[Ovmsdev] A query on vehicle type switch (and failure)
Mon Nov 27 07:37:06 HKT 2023
Michael,
From the condition in the v_type->SetValue, the type is only set if NewVehicle(type) is not NULL.
So the question is whether we should raise the signal or not? I guess that is debatable, and probably better not to (as otherwise it is being raised with type as the parameter, but the type is not actually being set as the vehicle type).
> On 26 Nov 2023, at 9:26 AM, Michael Geddes <frog at bunyip.wheelycreek.net> wrote:
> This code is from OvmsVehicleFactor::SetVehicle
> m_currentvehicle = NewVehicle(type);
> if (m_currentvehicle)
> m_currentvehicle->m_ready = true;
> m_currentvehicletype = std::string(type);
> StandardMetrics.ms_v_type->SetValue(m_currentvehicle ? type : "");
> MyEvents.SignalEvent("vehicle.type.set", (void*)type, strlen(type)+1);
> My question is about what happens when NewVehicle() returns NULL.
> Should m_currecntvehicletype, v.type and the SignalEvent all be set as blank? Any particular reason why only the v.type is set as blank?
> //.ichael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20231127/39ae13c9/attachment.htm>
