[Ovmsdev] Upgrading Mongoose ?
Tue Feb 13 04:45:27 HKT 2024
Michael,
I think you'll find all our PRs/commits to Mongoose here:
https://github.com/cesanta/mongoose/pull/894
I have no idea which have finally been merged or reimplemented by them,
they more or less ignored us until their code base was too far off.
Am 11.02.24 um 09:58 schrieb Michael Geddes:
> I've been looking at the work of Ludovic in updating OVMS to the new
> framework.  I've even put up a few pull-requests where this work has
> uncovered bugs due to improvements in the compiler.
> Ludovic did a great job in also updating the Mongoose library.  For
> those unaware, the big issue is that there was a massive reworking of
> the library just after the point where ovms forked the library.  I
> suspect some/many? of the changes that were made in our fork are no
> longer required.
> There was a lot done in moving some of the work that had to be done in
> the callers (ovms) code into the mongoose code which is great - and
> Ludovic has done that conversion - there are just a few more things
> that needed to be done on top of that.
> One of the things they did was remove mg_locals.h which allowed us to
> configure mongoose from our own custom include.
> The other really annoying thing they did was to remove the use of
> MG_ALLOC, MG_CALLOC in place of malloc( calloc(  etc. The problem with
> this is for freertos they define
> #define calloc(a, b) mg_calloc(a, b)
> #define free(a) vPortFree(a)
> #define malloc(a) pvPortMalloc(a)
> without any further condition.  Tihs means we don't have a way of
> defining these to our own versions  which is what we originally did...
> well not without forking the mongoose (which maybe we do anyway).
> It also means that any of our files that include mongoose.h  will have
> these redefined away from our own versions of these. Fortunately it
> seems we don't use those much.
> I also noticed that even the latest Mongoose MQTT doesn't appear to
> support aliases (and therefore optimising the amount of data used by a
> v3 server).. but it appears that wolfmqtt does - so should we be using
> that instead as a mqtt client??
> Does anybody else have some further input on this??
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240212/6657e823/attachment.sig>
