[Ovmsdev] A query on vehicle type switch (and failure)
Michael Geddes
Mon Nov 27 17:56:49 HKT 2023
I was also thinking adding this:
else
StandardMetrics.ms_v_type->Clear();
On Mon, 27 Nov 2023 at 15:25, Mark Webb-Johnson <mark at webb-johnson.net>
wrote:
> Michael,
> I’m not too bothered about it at the moment, but if you would to put in a
> PR for treating the “if (m_currentvehicle)” as set ready, set type, signal,
> and then an else for set type “” only, that would be acceptable to me.
> On 27 Nov 2023, at 3:14 PM, Michael Geddes <frog at bunyip.wheelycreek.net>
> wrote:
> So, would you be better if (in the case of null vehicle)
> m_currentVehicletype was also set to "" and we didn't fire the signal
> event?
> I was doing some other work in the area and noticed this.
> //.ichael
> On Mon, 27 Nov 2023 at 07:37, Mark Webb-Johnson <mark at webb-johnson.net>
> wrote:
>> Michael,
>> From the condition in the v_type->SetValue, the type is only set
>> if NewVehicle(type) is not NULL.
>> So the question is whether we should raise the signal or not? I guess
>> that is debatable, and probably better not to (as otherwise it is being
>> raised with type as the parameter, but the type is not actually being set
>> as the vehicle type).
>> Regards, Mark
>> On 26 Nov 2023, at 9:26 AM, Michael Geddes <frog at bunyip.wheelycreek.net>
>> wrote:
>> This code is from OvmsVehicleFactor::SetVehicle
>> m_currentvehicle = NewVehicle(type);
>> m_currentvehicle->m_ready = true;
>> m_currentvehicletype = std::string(type);
>> StandardMetrics.ms_v_type->SetValue(m_currentvehicle ? type : "");
>> MyEvents.SignalEvent("vehicle.type.set", (void*)type, strlen(type)+1);
>> My question is about what happens when NewVehicle() returns NULL.
>> Should m_currecntvehicletype, v.type and the SignalEvent all be set
>> as blank? Any particular reason why only the v.type is set as blank?
>> //.ichael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20231127/6b24a5c9/attachment.htm>
