[Ovmsdev] Firmware release 3.3.004
Mon Apr 1 19:59:31 HKT 2024
Applying the scheme as proposed, I've just released 3.3.004-4-gab8f16b7
to eap & main on ovms.dexters-web.de.
Am 30.03.24 um 12:59 schrieb Chris van der Meijden:
> Thank you for your quick response. Now I understand :-)
> Regards
> Chris
> Am Samstag, dem 30.03.2024 um 12:11 +0100 schrieb Michael Balzer:
>> Chris,
>> this does not affect the standard "edge" builds in any way, these
>> continue to be done on the latest "master" branch state.
>> The release branch is a pure backport branch. It's not intended to
>> get any commits that are not part of "master" already. It's only
>> purpose is to receive cherry-picks of bug fix commits from the master
>> branch, and to be used as the build branch for eap & main.
>> If you're a developer contributing some bug fix that needs to be
>> included in the release branch (and trigger an eap/main update
>> cycle), you can either simply request that  in your PR, and we will
>> do the cherry-pick for you, or you can create a secondary PR for the
>> current release branch. Note: the secondary PR needs to be based off
>> the release branch, not the master branch -- but you'll normally be
>> able to simply use your local release branch for this, as there will
>> normally be no concurrent changes to that branch. Btw, gitk is a
>> great assistance in cherry-picking, simply switch the branch, then
>> select the pick action from the commit's context menu (that's "Diese
>> Version pflücken" in the german version).
>> Only if you maintain some eap/main release server, you'll need to
>> switch to the release branch to build an update to the eap/main
>> release. That's only necessary if new commits (fixes) have been
>> pushed to the release branch, and can be automated easily.
>> Am 30.03.24 um 11:39 schrieb Chris van der Meijden:
>>> Hi Michael,
>>> sorry, I have diffulties to understand the new sceme. Could you
>>> explain it a bit more?
>>> I try to keep my reposotitory up to date with the main branch and
>>> compile the newest version to have my own (test) version of the
>>> newest commited code running. Do I now need to switch to the release
>>> branch? Will all commits in the release branch find their way at
>>> some time to the master branch, or will some drop out? Is the
>>> release branch now an even more early eap branch?
>>> What would you suggest to do for me, as I'm interested in compiling
>>> the latest, commited, code for just for testing purposes?
>>> Thanx.
>>> Regards
>>> Chris
>>> Am Samstag, dem 30.03.2024 um 09:20 +0100 schrieb Michael Balzer:
>>>> We need to add a few fixes to the 3.3.004 release.
>>>> I'd like to propose a new scheme to release important fixes to eap /
>>>> main. In the past, we set a new release tag if important fixes were
>>>> missing. That didn't take into account, that fixes could mix with new
>>>> features, that should not yet be released. That's the case now.
>>>> In my other projects, I create a dedicated release branch on every
>>>> major
>>>> release, and cherry-pick important fixes from master into that branch.
>>>> My proposal is, that we adopt that scheme here as well, i.e. add a
>>>> branch "release-3.3.004" beginning at tag "3.3.004", pick the commits
>>>> there that need to be added to 3.3.004, and publish the builds of that
>>>> branch to eap/main.
>>>> The slight disadvantage is more a theoretical issue: our build version
>>>> numbering scheme (git describe --always --tags --dirty) uses the
>>>> commit
>>>> distance to the last tag, so there will be a difference between the
>>>> same
>>>> version number 3.3.004-x on the release branch vs. on the master
>>>> branch.
>>>> But that only applies to the version number, not to the full version
>>>> code, as that also includes the abbreviated most recent commit hash at
>>>> build time.
>>>> Version numbers remain easily comparable: there will always be at
>>>> least
>>>> the same number of commits in the release branch as in the master
>>>> branch, so the version number on edge is still always equal or
>>>> higher to
>>>> eap/main.
>>>> As an example & for reviews / tests, I've created the branch
>>>> "release-3.3.004" as proposed, including the fixes that need to be
>>>> included now. The build version for this is currently
>>>> 3.3.004-4-gab8f16b7, that would become the eap / main release now.
>>>> Any objections?
>>>> Regards,
>>>> Michael
>>>> Am 25.03.24 um 02:22 schrieb Mark Webb-Johnson:
>>>>> I’ve done the same. 3.3.004 is now in EAP.
>>>>> A huge thanks to everyone involved in this.
>>>>> Regards, Mark
>>>>>> On 23 Mar 2024, at 5:28 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>>> Everyone,
>>>>>> I've just tagged version 3.3.004 and released the build to EAP on
>>>>>> ovms.dexters-web.de -- Mark, please follow up. As usual, we will
>>>>>> release this to MAIN in about a week.
>>>>>> This release has been long overdue, it includes numerous new
>>>>>> features, new vehicles and of course lots of bug fixes.
>>>>>> A huge thank you to everyone involved in this collaborative effort!
>>>>>> Changes since 3.3.003:
>>>>>> - MG EV Added support for MG5 (2020 - 2023) Short Range
>>>>>> - MG EV Added support for MG ZS EV (2023 - ) and MG5 (2020 -
>>>>>> 2023) Long Range
>>>>>> - OVMS Server v3 metrics filtering
>>>>>>    New configs:
>>>>>>      [server.v3] metrics.include         -- Comma-separated list
>>>>>> of metric names (with possible wildcard) matching metrics to send
>>>>>>      [server.v3] metrics.exclude         -- Comma-separated list
>>>>>> of metric names (with possible wildcard) matching metrics to not send
>>>>>> - Renault Zoe Phase 2: Initial support
>>>>>> - Improved output of bms shell command for narrow windows.
>>>>>>    New commands:
>>>>>>      bms volt                            -- Output only voltage
>>>>>> info if available
>>>>>>      bms temp                            -- Output only
>>>>>> temperature info if available
>>>>>> - Hyundai Ioniq 5: Initial support
>>>>>> - Support for specifying units in scripts
>>>>>>    New commands:
>>>>>>      metrics units                       -- Display available
>>>>>> unit identifiers
>>>>>>      metrics get                         -- Get at a particular
>>>>>> metric value (with a specified unit)
>>>>>>    Extended commands:
>>>>>>      metrics set                         -- Support setting with
>>>>>> a specified unit
>>>>>>    Extend functions
>>>>>>      OvmsMetrics.Value                   -- Optionally specify a
>>>>>> unit (and make 'decode' work) and to get values with units.
>>>>>>      OvmsMetrics.GetValues               -- Optionally specify a
>>>>>> unit to get values with units.
>>>>>>      OvmsMetrics.AsFloat                 -- Optionally specify a unit
>>>>>>    New DukTape function
>>>>>>      OvmsMetrics.HasValue                -- Returns true if the
>>>>>> metric has a valid value.
>>>>>> - Added power consumptions units: kWhP100K,KPkWh,MPkWh
>>>>>> - Consolidate custom trip power consumption metrics to single
>>>>>> value (kWhP100K)
>>>>>>    in Kia Niro and Kia Soul
>>>>>> - VFS: sorted directory listings & recursive directory listings
>>>>>>    New commands:
>>>>>>      vfs rls <path>                      -- List <path> and all
>>>>>> subdirectory contents
>>>>>> - Vehicle: emit standard events on charge/generator connection
>>>>>> type changes
>>>>>>    New events:
>>>>>>      vehicle.charge.type                 -- Vehicle charge
>>>>>> connection type has changed (e.g. ccs/type2/…)
>>>>>>      vehicle.gen.type                    -- Vehicle generator
>>>>>> - CAN logging: add possibility to log events (name) and metrics
>>>>>> (JSON object with name, value, unit)
>>>>>>    New configs:
>>>>>>      [can] log.events_filters            -- comma-separated list
>>>>>> of filters (with possible wildcard) matching an event name
>>>>>>      [can] log.metrics_filters           -- comma-separated list
>>>>>> of filters (with possible wildcard) matching a metric name
>>>>>> - Add units Bar, Permille
>>>>>> - Add user configuration for groups of metrics
>>>>>>    Adds the 'ToUser' unit that converts to the user specified unit.
>>>>>>    Add -u to 'metrics list' to view metrics as user units.
>>>>>> - Add completion for metrics set/get as well as units
>>>>>> - Mini Cooper SE: Initial support
>>>>>> - Hyundai Ioniq vFL: trip metrics, range estimations, TPMS, web
>>>>>> configuration,
>>>>>>      charge type detection, charge speed & time estimation
>>>>>>    New configs:
>>>>>>      [xhi] ctp.maxpower                -- Default charge power
>>>>>> limit [kW] for charge time estimations, default 0 = unlimited
>>>>>>      [xhi] ctp.soclimit                -- SOC level [%] for
>>>>>> secondary charge time estimation (sufficient SOC), default 80
>>>>>>      [xhi] notify.charge.delay.ccs     -- Wait time [sec] for DC
>>>>>> charge power to ramp up before sending the notification, default 15
>>>>>>      [xhi] notify.charge.delay.type2   -- … same for AC charging,
>>>>>> default 3
>>>>>>      [xhi] range.ideal                 -- ideal new car range
>>>>>> [km], default 200
>>>>>>      [xhi] range.user                  -- typical current user
>>>>>> range [km], default 200
>>>>>>      [xhi] range.smoothing             -- Number of SOC samples,
>>>>>> default 10 = ~ 5% SOC
>>>>>>      [xhi] tpms.pressure.warn              -- default 230 [kPa]
>>>>>>      [xhi] tpms.pressure.alert         -- default 220 [kPa]
>>>>>>      [xhi] tpms.temp.warn              -- default 90 [°C]
>>>>>>      [xhi] tpms.temp.alert             -- default 100 [°C]
>>>>>>    New metrics:
>>>>>>      xhi.b.range.user                  -- actual current user
>>>>>> range [km]
>>>>>>      xhi.e.state                       -- General/ignition state
>>>>>> flags
>>>>>> - Module: support deep sleep schedules
>>>>>>    New commands:
>>>>>>      module sleep                      -- Shutdown all components
>>>>>> and enter deep sleep for a time span or until a specific time.
>>>>>> - Add support for user-configured metrics in the web interface
>>>>>> and plugins:
>>>>>>     Adds an extra 'units' stream from the websocket containing
>>>>>> sub-streams:
>>>>>>       - metrics (for the current user unit/label for each metric)
>>>>>> (subscribe to units/metrics)
>>>>>>       - prefs (for any user preferences for unit groups/types)
>>>>>> (subscribe to units/prefs)
>>>>>>     Adds proxy arrays metrics_user[] , metrics_label[] available
>>>>>> to plugin pages.
>>>>>>     Adds various browser javascript functions and methods for
>>>>>> plugins related
>>>>>>       to displaying user configurations Auto-converts metric
>>>>>> display to user
>>>>>>       units in plugins that use attributes
>>>>>> - Cellular: add GPS/GNSS state control commands (for power
>>>>>> management)
>>>>>>    New commands:
>>>>>>      cellular gps [status]             -- output current modem
>>>>>> GPS/GNSS subsystem status
>>>>>>      cellular gps start                -- start modem GPS/GNSS
>>>>>> subsystem
>>>>>>      cellular gps stop                 -- stop modem GPS/GNSS
>>>>>> subsystem
>>>>>> - CAN framework: add bus reset command
>>>>>>    New commands:
>>>>>>      can [can1…4] reset                -- reset the CAN interface
>>>>>> - Vehicle: add support for custom command handlers, see…
>>>>>> https://docs.openvehicles.com/en/latest/userguide/scripting.html#ovmsvehicle-command-plugins
>>>>>> - Renault Twizy: read battery energy available from BMS (thanks
>>>>>> to Martin Bitz)
>>>>>>    New metrics:
>>>>>>      xrt.b.energy.avail                -- Current battery energy
>>>>>> available [kWh] (aged)
>>>>>>      xrt.b.energy.full                 -- Maximum battery energy
>>>>>> capacity [kWh] (aged, needs full charge)
>>>>>> - Add button on web file editor to reload obd2ECU (when obd2ECU
>>>>>> is enabled).
>>>>>> - Vehicle: add support for a geofence for valet mode similar to
>>>>>> parking/flatbed warnings.
>>>>>>    New Configs:
>>>>>>      [vehicle] valet.alarmdistance     -- How far away from the
>>>>>> original position before raising an alert (in metres)
>>>>>>      [vehicle] valet.alarminterval      -- How often the alarm
>>>>>> can be raised in minumtes
>>>>>> - Add metric and events related to obd2ecu process:
>>>>>>    New metric:
>>>>>>      m.obdc2ecu.on                     -- Is the OBD2ECU process
>>>>>> currently on.
>>>>>>    New events:
>>>>>>      obd2ecu.start                     -- Called after the
>>>>>> OBD2ECU process is started.
>>>>>>      obd2ecu.stop                      -- Called before the
>>>>>> OBD2ECU process is stopped.
>>>>>> - Web UI: Add configuration for Valet and Flatbed geofence to the
>>>>>> Locations config page.
>>>>>> - Network: New 'network ping' command to ping (ICMP) hostname or
>>>>>> IP address. (ESP-IDFv4+ only / needs to be enabled in menuconfig
>>>>>> - Developer Options)
>>>>>> - Vehicle: add automatic module shutdown/reboot based on 12V
>>>>>> battery voltage level
>>>>>>    New configs:
>>>>>>      [vehicle] 12v.shutdown            -- Shutdown voltage level
>>>>>> (default: disabled)
>>>>>>      [vehicle] 12v.wakeup              -- Reboot minimum voltage
>>>>>> level after shutdown (default: any)
>>>>>>      [vehicle] 12v.wakeup_interval     -- Reboot test interval in
>>>>>> seconds (default: 60)
>>>>>>    New events:
>>>>>>      vehicle.alert.12v.shutdown        -- 12V shutdown threshold
>>>>>> reached, entering deep sleep
>>>>>> - BYD Atto 3 initial support
>>>>>> - Vehicle: add 12V shutdown delay & notification
>>>>>>    New configs:
>>>>>>      [vehicle] 12v.shutdown_delay      -- Shutdown delay in
>>>>>> minutes (default: 2)
>>>>>>    New events:
>>>>>>      vehicle.alert.12v.low             -- 12V shutdown voltage
>>>>>> level detected
>>>>>>      vehicle.alert.12v.operational     -- 12V recovered above
>>>>>> shutdown level
>>>>>>    New notifications:
>>>>>>      [alert] batt.12v.shutdown         -- Alert about imminent
>>>>>> 12V shutdown
>>>>>> - VFS toolkit: add recursive options to mkdir (-p) & rmdir (-r)
>>>>>> commands
>>>>>> - Renault-Zoe-Ph1: add Cabin Pre-heat/cool Control
>>>>>> Regards,
>>>>>> Michael
>>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240401/dd0d385f/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240401/dd0d385f/attachment-0001.sig>
