[Ovmsdev] wolfssl has been converted to a git submodule
Simon Ehlen
ovms at highteq.de
Mon Feb 19 17:10:35 HKT 2024
Hi Mark,
when I look at the version.h from the master branch that is referenced as submodule, it also says 5.6.2.
https://github.com/openvehicles/wolfssl/blob/master/wolfssl/version.h
#define LIBWOLFSSL_VERSION_STRING "5.6.2"
[submodule "vehicle/OVMS.V3/components/wolfssl/wolfssl"]
path = vehicle/OVMS.V3/components/wolfssl/wolfssl
url = https://github.com/openvehicles/wolfssl.git
Kind regards,
Simon
Am 19.02.2024 um 09:26 schrieb Mark Webb-Johnson:
> Not sure what is going on for you. I just did a submodule update —init and —recursive, and get:
> $ git submodule status
> 7b953e7ebb440ce9461ee469159c3759450e7c98 components/mongoose/mongoose (6.2-882-g7b953e7)
> c05f6c7530a8670e3d0ffdf04ee4cecb2d3b0496 components/wolfssh/wolfssh (v1.4.10-stable)
> 2d5a0ccae50a2ea32fc933d707b465520cc90011 components/wolfssl/wolfssl (v4.7.0-stable-5-g2d5a0ccae)
> 7c3878f8302c0e84578a67473e49e60bc6b3ada7 components/zip/libzip (rel-1-5-1-60-g7c3878f)
> d6bcf4ca4d02479f058fff44cfd171f928148179 components/zip/zlib (v1.2.11-65-gd6bcf4c)
> I think v4.7.0 should be correct for wolfssl.
>> On 19 Feb 2024, at 4:29 AM, Simon Ehlen <ovms at highteq.de> wrote:
>> Hi,
>> when I run git submodule status, I get the following output:
>> /$ git submodule status
>> 7b953e7ebb440ce9461ee469159c3759450e7c98 vehicle/OVMS.V3/components/mongoose/mongoose (6.2-882-g7b953e7)
>> c05f6c7530a8670e3d0ffdf04ee4cecb2d3b0496 vehicle/OVMS.V3/components/wolfssh/wolfssh (v1.4.10-stable)
>> 9ffa9faecda87a7c0ce7521c83996c65d4e86943 vehicle/OVMS.V3/components/wolfssl/wolfssl (v*5.6.2*-stable)
>> 7c3878f8302c0e84578a67473e49e60bc6b3ada7 vehicle/OVMS.V3/components/zip/libzip (rel-1-5-1-60-g7c3878f)
>> d6bcf4ca4d02479f058fff44cfd171f928148179 vehicle/OVMS.V3/components/zip/zlib (v1.2.11-65-gd6bcf4c)/
>> I had the problem that after a git pull wolfssl was removed from my local source.
>> git submodule status then showed:
>> 23e018e58f15a238c8c77ebdf724a2b18ad5f28a vehicle/OVMS.V3/components/mongoose/mongoose (6.2-880-g23e018e)
>> 6ffb692964ec2dc7fae21790fb5bb13b4ef2ed94 vehicle/OVMS.V3/components/zip/libzip (rel-1-5-1-58-g6ffb692)
>> I then ran 'git submodule update --init --recursive' as described.
>> But although the module was present in .gitmodules, it was not downloaded.
>> I then used
>> $ git submodule add https://github.com/openvehicles/wolfssl.git vehicle/OVMS.V3/components/wolfssl/wolfssl
>> to add it manually.
>> But now my code no longer compiles.
>> I get the following error message during compile
>> make[1]: *** No rule to make target 'wolfssl/wolfcrypt/src/hc128.o', needed by 'libwolfssl.a'. Stop.
>> Is it because I now have version v5.6.2 of wolfssl instead of the expected submodule version v4.7.0?
>> How can I get my submobules to be included in the required version again?
>> I would be grateful for any help!
>> Kind regards,
>> Simon
>> Am 17.05.2023 um 23:24 schrieb Ludovic LANGE:
>>> Dear all,
>>> The PR https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/887 which converts wolfssl to a git submodule has been merged to master.
>>> For those that build / sync their trees manually, please ensure that you do `git submodule update --init --recursive` after the git pull, so that you can properly retrieve the submodule.
>>> You can confirm that everything is OK by doing:
>>> It should print (3rd line) a version of v4.7.0-stable-5-g2d5a0ccae.
>>> If instead you see:
>>> -2d5a0ccae50a2ea32fc933d707b465520cc90011 components/wolfssl/wolfssl
>>> then you need to use `git submodule update --init --recursive`
>>> Let me know if it's not working according to the plan.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240219/f92d51dc/attachment-0001.htm>
