[Ovmsdev] IDE setup help
    Jared Greco
    jaredgreco at gmail.com
    Fri Sep  1 14:56:34 HKT 2023
Hi All,
I am hoping to start work on adding the VW e-Golf vehicle, but struggling
with setup. Currently I am fighting two errors with
esp_task_wdt_get_trigger_tasknames() and xt_set_error_handler_callback()
not declared in scope. See attached.
What I did:
-went through dev setup doc (macOS)
-pulled master
-set up Eclipse IDE to build and flash using this
<https://docs.espressif.com/projects/esp-idf/en/v4.3/esp32/get-started-legacy/eclipse-setup.html>
I get the same errors when running "make flash" from the terminal.
Any ideas?
Thanks!
Jared
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230831/ad3886f0/attachment-0001.htm>
Name: Screen Shot 2023-08-31 at 11.46.14 PM.png
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230831/ad3886f0/attachment-0001.png>
