[Ovmsdev] Minimally viable vehicle module
Tue May 30 07:44:56 HKT 2023
There is no specific list, but I would suggest something like:
Car states
StandardMetrics.ms_v_env_awake
StandardMetrics.ms_v_env_on
Battery
StandardMetrics.ms_v_bat_soc
StandardMetrics.ms_v_bat_temp
StandardMetrics.ms_v_bat_range_est
StandardMetrics.ms_v_bat_range_ideal
Charging
StandardMetrics.ms_v_charge_current
StandardMetrics.ms_v_charge_voltage
StandardMetrics.ms_v_charge_pilot
StandardMetrics.ms_v_charge_inprogress
StandardMetrics.ms_v_charge_mode
StandardMetrics.ms_v_charge_state
StandardMetrics.ms_v_charge_substate
Vehicle
StandardMetrics.ms_v_vin
StandardMetrics.ms_v_type
StandardMetrics.ms_v_env_gear
StandardMetrics.ms_v_env_handbrake
StandardMetrics.ms_v_pos_speed
StandardMetrics.ms_v_door_chargeport
StandardMetrics.ms_v_inv_temp
StandardMetrics.ms_v_mot_temp
Nice to have are the StandardMetrics.ms_v_door_* metrics.
> On 30 May 2023, at 5:11 AM, Solterra <solterra at kezarnet.com> wrote:
> Hello,
> I'm trying to determine what the minimally viable vehicle module is? I'm implemented a handful of polling PIDs (SoC, Voltage, Current, Speed, Temperature, Odometer, etc.), and am starting to consider vehicle states and transitions.
> I'm wondering what I should target as a set good enough for a pull request to the main.
> Thank you
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230530/9878fa06/attachment.htm>
