[Ovmsdev] No GSM connection
Chris van der Meijden
chris at arachnon.de
Sat May 13 17:45:01 HKT 2023
Just for the record ...
I ordered a new, replacement, SIM card, installed it and broke the SIM
mounting on the modem *rolleyes*.
So then I ordered a new modem (SIM7600) from the UK (20 euro import
toll, thanx Brexit).
Now I'm up and running with LTE on -75 dBm :-))
Am Montag, dem 17.04.2023 um 10:42 +0200 schrieb Chris van der Meijden:
> Hi Mark,
> thanx for your response.
> I orderded a new SIM card today. The one I use is 8 years old (wow,
> I'm using OVMS since 8 years now ...).
> Another esotheric shot, but all other parameters can be excluded I
> think.
> Regards
> Chris
> Am Freitag, dem 14.04.2023 um 11:22 +0800 schrieb Mark Webb-Johnson:
> > Chris,
> > The modem power on/off is not instance. Think of power off like
> > shutdown on a computer (with the shutdown taking a minute or so),
> > and power on like turning on your computer (with the actual boot
> > sequence taking a minute or so). You can see this with ‘cellular
> > status’ and the states ‘powering on’, ‘powering off’, etc.
> > The reason I mention that is that I suspect the reason you don’t
> > see ICCID is the modem is not fully powered on and boot up
> > complete.
> > I suggest you reboot the module. Then watch ‘cellular status’ to
> > see the modem power on. When fully on, check the ICCID and
> > hopefully it will be there. If not, then there is some problem
> > reading the SIM (but then seeing a network registration status
> > would not make sense).
> > As to the registration searching, that is pretty low level and
> > controlled by the modem. It simply can’t find a network to connect
> > to. Are you certain you still have 2G coverage there?
> > > https://www.congstar.de/hilfe-service/netzabdeckung/
> > Regards, Mark.
> > > On 13 Apr 2023, at 2:30 PM, Chris van der Meijden
> > > <chris at arachnon.de> wrote:
> > > For the second time within a month I have no GSM connection and
> > > I'm not able to reestablish the connection.
> > > The SIM card is "Congstar" Prepaid (with enough money on the
> > > card). The Network is 2G and connections are normally without any
> > > problems here.
> > > What I can see, is that I have a signal around -70 dBm, but can't
> > > get a network registration:
> > > Cellular Modem
> > > MODEM Status
> > > Model: SIM5360
> > > Network Registration: Searching
> > > Provider:
> > > Signal: -69 dBm
> > > Mode:
> > > State: NetWait
> > > Mux: Status up
> > > PPP: Not running
> > > GPS: Not running
> > > I can't get an ICCID
> > > Cellular modem configuration
> > > SIM ICCID: (power cellular modem on to read) Power mode of
> > > cellular is now on
> > > This is the log output
> > > log level debug cellular
> > > D (455339) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ
> > > D (455349) cellular: mux-rx-line #3: AT+CREG?;+CCLK?;+CSQ
> > > D (455359) cellular: mux-rx-line #3: +CREG: 0,2
> > > D (455359) cellular: mux-rx-line #3: +CCLK:
> > > "80/01/06,00:07:36+08"
> > > D (455359) cellular: mux-rx-line #3: +CSQ: 22,99
> > > D (455359) cellular: mux-rx-line #3: OK
> > > D (456339) cellular: mux-tx #3: AT+CPSI?
> > > D (456349) cellular: mux-rx-line #3: AT+CPSI?
> > > D (456349) cellular: mux-rx-line #3: +CPSI: NO SERVICE,Online
> > > D (456349) cellular: mux-rx-line #3: OK
> > > D (457339) cellular: mux-tx #3: AT+COPS?
> > > D (457349) cellular: mux-rx-line #3: AT+COPS?
> > > D (457349) cellular: mux-rx-line #3: ERROR
> > > and this is the Info output on the console
> > > I (1444379) gsm-mux: Start MUX
> > > I (1444449) gsm-mux: Channel #0 is open
> > > I (1444459) gsm-mux: Channel #1 is open
> > > I (1444459) gsm-mux: Channel #2 is open
> > > I (1444469) gsm-mux: Channel #3 is open
> > > I (1444479) gsm-mux: Channel #4 is open
> > > I (1444789) webserver: HTTP POST /api/execute
> > > I (1444799) webcommand: HttpCommandStream[0x3f8ba0b4]: 3478800
> > > bytes free, executing: cellular status
> > > I (1445339) cellular: State: Enter NetWait state
> > > I (1445599) webserver: HTTP POST /api/execute
> > > I (1445599) webcommand: HttpCommandStream[0x3f8ba0b4]: 3478584
> > > I (1455359) cellular: Network Registration status: Searching
> > > I (1455359) cellular: Signal Quality is: 22 (-69 dBm)
> > > I (1461919) webserver: HTTP GET /shell
> > > I (1475359) cellular: Signal Quality is: 18 (-77 dBm)
> > > I (1485359) cellular: Signal Quality is: 21 (-71 dBm)
> > > The live events show this
> > > Live Events
> > > [08:02:08]system.modem.poweringon
> > > [08:02:08]egpio.output.0.high
> > > [08:02:10]egpio.output.0.low
> > > [08:02:15]system.modem.installed
> > > [08:02:15]system.modem.poweredon
> > > [08:02:35]system.modem.muxstart
> > > [08:02:36]system.modem.netwait
> > > And this is my module information
> > > Module
> > > Last boot was 1719 second(s) ago
> > > Time at boot: 2023-04-13 07:35:21 CEST
> > > This is reset #0 since last power cycle
> > > Detected boot reason: PowerOn (16/14)
> > > Reset reason: Unknown/unset (0)
> > > Crash counters: 0 total, 0 early
> > > Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1; MODEM SIM5360
> > > Firmware: 3.3.003-413-ge0a8e914/ota_0/main (build idf v3.3.4-849-
> > > g6e214dc33 Apr 12 2023 20:20:24)
> > > Last time this happened I was able to get the connection back by
> > > performing some esotheric button pressing on "Start Modem", "Stop
> > > Modem" and "Power cellular Modem on" in the WebUI, but now it
> > > does not help.
> > > I compiled the newest version yesterday and I did some reboots of
> > > the module and I even pulled the fuse to completely power off my
> > > OVMS in the car, but no success.
> > > Is there anything I can do to do some more troubleshooting? Any
> > > thoughts on possible causes?
> > > Thanx
> > > Regards
> > > Chris
> > > _______________________________________________
> > > OvmsDev mailing list
> > > OvmsDev at lists.openvehicles.com
> > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230513/d2be9ec3/attachment.htm>
