[Ovmsdev] [Action Required] Update your apps to the latest Firebase Cloud Messaging APIs and SDKs
Tue Jan 9 16:54:34 HKT 2024
Installed and a quick check of stuff seems to be working.
On Tue, 9 Jan 2024, 16:19 Michael Balzer, <dexter at expeedo.de> wrote:
> Everyone,
> the Android App "latest" build is now updated to use the official OVMS API
> key.
> This is now a release candidate, can & should be tested as a replacement
> for the current play store release.
> As written before, this works regardless of the server side API update, if
> no errors are found I'll release that to all users.
> Am 06.01.24 um 20:54 schrieb Michael Balzer:
> Everyone,
> we need some auditing & beta test help on this.
> I've just finished the migration for the server & App side. Everything
> works fine in my test environment, but I had WTF moments on the way. Some
> magically resolved themselves on the next day, so I have no idea why they
> occured in the first place.
> New server code is in Server/fcm, see README for details:
> https://github.com/openvehicles/Open-Vehicle-Server/tree/fcm/v3
> The server now uses a child process for FCM communication, as each
> delivery attempt now takes 0.3 seconds. The new code also now automatically
> cleans up expired App tokens.
> New App code & build is in Android/master:
> https://github.com/openvehicles/Open-Vehicle-Android/tree/master/latest
> The App currently uses my API IDs (File "google-services.json") instead of
> the official OpenVehicles version, this needs to be changed for the
> release. It should nevertheless work with api.openvehicles.com, but I
> haven't tested that yet.
> FCM makes it harder to configure an App for other servers than build into
> the App. I've done some experimentation and found a way to still keep the
> configuration as simple as before, i.e. you just need the custom FCM sender
> ID (which now always is the FCM/cloud project ID). Caveat is, this uses
> undocumented behaviour, so may need to be changed in the future.
> See my comment & explanation here:
> https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicleApp/src/main/java/com/openvehicles/OVMS/ui/MainActivity.java#L404
> Code audits & tests are welcome.
> When running your own server, follow the steps described in the README to
> get & install your FCM key. FCM keys btw. don't expire until the year
> 10000. Connect your module & App to your server, use "notify raise" to send
> test messages.
> Btw, FCM migration doesn't need to be done in a specific order
> (server/App): this is just an API change on both sides, the infrastructure
> behind the scenes is more or less identical. An FCM App receives GCM
> transmissions and vice versa. Please test that as well if possible.
> We need to finish migration before June 20, as the GCM APIs will then be
> switched off.
> Am 29.06.23 um 06:17 schrieb Mark Webb-Johnson:
> Oh, google. They do love to deprecate…
> I can handle the server side. But not sure what needs to be done there.
> Presumably this like the C2DM -> GCM migration we did a while ago (using a
> new agreed token type apns/c2dm/gcm/etc, if the new approache is not
> backwards compatible). The current server seems to call:
> https://fcm.googleapis.com/fcm/send
> On 21 Jun 2023, at 7:25 PM, Michael Balzer <dexter at expeedo.de>
> Signed PGP part
> Time for another Google API deprecation.
> It seems we'll need to update the Android App & possibly the server now to
> the FCM API for push notifications, the old GCM API will stop working in
> June 2024.
> Anyone volunteering to take care of this?
> -------- Weitergeleitete Nachricht --------
> Betreff: [Action Required] Update your apps to the latest Firebase Cloud
> Datum:  Tue, 20 Jun 2023 13:26:22 -0700
> Von:  Firebase <firebase-noreply at google.com> <firebase-noreply at google.com>
> Antwort an:  Firebase <firebase-noreply at google.com>
> An:  dexter at expeedo.de
> [image: Firebase Console]
> <https://notifications.google.com/g/p/ACUgQrEqj5I8-oiq75nsyLmVgMI_2P_O30pr9ZcpVmk-O8L3G7S5GLuDAQBGbLzVLag80DcGOGlPohe0LlxV3Am7cZNv3WRo1rwY30WWKavJb9NJTk1FmXuKrvFZt8XgZ17HnYFO11bDbl7kSR_82CXEwuwTZU4-udfbmAeK7zzJ3qZft1R_jSAmBvOt677OdR1wfx-Q>
> Hi Michael,
> We’re writing to let you know that starting *June 20, 2024* the legacy
> Firebase Cloud Messaging (FCM) APIs will be discontinued.
> What do you need to know?
> On *June 20, 2024,* we’re reducing the number of Firebase Cloud Messaging
> (FCM) legacy register APIs and legacy send APIs that provide similar
> functionality. This step will allow us to provide you with a more
> consistent experience and align with Google security standards to improve
> security, reliability and performance.
> Because of these API decommissions, some already-deprecated SDKs and
> features will stop working after *June 20, 2024.*
> Please consult the tables below to find which Firebase Cloud Messaging
> (FCM) APIs and corresponding services/SDKs/features will be discontinued
> and replaced with new alternatives.
> *Discontinued Send API*
> *Decommissioned service*
> *New alternative*
> *Legacy HTTP Protocol*
> Sending messages via the Legacy HTTP API.
> Send messages via the HTTP v1 API.
> *XMPP Protocol*
> Sending upstream and downstream messages via the XMPP API.
> Send downstream messages via the HTTP v1 API.
> Send upstream messages via HTTP/gRPC
> <https://notifications.google.com/g/p/ACUgQrFKp0BdXKuz3_mUi3W9wdl6DV3Ib_q0Hn9_rFkVCttPt1pfUS9zAavG0IHLz8EEex1Xah-SSAfcgb2zSplnVRd5kYFwn3MN31jskkUBf1w_RdTqd1tuSW3w6CKsMVdUC9bJHCVT9qvQXy4G6_8J5J-aT-4UFsRnmM4ASLagXT9eO188Q1gAxo7IH3vsHg-U55h8rnJ9zzRdh-DNTbMvJhXav_T7Bw>
>  directly from the App to your server.
> *Batch send API*
> Including multiple send requests in a single HTTP request to FCM known as
> Batch Send.
> Send messages via the HTTP v1 API, which has been optimized for fanout
> performance
> *Discontinued Register API*
> *Decommissioned SDK*
> *New alternative*
> *GCM register API*
> Google Cloud Messaging(GCM) SDKs (deprecated in 2018).
> Latest FCM Android SDK.
> *Legacy Web register API*
> FCM JS SDK version<7.0.0 (deprecated in 2019)
> Latest FCM JS SDK.
> *Instance ID Server API for Web*
> No SDK related to this API.
> Latest FCM JS SDK.
> *Discontinued Feature*
> *New alternative*
> *Server keys*
> Authenticating requests with server keys.
> Authenticate requests with access tokens generated from authorized
> service accounts
> <https://notifications.google.com/g/p/ACUgQrE8LxWKrfZvL3R5hoSruQL4An9Vg5kFcDYASULp7A5SyUubGdXnXerewny9Rr8OJNp2fTgybuON0zkL4u2XSRmhn29NBmTFNdbm9q-OXyYQVSFt_ax2KxIYXCYbGR1bTLMqPLoLzMpdTgcuyd6wKJCIJj7ToMCrVJzWqOxbg6QUof0_-BUGyGhtnimrCtd-gb5en_iFRjq5OwpVDzqJex2vhuqgrVoeBvAkg344MePoYgqRrkoO113zUXz9flSPIyevZT6KZ4E>
> *iOS Direct Channel*
> Sending messages via FCM’s direct channel to iOS devices while they are
> running in the foreground.
> All iOS messages will be sent via APNS channel.
> What do you need to do?
> Take the following actions before *June 20, 2024*, to ensure that you
> have access to the latest supported features and to reduce the risk of
> future decommissions affecting your usage:
>    - *Follow the instructions described in *Firebase FAQ
>    <https://notifications.google.com/g/p/ACUgQrF1q42xLDBDWvEr5RHaOfbnfKhv0UdWXB6Vy1kLOjasVBtYD0Wjp4aQJlSaeYnw695zGgel_4mXfwd5JHyH3hmINX1yjPPMSUIxlWcV8-8Af9jmWTRzELbajU3hoHr3k5e8X4QnZaoBBqlKW9ZwgPvaX0SEG_Q761kFR-vQisPxahLO6tzNfIkO3wdWa9b6XDKynfH7tcuSSS5YX3B-wdvH6XeRsMo-Tw>
>     to migrate your individual APIs.
>    - *Update to the latest versions of Firebase SDKs*.
> *Platform*
> *Recommended FCM SDK version*
> Android
> >= 23.1.2
> iOS
> >= 10.10.0
> Web (Javascript)
> >= 9.22.1
> Your Firebase project(s) that use Firebase Cloud Messaging APIs are listed
> below:
>    - MyOvmsServer (1043773844049)
>    <https://notifications.google.com/g/p/ACUgQrEotRQKxV6LgEoXckEV9bLkUuhj9b1dUEtZwXeBD6i1JG2SipBCU3_-A46djD3KV4k7XrIbasB60E_K8d6_dHHvHD-_2cnyBUix-DEEIJkWkzw6-xrvJDz64B0VJ3FWbNJ4UorZX4uwFpCyKCfCDYM4lMYSuHF4e8JO88lnZyTC_Qa4wW0Kr4YdCa4W7_3w_rq9_-KINgSiodkUhsW7TvTYl1M>
>       - *Your recent usage of impacted APIs/features: Server Keys*
>       - *Your recent usage of impacted APIs/features: Legacy HTTP
>       protocol*
> We’re here to help
> If you have any questions, please review the Firebase FAQs
> Thanks,
> Todd on behalf of the Firebase team
> *Was this information helpful?*
> [image: Yes]
> <https://notifications.google.com/g/p/ACUgQrG_D9izaxqaPAZL66peR0D-yHGGWiULfqLYNXkYVDs80RnpgeXgBN9m4ZnaHzuqsYlOfmgjFoUOsubDA7WspKOx5stGqGz--VfYcwvRfcyYu8wpw3AGMncVzPV7JAmFxyvmWXSFwq2XGOMXnFc1YZFt5J95Sz9hEaOrLOKX4og8ftEzmGUD6Zmv-OofJZ4g6roE8QdQ4L9DIP_mFpopj6y27eSinWXQTZoUBHhCVQ5hGICPSorDMyXpqbhKCdouUctpgfshicsSM_S8LReB3sRCqkl0PQ6RkgRnaBHi4y82il1Hcp4jv1NiDVxrF1w5kg>
>      [image: Neutral]
> <https://notifications.google.com/g/p/ACUgQrFnFdXuJ_VF6ChjiUeTeV5elzVrPymaFMqIFMkzFQvDJk1H8Vs9uUUt76f7Xe2hDm2I35eLjYIdq613WGZApFeuZuv4m4_Iubc9fhSe1sG_m67t1b1CFvQaomK_klAYbLBQIHzrxKtOAlmJfr8L8yO2ILSG0RJkj0CqDnrR4UsTtw8LGENRKq7cnyhBaQr7HrQVfvk1LYOYUbJLvrsp-_g3wvDF-VUQbIkwnDoZNG9AAg8mZIze5vUr32smAfDHfLE_2jZ1HpU4d9XVZ8S7Aph1sX6Nh9J9frhzn9tWZ1MKhVXbRbcCocQK8dD47hUA6OWi6R8>
>      [image: No]
> <https://notifications.google.com/g/p/ACUgQrFb7NDlSkpL4nuGR0g71bgiRuj39SdywVWgFU-V2bmH2sTpWfqP5wOUFG7s8ac6UZHkK2C1YI9ygFwG8W0f4biaJ7NHCvbBCBVpx4qEZWIUe4vPCvT_AtResGaRUZdjcQwchak5V7wjkbCkPSrBwL4_YEg6Clr5tnpkrDQhvxN1uaC2lSKxqNCUYucmV2C-JjRFwjJYG_veUreyuWkV-KiruZVSp7iwhaPvvY2s-mAe9MdTZAwfjeWu6fWjTijb6sMrzS_3z7unUgJg0yFm6lBNaPBINYLBQObetHggsrv5dd2elYGrpoEyQPLuxbU8>
> You have received this mandatory service announcement to update you about
> important changes to Firebase or your account.
> © 2023 Google LLC
> 1600 Amphitheatre Parkway
> Mountain View, CA 94043 USA
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240109/3e212920/attachment-0001.htm>
