[Ovmsdev] Toyota bZ4X and Subaru Solterra
Michael Geddes
Tue May 30 08:21:00 HKT 2023
Just FYI on the Ioniq5 I was able to see using the 'valid bits' which of
the battery voltages were valid, therefore hopefully what the overall
battery capacity is. I have not got feedback on any different battery
configs yet... You can have a look at what I've done there anyway.
Sounds good anyway.
On Tue, 30 May 2023, 3:29 am Solterra, <solterra at kezarnet.com> wrote:
> It's Toyota's e-TNGA platform. I know the CAN network is the same for
> Toyota bZ4X and Subaru Solterra, but I'm not sure about the bZ3 (China) and
> Lexus RZ... One complicating factor is there are two battery configurations
> for the bZ4X, one of which is shared with the Solterra.
> Probably a detail for down the road a bit. For now, I've just created a
> bZ4X vehicle module and am tinkering under that.
> On 2023-05-28 21:45, Mark Webb-Johnson wrote:
> Solterra,
> Michael's advice is good.
> If it is just two names for essentially the same vehicle, I think you can
> refer to vehicle_voltampera (which implemented the Chevy Volt and Open
> Ampera vehicle support). These were essentially the same vehicle platform,
> but with minor bodywork differences and labelling.
> If the two vehicles share the same platform (such as BMS, battery, etc)
> but are otherwise very different, then I suggest you implement a
> vehicle_<platform> for that platform, and derive two classes from that in
> the same /src/ directory (one for each vehicle type). That will allow you
> to put all common support code in the base platform, but have each vehicle
> type customisable (and individually selectable).
> Looking at images of the cars, it seems they are closest to the Volt
> Ampera situation. Perhaps BZSS?
> On 28 May 2023, at 8:23 AM, Michael Geddes <frog at bunyip.wheelycreek.net>
> wrote:
> Hey Solterra,
> I couldn't say definitively but imho there are various options depending
> on HOW different.
> 1) They are exactly the same - or differences can be distinguished from
> responses: Register the name with both in it. Done. (This has happened with
> some older Kia + Hyundai even)
> 2) They are mostly the same. You could probably keep the one directory
> but have 2 wrapper classes constructing the base class with a parameter
> and register both in the factory Init. (Not sure if there are examples -
> ask the other Michael if this is ok).
> 3) They have a lot of commonality. You can inherit off a base class - or
> inherit one vehicle impl off the other... But put them in separate
> directories. (This happens for Ioniq 5 and a bunch of other Kia + Hyundai
> cars).
> //.ichael Geddes
> On Sat, 27 May 2023 at 21:19, Solterra <solterra at kezarnet.com> wrote:
> Hello again,
> I've finished my initial vehicle investigation and am not ready to add
> support to OVMS.
> When creating the vehicle stub, is there guidance for situations like on
> this vehicle? There are two makes and models that are essentially the same.
> Can I create a common 'components/vehicle_toyota_bz4x' and point two
> vehicle selections to it somewhere else?
> Thank you
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230530/c6da66c9/attachment-0001.htm>
