[Ovmsdev] Time units and functions
Sun Oct 22 08:30:24 HKT 2023
Michael,
BTW I've since added AsString() implementation for both the LocalTime,
UTCTime, and LocalDate and UTCDate.
The Date values need to be the format   yyyy-mm-ddThh:nn:ss - ie
2023-02-20T13:01:00  I figured that would be the
easiest to avoid having a space in the value!
Also more inline below:
//.ichael
On Sat, 21 Oct 2023 at 14:39, Michael Balzer <dexter at expeedo.de> wrote:
> Michael,
> Am 20.10.23 um 07:02 schrieb Michael Geddes:
> > Hi all,
> > firstly, it seems we are using a bunch of time functions that are not
> > thread-safe  (localtime gmtime and asctime)  (See recommendation here:
> https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/system/system_time.html)
> > - so I'll push up a p/r for that.
> I don't see which recommendation you refer to on that page, but you're
> right, we shouldn't use these unsafe calls. The correct way to avoid
> concurrency issues is to use the "_r" versions of these, i.e.
> "localtime_r" etc. -- these are included in newlib.
It's in the section 'Get Current Time' as a code snippet, however yes, I'm
using the _r versions of the functions.
> > Next is the couple of Metrics that are using the unit 'Seconds' but
> > which are really time_t values..
> > I'm looking to add a new Group of metrics for time with units
> > UnixEpoch, UTCDate & LocalDate.
> > This is what I have  at the moment with the default metrics for
> > m.time.utc as UTCDate and v.p.gpstime as LocalDate.   (I can make them
> > the same)
> > m.time.utc                               2023-10-19 11:22:28 UTC
> > v.p.gpstime                              2023-10-19 19:22:26 AWST
> > Currently I've changed these in the JSON to be exported as
> > "%FT%T.000Z"  which is a semi standard for JSON.
> > The 'conversion' for the date values doesn't do anything - these
> > really only effect the output.
> > I've also been looking at v.g.timerstart which is UTCTime & LocalTime
> > units.  I've fixed up conversions both way..
> > v.g.timerstart                           18:00:00local
> > Thoughts on these? Cautions?
> As long as the current uses won't be affected (shouldn't, as they use
> AsInt()), I think that will be fine.
Yeah, as for as the code goes they are still integers.  At the moment the
main change is that I have
m.time.utc default to UTCTime unit (rather than UnixEpoch) and v.p.gpstime
default to LocalTime.  This will
mean changes to the user interface and scripting interface for those
values.  I'm ok with leaving it like that or I could just
default to UnixEpoch.
> Btw, v.c.timerstart is the pendant for the charge timer.
AH yeah, I worked that bit out. I initially though UTCTime was for a time_t
value but I twigged to where that value was coming from
and what that meant.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20231022/353bd92b/attachment.htm>
