[Ovmsdev] UI redesign in Android App - Needs beta testing
van der Meijden, Chris chris at arachnon.de
Mon Dec 30 19:12:44 HKT 2024
I like the design of the Mercedes Ne app. Don't need a one to one copy, but it has a good mixture between info and links, I think.
Am 30. Dezember 2024 11:29:37 MEZ schrieb Developer From Jokela <info at developerfromjokela.com>:
>Hi.
>What info would you like to be shown on main screen?
>On 30. Dec 2024, at 11.16, Chris van der Meijden <chris at arachnon.de> wrote:
>Also many thanks for the effort. The new design is not my cup of tea, but that is question of personal liking I suppose. For me the menu is far to present, whereas the information of the vehicle seems barely visible.
>For the e-Up the climate control throws an error. "Fehler bei der Kommandoausführung".
>Kind regards
>Chris
>Am Montag, dem 30.12.2024 um 15:20 +0800 schrieb Michael Geddes via OvmsDev:
>Thanks for the update. In general I like the new design.
>I've attached a screen shot. The list box items need to resize for larger fonts to stop them being all cut off.
>Also where does the "Unknown Vehicle model" come from?
><1000012000.jpg>
>I have a slightly larger font setting:
><1000012001.jpg>
>Also here:
><1000012002.jpg>
>..where the labels are overlapping due to the font size.
>And the ... here:
><1000012003.jpg>
>I'm also getting a crash when opening the settings on the map. (App disappears. First time it prompted to clear cache which I did)
>Is there a new widget? If I click on the widget I see the old UI.
>//.ichael
>On Mon, 30 Dec 2024, 07:28 Developer From Jokela via OvmsDev, <ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com>> wrote:
>Hi Android users.
>I’ve recently redesigned UI for Android and it would need some testing.
>Here is the latest build available for UI redesign: https://github.com/openvehicles/Open-Vehicle-Android/tree/test-dfj-ui/latest
>Please report any issues, improvement suggestions, etc.
>Thank you!
>Br, DFJ
>_______________________________________________
>OvmsDev mailing list
>OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
>http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241230/ecc9736e/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241230/ecc9736e/attachment-0001.png>
