[Ovmsdev] V3 Server
Wed May 17 16:17:56 HKT 2023
Hi Mark,
thanks for the new development and for your thoughts on V3 and V2.
I would like to add, that the V2 server for me is still a good server
to use as a selfhostet, standalone server.
This, simple, functionallity should ideally be kept in future
development from my perspective.
Regards
Chris
Am Mittwoch, dem 17.05.2023 um 13:07 +0800 schrieb Mark Webb-Johnson:
> I have committed some small changes today that address nagging
> problems I’ve seen on the api.openvehicles.com server.
> The most interesting of these shows in the logs as:
> > 11:04:30.799832 +0800 info  OVMS::Server::ApiV2: #497 - - new
> > connection from <redacted>:<redacted>
> > 11:04:30.800143 +0800 info  OVMS::Server::Core: #497 - - ConnStart
> > 11:04:32.147232 +0800 error OVMS::Server::ApiV2: #497 A
> > <owner/vehicle> disconnected
> > 11:04:32.149214 +0800 info  OVMS::Server::Core: #497
> > A <owner/vehicle> AppDisconnect
> > 11:04:32.149614 +0800 info  OVMS::Server::Core: #497 - - ConnFinish
> > 11:04:32.149924 +0800 info  OVMS::Server::ApiV2: #497
> > A <owner/vehicle> got proto #/A login
> > 11:04:32.150859 +0800 info  OVMS::Server::Core: #497 -
> >  <owner/vehicle> AppConnect
> > 11:04:45.071599 +0800 info  OVMS::Server::ApiV2: #501
> > C <owner/vehicle> got proto #0/C login
> > 11:04:45.072874 +0800 info  OVMS::Server::Core: #501
> > C <owner/vehicle> CarConnect
> > 11:04:45.073157 +0800 error OVMS::Server::Core: #497
> >  <owner/vehicle> ClientsTransmit mismatch /
> So at 11:04:30.799832 we got a new connection from an App. Then
> at 11:04:32.147232 it disconnected. Then at 11:04:32.149924 we got
> the login. Huh? The rest is the car loging in and trying to inform
> the messed up app connection.
> I guess the login message was held in a push_read buffer within
> AnyEvent::Handle, but the disconnect error took priority and was
> delivered first. Fix I made for this is to shutdown reads when
> handling the disconnect, and another check to not login if the
> connection has been cleared half way through negotiation.
> Anyway, seems better now, but api.openvehicles.com is still
> experiencing heavy load (due to sheer number of concurrent users we
> have now, combined with a large number of HTTP API users and cpu-
> intensive SSL connections). It seems that one single HTTPS API user
> is equivalent to about 50 API v2 users. I think the only way of
> easily scaling this further now is a switch to MQTT, and have been
> wondering if the API v2 server could just be a simple bi-directional
> translator to/from MQTT (which would give us a nice migration path
> and better support IOT).
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230517/70a5d3ba/attachment.htm>
