + Have a question about ovms_module 'Name'
Fri Jan 26 09:34:09 HKT 2024
Michael,
Unfortunately, Steve passed away in 2022 so is unlikely to reply :-(
He did work on some of the lower level and more complex parts of OVMS, as well as the command processing framework, and is sorely missed.
I can’t help much with the code you are working on, other than to ask if this functionality is still required in the v5 IDF framework? A lot of stuff we did back then was to address inadequacies in the very new early buggy frameworks coming out of Espressif for the just released ESP-32.
An embedded message was scrubbed...
Subject: Passing of Steve Casner
Date: Fri, 8 Jul 2022 08:19:25 +0800
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240126/251d3df8/attachment-0001.eml>
> On 26 Jan 2024, at 9:23 AM, Michael Geddes <frog at bunyip.wheelycreek.net> wrote:
> Does this help? Any thoughts on what this was meant to do ? I've CCd Stephen with a hope he might chip in?
